[OpenDroneMap-users] odm_data_pacifica No valid GPS position found
Ivan Ma
ivanma72 at gmail.com
Fri Mar 27 15:49:16 PDT 2015
I cloned the odm_data_pacifica image set and tried to run a simple test on
the dataset. Unfortunately, it exited with this error while running
georeferencing:
- running georeferencing - Fri Mar 27 12:30:53 EDT 2015
Error in OdmExtractUtm:
For more detailed information, see log file.
quitting cause:
"/home/ivanma/Documents/mdp/odm_data_pacifica/../OpenDroneMap/bin/odm_georef"
-bundleFile
/home/ivanma/Documents/mdp/odm_data_pacifica/reconstruction-with-image-size-2400/pmvs/bundle.rd.out
-coordFile
/home/ivanma/Documents/mdp/odm_data_pacifica/reconstruction-with-image-size-2400/odm_georeferencing/coordFile.txt
-inputFile
/home/ivanma/Documents/mdp/odm_data_pacifica/reconstruction-with-image-size-2400-results/odm_texturing/odm_textured_model.obj
-outputFile
/home/ivanma/Documents/mdp/odm_data_pacifica/reconstruction-with-image-size-2400-results/odm_texturing/odm_textured_model_geo.obj
-logFile
/home/ivanma/Documents/mdp/odm_data_pacifica/reconstruction-with-image-size-2400/odm_georeferencing/odm_georeferencing_log.txt
returned with code 256
I have attached the error log as well.
URL: <http://lists.osgeo.org/pipermail/opendronemap-users/attachments/20150327/217d0d5d/attachment.html>
/home/ivanma/Documents/mdp/odm_data_pacifica/../OpenDroneMap/bin/odm_georef_log.txt
Arguments given
-bundleFile
-coordFile
-inputFile
-outputFile
-logFile
Reading cameras from: /home/ivanma/Documents/mdp/odm_data_pacifica/reconstruction-with-image-size-2400/pmvs/bundle.rd.out
Reading cameras georeferenced positions from: /home/ivanma/Documents/mdp/odm_data_pacifica/reconstruction-with-image-size-2400/odm_georeferencing/coordFile.txt
Reading textured mesh from: /home/ivanma/Documents/mdp/odm_data_pacifica/reconstruction-with-image-size-2400-results/odm_texturing/odm_textured_model.obj
Writing output to: /home/ivanma/Documents/mdp/odm_data_pacifica/reconstruction-with-image-size-2400-results/odm_texturing/odm_textured_model_geo.obj
Log file path was set to: /home/ivanma/Documents/mdp/odm_data_pacifica/reconstruction-with-image-size-2400/odm_georeferencing/odm_georeferencing_log.txt
Missing input in order to use GCP for georeferencing. Using EXIF data instead.
Error in Georef:
Failed opening /home/ivanma/Documents/mdp/odm_data_pacifica/reconstruction-with-image-size-2400/odm_georeferencing/coordFile.txt for reading.
More information about the OpenDroneMap-users
