[OpenDroneMap-users] Errors installing in Lubuntu 17.04
Rion Lerm rion at saeon.ac.za
Fri Apr 28 04:40:42 PDT 2017
I second Carlos' suggestion on Dockker install instructions.
Regards,
*Rion Lerm (jnr.)*
(+27) 76 913 8381 (Cell)
(+27) 13 735 3536 (Office)
Ndlovu Node
Phalaborwa Gate, Kruger National Park
South African Environmental Observation Network (SAEON)
Click here to learn about SAEON <http://www.saeon.ac.za/saeon-background>
On 27 April 2017 at 02:24, Carlos Grohmann <carlos.grohmann at gmail.com>
wrote:
> Ok, I got it running under Docker.
> I didn't understand at first how docker works, and was under the
> impression that I *had* to compile it from source. After I realized that
> 'docker pull opendronemap/opendronemap' was the way to go, it all got
> easier.
> BTW, I would recommend updating the instructions with 'docker pull'
> followed by usage examples. This would simplify things and make it easier
> for novices in docker.
> best
> Carlos
> On Wed, Apr 26, 2017 at 11:51 AM, Carlos Grohmann <
> carlos.grohmann at gmail.com> wrote:
>> I see.
>> Ok, trying the version 0.3 (downloaded as tar.gz, since the git repo is
>> about 1.4GB...), and running
>> docker build -t packages -f Dockerfile .
>> gives me an error with opencv:
>> -- Installing: /code/SuperBuild/install/share
>> /OpenCV/lbpcascades/lbpcascade_profileface.xml
>> /OpenCV/lbpcascades/lbpcascade_silverware.xml
>> [ 59%] Completed 'opencv'
>> [ 59%] Built target opencv
>> make: *** [all] Error 2
>> Makefile:83: recipe for target 'all' failed
>> The command '/bin/sh -c cd SuperBuild && mkdir build && cd build && cmake
>>  .. && make -j$(nproc)     && cd ../.. && mkdir build && cd build && cmake
>> .. && make -j$(nproc)' returned a non-zero code: 2
>> thanks
>> Carlos
>> On Wed, Apr 26, 2017 at 11:21 AM, Dakota M. Benjamin <
>> dmb2 at clevelandmetroparks.com> wrote:
>>> All,
>>> I think this issue is related: https://github.com/Op
>>> enDroneMap/OpenDroneMap/issues/410
>>> For now I would suggest trying the docker install process detailed in
>>> the README while we look into these issues.
>>> [image: http://sig.cmparks.net/cmp-ms-90x122.png]Dakota Benjamin
>>> Geospatial Developer
>>> 216-635-3255 <(216)%20635-3255> (Office)
>>> clevelandmetroparks.com <http://www.clemetparks.com/>
>>> *From:* OpenDroneMap-users <opendronemap-users-bounces at lists.osgeo.org>
>>> on behalf of Carlos Grohmann <carlos.grohmann at gmail.com>
>>> *Sent:* Wednesday, April 26, 2017 9:52:57 AM
>>> *To:* opendronemap-users at lists.osgeo.org
>>> *Subject:* Re: [OpenDroneMap-users] Errors installing in Lubuntu 17.04
>>> Thanks Martin
>>> Those errors were fized by installing libpcl-dev and libopencv-dev.
>>> Now I'm getting errors in the compilation step:
>>> modules/odm_georef/CMakeFiles/odm_georef.dir/build.make:86: recipe for
>>> target 'modules/odm_georef/CMakeFiles/odm_georef.dir/src/Georef.cpp.o'
>>> failed
>>> make[2]: *** [modules/odm_georef/CMakeFiles
>>> /odm_georef.dir/src/Georef.cpp.o] Error 1
>>> CMakeFiles/Makefile2:170: recipe for target
>>> 'modules/odm_georef/CMakeFiles/odm_georef.dir/all' failed
>>> make[1]: *** [modules/odm_georef/CMakeFiles/odm_georef.dir/all] Error 2
>>> Configuration Finished
>>> From what I see, it's looking for Georef.cpp at
>>> ???/modules/odm_georef/CMakeFiles/odm_georef.dir/src/
>>> but I only found this file at
>>> OpenDroneMap/modules/odm_georef/src
>>> thanks again
>>> Carlos
>>> On Wed, Apr 26, 2017 at 2:23 AM, Martin Weis <
>>> martin.weis.newsadress at gmx.de> wrote:
>>>> Hello!
>>>> Am 26.04.2017 um 03:57 schrieb Carlos Grohmann:
>>>> > I'm trying to install ODM on a Lubuntu 17.04 virtual machine
>>>> (VirtualBox
>>>> > running in MacOS).
>>>> > I'm getting errors with PCL and PDAL. (I'm running as root due some
>>>> > permissions errors in earlier attempts)
>>>> pcl and opencv, as it seems...
>>>> > CMake Warning at modules/odm_georef/CMakeLists.txt:16 (find_package):
>>>> >   Could not find a package configuration file provided by "PCL"
>>>> (requested
>>>> >   version 1.7) with any of the following names:
>>>> >     PCLConfig.cmake
>>>> >     pcl-config.cmake
>>>> >   Could not find a package configuration file provided by "OpenCV"
>>>> with any
>>>> >     OpenCVConfig.cmake
>>>> >     opencv-config.cmake
>>>> On U16.04 these files are in packages:
>>>> apt-file search PCLConfig.cmake
>>>> libpcl-dev: /usr/lib/x86_64-linux-gnu/cmake/pcl/PCLConfig.cmake
>>>> apt-file search OpenCVConfig.cmake
>>>> libopencv-dev: /usr/share/OpenCV/OpenCVConfig.cmake
>>>> Did you install these packages?
>>>> apt install libpcl-dev libopencv-dev
>>>> # maybe redo cmake config to update cached content.
>>>> Good luck
>>>> Martin
>>>> _______________________________________________
>>>> OpenDroneMap-users mailing list
>>>> OpenDroneMap-users at lists.osgeo.org
>>>> https://lists.osgeo.org/mailman/listinfo/opendronemap-users
>>> Prof. Carlos Henrique Grohmann
>>> Institute of Energy and Environment - Univ. of São Paulo, Brazil
>>> - Digital Terrain Analysis | GIS | Remote Sensing -
>>> http://carlosgrohmann.com
>>> http://orcid.org/0000-0001-5073-5572
>>> ________________
>>> Can’t stop the signal.
>> ________________
> ________________
URL: <http://lists.osgeo.org/pipermail/opendronemap-users/attachments/20170428/3f691fa3/attachment.html>
More information about the OpenDroneMap-users mailing list
