[OpenDroneMap-users] Tips and tricks for model re-runs
Frederic Muller
fred at cm17.com
Wed Mar 11 00:11:31 PDT 2015
Hi!
Just installed ODM and trying to have it run first. I'm using the images
GitHub of the project and specifically ran on COPR images.
Unfortunately it has failed twice with the same error message which is
"Error in OdmTexturing:
Failed to read image:
'/home/fred/Documents/odm_data/copr//IMG_0031.jpg'
I looked at the image and it opens fine, but maybe the problem comes
because of the double /?
Or is copr data set not ready?
Thank you.
Fred
On 03/10/2015 11:25 PM, Alex Mandel wrote:
>I added a full gcp list to the copr data set. It runs but I have yet to
>verify how well it did in real world terms.
>Feel free to test with that.
>Thanks,
>Alex
On 03/05/2015 07:11 PM, Stephen Mather wrote:
> Hi Ivan,
> Boruszyn now has GCPs associated with it:
> https://github.com/merkato/odm_boruszyn_kap
> PUWG1992
> And all these GCPs are valid when processed. Boruszyn does not make ideal
> orthos, due to the geometry difficulties of a KAP flight, but it's such an
> amazing dataset.
> Somewhere I have a couple more GCPs for Langley, but I can't find
them... .
> I know Aaron Racicot, the originator of that dataset, is working both on
> GCPs and EXIF camera positions for that dataset. He's nearly done with
> that, so stay tuned.
> Also, there's a new graceful-exit branch (thanks to Spotscale) to test:
> https://github.com/OpenDroneMap/OpenDroneMap/tree/graceful-exit-gcp
> Please give this a test on datasets that have no EXIF and no GCPs.
> Thanks,
> Best,
> Steve
> On Wed, Mar 4, 2015 at 8:03 AM, Ivan Lizarazo <ivan.lizarazo at gmail.com>
> wrote:
>> Nice work, Steve. It's really helpful.
>> I ran ODM with the Langley dataset using this gcp_list.txt (taken
from the
>> wiki):
>> *WGS84 UTM 10N*
>> *544256.7 5320919.9 5 3044 2622 img_0525.jpg*
>> *544157.7 5320899.2 5 4193 1552 img_0585.jpg*
>> *544033.4 5320876.0 5 1606 2763 img_0690.jpg*
>> After a while, ODM quit the georeferencing job. This is the last part of
>> the odm_georeferencing_log.txt:
>> *Reading following GCPs from file:*
>> *x_: 544257 y_: 5.32092e+06 z_: 5 pixelX_: 2622 pixelY_: 3044 image:
>> img_0525.jpg*
>> *x_: 544158 y_: 5.3209e+06 z_: 5 pixelX_: 1552 pixelY_: 4193 image:
>> img_0585.jpg*
>> *x_: 544033 y_: 5.32088e+06 z_: 5 pixelX_: 2763 pixelY_: 1606 image:
>> img_0690.jpg*
>> *The calculated easting offset for the georeferenced system: 544149*
>> *The calculated northing offset for the georeferenced system: 5.3209e+06*
>> *Recalculated GCPs with offset:*
>> *x_: 107.7 y_: 21.9 z_: 5*
>> *x_: 8.7 y_: 1.2 z_: 5*
>> *x_: -115.6 y_: -22 z_: 5*
>> *Reading mesh file
/home/ivan/odm_data/langley/reconstruction-with-image-size-2400-results/odm_texturing/odm_textured_model.obj*
>> *Successfully loaded
/home/ivan/odm_data/langley/reconstruction-with-image-size-2400-results/odm_texturing/odm_textured_model.obj.*
>> *Position in model for gcp 3: x=13.1883 y=-2.29253 z=-15.2447*
>> *Error in Georef:*
>> *Less than 3 GCPs have correspondences in the generated model.*
>> I understand that more than 3 GCP are needed to succeed. Do you have
>> more GCP available for the Landley dataset?
>> Could anybody provide a GCP list for any of the ODM sample datasets?
>> Best regards,
>> Ivan
>> On Sun, Mar 1, 2015 at 8:32 PM, Stephen Mather <stephen at
smathermather.com>
>> wrote:
>>> Hi All,
>>> I was playing today with the Langley dataset, working on the
>>> georeferencing / orthophoto tests, and hadn't loaded enough (useable)
>>> points in my gcp file for the georeferencing / orthophoto generation.
>>> So, I added some more ground control points to
>>> and wanted to rerun, but not everything. Since the latest step we
can start
>>> from (at this time) is pmvs, here was the command I ran so that I
wouldn't
>>> have to rerun all the matching and bundler:
>>> run.pl --resize-to 3000 --start-with pmvs
>>> It completed in 30 minutes instead of 8 hours, which was refreshingly
>>> short, and reran PMVS (point cloud model creation), meshing, mesh
>>> texturing, and orthophoto generation.
>>> Hope this helps,
>>> Best,
>>> Steve
>>> OpenDroneMap-users mailing list
>>> OpenDroneMap-users at lists.osgeo.org
>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/opendronemap-users
More information about the OpenDroneMap-users
