[OpenDroneMap-users] [OpenDroneMap-dev] library error in OdmTexturing
Giuseppe Amatulli giuseppe.amatulli at gmail.com
Thu Oct 1 13:51:39 PDT 2015
Hi Benjamin,
I rerun the computation with the last  python-port
<https://github.com/OpenDroneMap/OpenDroneMap/tree/python-port> version,
using run.py --use-opensfm True .
I got the following error.
  - running meshing - Wed Sep 30 12:19:59  2015
running "/home/ubuntu/drone/OpenDroneMap/bin/odm_meshing" -inputFile
/home/ubuntu/drone/dati/103MSDCF/reconstruction-with-image-size-2400-results/option-0000.ply
-outputFile
/home/ubuntu/drone/dati/103MSDCF/reconstruction-with-image-size-2400-results/odm_mesh-0000.ply
-logFile
/home/ubuntu/drone/dati/103MSDCF/reconstruction-with-image-size-2400/odm_meshing/odm_meshing_log.txt
-maxVertexCount 100000 -octreeDepth 9 -samplesPerNode 1 -solverDivide 9
b
quitting cause:
-outputFile
-logFile
returned with code 256.
Probably is something with my pictures  (268 JPG) due that with
odm_data_seneca works fine.
Do you think that is possible to track/solve the error?
Thanks
Best Giuseppe
On 16 September 2015 at 08:17, Dakota Benjamin <dmb2 at clevelandmetroparks.com
> wrote:
> I'm not sure what the problem is as I have been unable to reproduce it. I
> just merged a big update that uses OpenSFM in place of bundler. Try running
> run.py with the following: '--use-opensfm True'.
> Dakota Benjamin
> Cleveland Metroparks
> Planning, Design, and Natural Resources
> http://www.clevelandmetroparks.com/ <http://www.clemetparks.com/>
> *From:* Giuseppe Amatulli <giuseppe.amatulli at gmail.com>
> *Sent:* Tuesday, September 15, 2015 10:00 PM
> *To:* Dakota Benjamin
> *Cc:* opendronemap-users at lists.osgeo.org; Stefano Casalegno
> *Subject:* Re: [OpenDroneMap-dev] library error in OdmTexturing
> Thanks Benjamin,
> yes i was able to install python-port but when i run run.py i got the
> below error.
> Is the error related to a dataset or to an installation issues?
> Please consider that, I have a dataset of 268 photos got with a "SONY
> ILCE-QX1": 23.2 ( I got value from the following page
> http://www.dpreview.com/products/sony/slrs/sony_ilceqx1 ).
> Thanks
> Best
> Giuseppe
> --constrain_focal_weight 0.0
> --estimate_distortion
> --run_bundle" >
> "/home/ubuntu/drone/dati/103MSDCF/reconstruction-with-image-size-2400/options.txt"
> b
> running "/home/ubuntu/drone/OpenDroneMap/bin/bundler"
> "/home/ubuntu/drone/dati/103MSDCSegmentation fault (core dumped)
> F/reconstruction-with-image-size-2400/list.txt" --options_file
> > bundle/out
> b
> quitting cause:
> "/home/ubuntu/drone/dati/103MSDCF/reconstruction-with-image-size-2400/list.txt"
> --options_file
> > bundle/out
> returned with code 35584.
> On 15 September 2015 at 09:25, Dakota Benjamin <
> dmb2 at clevelandmetroparks.com> wrote:
>> Hi,
>> Try switching to the python-port branch. We are beginning to shift over
>> to using run.py instead of run.pl, which now has more functionality and
>> is seeing rapid improvements.
>> Dakota Benjamin
>> *From:* opendronemap-dev-bounces at lists.osgeo.org <
>> opendronemap-dev-bounces at lists.osgeo.org> on behalf of Giuseppe Amatulli
>> *Sent:* Tuesday, September 15, 2015 9:14 AM
>> *To:* opendronemap-dev at lists.osgeo.org;
>> *Cc:* Stefano Casalegno
>> *Subject:* [OpenDroneMap-dev] library error in OdmTexturing
>> Hi
>> I'm preparing some material for a Drone-Course at Yale and I'm
>> encountering sum problems in using OpenDroneMap.
>> In particular:
>> I run run.pl but I get the below error due to libdc1394 dependency (see
>> log file below).
>> I'm running Ubuntu 14.04 with ubuntugis-unstable repository.
>> I try to manually install
>> sudo apt-get install libpcl1 libpcl1-dev libdc1394-22 libdc1394-22-dbg
>> libdc1394-22-dev libdc1394-22-doc libdc1394-utils
>> and re-install the sw but the error persist.
>> Any solution?
>> Thanks
>> Best
>> Giuseppe
>> ############### error #######
>>   - running texturing - Tue Sep 15 12:37:55 UTC 2015
>> libdc1394 error: Failed to initialize libdc1394
>> Error in OdmTexturing:
>> Failed to read image:
>> '/home/ubuntu/drone/dati/103MSDCF//DSC01529.jpg'
>> For more detailed information, see log file.
>> quitting cause:
>> "/home/ubuntu/drone/dati/103MSDCF/../../sw/OpenDroneMap-gh-pages/bin/odm_texturing"
>> -bundleFile /home/ubuntu/drone/dati/103MSDCF/reconstruction-with-im
>> age-size-2400/pmvs/bundle.rd.out -imagesPath
>> /home/ubuntu/drone/dati/103MSDCF/ -imagesListPath
>> 2400/pmvs/list.rd.txt -inputModelPath
>> -outputFolder /home/ubuntu
>> /drone/dati/103MSDCF/reconstruction-with-image-size-2400-results/odm_texturing/
>> -textureResolution 4096 -bundleResizedTo 2400 -textureWithSize 3600
>> -logFile /h
>> ome/ubuntu/drone/dati/103MSDCF/reconstruction-with-image-size-2400/odm_texturing/odm_texturing_log.txt
>> Giuseppe Amatulli, Ph.D.
>> Department of Ecology and Evolutionary Biology, Yale University.
>> Jetz Lab, OML Room 405
>> P.O. Box 208106
>> 165 PROSPECT ST
>> New Haven, CT 06520-8106
>> Teaching: spatial-ecology.net
>> Work:  http://sbsc.yale.edu/giuseppe-amatulli
>> <http://www.spatial-ecology.net>
> P.O. Box 208106
> 165 PROSPECT ST
P.O. Box 208106
165 PROSPECT ST
URL: <http://lists.osgeo.org/pipermail/opendronemap-users/attachments/20151001/e0284f3a/attachment.html>
More information about the OpenDroneMap-users mailing list
