[OpenDroneMap-users] New Error After Install
Todd Pals tpalshadow at gmail.com
Fri Mar 20 17:21:29 PDT 2015
I'm sorry to waste everyone's time, I rebooted the machine, moved the
directory around and it appears to be running now.
On Fri, 20 Mar 2015 at 19:10 Todd Pals <tpalshadow at gmail.com> wrote:
> Install finished now.  When I run on the odm_data_copr I get the following:
>  - finding keypoints - Fri Mar 20 18:55:33 CDT 2015
> When using programs that use GNU Parallel to process data for publication
> please cite:
>   O. Tange (2011): GNU Parallel - The Command-Line Power Tool,
>   ;login: The USENIX Magazine, February 2011:42-47.
> This helps funding further development; and it won't cost you a cent.
> Or you can get GNU Parallel without this requirement by paying 10000 EUR.
> To silence this citation notice run 'parallel --bibtex' once or use
> '--no-notice'.
> 1/41 - Killed
> parallel: Starting no more jobs. Waiting for 1 jobs to finish. This job
> failed:
> echo -n "1/41 - " && convert -format pgm "/home/todd/Documents/
> OpenDroneMap/test/odm_data_copr/reconstruction-with-image-size-2400/IMG_0022.jpg"
> "/home/todd/Documents/OpenDroneMap/test/odm_data_copr/reconstruction-with-image-size-2400/IMG_0022.pgm"
> && "/home/todd/Documents/OpenDroneMap/test/odm_data_copr/../../bin/vlsift"
> -o "/home/todd/Documents/OpenDroneMap/test/odm_data_
> copr/reconstruction-with-image-size-2400/IMG_0022.key.sift" > /dev/null
> && perl "/home/todd/Documents/OpenDroneMap/test/odm_data_
> copr/../../bin/../convert_vlsift_to_lowesift.pl" "/home/todd/Documents/
> OpenDroneMap/test/odm_data_copr/reconstruction-with-image-size-2400/IMG_0022"
> && gzip -f "/home/todd/Documents/OpenDroneMap/test/odm_data_
> copr/reconstruction-with-image-size-2400/IMG_0022.key" && rm -f
> && rm -f "/home/todd/Documents/OpenDroneMap/test/odm_data_
> quitting cause:
> "/home/todd/Documents/OpenDroneMap/test/odm_data_copr/../../bin/parallel"
> --halt-on-error 1 -j+0 < "/home/todd/Documents/OpenDroneMap/test/odm_data_
> copr/reconstruction-with-image-size-2400/_vlsift.templist.txt"
> returned with code 35072
> root at todd-VirtualBox:/home/todd/Documents/OpenDroneMap/
> test/odm_data_copr#
> Thanks everyone!
> Todd Pals
URL: <http://lists.osgeo.org/pipermail/opendronemap-users/attachments/20150321/c5d8b30b/attachment.html>
More information about the OpenDroneMap-users mailing list
