[OpenDroneMap-users] Cloud Processing (Stephen Mather)
Ian Ray
ian at airshark.io
Fri Feb 27 18:28:17 PST 2015
One neat trick on Amazon EC2 is to use the Spot Instances - you can get
the much more powerful r3.8xlarge instance type for about $0.25 / hr.
That's 32 cores and 244GB of RAM! I didn't specifically time it, but if
memory serves that chewed through the Langley dataset in about an hour
end to end.
Just make sure that you request the spot instance in an availability
zone that hasn't had price spikes in the past ~24 hours, and that you
set the Max Price well above any spikes so your server doesn't get
automatically shutdown based on price:
http://docs.aws.amazon.com/AWSEC2/latest/UserGuide/using-spot-instances-history.html
http://docs.aws.amazon.com/AWSEC2/latest/UserGuide/using-regions-availability-zones.html#using-regions-availability-zones-launching
More information about the OpenDroneMap-users
