[OpenDroneMap-users] Issues processing the copr data image set
Ivan Lizarazo
ivan.lizarazo at gmail.com
Fri Mar 13 10:46:26 PDT 2015
Hi Fred
To get a clue, please review the last few lines of your
odm_georeferencing_log.txt
and let us know what it says.
Regards,
Ivan
On Fri, Mar 13, 2015 at 12:28 PM, Frederic Muller <fred at cm17.com> wrote:
> Hi again,
> So I renamed all the images and put them in small letters. And now while
> I went further away in the process I still have another issue:
> quitting cause:
> "/home/fred/Documents/images/odm_data/copr/../../../odm/OpenDroneMap/bin/odm_georef"
> -bundleFile
> /home/fred/Documents/images/odm_data/copr/reconstruction-with-image-size-2400/pmvs/bundle.rd.out
> -gcpFile /home/fred/Documents/images/odm_data/copr/gcp_list.txt -imagesPath
> /home/fred/Documents/images/odm_data/copr/ -imagesListPath
> /home/fred/Documents/images/odm_data/copr/reconstruction-with-image-size-2400/pmvs/list.rd.txt
> -bundleResizedTo 2400 -inputFile
> /home/fred/Documents/images/odm_data/copr/reconstruction-with-image-size-2400-results/odm_texturing/odm_textured_model.obj
> -outputFile
> /home/fred/Documents/images/odm_data/copr/reconstruction-with-image-size-2400-results/odm_texturing/odm_textured_model_geo.obj
> -logFile
> /home/fred/Documents/images/odm_data/copr/reconstruction-with-image-size-2400/odm_georeferencing/odm_georeferencing_log.txt
> returned with code 256
> Any idea what this could be?
> Thank you.
> Fred
> On 03/12/2015 10:58 PM, Alex Mandel wrote:
> > It's not the data set. Most of us have been hitting this bug with the
> > case of JPG not working and needing them to be jpg.
> > https://github.com/OpenDroneMap/OpenDroneMap/issues/33
> > I'll check that data set and update the names if they are still in caps
> > in git.
> > Thanks,
> > Alex
> > On 03/11/2015 12:11 AM, Frederic Muller wrote:
> >> Hi!
> >> Just installed ODM and trying to have it run first. I'm using the images
> >> GitHub of the project and specifically ran on COPR images.
> >> Unfortunately it has failed twice with the same error message which is
> >> "Error in OdmTexturing:
> >> Failed to read image:
> >> '/home/fred/Documents/odm_data/copr//IMG_0031.jpg'
> >> I looked at the image and it opens fine, but maybe the problem comes
> >> because of the double /?
> >> Or is copr data set not ready?
> >> Thank you.
> >> Fred
> OpenDroneMap-users mailing list
> OpenDroneMap-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/opendronemap-users
URL: <http://lists.osgeo.org/pipermail/opendronemap-users/attachments/20150313/ab80ac1f/attachment.html>
More information about the OpenDroneMap-users
