[OpenLayers-Commits] r10941 - in sandbox/august/trunk: . build examples lib lib/OpenLayers lib/OpenLayers/BaseTypes lib/OpenLayers/Control lib/OpenLayers/Format lib/OpenLayers/Format/OWSCommon lib/OpenLayers/Format/SLD lib/OpenLayers/Handler lib/OpenLayers/Layer lib/OpenLayers/Layer/Google lib/OpenLayers/Layer/WMS lib/OpenLayers/Popup lib/OpenLayers/Renderer lib/OpenLayers/Strategy lib/OpenLayers/Tile lib/OpenLayers/Tile/Image tests tests/BaseTypes tests/Control tests/Format tests/Format/WFST tests/Format/WMC tests/Handler tests/Layer tests/Layer/WMS tests/Marker tests/Popup tests/Renderer tests/Strategy tests/manual theme/default tools
commits-20090109 at openlayers.org commits-20090109 at openlayers.org
Fri Dec 3 01:40:11 EST 2010
Author: augusttown
Date: 2010-12-02 22:40:11 -0800 (Thu, 02 Dec 2010)
New Revision: 10941
Added:
   sandbox/august/trunk/examples/donut.html
   sandbox/august/trunk/examples/donut.js
   sandbox/august/trunk/examples/kml-layer.js
   sandbox/august/trunk/examples/single-tile.html
   sandbox/august/trunk/examples/single-tile.js
   sandbox/august/trunk/examples/strategy-cluster-extended.html
   sandbox/august/trunk/examples/strategy-cluster-extended.js
   sandbox/august/trunk/tests/OpenLayers1.html
   sandbox/august/trunk/tests/OpenLayers2.html
   sandbox/august/trunk/tests/OpenLayers3.html
   sandbox/august/trunk/tests/OpenLayers4.html
   sandbox/august/trunk/tests/manual/page-position.html
Removed:
   sandbox/august/trunk/examples/notile.html
   sandbox/august/trunk/tests/OpenLayers.html
   sandbox/august/trunk/build/full.cfg
   sandbox/august/trunk/build/library.cfg
   sandbox/august/trunk/build/license.txt
   sandbox/august/trunk/build/lite.cfg
   sandbox/august/trunk/examples/Jugl.js
   sandbox/august/trunk/examples/example-list.html
   sandbox/august/trunk/examples/getfeature-wfs.html
   sandbox/august/trunk/examples/kml-layer.html
   sandbox/august/trunk/examples/measure.html
   sandbox/august/trunk/examples/proxy.cgi
   sandbox/august/trunk/examples/snapping.html
   sandbox/august/trunk/examples/sos.html
   sandbox/august/trunk/examples/strategy-cluster.html
   sandbox/august/trunk/examples/sundials-spherical-mercator.html
   sandbox/august/trunk/examples/vector-features.html
   sandbox/august/trunk/lib/OpenLayers.js
   sandbox/august/trunk/lib/OpenLayers/BaseTypes.js
   sandbox/august/trunk/lib/OpenLayers/BaseTypes/Class.js
   sandbox/august/trunk/lib/OpenLayers/Control/GetFeature.js
   sandbox/august/trunk/lib/OpenLayers/Control/Measure.js
   sandbox/august/trunk/lib/OpenLayers/Control/ModifyFeature.js
   sandbox/august/trunk/lib/OpenLayers/Control/OverviewMap.js
   sandbox/august/trunk/lib/OpenLayers/Control/PanZoomBar.js
   sandbox/august/trunk/lib/OpenLayers/Control/Panel.js
   sandbox/august/trunk/lib/OpenLayers/Control/SLDSelect.js
   sandbox/august/trunk/lib/OpenLayers/Control/WMTSGetFeatureInfo.js
   sandbox/august/trunk/lib/OpenLayers/Events.js
   sandbox/august/trunk/lib/OpenLayers/Format/OWSCommon/v1.js
   sandbox/august/trunk/lib/OpenLayers/Format/SLD/v1.js
   sandbox/august/trunk/lib/OpenLayers/Format/SOSGetObservation.js
   sandbox/august/trunk/lib/OpenLayers/Handler/Box.js
   sandbox/august/trunk/lib/OpenLayers/Handler/Drag.js
   sandbox/august/trunk/lib/OpenLayers/Handler/Path.js
   sandbox/august/trunk/lib/OpenLayers/Handler/Polygon.js
   sandbox/august/trunk/lib/OpenLayers/Lang.js
   sandbox/august/trunk/lib/OpenLayers/Layer.js
   sandbox/august/trunk/lib/OpenLayers/Layer/AgsTiled.js
   sandbox/august/trunk/lib/OpenLayers/Layer/EventPane.js
   sandbox/august/trunk/lib/OpenLayers/Layer/Google/v3.js
   sandbox/august/trunk/lib/OpenLayers/Layer/SphericalMercator.js
   sandbox/august/trunk/lib/OpenLayers/Layer/TileCache.js
   sandbox/august/trunk/lib/OpenLayers/Layer/Vector.js
   sandbox/august/trunk/lib/OpenLayers/Layer/WMS.js
   sandbox/august/trunk/lib/OpenLayers/Layer/WMS/Post.js
   sandbox/august/trunk/lib/OpenLayers/Layer/XYZ.js
   sandbox/august/trunk/lib/OpenLayers/Map.js
   sandbox/august/trunk/lib/OpenLayers/Popup.js
   sandbox/august/trunk/lib/OpenLayers/Popup/Anchored.js
   sandbox/august/trunk/lib/OpenLayers/Projection.js
   sandbox/august/trunk/lib/OpenLayers/Renderer/Canvas.js
   sandbox/august/trunk/lib/OpenLayers/Renderer/Elements.js
   sandbox/august/trunk/lib/OpenLayers/Renderer/SVG.js
   sandbox/august/trunk/lib/OpenLayers/Renderer/VML.js
   sandbox/august/trunk/lib/OpenLayers/SingleFile.js
   sandbox/august/trunk/lib/OpenLayers/Strategy/Filter.js
   sandbox/august/trunk/lib/OpenLayers/Tile/Image.js
   sandbox/august/trunk/lib/OpenLayers/Tile/Image/IFrame.js
   sandbox/august/trunk/lib/OpenLayers/Util.js
   sandbox/august/trunk/readme.txt
   sandbox/august/trunk/release-license.txt
   sandbox/august/trunk/tests/BaseTypes/Element.html
   sandbox/august/trunk/tests/Control/LayerSwitcher.html
   sandbox/august/trunk/tests/Control/Measure.html
   sandbox/august/trunk/tests/Control/ModifyFeature.html
   sandbox/august/trunk/tests/Control/PanZoom.html
   sandbox/august/trunk/tests/Control/Panel.html
   sandbox/august/trunk/tests/Control/SLDSelect.html
   sandbox/august/trunk/tests/Feature.html
   sandbox/august/trunk/tests/Format/GML.html
   sandbox/august/trunk/tests/Format/SOSGetObservation.html
   sandbox/august/trunk/tests/Format/WFST/v1_1_0.html
