[OpenDroneMap-users] ERROR 6: The GeoJSON driver does not overwrite existing files.
Maik Pohl
pohl at fog-gmbh.com
Fri Oct 16 01:39:32 PDT 2020
Hello opendronemap-users,
i have a program written in python, that runs opendronemap through
docker from a subprocess.
There are two variations:
1. i run
docker run --rm -v /inpath:/datasets/code -v
/outpath:/datasets/code/odm_orthophoto/ opendronemap/odm --project-path
/datasets --fast-orthophoto --rerun-all
Close to finishing, i get this error:
[INFO] running pdal info --boundary --filters.hexbin.edge_size=1
--filters.hexbin.threshold=0
/datasets/code/odm_georeferencing/odm_georeferenced_model.decimated.las
/datasets/code/odm_georeferencing/odm_georeferenced_model.boundary.json[0m
File "/code/run.py", line 68, in <module>
app.execute()
File "/code/stages/odm_app.py", line 95, in execute
self.first_stage.run()
File "/code/opendm/types.py", line 356, in run
self.next_stage.run(outputs)
[Previous line repeated 5 more times]
File "/code/opendm/types.py", line 337, in run
self.process(self.args, outputs)
File "/code/stages/odm_georeferencing.py", line 135, in process
decimation_step=decimation_step)
File "/code/opendm/cropper.py", line 236, in create_bounds_gpkg
bounds_geojson_path = self.create_bounds_geojson(pointcloud_path,
buffer_distance, decimation_step)
File "/code/opendm/cropper.py", line 207, in create_bounds_geojson
layer = out_ds.CreateLayer("convexhull", geom_type=ogr.wkbPolygon)
AttributeError: 'NoneType' object has no attribute 'CreateLayer'
Then i run
this runs to the end and i get an orthophoto.
The second variation is for better quality orthophotos. I run:
/datasets --depthmap-resolution 1000 --ignore-gsd --mesh-size 450000
--mesh-octree-depth 11 --texturing-nadir-weight 30 --dem-resolution 2.0
--orthophoto-resolution 2.0 --orthophoto-compression NONE
--orthophoto-cutline true --skip-3dmodel --rerun-all
I get the same error as above.
Like before, i run the same command again without --rerun-all but then
get the same error.
How can i solve this error?
Thank you, sincerely Maik Pohl
More information about the OpenDroneMap-users
