[OpenDroneMap-users] [OpenDroneMap-dev] Beta v0.1 Release and Changelog
Kshitij Sharma
ksharma at gmail.com
Mon Jun 20 19:00:51 PDT 2016
Hello Dakota,
Thanks for the information. As of now, what is the difference between the
release zip file vs.
https://github.com/OpenDroneMap/OpenDroneMap/wiki/1.-Installation? If we
were to follow the instructions from the wiki, would we get the same
release that you have sent the email for?
Thanks much.
kshitij
Kshitij Sharma
https://www.linkedin.com/in/kshitijsharma
+91 9632366466
On Wed, Jun 15, 2016 at 7:59 PM, Dakota Benjamin <
dmb2 at clevelandmetroparks.com> wrote:
> And we are live! Thanks to everyone who has contributed to OpenDroneMap
> thus far.
> The link to download the release is here:
> https://github.com/OpenDroneMap/OpenDroneMap/releases/download/v0.1/OpenDroneMap-v0_1.zip
> Dakota
> [image: http://sig.cmparks.net/cmp-ms-90x122.png]Dakota Benjamin
> Geospatial Developer
> clevelandmetroparks.com <http://www.clemetparks.com/>
> *From:* OpenDroneMap-dev <opendronemap-dev-bounces at lists.osgeo.org> on
> behalf of Dakota Benjamin <dmb2 at clevelandmetroparks.com>
> *Sent:* Tuesday, June 14, 2016 10:50:30 AM
> *To:* opendronemap-users at lists.osgeo.org; opendronemap-dev at lists.osgeo.org
> *Subject:* [OpenDroneMap-dev] Beta v0.1 Release and Changelog
> OpenDroneMap users,
> Tomorrow we will be publishing a huge update. We've incorporated a
> processing framework for the ODM toolchain and improved the installation
> process. If you've been using the "dev" branch on GitHub recently, this is
> nothing new for you. Read below for the changelog and watch for another
> email tomorrow when the release is finalized.
> Installation
> - cmake superbuild for all components
> - Now you will run the following to install or update ODM:
> bash ./configure.sh
> mkdir build && cd build && cmake .. && make && cd ..
> # copy paste the following (with correct directory structure) into your ~/.bashrc (or other preferred method) (requires logout/in to work)
> export PYTHONPATH=$PYTHONPATH:<ODMDIR>/SuperBuild/install/lib/python2.7/dist-packages:<ODMDIR>/SuperBuild/src/opensfm
> export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:<ODMDIR>/SuperBuild/install/lib
> Running ODM
> Use these instructions to run the processing script
> <https://github.com/OpenDroneMap/OpenDroneMap/tree/dev#running-opendronemap>.
> Note there are significant differences from the previous version, namely
> you have to specify --project-path
> Code restructure
> - Object Oriented Code
> - Ecto <https://plasmodic.github.io/ecto/> processing framework
> - Project tree:
> - Your ODM project will have a more organized structure. One big
> change is that your images must be placed in a "images/" subdirectory in
> the project folder.
> - Testing framework
> Feature additions / changes
> - Add XYZ pointcloud output
> - benchmarking with --time
> - Replacement of LASTools with PDAL
> - Control script updates - --rerun-from, --rerun-all
> - Remove local ccd_defs in lieu of OpenSfM sensor data file.
> Please email me with questions or comments. If you want to use the updates
> before the release, simply run "git checkout dev" and use the installation
> method above.
> Happy Processing!
> Dakota
> OpenDroneMap-dev mailing list
> OpenDroneMap-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/opendronemap-dev
URL: <http://lists.osgeo.org/pipermail/opendronemap-users/attachments/20160621/e841859b/attachment.html>
More information about the OpenDroneMap-users