   sandbox/august/trunk/tests/Format/WMC.html
   sandbox/august/trunk/tests/Format/WMC/v1_1_0.html
   sandbox/august/trunk/tests/Handler/Polygon.html
   sandbox/august/trunk/tests/Layer/EventPane.html
   sandbox/august/trunk/tests/Layer/GeoRSS.html
   sandbox/august/trunk/tests/Layer/MapServer.html
   sandbox/august/trunk/tests/Layer/SphericalMercator.html
   sandbox/august/trunk/tests/Layer/Text.html
   sandbox/august/trunk/tests/Layer/Vector.html
   sandbox/august/trunk/tests/Layer/WMS.html
   sandbox/august/trunk/tests/Layer/WMS/Post.html
   sandbox/august/trunk/tests/Layer/XYZ.html
   sandbox/august/trunk/tests/Marker/Box.html
   sandbox/august/trunk/tests/Popup.html
   sandbox/august/trunk/tests/Popup/Anchored.html
   sandbox/august/trunk/tests/Projection.html
   sandbox/august/trunk/tests/Renderer/Canvas.html
   sandbox/august/trunk/tests/Renderer/Elements.html
   sandbox/august/trunk/tests/Renderer/VML.html
   sandbox/august/trunk/tests/Request.html
   sandbox/august/trunk/tests/Strategy/Filter.html
   sandbox/august/trunk/tests/Util.html
   sandbox/august/trunk/tests/list-tests-2.html
   sandbox/august/trunk/tests/list-tests.html
   sandbox/august/trunk/tests/run-tests-2.html
   sandbox/august/trunk/theme/default/style.css
   sandbox/august/trunk/tools/mergejs.py
Merge with trunk at revision 10940.
Property changes on: sandbox/august/trunk
___________________________________________________________________
Modified: svn:mergeinfo
   - /trunk/openlayers:10329-10354,10357-10502,10504-10808
   + /trunk/openlayers:10329-10354,10357-10502,10504-10940
Modified: sandbox/august/trunk/build/full.cfg
--- sandbox/august/trunk/build/full.cfg	2010-12-01 22:47:34 UTC (rev 10940)
+++ sandbox/august/trunk/build/full.cfg	2010-12-03 06:40:11 UTC (rev 10941)
@@ -3,7 +3,6 @@
 [first]
-OpenLayers.js
 OpenLayers/Util.js
@@ -14,19 +13,6 @@
 [include]
 [exclude]
-Firebug/firebug.js
-Firebug/firebugx.js
-OpenLayers/Lang/ca.js
-OpenLayers/Lang/cs-CZ.js
-OpenLayers/Lang/da-DK.js
-OpenLayers/Lang/de.js
-OpenLayers/Lang/en-CA.js
-OpenLayers/Lang/es.js
-OpenLayers/Lang/fr.js
-OpenLayers/Lang/it.js
-OpenLayers/Lang/nb.js
-OpenLayers/Lang/nl.js
-OpenLayers/Lang/pt-BR.js
-OpenLayers/Lang/sv-SE.js
-OpenLayers/Lang/zh-TW.js
-OpenLayers/Lang/zh-CN.js
+Firebug
+OpenLayers.js
+OpenLayers/Lang
Modified: sandbox/august/trunk/build/library.cfg
--- sandbox/august/trunk/build/library.cfg	2010-12-01 22:47:34 UTC (rev 10940)
+++ sandbox/august/trunk/build/library.cfg	2010-12-03 06:40:11 UTC (rev 10941)
@@ -4,7 +4,6 @@
 [first]
-OpenLayers.js
 OpenLayers/Util.js
@@ -15,8 +14,8 @@
 [include]
 [exclude]
-Firebug/firebug.js
+Firebug
+OpenLayers.js
 OpenLayers/Format/GeoRSS.js
 OpenLayers/Format/GML.js
 OpenLayers/Format/WKT.js
@@ -50,19 +49,6 @@
 OpenLayers/Renderer.js
+OpenLayers/Lang
Modified: sandbox/august/trunk/build/license.txt
--- sandbox/august/trunk/build/license.txt	2010-12-01 22:47:34 UTC (rev 10940)
+++ sandbox/august/trunk/build/license.txt	2010-12-03 06:40:11 UTC (rev 10941)
@@ -90,3 +90,36 @@
  * issues. Applications that use the code below will continue to work seamlessly
  * when that happens.
+ * OpenLayers.Util.pagePosition is based on Yahoo's getXY method, which is
+ * Copyright (c) 2006, Yahoo! Inc.
+ * All rights reserved.
+ * Redistribution and use of this software in source and binary forms, with or
+ * without modification, are permitted provided that the following conditions
+ * are met:
+ * * Redistributions of source code must retain the above copyright notice,
+ *   this list of conditions and the following disclaimer.
+ * * Redistributions in binary form must reproduce the above copyright notice,
+ *   this list of conditions and the following disclaimer in the documentation
+ *   and/or other materials provided with the distribution.
+ * * Neither the name of Yahoo! Inc. nor the names of its contributors may be
+ *   used to endorse or promote products derived from this software without
+ *   specific prior written permission of Yahoo! Inc.
+ * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
+ * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+ * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
+ * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
+ * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
+ * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
+ * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
+ * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
+ * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
+ * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
+ * POSSIBILITY OF SUCH DAMAGE.
\ No newline at end of file
Modified: sandbox/august/trunk/build/lite.cfg
--- sandbox/august/trunk/build/lite.cfg	2010-12-01 22:47:34 UTC (rev 10940)
+++ sandbox/august/trunk/build/lite.cfg	2010-12-03 06:40:11 UTC (rev 10941)
@@ -6,7 +6,6 @@
 [first]
-OpenLayers.js
 OpenLayers/Util.js
Modified: sandbox/august/trunk/examples/Jugl.js
--- sandbox/august/trunk/examples/Jugl.js	2010-12-01 22:47:34 UTC (rev 10940)
+++ sandbox/august/trunk/examples/Jugl.js	2010-12-03 06:40:11 UTC (rev 10941)
@@ -1,84 +1,8 @@
  * Jugl.js -- JavaScript Template Library
- * Copyright 2007 Tim Schaub
- * Released under the MIT license.  Please see
- * http://svn.tschaub.net/jugl/trunk/license.txt for the full license.
