[OpenDroneMap-users] Install Issue
Todd Pals
tpalshadow at gmail.com
Thu Mar 19 10:32:21 PDT 2015
Thanks for the hints, none of that made a difference...I might wipe this
virtual machine and try again from scratch. It was a fresh install of
Ubuntu downloaded and installed soley for trying to get opendronemap to
work, so I won't be losing out on anything. I'm just using the .iso from
ubuntu.com, is there something else I should be using?
On Thu, 19 Mar 2015 at 12:02 Dennis Baldwin <db at unmannedairlines.com> wrote:
> Try this:
> https://coderwall.com/p/3n6xka/fix-apt-on-old-unsupported-ubuntu-releases
> and if that doesn't work I'm attaching my sources.list that maybe you can
> try.
> Good luck and keep us posted.
> On Thu, Mar 19, 2015 at 11:51 AM, Todd Pals <tpalshadow at gmail.com> wrote:
>> I do get an error:
>> Fetched 2,606 kB in 18s (138 kB/s)
>> W: Failed to fetch
>> http://dl.google.com/linux/chrome/deb/dists/stable/main/binary-amd64/Packages
>> 403 Forbidden [IP: 74.125.196.136 80]
>> W: Failed to fetch
>> http://dl.google.com/linux/chrome/deb/dists/stable/main/binary-i386/Packages
>> E: Some index files failed to download. They have been ignored, or old
>> ones used instead.
>> Here are the contents of sources.list:
>> #deb cdrom:[Ubuntu 14.04.2 LTS _Trusty Tahr_ - Release amd64
>> (20150218.1)]/ trus
>> ty main restricted
>> # See http://help.ubuntu.com/community/UpgradeNotes for how to upgrade to
>> # newer versions of the distribution.
>> deb http://us.archive.ubuntu.com/ubuntu/ trusty main restricted
>> deb-src http://us.archive.ubuntu.com/ubuntu/ trusty main restricted
>> ## Major bug fix updates produced after the final release of the
>> ## distribution.
>> deb http://us.archive.ubuntu.com/ubuntu/ trusty-updates main restricted
>> deb-src http://us.archive.ubuntu.com/ubuntu/ trusty-updates main
>> restricted
>> ## N.B. software from this repository is ENTIRELY UNSUPPORTED by the
>> Ubuntu
>> ## team. Also, please note that software in universe WILL NOT receive any
>> ## review or updates from the Ubuntu security team.
>> deb http://us.archive.ubuntu.com/ubuntu/ trusty universe
>> deb-src http://us.archive.ubuntu.com/ubuntu/ trusty universe
>> deb http://us.archive.ubuntu.com/ubuntu/ trusty-updates universe
>> deb-src http://us.archive.ubuntu.com/ubuntu/ trusty-updates universe
>> Ubuntu
>> ## team, and may not be under a free licence. Please satisfy yourself as
>> to
>> ## your rights to use the software. Also, please note that software in
>> ## multiverse WILL NOT receive any review or updates from the Ubuntu
>> ## security team.
>> deb http://us.archive.ubuntu.com/ubuntu/ trusty multiverse
>> deb-src http://us.archive.ubuntu.com/ubuntu/ trusty multiverse
>> deb http://us.archive.ubuntu.com/ubuntu/ trusty-updates multiverse
>> deb-src http://us.archive.ubuntu.com/ubuntu/ trusty-updates multiverse
>> ## N.B. software from this repository may not have been tested as
>> ## extensively as that contained in the main release, although it includes
>> ## newer versions of some applications which may provide useful features.
>> ## Also, please note that software in backports WILL NOT receive any
>> review
>> ## or updates from the Ubuntu security team.
>> deb http://us.archive.ubuntu.com/ubuntu/ trusty-backports main
>> restricted univer
>> se multiverse
>> deb-src http://us.archive.ubuntu.com/ubuntu/ trusty-backports main
>> restricted un
>> iverse multiverse
>> deb http://security.ubuntu.com/ubuntu trusty-security main restricted
>> deb-src http://security.ubuntu.com/ubuntu trusty-security main restricted
>> deb http://security.ubuntu.com/ubuntu trusty-security universe
>> deb-src http://security.ubuntu.com/ubuntu trusty-security universe
>> deb http://security.ubuntu.com/ubuntu trusty-security multiverse
>> deb-src http://security.ubuntu.com/ubuntu trusty-security multiverse
>> ## Uncomment the following two lines to add software from Canonical's
>> ## 'partner' repository.
>> ## This software is not part of Ubuntu, but is offered by Canonical and
>> the
>> ## respective vendors as a service to Ubuntu users.
>> # deb http://archive.canonical.com/ubuntu trusty partner
>> # deb-src http://archive.canonical.com/ubuntu trusty partner
>> ## This software is not part of Ubuntu, but is offered by third-party
>> ## developers who want to ship their latest software.
