[OpenDroneMap-users] No orthophoto output
Stephen Mather stephen at smathermather.com
Mon Sep 28 19:31:19 PDT 2015
Hmm. Fair. We've got some newly collected imagery we are testing. We can
try to make sure there's something that meets all those criteria (except
maybe a few more images than 10-15, as that's a small set to successfully
process).
Cheers,
Best,
Steve
On Sat, Sep 26, 2015 at 9:56 AM, Simon Stock <simon.stock at web.de> wrote:
> To try if I could generate an orthophoto with an existing gcp_list.txt
> file, I used the "boruszyn" example dataset (cause I don't know how to
> generate one for the "pacifica" dataset without knowing where the pictures
> have been taken).
> This is what I get (after a pretty long time):
> OpenCV Error: Assertion failed (0 <= roi.x && 0 <= roi.width && roi.x
> + roi.width <= m.cols && 0 <= roi.y && 0 <= roi.height && roi.y +
> roi.height <= m.rows) in Mat, file /build/buildd/opencv-
> 2.4.8+dfsg1/modules/core/src/matrix.cpp, line 323
> Error in OdmTexturing:
> /build/buildd/opencv-2.4.8+dfsg1/modules/core/src/matrix.cpp:323: error:
> (-215) 0 <= roi.x
> && 0 <= roi.width && roi.x + roi.width <= m.cols && 0 <= roi.y && 0 <=
> roi.height && roi.y + roi.height <= m.rows in function Mat
> For more detailed information, see log file.
> quitting cause:
> "/home/simon/OpenDroneMap/ortho3/../bin/odm_texturing" -bundleFile
> /home/simon/OpenDroneMap/ortho3/reconstruction-with-image-size-
> 2400/pmvs/bundle.rd.out -imagesPath /home/simon/OpenDroneMap/ortho3/
> -imagesListPath /home/simon/OpenDroneMap/ortho3/reconstruction-with-
> image-size-2400/pmvs/list.rd.txt -inputModelPath
> /home/simon/OpenDroneMap/ortho3/reconstruction-with-image-size-2400-
> results/odm_mesh-0000.ply -outputFolder
> results/odm_texturing/ -textureResolution 4096 -bundleResizedTo 2400
> -textureWithSize 3600 -logFile
> 2400/odm_texturing/odm_texturing_log.txt
> returned with code 256
> Is there example data available (maybe with not more than 10-15 pictures)
> which already has been tried & tested and can be used to generate an
> orthophoto?
> Thanks a lot,
> Simon
> Am 26.09.2015 um 11:55 schrieb Simon Stock:
>> Hi Steve,
>> I had a look at the "Running ODM with Ground Control" section of the
>> mentioned link but I have no clue what I have to write in the gcp_list.txt
>> file. As mentioned before I'm using the pacifica sample dataset and that
>> doesn't include GPS coordinates.
>> Isn't it possible to generate an orthophoto without georeferencing it but
>> doing this afterwards in GIS?
>> Thanks,
>> Simon
> OpenDroneMap-users mailing list
> OpenDroneMap-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/opendronemap-users
URL: <http://lists.osgeo.org/pipermail/opendronemap-users/attachments/20150928/750c3beb/attachment.html>
More information about the OpenDroneMap-users mailing list