+ * Copyright 2007-2010 Tim Schaub
+ * Released under the MIT license.  Please see
+ * http://github.com/tschaub/jugl/blob/master/license.txt for the full license.
-(function(){var Jugl={prefix:"jugl",namespaceURI:"http://namespace.jugl.org/"};Jugl.Array={indexOf:function(array,obj){for(var i=0;i<array.length;i++){if(array[i]==obj)return i;}
-return-1;}};Jugl.Function={bind:function(method,object){var args=[];for(var i=2;i<arguments.length;++i){args.push(arguments[i]);}
-return function(){for(var i=0;i<arguments.length;++i){args.push(arguments[i]);}
-return method.apply(object,args);}}};Jugl.Node={appendChild:function(parent,child){if(typeof(parent)=="string"){var obj=document.getElementById(parent);if(!obj){throw Error("Element id not found: "+parent);}
-parent=obj;}
-if(typeof(child)=="string"){var obj=document.getElementById(child);if(!obj){throw Error("Element id not found: "+child);}
-child=obj;}
-if(child.namespaceURI&&child.xml){var wrapper=document.createElement('div');wrapper.innerHTML=child.xml;var children=wrapper.childNodes;for(var i=0;i<children.length;++i){parent.appendChild(children[i]);}}else{if(parent.ownerDocument&&parent.ownerDocument.importNode){child=parent.ownerDocument.importNode(child,true);}
-parent.appendChild(child);}
-return child;}};Jugl.Object={extend:function(destination,source){destination=destination||{};source=source||{};for(property in source){destination[property]=source[property];}
-return destination;},applyDefaults:function(destination,source){destination=destination||{};source=source||{};for(property in source){if(destination[property]===undefined){destination[property]=source[property];}}
-return destination;}};Jugl.Request={loadTemplate:function(url,onComplete,caller){var createTemplate=function(request){var doc,template;try{doc=request.responseXML;template=new Jugl.Template(doc.documentElement);}catch(invalidXML){try{doc=document.createElement("div");doc.innerHTML=request.responseText;template=new Jugl.Template(doc.firstChild);}catch(invalidHTML){var msg="Can't make HTML out of response: "+
-request.responseText;Jugl.Console.error(msg);throw invalidHTML;}}
-var complete=Jugl.Function.bind(onComplete,caller);complete(template);}
-Jugl.Request.loadUrl(url,createTemplate);},loadUrl:function(url,onComplete,caller){var complete=(caller)?Jugl.Function.bind(onComplete,caller):onComplete;var request=Jugl.Request.createXMLHttpRequest();request.open("GET",url);request.onreadystatechange=function(){if(request.readyState==4){complete(request);}}
-request.send(null);},createXMLHttpRequest:function(){if(typeof XMLHttpRequest!="undefined"){return new XMLHttpRequest();}else if(typeof ActiveXObject!="undefined"){return new ActiveXObject("Microsoft.XMLHTTP");}else{throw new Error("XMLHttpRequest not supported");}}};Jugl.Class=function(){var Class=function(){if(this===Jugl){var msg="Create an instance of a Jugl "+"class with the new keyword";throw Error(msg);}
-this.initialize.apply(this,arguments);}
-var extended={toString:function(){return"["+this.CLASS_NAME+"]";}};var parent;for(var i=0;i<arguments.length;++i){if(typeof arguments[i]=="function"){parent=arguments[i].prototype;}else{parent=arguments[i];}
-Jugl.Object.extend(extended,parent);}
-Class.prototype=extended;return Class;};Jugl.Console={log:function(){},debug:function(){},info:function(){},warn:function(){},error:function(){},assert:function(){},dir:function(){},dirxml:function(){},trace:function(){},group:function(){},groupEnd:function(){},time:function(){},timeEnd:function(){},profile:function(){},profileEnd:function(){},count:function(){}};(function(){if(window.console){var scripts=document.getElementsByTagName("script");for(var i=0;i<scripts.length;++i){if(scripts[i].src.indexOf("firebug.js")!=-1){Jugl.Object.extend(Jugl.Console,console);break;}}}})();Jugl.Attribute=Jugl.Class({element:null,node:null,type:null,nodeValue:null,template:null,initialize:function(element,node,type){this.element=element;this.node=node;this.type=type;this.nodeValue=node.nodeValue;this.nodeName=node.nodeName;this.template=element.template;},splitAttributeValue:function(value){value=(value!=null)?value:this.nodeValue;var matches=this.template.regExes.trimSpace.exec(value);var
  items;if(matches&&matches.length==3){items=[matches[1],matches[2]];}
-return items;},splitExpressionPrefix:function(){var items=this.splitAttributeValue();if(!items||(items[0]!='structure'&&items[0]!='text')){items=[null,this.nodeValue];}
-return items;},getAttributeValues:function(){var trimmed=this.nodeValue.replace(/[\t\n]/g,"").replace(/;\s*$/,"");var tabbed=trimmed.replace(/;;/g,"\t");var newlined=tabbed.split(";").join("\n");return newlined.replace(/\t/g,";").split(/\n/g);},removeSelf:function(){this.element.removeAttributeNode(this);},process:function(){return this.processAttribute[this.type].apply(this,[]);},evalInScope:function(str){var expression="with(this.element.scope){"+str+"}";return eval(expression);},processAttribute:{"define":function(){var values=this.getAttributeValues();var pair;for(var i=0;i<values.length;++i){pair=this.splitAttributeValue(values[i]);this.element.scope[pair[0]]=this.evalInScope(pair[1]);}
-this.removeSelf();return true;},"condition":function(){var proceed;try{proceed=!!(this.evalInScope(this.nodeValue));}catch(err){var message=err.name+": "+err.message+"\n"+"attribute: "+this.nodeName;Jugl.Console.error(message);throw err;}
-this.removeSelf();if(!proceed){this.element.removeSelf();}
-return proceed;},"repeat":function(){var pair=this.splitAttributeValue();var key=pair[0];var list=this.evalInScope(pair[1]);this.removeSelf();if(!(list instanceof Array)){var items=new Array();for(var p in list){items.push(p);}
-list=items;}
-var element;var previousSibling=this.element;var length=list.length;for(var i=0;i<length;++i){element=this.element.clone();element.scope[key]=list[i];element.scope.repeat[key]={index:i,number:i+1,even:!(i%2),odd:!!(i%2),start:(i==0),end:(i==length-1),length:length};previousSibling.insertAfter(element);element.process();previousSibling=element;}
-this.element.removeSelf();return false;},"content":function(){var pair=this.splitExpressionPrefix();var str;try{str=this.evalInScope(pair[1]);}catch(err){Jugl.Console.error("Failed to eval in element scope: "+
-pair[1]);throw err;}
