[OpenDroneMap-users] uninstall open drone map
Chris
housec01 at gmail.com
Fri Jul 31 10:34:04 PDT 2015
I think i see what is happenning. The install.sh is not finishing.
OpenDroneMap-gh-pages$ ./install.sh
created by Daniel Schwarz/daniel.schwarz at topoi.org
released under Creative Commons/CC-BY
Attribution
if the script doesn't finish properly
(i.e. it doesn't print "script finished" at the end)
please email me the content of the logs folder
- script started - Fri Jul 31 13:26:27 EDT 2015
> installing required packages
- installing git submodules
Submodule path 'src/bundler': checked out
'b34cc5dcd54345272028b68f82fa4d0ae8a103c9'
Submodule path 'src/ceres-solver': checked out
'b0696f6269d12abc6ea63083d565fe2ec8172da9'
- updating
.../OpenDroneMap-gh-pages$
That's it that's the end...it looks like it did ok..no errors but it
definitely doesn't not say "script finished" at the end....
Note I am a bit disappointed that I had a perfectly working (albeit
older) version before i decided to pull the updates and
reinstall....guess i should have heeded "if it ain't broke don't fix it"
--Chris
On 07/31/2015 11:52 AM, Alex Mandel wrote:
> On 07/30/2015 10:49 AM, Chris wrote:
>> Thanks Dakota!
>> I got this error...
>> .../OpenDroneMap-gh-pages$ git pull origin gh-pages
>> From https://github.com/OpenDroneMap/OpenDroneMap
>> * branch gh-pages -> FETCH_HEAD
>> error: Untracked working tree file '.gitignore' would be overwritten by
>> merge.
> That just means you made a file called .gitignore locally that will be
> overwritten by the repo version.
>> I ran the install.sh anyhow that went a bit quickly i thought
>> I tried sample data but it errors out finding keypoints...
>> - finding keypoints - Thu Jul 30 13:41:37 EDT 2015
>> sh: 1: .../OpenDroneMap-gh-pages/bin/parallel: not found
> Exactly what it sounds like, you need install the program called
> Parallel. Install.sh should have done that, go back and check that it
> actually did, and there weren't any warnings or errors. Sometimes you
> might need to download the right tar manually before running install
> Line 169 parallel.tar.bz2
> http://ftp.gnu.org/gnu/parallel/parallel-20141022.tar.bz2
> -Alex
>> quitting cause:
>> ".../OpenDroneMap-gh-pages/bin/parallel" --halt-on-error 1 -j+0 <
>> ".../odm_data_benchmark-master/reconstruction-with-image-size-2400/_vlsift.templist.txt"
>> returned with code 32512
>> any ideas?
>> Thanks
>> --Chris
>> On 07/30/2015 09:17 AM, Dakota Benjamin wrote:
>>> In the base directory (i.e. where run.pl is), run "git pull origin
>>> gh-pages" in the command line then run install.sh again.
>>> git pull will pull all the latest changes that have been made to the
>>> gh-pages branch (the main branch) of the repo to your local machine.
>>> Dakota Benjamin
>>> GIS Intern
>>> http://www.clevelandmetroparks.com/
>>> ________________________________________
>>> From: opendronemap-users-bounces at lists.osgeo.org
>>> <opendronemap-users-bounces at lists.osgeo.org> on behalf of Chris
>>> <housec01 at gmail.com>
>>> Sent: Wednesday, July 29, 2015 10:04 PM
>>> To: opendronemap-users at lists.osgeo.org
>>> Subject: [OpenDroneMap-users] uninstall open drone map
>>> Hi All,
>>> I am new to github but i manage to fumble my way through. I am not
>>> familiar with how to update ODM however. I did not see any uninstall.sh
>>> or read it in the readme or the log. So with that in mind is there a
>>> proper way to uninstall and update or to update ODM? Thanks for any help
>>> Chris
>>> OpenDroneMap-users mailing list
>>> OpenDroneMap-users at lists.osgeo.org
>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/opendronemap-users
More information about the OpenDroneMap-users
