[OpenDroneMap-users] pmvs2 Failed and I dont know why
Jan Michálek godzilalalala at gmail.com
Tue Jul 14 00:21:04 PDT 2015
Hello Stephen
Overlap can be between 60-90% by my estimate.
I opened point cloud files and on my shots are some granite stones, some
rain bleached branches and lots of grass blades.
In ply files i found only points on stones and on branches, no points on
grass. Maybe is this my problem, that grass from one and half meter is so
complicated for pmvs.
Je;
2015-07-13 22:23 GMT+02:00 Stephen Mather <stephen at smathermather.com>:
> Hi Jan,
> How much overlap do you have in your images? 80-90% overlap is recommended.
> Cheers,
> Best,
> Steve
> On Sat, Jul 11, 2015 at 2:13 PM, Jan Michálek <godzilalalala at gmail.com>
> wrote:
> > Hello
> > I`m totaly newbie in photogrammetry, cameras etc. Maybe is my problem
> banal.
> > I had installed odm and tried on some data, benchmark and pacifica gone
> OK.
> > I tried my own dataset (82 shots of some stones on the way) and proces
> > failed on pmvs with this:
> > 38 Harris running ...3072 harris done
> > DoG running...4249 dog done
> > 40 Harris running ...3024 harris done
> > DoG running...4251 dog done
> > done
> > adding seeds
> (4,1649)(28,452)(11,187)(15,807)(24,1313)(16,137)(17,111)(1,161)(26,2)(9,556)(3,71)(22,298)(19,42)(2,10)(0,174)(23,76)(25,0)(18,1)(13,415)(8,18)(5,2)(21,20)(7,54)(12,11)(14,0)(20,0)(27,7)(6,0)(10,0)done
> > ---- Initial: 0 secs ----
> > Total pass fail0 fail1 refinepatch: 310846 8685 268951 33210 41895
> > Total pass fail0 fail1 refinepatch: 100 2.79399 86.5223 10.6837 13.4777
> > Expanding patches...
> > ---- EXPANSION: 1735 secs ----
> > Total pass fail0 fail1 refinepatch: 589381 424860 80197 84324 509184
> > Total pass fail0 fail1 refinepatch: 100 72.0858 13.607 14.3072 86.393
> > FilterOutside
> > mainbody:
> > Gain (ave/var): 0.921361 0.637559
> > 430699 -> 426588 (99.0455%)     0 secs
> > Filter Exact: *****************Killed
> > quitting cause:
> >         "/home/azureuser/src/OpenDroneMap/bin/pmvs2" pmvs/ option-0000
> > returned with code 35072
> > my option-0000
> > looks like
> > # generated by genOption. mode 1. cluster: 0
> > level 1
> > csize 2
> > threshold 0.7
> > wsize 7
> > minImageNum 3
> > CPU 1
> > setEdge 0
> > useBound 0
> > useVisData 1
> > sequence -1
> > maxAngle 10
> > quad 2.0
> > timages 29 0 3 4 5 6 7 9 10 12 13 14 16 17 18 21 22 24 25 26 28 30 31 32
> 33
> > 35 36 37 38 40
> > oimages 0
> > i think i should change this file, but I dont know in what way.
> > Please, can somebody give me advice how i should change parameters on
> this
> > process to obtain good result?
> > Thanks
> > Je;
> > OpenDroneMap-users mailing list
> > OpenDroneMap-users at lists.osgeo.org
> > http://lists.osgeo.org/cgi-bin/mailman/listinfo/opendronemap-users
URL: <http://lists.osgeo.org/pipermail/opendronemap-users/attachments/20150714/9d72cd4f/attachment.html>
More information about the OpenDroneMap-users mailing list