-this.removeSelf();if(pair[0]=='structure'){try{this.element.node.innerHTML=str;}catch(err){var wrapper=document.createElement('div');var msg;try{wrapper.innerHTML=str;}catch(invalidHTML){msg="Can't transform string into valid HTML : "+
-str;Jugl.Console.error(msg);throw invalidHTML;}
-if(this.element.node.xml&&this.template.xmldom){while(this.element.node.firstChild){this.element.node.removeChild(this.element.node.firstChild);}
-this.template.xmldom.loadXML(wrapper.outerHTML);var children=this.template.xmldom.firstChild.childNodes;try{for(var i=0;i<children.length;++i){this.element.node.appendChild(children[i]);}}catch(invalidXML){msg="Can't transform string into valid XHTML : "+
-str;Jugl.Console.error(msg);throw invalidXML;}}else{try{this.element.node.innerHTML=wrapper.innerHTML;}catch(invalidXML){msg="Can't transform string into valid XHTML : "+
-str;Jugl.Console.error(msg);throw invalidXML;}}}}else{var text;if(this.element.node.xml&&this.template.xmldom){text=this.template.xmldom.createTextNode(str);}else{text=document.createTextNode(str);}
-var child=new Jugl.Element(this.template,text);this.element.removeChildNodes();this.element.appendChild(child);}
-return true;},"replace":function(){var pair=this.splitExpressionPrefix();var str;try{str=this.evalInScope(pair[1]);}catch(err){Jugl.Console.error("Failed to eval in element scope: "+
-this.removeSelf();if(pair[0]=='structure'){var wrapper=document.createElement('div');try{wrapper.innerHTML=str;}catch(err){msg="Can't transform string into valid HTML : "+
-str;Jugl.Console.error(msg);throw err;}
-if(this.element.node.xml&&this.template.xmldom){try{this.template.xmldom.loadXML(wrapper.outerHTML);}catch(err){msg="Can't transform string into valid XML : "+
-wrapper=this.template.xmldom.firstChild;}
-while(wrapper.firstChild){var child=wrapper.removeChild(wrapper.firstChild);if(this.element.node.ownerDocument&&this.element.node.ownerDocument.importNode){if(child.ownerDocument!=this.element.node.ownerDocument){child=this.element.node.ownerDocument.importNode(child,true);}}
-this.element.node.parentNode.insertBefore(child,this.element.node);}}else{var text;if(this.element.node.xml&&this.template.xmldom){text=this.template.xmldom.createTextNode(str);}else{text=document.createTextNode(str);}
-var replacement=new Jugl.Element(this.template,text);this.element.insertBefore(replacement);}
-this.element.removeSelf();return true;},"attributes":function(){var values=this.getAttributeValues();var pair,name,value;for(var i=0;i<values.length;++i){pair=this.splitAttributeValue(values[i]);name=pair[0];value=this.evalInScope(pair[1]);if(value!==false){this.element.setAttribute(name,value);}}
-this.removeSelf();return true;},"omit-tag":function(){var omit;try{omit=((this.nodeValue=="")||!!(this.evalInScope(this.nodeValue)));}catch(err){Jugl.Console.error("Failed to eval in element scope: "+
-this.nodeValue);throw err;}
-this.removeSelf();if(omit){var children=this.element.getChildNodes();var child;for(var i=0;i<children.length;++i){this.element.insertBefore(children[i]);}
-this.element.removeSelf();}},"reflow":function(){var reflow;try{reflow=((this.nodeValue=="")||!!(this.evalInScope(this.nodeValue)));}catch(err){Jugl.Console.error("Failed to eval in element scope: "+
-this.removeSelf();if(reflow){if(this.element.node.outerHTML){this.element.node.outerHTML=this.element.node.outerHTML;}else{this.element.node.innerHTML=this.element.node.innerHTML;}}}},CLASS_NAME:"Jugl.Attribute"});Jugl.Element=Jugl.Class({template:null,node:null,scope:null,initialize:function(template,node){this.template=template;this.node=node;this.scope=new Object();this.scope.repeat=new Object();},clone:function(){var node=this.node.cloneNode(true);node.removeAttribute("id");var element=new Jugl.Element(this.template,node);Jugl.Object.extend(element.scope,this.scope);return element;},getAttribute:function(localName){var node;if(this.node.nodeType==1){if(this.template.usingNS){node=this.node.getAttributeNodeNS(Jugl.namespaceURI,localName);}else{node=this.node.getAttributeNode(Jugl.prefix+":"+
-localName);}
-if(node&&!node.specified){node=false;}}
-var attribute;if(node){attribute=new Jugl.Attribute(this,node,localName);}else{attribute=node;}
-return attribute;},setAttribute:function(name,value){this.node.setAttribute(name,value);},removeAttributeNode:function(attribute){this.node.removeAttributeNode(attribute.node);},getChildNodes:function(){var numNodes=this.node.childNodes.length;var children=new Array(numNodes);var node,scope;for(var i=0;i<numNodes;++i){node=new Jugl.Element(this.template,this.node.childNodes[i]);node.scope=Jugl.Object.extend({},this.scope);children[i]=node;}
-return children;},removeChildNodes:function(){while(this.node.hasChildNodes()){this.node.removeChild(this.node.firstChild);}},removeChild:function(element){this.node.removeChild(element.node);return node;},removeSelf:function(){this.node.parentNode.removeChild(this.node);},importNode:function(element){if(this.node.ownerDocument&&this.node.ownerDocument.importNode){if(element.node.ownerDocument!=this.node.ownerDocument){element.node=this.node.ownerDocument.importNode(element.node,true);}}},appendChild:function(element){this.importNode(element);this.node.appendChild(element.node);},insertAfter:function(element){this.importNode(element);var parent=this.node.parentNode;var sibling=this.node.nextSibling;if(sibling){parent.insertBefore(element.node,sibling);}else{parent.appendChild(element.node);}},insertBefore:function(element){this.importNode(element);var parent=this.node.parentNode;parent.insertBefore(element.node,this.node);},process:function(){var attribute;var keepProcessing
 =true;var series=["define","condition","repeat"];for(var i=0;i<series.length;++i){attribute=this.getAttribute(series[i]);if(attribute){try{keepProcessing=attribute.process();}catch(err){Jugl.Console.error("Failed to process "+
-series[i]+" attribute");throw err;}
-if(!keepProcessing){return;}}}
-var content=this.getAttribute("content");if(content){try{content.process();}catch(err){Jugl.Console.error("Failed to process content attribute");throw err;}}else{var replace=this.getAttribute("replace");if(replace){try{replace.process();}catch(err){Jugl.Console.error("Failed to process replace attribute");throw err;}}}
