[OpenDroneMap-users] gdal problem
Stephen Mather stephen at smathermather.com
Tue Feb 23 18:42:58 PST 2016
Hi Cezar,
Your gaps are caused by not mosaicking the sets of images before running
them through gdal2tiles. You'd need to use gdalmerge prior to gdal2tiles
and be sure to set your no-data value in order to set the overlap rule.
Otherwise what you get is the transparent values in one mosaic overwrite
the values in the images below.
Hope this helps,
Best,
Steve
On Mon, Feb 8, 2016 at 5:19 PM, Cezar Popescu <cezar.popescu at gmail.com>
wrote:
> Hello guys and i am happy to meet you all. I am aware that my problem it
> is not strictly tied to ODM but i am kindda new to this field and you are
> the only ones i know and i could ask for help. So, if someone has a little
> time to have a look to my problem and give me a solution i'd be very
> content.
> Now, i´ve generated some georeferenced png + kml from a bunch of geotagged
> jpegs. After that i´ve run a gdalbuildvrt and gdal2tiles on that vrt file.
> The problem is the generated tiles have huge gaps that are not present in
> the original pngs.
> I´ve uploaded the original png+kml, vrt and the generated tiles (763.8MB)
> here: http://s.go.ro/w9712i40 | password: 806217
> Also, if you are curious, all the files (original jpegs) are uploaded
> here: http://s.go.ro/8vl2v1nr | password: 421405
> If i load each individual png in google earth, the gaps are not present as
> you can see in this printscreen http://s.go.ro/4bzls9qw
> I hope someone will see why the ugly tiles happens and what is the
> workaround. Thank you very much for your time :)
> ps> i am sorry about the password, it is automatically enforced by that
> storage system, nothing i can do about it.
> *Cezar Popescu*
> (+40) 723.178-176
> My website: Atelierele Albe <http://atelierelealbe.eu>
> In my spare time i do Costică Acsinte <http://colectiacosticaacsinte.eu>
> OpenDroneMap-users mailing list
> OpenDroneMap-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/opendronemap-users
URL: <http://lists.osgeo.org/pipermail/opendronemap-users/attachments/20160223/174a9f2e/attachment.html>
More information about the OpenDroneMap-users mailing list
