[OpenDroneMap-users] Trouble installing ec2 ubuntu instance
William Rudisill william.rudisill at gmail.com
Sat Dec 12 14:21:55 PST 2015
Awesome, I was able to install it! Thanks. My ultimate goal here is to make
an ami and create a good workflow for booting an instance, processing
images, and moving the output to my local machine.
One more problem:
I'm using some sample imagery from the github page, "odm_data_caliterra".
When I run the code, I get the following error:
" found 77 usable images
  using max image size of 2400 x 2400
  File "/home/ubuntu/volume/OpenDroneMap/run.py", line 1001, in <module>
    os.chdir(jobOptions["jobDir"])
OSError: [Errno 2] No such file or directory:
'/home/ubuntu/volume/odm_data_caliterra/reconstruction-with-image-size-2400' "
I looked at the run.py file but I can't figure out what's going on.
Best,
Will
On Thu, Dec 10, 2015 at 6:23 AM, Jose Luis Bossio <joseluisbossio at gmail.com>
wrote:
> Hi Will, could you send to us some log about your installation about the
> error?
> Best Regards,
> Jose Luis Bossio
> @jlbsensedrone
> On 10 December 2015 at 01:00, William Rudisill <william.rudisill at gmail.com
> > wrote:
>> Hi all,
>> I've been having some trouble installing it however. I'm running ubuntu
>> on a amazon EC2 instance. When I run the install.sh script it will get to
>> 'building and installing pcl phase' before it aborts.
>> Any ideas?
>> Best,
>> Will
>> OpenDroneMap-users mailing list
>> OpenDroneMap-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/opendronemap-users
URL: <http://lists.osgeo.org/pipermail/opendronemap-users/attachments/20151212/96f3642b/attachment.html>
More information about the OpenDroneMap-users mailing list