-var attributes=this.getAttribute("attributes");if(attributes){try{attributes.process();}catch(err){Jugl.Console.error("Failed to process attributes attribute");throw err;}}
-if(!content&&!replace){this.processChildNodes();}
-var omit=this.getAttribute("omit-tag");if(omit){try{omit.process();}catch(err){Jugl.Console.error("Failed to process omit-tag attribute");throw err;}}
-var reflow=this.getAttribute("reflow");if(reflow){try{reflow.process();}catch(err){Jugl.Console.error("Failed to process reflow attribute");throw err;}}},processChildNodes:function(){var children=this.getChildNodes();for(var i=0;i<children.length;++i){try{children[i].process();}catch(err){Jugl.Console.error("Failed to process child node: "+i);throw err;}}},CLASS_NAME:"Jugl.Element"});Jugl.Template=Jugl.Class({node:null,usingNS:false,xhtmlns:"http://www.w3.org/1999/xhtml",xmldom:window.ActiveXObject?new ActiveXObject("Microsoft.XMLDOM"):null,regExes:{trimSpace:(/^\s*(\w+)\s+(.*?)\s*$/)},loaded:false,loading:false,initialize:function(config){if(typeof config=="string"||(config&&config.nodeType==1)){config={node:config};}
-config=config||{};if(typeof(config.node)=="string"){config.node=document.getElementById(config.node);if(!config.node){throw Error("Element id not found: "+config.node);}}
-if(config.node){this.node=config.node;this.loaded=true;}else if(config.url){this.load({url:config.url,callback:config.callback,scope:config.scope});}},process:function(config){if(config&&!config.context&&!config.clone&&!config.string&&!config.parent){config={context:config}}
-config=Jugl.Object.applyDefaults(config,{context:null,clone:false,string:false});if(this.node.getAttributeNodeNS){if(this.node.getAttributeNodeNS(Jugl.xhtmlns,Jugl.prefix)){this.usingNS=true;}}
-var element=new Jugl.Element(this,this.node);if(config.clone){element=element.clone();}
-if(config.context){element.scope=config.context;}
-try{element.process();}catch(err){Jugl.Console.error("Failed to process "+
-this.node.nodeName+" node");throw err;}
-var data;if(config.string){if(element.node.innerHTML){data=element.node.innerHTML;}else{if(this.xmldom){data=element.node.xml;}else{var serializer=new XMLSerializer();data=serializer.serializeToString(element.node);}}}else{data=element.node;if(config.parent){if(config.clone){data=Jugl.Node.appendChild(config.parent,element.node);}else{this.appendTo(config.parent);}}}
-return data;},load:function(config){if(typeof config=="string"){config={url:config};}
-config=config||{};this.loading=true;var setNode=function(template){this.node=template.node;this.loading=false;this.loaded=true;if(config.callback){config.callback.apply(config.scope,[template]);}}
-Jugl.Request.loadTemplate(config.url,setNode,this);},appendTo:function(parent){this.node=Jugl.Node.appendChild(parent,this.node);return this;},CLASS_NAME:"Jugl.Template"});window["http://jugl.tschaub.net/trunk/lib/Jugl.js"]=Jugl;})();
+(function(){var f={prefix:"jugl",namespaceURI:null,loadTemplate:function(h){var i=function(l){var m,k,n=!l.status||(l.status>=200&&l.status<300);if(n){try{m=l.responseXML;k=new e(m.documentElement)}catch(j){m=document.createElement("div");m.innerHTML=l.responseText;k=new e(m.firstChild)}if(h.callback){h.callback.call(h.scope,k)}}else{if(h.failure){h.failure.call(h.scope,l)}}};d(h.url,i)}};var g=function(h,j){h=h||{};j=j||{};for(var i in j){h[i]=j[i]}return h};var a=function(l,o){var m,n,k,j,h;if(typeof(l)==="string"){m=document.getElementById(l);if(!m){throw Error("Element id not found: "+l)}l=m}if(typeof(o)==="string"){m=document.getElementById(o);if(!m){throw Error("Element id not found: "+o)}o=m}if(o.namespaceURI&&o.xml){n=document.createElement("div");n.innerHTML=o.xml;k=n.childNodes;for(j=0,h=k.length;j<h;++j){l.appendChild(k[j])}}else{if(l.ownerDocument&&l.ownerDocument.importNode&&l.ownerDocument!==o.ownerDocument){o=l.ownerDocument.importNode(o,true)}l.appendChild(o)
 }return o};var d=function(h,k,i){var j;if(typeof XMLHttpRequest!=="undefined"){j=new XMLHttpRequest()}else{if(typeof ActiveXObject!=="undefined"){j=new ActiveXObject("Microsoft.XMLHTTP")}else{throw new Error("XMLHttpRequest not supported")}}j.open("GET",h);j.onreadystatechange=function(){if(j.readyState===4){k.call(i,j)}};j.send(null)};var b=function(h,i){this.template=h;this.node=i;this.scope={};this.scope.repeat={}};g(b.prototype,{clone:function(){var i=this.node.cloneNode(true);i.removeAttribute("id");var h=new b(this.template,i);g(h.scope,this.scope);return h},getAttribute:function(h){var j;if(this.node.nodeType===1){if(this.template.usingNS){j=this.node.getAttributeNodeNS(f.namespaceURI,h)}else{j=this.node.getAttributeNode(f.prefix+":"+h)}if(j&&!j.specified){j=false}}var i;if(j){i=new c(this,j,h)}else{i=j}return i},setAttribute:function(h,i){this.node.setAttribute(h,i)},removeAttributeNode:function(h){this.node.removeAttributeNode(h.node)},getChildNodes:function(){var k
 =this.node.childNodes.length;var j=new Array(k);var l;for(var h=0;h<k;++h){l=new b(this.template,this.node.childNodes[h]);l.scope=g({},this.scope);j[h]=l}return j},removeChildNodes:function(){while(this.node.hasChildNodes()){this.node.removeChild(this.node.firstChild)}},removeChild:function(h){this.node.removeChild(h.node);return node},removeSelf:function(){this.node.parentNode.removeChild(this.node)},importNode:function(h){if(this.node.ownerDocument&&this.node.ownerDocument.importNode){if(h.node.ownerDocument!==this.node.ownerDocument){h.node=this.node.ownerDocument.importNode(h.node,true)}}},appendChild:function(h){this.importNode(h);this.node.appendChild(h.node)},insertAfter:function(h){this.importNode(h);var j=this.node.parentNode;var i=this.node.nextSibling;if(i){j.insertBefore(h.node,i)}else{j.appendChild(h.node)}},insertBefore:function(h){this.importNode(h);var i=this.node.parentNode;i.insertBefore(h.node,this.node)},process:function(){var j;var r=true;var n=["define"
