[OpenDroneMap-users] uninstall open drone map
Stephen Mather
stephen at smathermather.com
Wed Aug 5 10:51:27 PDT 2015
Hi Chris,
Sorry for the radio silence. I'll try to help when I am back from
vacation next week. Hopefully someone can help you troubleshoot in the
meantime.
Cheers,
Best,
Steve
On Wed, Aug 5, 2015 at 1:15 PM, Chris <housec01 at gmail.com> wrote:
> All,
> after several attempts at reinstalling ODM I am left with no ODM. I have
> tried pull gh-pages, i tried a zip file to a different folder. I have
> deleted existing folders. I cannot get the script to finish installing.
> Has this happened before? It barely gets going says "updating" "installing"
> then goes back to command prompt...no errors just quits...the only 2 log
> files in the logs folder are apt-get and system info (name of computer etc).
> Thanks for any help with this...this is very important to me to get back up
> and running.
> --Chris
> On 07/31/2015 11:52 AM, Alex Mandel wrote:
>> On 07/30/2015 10:49 AM, Chris wrote:
>>> Thanks Dakota!
>>> I got this error...
>>> .../OpenDroneMap-gh-pages$ git pull origin gh-pages
>>> From https://github.com/OpenDroneMap/OpenDroneMap
>>> * branch gh-pages -> FETCH_HEAD
>>> error: Untracked working tree file '.gitignore' would be overwritten by
>>> merge.
>> That just means you made a file called .gitignore locally that will be
>> overwritten by the repo version.
>>> I ran the install.sh anyhow that went a bit quickly i thought
>>> I tried sample data but it errors out finding keypoints...
>>> - finding keypoints - Thu Jul 30 13:41:37 EDT 2015
>>> sh: 1: .../OpenDroneMap-gh-pages/bin/parallel: not found
>> Exactly what it sounds like, you need install the program called
>> Parallel. Install.sh should have done that, go back and check that it
>> actually did, and there weren't any warnings or errors. Sometimes you
>> might need to download the right tar manually before running install
>> Line 169 parallel.tar.bz2
>> http://ftp.gnu.org/gnu/parallel/parallel-20141022.tar.bz2
>> -Alex
>>> quitting cause:
>>> ".../OpenDroneMap-gh-pages/bin/parallel" --halt-on-error 1 -j+0 <
>>> ".../odm_data_benchmark-master/reconstruction-with-image-size-2400/_vlsift.templist.txt"
>>> returned with code 32512
>>> any ideas?
>>> Thanks
>>> --Chris
>>> On 07/30/2015 09:17 AM, Dakota Benjamin wrote:
>>>> In the base directory (i.e. where run.pl is), run "git pull origin
>>>> gh-pages" in the command line then run install.sh again.
>>>> git pull will pull all the latest changes that have been made to the
>>>> gh-pages branch (the main branch) of the repo to your local machine.
>>>> Dakota Benjamin
>>>> GIS Intern
>>>> http://www.clevelandmetroparks.com/
>>>> ________________________________________
>>>> From: opendronemap-users-bounces at lists.osgeo.org
>>>> <opendronemap-users-bounces at lists.osgeo.org> on behalf of Chris
>>>> Sent: Wednesday, July 29, 2015 10:04 PM
>>>> To: opendronemap-users at lists.osgeo.org
>>>> Subject: [OpenDroneMap-users] uninstall open drone map
>>>> Hi All,
>>>> I am new to github but i manage to fumble my way through. I am not
>>>> familiar with how to update ODM however. I did not see any uninstall.sh
>>>> or read it in the readme or the log. So with that in mind is there a
>>>> proper way to uninstall and update or to update ODM? Thanks for any
>>>> help
>>>> Chris
>>>> _______________________________________________
>>>> OpenDroneMap-users mailing list
>>>> OpenDroneMap-users at lists.osgeo.org
>>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/opendronemap-users
More information about the OpenDroneMap-users
