[OpenDroneMap-users] ODM quits with keyerror
Ted Fines ted at apecity.com
Mon Apr 4 16:07:14 PDT 2016
Environment: ODM installed today (3/4/2016) on Ubuntu 14.04 w/ 4 GB of
RAM.  I've successfully had it process the caliterra sample image set.
I am getting an error when directing it to my own image set.  The output
when I try to run run.py is below (there are no log files produced).  Any
help?
Thanks in advance,
Ted
ubuntu at odm:~/Test_images$ ~/OpenDroneMap/run.py
  - configuration:
     start_with : resize
     end_with : odm_orthophoto
     force_focal : None
     odm_texturing_textureWithSize : 3600
     matcher_neighbors : 8
     matcher_threshold : 2.0
     cmvs_maxImages : 500
     odm_orthophoto_resolution : 20.0
     pmvs_threshold : 0.7
     zip_results : False
     resize_to : 2400
     use_opensfm : True
     min_num_features : 6000
     odm_meshing_octreeDepth : 9
     odm_meshing_solverDivide : 9
     pmvs_wsize : 7
     odm_texturing_textureResolution : 4096
     matcher_ratio : 0.6
     odm_meshing_samplesPerNode : 1.0
     odm_meshing_maxVertexCount : 100000
     matcher_distance : 0
     pmvs_level : 1
     run_only : None
     job_dir_name : None
     odm_georeferencing_useGcp : False
     odm_georeferencing_gcpFile : gcp_list.txt
     pmvs_csize : 2
     pmvs_minImageNum : 3
     force_ccd : None
  - source files - Mon Apr 04 17:56:05  2016
  File "/home/ubuntu/OpenDroneMap/run.py", line 986, in <module>
    prepare_objects()
  File "/home/ubuntu/OpenDroneMap/run.py", line 415, in prepare_objects
    fileObject["ccd"] = float(ccdWidths[fileObject["id"]])
KeyError: u'DJI FC550'
URL: <http://lists.osgeo.org/pipermail/opendronemap-users/attachments/20160404/9ac880ec/attachment.html>
More information about the OpenDroneMap-users mailing list