 ,"condition","repeat"];for(var o=0,p=n.length;o<p;++o){j=this.getAttribute(n[o]);if(j){r=j.process();if(!r){return}}}var q=this.getAttribute("content");if(q){q.process()}else{var k=this.getAttribute("replace");if(k){k.process()}}var m=this.getAttribute("attributes");if(m){m.process()}if(!q&&!k){this.processChildNodes()}var h=this.getAttribute("omit-tag");if(h){h.process()}var l=this.getAttribute("reflow");if(l){l.process()}},processChildNodes:function(){var k=this.getChildNodes();for(var j=0,h=k.length;j<h;++j){k[j].process()}}});var e=function(h){h=h||{};if(typeof h==="string"||(h.nodeType===1)){h={node:h}}if(typeof(h.node)==="string"){h.node=document.getElementById(h.node);if(!h.node){throw Error("Element id not found: "+h.node)}}if(h.node){this.node=h.node;this.loaded=true}else{if(h.url){this.load({url:h.url,callback:h.callback,scope:h.scope})}}};g(e.prototype,{node:null,usingNS:false,xmldom:window.ActiveXObject?new ActiveXObject("Microsoft.XMLDOM"):null,trimSpace:(/^\s*(
 \w+)\s+(.*?)\s*$/),loaded:false,loading:false,process:function(h){var i,j;h=g({context:null,clone:false,string:false},h);this.usingNS=this.node.getAttributeNodeNS&&f.namespaceURI;i=new b(this,this.node);if(h.clone||h.string){i=i.clone()}if(h.context){i.scope=h.context}i.process();if(h.string){if(i.node.innerHTML){j=i.node.innerHTML}else{if(this.xmldom){j=i.node.xml}else{j=(new XMLSerializer).serializeToString(i.node)}}}else{j=i.node;if(h.parent){if(h.clone){j=a(h.parent,i.node)}else{this.appendTo(h.parent)}}}return j},load:function(j){if(typeof j==="string"){j={url:j}}j=j||{};this.loading=true;var h=function(k){this.node=k.node;this.loading=false;this.loaded=true;if(j.callback){j.callback.apply(j.scope,[k])}};var i;if(j.failure){i=(function(){return function(k){j.failure.call(j.scope,k)}})()}f.loadTemplate({url:j.url,callback:h,failure:i,scope:this})},appendTo:function(h){this.node=a(h,this.node);return this}});var c=function(h,j,i){this.element=h;this.node=j;this.type=i;thi
 s.nodeValue=j.nodeValue;this.nodeName=j.nodeName;this.template=h.template};g(c.prototype,{splitAttributeValue:function(i){i=(i!=null)?i:this.nodeValue;var h=this.template.trimSpace.exec(i);return h&&h.length===3&&[h[1],h[2]]},splitExpressionPrefix:function(){var h=this.splitAttributeValue();if(!h||(h[0]!="structure"&&h[0]!="text")){h=[null,this.nodeValue]}return h},getAttributeValues:function(){return this.nodeValue.replace(/[\t\n]/g,"").replace(/;\s*$/,"").replace(/;;/g,"\t").split(";").join("\n").replace(/\t/g,";").split(/\n/g)},removeSelf:function(){this.element.removeAttributeNode(this)},process:function(){return this.processAttribute[this.type].apply(this,[])},evalInScope:function(k){var i=this.element.scope;var h=[];var j=[];for(key in i){h.push(key);j.push(i[key])}var l=new Function(h.join(","),"return "+k);return l.apply({},j)},processAttribute:{define:function(){var l,k,j,h=this.getAttributeValues();for(k=0,j=h.length;k<j;++k){l=this.splitAttributeValue(h[k]);this.e
 lement.scope[l[0]]=this.evalInScope(l[1])}this.removeSelf();return true},condition:function(){var h=!!(this.evalInScope(this.nodeValue));this.removeSelf();if(!h){this.element.removeSelf()}return h},repeat:function(){var l=this.splitAttributeValue();var r=l[0];var o=this.evalInScope(l[1]);this.removeSelf();if(!(o instanceof Array)){var q=new Array();for(var j in o){q.push(j)}o=q}var m;var h=this.element;for(var n=0,k=o.length;n<k;++n){m=this.element.clone();m.scope[r]=o[n];m.scope.repeat[r]={index:n,number:n+1,even:!(n%2),odd:!!(n%2),start:(n===0),end:(n===k-1),length:k};h.insertAfter(m);m.process();h=m}this.element.removeSelf();return false},content:function(){var m=this.splitExpressionPrefix();var p=this.evalInScope(m[1]);this.removeSelf();if(m[0]==="structure"){try{this.element.node.innerHTML=p}catch(l){var h=document.createElement("div");h.innerHTML=p;if(this.element.node.xml&&this.template.xmldom){while(this.element.node.firstChild){this.element.node.removeChild(this.ele
 ment.node.firstChild)}this.template.xmldom.loadXML(h.outerHTML);var k=this.template.xmldom.firstChild.childNodes;for(var n=0,o=k.length;n<o;++n){this.element.node.appendChild(k[n])}}else{this.element.node.innerHTML=h.innerHTML}}}else{var q;if(this.element.node.xml&&this.template.xmldom){q=this.template.xmldom.createTextNode(p)}else{q=document.createTextNode(p)}var j=new b(this.template,q);this.element.removeChildNodes();this.element.appendChild(j)}return true},replace:function(){var k=this.splitExpressionPrefix();var j=this.evalInScope(k[1]);this.removeSelf();if(k[0]==="structure"){var m=document.createElement("div");m.innerHTML=j;if(this.element.node.xml&&this.template.xmldom){this.template.xmldom.loadXML(m.outerHTML);m=this.template.xmldom.firstChild}while(m.firstChild){var l=m.removeChild(m.firstChild);if(this.element.node.ownerDocument&&this.element.node.ownerDocument.importNode){if(l.ownerDocument!=this.element.node.ownerDocument){l=this.element.node.ownerDocument.impor
 tNode(l,true)}}this.element.node.parentNode.insertBefore(l,this.element.node)}}else{var i;if(this.element.node.xml&&this.template.xmldom){i=this.template.xmldom.createTextNode(j)}else{i=document.createTextNode(j)}var h=new b(this.template,i);this.element.insertBefore(h)}this.element.removeSelf();return true},attributes:function(){var h=this.getAttributeValues();var n,k,m;for(var l=0,j=h.length;l<j;++l){n=this.splitAttributeValue(h[l]);k=n[0];m=this.evalInScope(n[1]);if(m!==false){this.element.setAttribute(k,m)}}this.removeSelf();return true},"omit-tag":function(){var l=((this.nodeValue==="")||!!(this.evalInScope(this.nodeValue)));this.removeSelf();if(l){var k=this.element.getChildNodes();for(var j=0,h=k.length;j<h;++j){this.element.insertBefore(k[j])}this.element.removeSelf()}},reflow:function(){var h=((this.nodeValue==="")||!!(this.evalInScope(this.nodeValue)));this.removeSelf();if(h){if(this.element.node.outerHTML){this.element.node.outerHTML=this.element.node.outerHTML}el
 se{this.element.node.innerHTML=this.element.node.innerHTML}}}}});window.jugl=g(f,{Template:e})})();
Copied: sandbox/august/trunk/examples/donut.html (from rev 10940, trunk/openlayers/examples/donut.html)
--- sandbox/august/trunk/examples/donut.html	                        (rev 0)
+++ sandbox/august/trunk/examples/donut.html	2010-12-03 06:40:11 UTC (rev 10941)
@@ -0,0 +1,59 @@
+<!DOCTYPE html>
+<html>
+    <head>
+        <title>OpenLayers Polygon Hole Digitizing</title>
+        <link rel="stylesheet" href="../theme/default/style.css" type="text/css">
+        <link rel="stylesheet" href="style.css" type="text/css">
+        <style>
+            #controlToggle li {
+                list-style: none;
+            .olControlAttribution {
+                font-size: 9px;
