[OpenDroneMap-users] Fwd: Fwd: First-time installation behaviour
Dakota Benjamin dmb2 at clevelandmetroparks.com
Wed Aug 19 06:14:28 PDT 2015
Hey, I saw your issue on GitHub. Sorry for not responding here first. Let's continue discussion here.
There should be a logs folder in the install directory. Can you open file with the latest last modification time and post them here?
Dakota Benjamin
GIS Intern
http://www.clevelandmetroparks.com/<http://www.clemetparks.com/>
From: opendronemap-users-bounces at lists.osgeo.org <opendronemap-users-bounces at lists.osgeo.org> on behalf of Rion Lerm <rion at saeon.ac.za>
Sent: Friday, August 14, 2015 4:13 AM
To: OpenDroneMap users
Subject: [OpenDroneMap-users] Fwd: Fwd: First-time installation behaviour
I am installing OpenDroneMap on a Windows host for the first time. So far so good, but the installation seems to be pausing for hours at command line:
> clapack
- building clapack
?What could the issue be?
I use Oracle VM, Vagrant machine (odm_vagrant), Ubuntu (odm vagrant explains). Everything works fine when I run the commands through Git Shell, but after doing all the downloads and unpacking the files I suppose it gets stuck as mentioned above.
My org. is currently in process purchasing a UAV and I need ODM to run successfully as we do not want to purchase Pix4D or PhotoScan for image compilation, analysis and point clouds.
URL: <http://lists.osgeo.org/pipermail/opendronemap-users/attachments/20150819/41a5152b/attachment.html>
More information about the OpenDroneMap-users mailing list
