[OpenDroneMap-users] How to troubleshoot orthophoto
Khyale Nascimento
khyale at hotmail.com
Wed Jul 27 18:08:19 PDT 2016
I have the same problem reported by Dennis. Large regions in my orthophoto may be skewed or distorted. I used the same set of images in pix4dmapper and it works well. I used 65 images captured from Inspire 1. The value of altitude extracted from exif data may interfere in the reconstruction?
In reconstruction, should I use the Absolute Altitude (AMSL, altitude Above Mean Sea Level) or Relative Altitude (AGL, altitude Above Ground Level)? The image's exif data gives me both. In Inspire 1, the 'Relative Altitude' is calculated from the barometer sensor data. And I note the ODM uses the altitude AMSL in the their processes.
Thanks,
Khyale.
Date: Wed, 27 Jul 2016 15:59:49 -0500
To: s_mailinglist at geraschs.de
Subject: Re: [OpenDroneMap-users] How to troubleshoot orthophoto
CC: opendronemap-users at lists.osgeo.org
Simon, thanks for the suggestion.
My GPS EXIF data is all accurate from my testing. I've run it through Photoscan multiple times and have tried ODM a few times over the past several days. If you want to see the dataset you can find it here:
https://www.dropbox.com/sh/zyuxr73df4ozitu/AABixfPR-nmOHU5yL_1MOmyka?dl=0
This includes the source imagery (95 files) plus the output geotiff from Photoscan.
On Wed, Jul 27, 2016 at 3:33 PM, Simon <s_mailinglist at geraschs.de> wrote:
Hi Dennis,
have you used the georeferencing option in one of the two ways possible?
Could be related to wrong GPS info in the exif tags, or in the GCP-lists
file...
Regards, Simon
On 07/27/2016 09:55 PM, Dennis Baldwin wrote:
> Hi,
> I've been working with some aerial imagery that I shot over the past
> few months. Basically doing a comparison of ODM output with my
> Photoscan results. Unfortunately with the latest codebase I've been
> getting some pretty strange results when generating an orthophoto. You
> can see what I'm talking about here:
> https://www.dropbox.com/sh/extsb6o6jaoq8t2/AADRvkeINPydFVwKDaheZtzSa?dl=0
> You can see the intended results from Photoscan (after running through
> gdal2tiles) here:
> http://www.unmannedairlines.com/dev/tiger_stadium
> My question is what is the best way to go about troubleshooting these
> results? I have all of the log output, but am not sure of the best
> place to start. This imagery was generated with a Phantom 4 so I did
> have to do some manipulation of focallength and ccd width just to get
> ODM to run. Perhaps I botched something there.
> Any insight of where to start would be much appreciated.
> Thanks,
> Dennis
> OpenDroneMap-users mailing list
> OpenDroneMap-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/opendronemap-users
URL: <http://lists.osgeo.org/pipermail/opendronemap-users/attachments/20160728/980e1afe/attachment.html>
More information about the OpenDroneMap-users