+                bottom: 2px;
+            #output {
+                margin: 1em;
+                font-size: 0.9em;
+        </style>
+    </head>
+    <body>
+        <h1 id="title">Drawing Holes in Polygons</h1>
+        <div id="tags">
+            draw polygon hole
+        </div>
+        <p id="shortdesc">
+            The DrawFeature control can be used to digitize donut polygons.
+        </p>
+        <div id="map" class="smallmap"></div>
+        <ul id="controlToggle">
+            <li>
+                <input type="radio" name="type" value="none" id="noneToggle"
+                       onclick="toggleControl(this);" checked="checked">
+                <label for="noneToggle">navigate</label>
+            </li>
+            <li>
+                <input type="radio" name="type" value="polygon" id="polygonToggle" onclick="toggleControl(this);">
+                <label for="polygonToggle">draw polygon</label>
+            </li>
+        </ul>
+        <div id="output"></div>
+        <div id="docs">
+            <p>
+                To digitize holes in polygons, hold down the <code>Alt</code>
+                key and draw over an existing polygon.  By default, the
+                <code>Shift</code> key triggers freehand drawing.  Use a
+                combination of the <code>Shift</code> and <code>Alt</code> keys
+                to digitize holes in freehand mode.
+            </p>
+            <p>
+                See the <a href="donut.js" target="_blank">
+                donut.js source</a> for details on how this is done.
+            </p>
+        </div>
+        <script src="../lib/OpenLayers.js"></script>
+        <script src="donut.js"></script>
+    </body>
+</html>
Copied: sandbox/august/trunk/examples/donut.js (from rev 10940, trunk/openlayers/examples/donut.js)
--- sandbox/august/trunk/examples/donut.js	                        (rev 0)
+++ sandbox/august/trunk/examples/donut.js	2010-12-03 06:40:11 UTC (rev 10941)
@@ -0,0 +1,38 @@
+var map = new OpenLayers.Map({
+    div: "map",
+    layers: [
+        new OpenLayers.Layer.OSM(),
+        new OpenLayers.Layer.Vector()
+    center: new OpenLayers.LonLat(0, 0),
+    zoom: 1
+var draw = new OpenLayers.Control.DrawFeature(
+    map.layers[1],
+    OpenLayers.Handler.Polygon,
+    {handlerOptions: {holeModifier: "altKey"}}
+map.addControl(draw);
+// optionally listen for sketch events on the layer
+var output = document.getElementById("output");
+function updateOutput(event) {
+    window.setTimeout(function() {
+        output.innerHTML = event.type + " " + event.feature.id;
+    }, 100);
+map.layers[1].events.on({
+    sketchmodified: updateOutput,
+    sketchcomplete: updateOutput
+// add behavior to UI elements
+function toggleControl(element) {
+    if (element.value === "polygon" && element.checked) {
+        draw.activate();
+    } else {
+        draw.deactivate();
+document.getElementById("noneToggle").checked = true;
Modified: sandbox/august/trunk/examples/example-list.html
--- sandbox/august/trunk/examples/example-list.html	2010-12-01 22:47:34 UTC (rev 10940)
+++ sandbox/august/trunk/examples/example-list.html	2010-12-03 06:40:11 UTC (rev 10941)
@@ -98,8 +98,6 @@
         <script type="text/javascript" src="Jugl.js"></script>
         <script type="text/javascript" src="example-list.js"></script>
         <script type="text/javascript">
-            // import
-            var Jugl = window["http://jugl.tschaub.net/trunk/lib/Jugl.js"];
             var template, target;
             function listExamples(examples) {
@@ -201,7 +199,7 @@
             window.onload = function() {
-                template = new Jugl.Template("template");
+                template = new jugl.Template("template");
                 target = document.getElementById("examples");
                 listExamples(info.examples);
                 document.getElementById("exwin").src = "../examples/example.html";
Modified: sandbox/august/trunk/examples/getfeature-wfs.html
--- sandbox/august/trunk/examples/getfeature-wfs.html	2010-12-01 22:47:34 UTC (rev 10940)
+++ sandbox/august/trunk/examples/getfeature-wfs.html	2010-12-03 06:40:11 UTC (rev 10941)
@@ -18,8 +18,8 @@
             layer = new OpenLayers.Layer.WMS(
                 "States WMS/WFS",
-                "http://demo.opengeo.org/geoserver/ows",
-                {layers: 'topp:states', format: 'image/gif'}
+                "http://v2.suite.opengeo.org/geoserver/ows",
+                {layers: 'usa:states', format: 'image/gif'}
             select = new OpenLayers.Layer.Vector("Selection", {styleMap:
                 new OpenLayers.Style(OpenLayers.Feature.Vector.style["select"])
Modified: sandbox/august/trunk/examples/kml-layer.html
--- sandbox/august/trunk/examples/kml-layer.html	2010-12-01 22:47:34 UTC (rev 10940)
+++ sandbox/august/trunk/examples/kml-layer.html	2010-12-03 06:40:11 UTC (rev 10941)
@@ -1,45 +1,33 @@
-<html xmlns="http://www.w3.org/1999/xhtml">
-  <head>
-    <link rel="stylesheet" href="../theme/default/style.css" type="text/css" />
-    <link rel="stylesheet" href="style.css" type="text/css" />
-    <script src="../lib/OpenLayers.js"></script>
-    <script type="text/javascript">
-        var lon = 5;
-        var lat = 40;
-        var zoom = 5;
-        var map, layer;
+<!DOCTYPE html>
+<html>
+    <head>
+    </head>
+    <body>
+    <h1 id="title">KML Layer Example</h1>
-        function init(){
-            map = new OpenLayers.Map('map');
-            layer = new OpenLayers.Layer.WMS( "OpenLayers WMS",
-                    "http://vmap0.tiles.osgeo.org/wms/vmap0", {layers: 'basic'} );
-            map.addLayer(layer);
-            map.addLayer(new OpenLayers.Layer.GML("KML", "kml/lines.kml",
-                format: OpenLayers.Format.KML,
-                formatOptions: {
-                  extractStyles: true,
-                  extractAttributes: true,
-                  maxDepth: 2
-            map.zoomToExtent(new OpenLayers.Bounds(-112.306698,36.017792,-112.03204,36.18087));
-    </script>
-  </head>
-  <body onload="init()">
-      <h1 id="title">KML Layer Example</h1>
+    <div id="tags">KML</div>
-      <div id="tags">
-        KML
-      </div>
-      <p id="shortdesc">
-          Demonstrates loading and displaying a KML file on top of a basemap.
