[OpenDroneMap-users] Install Issue
Dennis Baldwin
db at unmannedairlines.com
Thu Mar 19 09:46:57 PDT 2015
Strange. I just did an install on 14.04 with no problems. I wonder if it's
an issue with your sources.list. It looks like it's failing here:
https://github.com/OpenDroneMap/OpenDroneMap/blob/gh-pages/install.sh#L107
Try running this directly from your command line and see if you still get
that 403 error:
sudo apt-get update --assume-yes
If so, paste your /etc/apt/sources.list and I'll compare with mine.
On Thu, Mar 19, 2015 at 11:31 AM, Todd Pals <tpalshadow at gmail.com> wrote:
> apt-get_get.log and sysinfo.txt are the only two files in the logs
> directory.
> On Thu, 19 Mar 2015 at 11:27 Dennis Baldwin <db at unmannedairlines.com>
> wrote:
>> Hey Todd,
>> What about attaching apt-get_install.log? I see those 403 in the
>> apt-get_get.log but not sure those are really the problem. The
>> apt-get_install should hopefully give us more info.
>> Dennis
>> On Thu, Mar 19, 2015 at 8:42 AM, Todd Pals <tpalshadow at gmail.com> wrote:
>>> Here are the logs, thanks!
>>> On Wed, 18 Mar 2015 at 21:56 Alex Mandel <tech_dev at wildintellect.com>
>>> wrote:
>>>> Yup check the log, if you're install stopped at the Updating step then
>>>> there was a failure really early on installing packages via apt-get.
>>>> FYI, the install.sh is really readable.
>>>> -Alex
>>>> On 03/18/2015 07:16 PM, Blake Girardot wrote:
>>>> > Hi,
>>>> > There should be a logs folder in the install directory. Can you open
>>>> > file with the latest last modification time and put the contents of
>>>> that
>>>> > log in an email?
>>>> > Cheers,
>>>> > Blake
>>>> > On 3/19/2015 3:06 AM, Todd Pals wrote:
>>>> >> First let me apologize for incorrectly posting to the github earlier
>>>> >> today, I'm sorry about that.
>>>> >> I am new to the Linux, so if I'm completely dumb in what I'm asking,
>>>> >> just let me know. You won't hurt my feelings. I'm running Ubuntu
>>>> 14.04
>>>> >> LTS on an Oracle VirtualBox (setup just for this).
>>>> >> When I run the install I get this:
>>>> >> todd at todd-VirtualBox:~/Documents/OpenDroneMap$ sudo ./install.sh
>>>> >> created by Daniel Schwarz/daniel.schwarz at topoi.org
>>>> >> <mailto:daniel.schwarz at topoi.org>
>>>> >> released under Creative Commons/CC-BY
>>>> >> Attribution
>>>> >> if the script doesn't finish properly
>>>> >> (i.e. it doesn't print "script finished" at the end)
>>>> >> please email me the content of the logs folder
>>>> >> script started - Wed Mar 18 16:18:44 CDT 2015
>>>> >> installing required packages
>>>> >> - updating
>>>> >> And nothing seems to happen. If I try and run a set of the sample
>>>> images
>>>> >> or the set that Dennis Baldwin has in his videos I get this:
>>>> >> sh: 1: jhead: not found
>>>> >> no CCD width or focal length found for img_4851.jpg - camera: " "sh:
>>>> 1:
>>>> >> jhead: not found
>>>> >> Any help would be appreciated!
>>>> >> -Todd
>>>> >> _______________________________________________
>>>> >> OpenDroneMap-users mailing list
>>>> >> OpenDroneMap-users at lists.osgeo.org
>>>> >> http://lists.osgeo.org/cgi-bin/mailman/listinfo/opendronemap-users
URL: <http://lists.osgeo.org/pipermail/opendronemap-users/attachments/20150319/9a41cf4e/attachment-0001.html>
More information about the OpenDroneMap-users