>> deb http://extras.ubuntu.com/ubuntu trusty main
>> deb-src http://extras.ubuntu.com/ubuntu trusty main
>> todd at todd-VirtualBox:/etc/apt$
>> Thanks!
>> On Thu, 19 Mar 2015 at 11:46 Dennis Baldwin <db at unmannedairlines.com>
>> wrote:
>>> Strange. I just did an install on 14.04 with no problems. I wonder if
>>> it's an issue with your sources.list. It looks like it's failing here:
>>> https://github.com/OpenDroneMap/OpenDroneMap/blob/gh-pages/install.sh#L107
>>> Try running this directly from your command line and see if you still
>>> get that 403 error:
>>> sudo apt-get update --assume-yes
>>> If so, paste your /etc/apt/sources.list and I'll compare with mine.
>>> On Thu, Mar 19, 2015 at 11:31 AM, Todd Pals <tpalshadow at gmail.com>
>>> wrote:
>>>> apt-get_get.log and sysinfo.txt are the only two files in the logs
>>>> directory.
>>>> On Thu, 19 Mar 2015 at 11:27 Dennis Baldwin <db at unmannedairlines.com>
>>>> wrote:
>>>>> Hey Todd,
>>>>> What about attaching apt-get_install.log? I see those 403 in the
>>>>> apt-get_get.log but not sure those are really the problem. The
>>>>> apt-get_install should hopefully give us more info.
>>>>> Dennis
>>>>> On Thu, Mar 19, 2015 at 8:42 AM, Todd Pals <tpalshadow at gmail.com>
>>>>> wrote:
>>>>>> Here are the logs, thanks!
>>>>>> On Wed, 18 Mar 2015 at 21:56 Alex Mandel <tech_dev at wildintellect.com>
>>>>>> wrote:
>>>>>>> Yup check the log, if you're install stopped at the Updating step
>>>>>>> then
>>>>>>> there was a failure really early on installing packages via apt-get.
>>>>>>> FYI, the install.sh is really readable.
>>>>>>> -Alex
>>>>>>> On 03/18/2015 07:16 PM, Blake Girardot wrote:
>>>>>>> > Hi,
>>>>>>> > There should be a logs folder in the install directory. Can you
>>>>>>> open
>>>>>>> > file with the latest last modification time and put the contents
>>>>>>> of that
>>>>>>> > log in an email?
>>>>>>> > Cheers,
>>>>>>> > Blake
>>>>>>> > On 3/19/2015 3:06 AM, Todd Pals wrote:
>>>>>>> >> First let me apologize for incorrectly posting to the github
>>>>>>> earlier
>>>>>>> >> today, I'm sorry about that.
>>>>>>> >> I am new to the Linux, so if I'm completely dumb in what I'm
>>>>>>> asking,
>>>>>>> >> just let me know. You won't hurt my feelings. I'm running Ubuntu
>>>>>>> 14.04
>>>>>>> >> LTS on an Oracle VirtualBox (setup just for this).
>>>>>>> >> When I run the install I get this:
>>>>>>> >> todd at todd-VirtualBox:~/Documents/OpenDroneMap$ sudo ./install.sh
>>>>>>> >> created by Daniel Schwarz/daniel.schwarz at topoi.org
>>>>>>> >> <mailto:daniel.schwarz at topoi.org>
>>>>>>> >> released under Creative Commons/CC-BY
>>>>>>> >> Attribution
>>>>>>> >> if the script doesn't finish properly
>>>>>>> >> (i.e. it doesn't print "script finished" at the end)
>>>>>>> >> please email me the content of the logs folder
>>>>>>> >> script started - Wed Mar 18 16:18:44 CDT 2015
>>>>>>> >> installing required packages
>>>>>>> >> - updating
>>>>>>> >> And nothing seems to happen. If I try and run a set of the sample
>>>>>>> images
>>>>>>> >> or the set that Dennis Baldwin has in his videos I get this:
>>>>>>> >> sh: 1: jhead: not found
>>>>>>> >> no CCD width or focal length found for img_4851.jpg - camera: "
>>>>>>> "sh: 1:
>>>>>>> >> jhead: not found
>>>>>>> >> Any help would be appreciated!
>>>>>>> >> -Todd
>>>>>>> >> _______________________________________________
>>>>>>> >> OpenDroneMap-users mailing list
>>>>>>> >> OpenDroneMap-users at lists.osgeo.org
>>>>>>> >> http://lists.osgeo.org/cgi-bin/mailman/listinfo/
>>>>>>> opendronemap-users
>>>>>>> > http://lists.osgeo.org/cgi-bin/mailman/listinfo/opendronemap-users
URL: <http://lists.osgeo.org/pipermail/opendronemap-users/attachments/20150319/af8d73b6/attachment.html>
More information about the OpenDroneMap-users