+        Demonstrates loading and displaying a KML file on top of a basemap.
     </p>
-    <div id="docs"></div>
-  </body>
+    <div id="docs">
+        <p>
+            A vector layer can be populated with features from a KML document
+            by configuring the layer with an HTTP protocol that points to the
+            KML document and is configured with a KML format for parsing features.
+            The fixed strategy is used to load all features at once.
+        </p>
+        <p>
+            View the <a href="kml-layer.js" target="_blank">kml-layer.js</a>
+            source to see how this is done.
+        </p>
+    </div>
+    <script src="kml-layer.js"></script>
+    </body>
 </html>
Copied: sandbox/august/trunk/examples/kml-layer.js (from rev 10940, trunk/openlayers/examples/kml-layer.js)
--- sandbox/august/trunk/examples/kml-layer.js	                        (rev 0)
+++ sandbox/august/trunk/examples/kml-layer.js	2010-12-03 06:40:11 UTC (rev 10941)
@@ -0,0 +1,22 @@
+    div: "map",
+    layers: [
+        new OpenLayers.Layer.WMS(
+            "WMS", "http://vmap0.tiles.osgeo.org/wms/vmap0",
+            {layers: "basic"}
+        new OpenLayers.Layer.Vector("KML", {
+            strategies: [new OpenLayers.Strategy.Fixed()],
+            protocol: new OpenLayers.Protocol.HTTP({
+                url: "kml/lines.kml",
+                format: new OpenLayers.Format.KML({
+                    extractStyles: true,
+                    extractAttributes: true,
+                    maxDepth: 2
+    center: new OpenLayers.LonLat(-112.169, 36.099),
+    zoom: 11
Modified: sandbox/august/trunk/examples/measure.html
--- sandbox/august/trunk/examples/measure.html	2010-12-01 22:47:34 UTC (rev 10940)
+++ sandbox/august/trunk/examples/measure.html	2010-12-03 06:40:11 UTC (rev 10941)
@@ -132,6 +132,13 @@
                 control.geodesic = element.checked;
+        function toggleImmediate(element) {
+            for(key in measureControls) {
+                var control = measureControls[key];
+                control.setImmediate(element.checked);
     </script>
   </head>
@@ -164,13 +171,19 @@
                 <input type="checkbox" name="geodesic" id="geodesicToggle" onclick="toggleGeodesic(this);" />
                 <label for="geodesicToggle">use geodesic measures</label>
             </li>
+            <li>
+                <input type="checkbox" name="immediate" id="immediateToggle" onclick="toggleImmediate(this);" />
+                <label for="immediateToggle">use immediate measures</label>
+            </li>
         </ul>
         <p>Note that the geometries drawn are planar geometries and the
         metrics returned by the measure control are planar measures by
         default.  If your map is in a geographic projection or you have the
         appropriate projection definitions to transform your geometries into
         geographic coordinates, you can set the "geodesic" property of the control
-        to true to calculate geodesic measures instead of planar measures.</p>
+        to true to calculate geodesic measures instead of planar measures.
+        Also you have the possibility to set the "immediate" property to true
+        to get a new calculated value once the mouse has been mooved.</p>
     </div>
   </body>
 </html>
Deleted: sandbox/august/trunk/examples/notile.html
--- sandbox/august/trunk/examples/notile.html	2010-12-01 22:47:34 UTC (rev 10940)
+++ sandbox/august/trunk/examples/notile.html	2010-12-03 06:40:11 UTC (rev 10941)
@@ -1,42 +0,0 @@
-  <head>
-    <title>OpenLayers: Single Tile</title>
-        var map;
-        function init(){
-            map = new OpenLayers.Map('mapDiv', {maxResolution: 'auto'});
-            var old_ol_wms = new OpenLayers.Layer.WMS.Untiled( "WMS.Untiled",
-                "http://vmap0.tiles.osgeo.org/wms/vmap0?", {layers: 'basic'} );
-            old_ol_wms.addOptions({isBaseLayer: true});
-            var new_ol_wms = new OpenLayers.Layer.WMS( "WMS w/singleTile",
-                "http://vmap0.tiles.osgeo.org/wms/vmap0?", {layers: 'basic'},
-                { singleTile: true, ratio: 1 } );
-            new_ol_wms.addOptions({isBaseLayer: true});
-            map.addLayers([old_ol_wms, new_ol_wms]);
-            map.addControl(new OpenLayers.Control.LayerSwitcher());
-            map.setCenter(new OpenLayers.LonLat(6.5, 40.5), 4);
-    </script>
-  </head>
-    <h1 id="title">Untiled Example</h1>
-    <div id="tags">
-        tile, ratio, singleTile, performance
-    </div>
-      Create an untiled WMS layer using the singleTile: true, option or the deprecated
-      WMS.Untiled layer.
-    </p>
-    <div id="mapDiv" class="smallmap"></div>
-    <p> The first layer is an old OpenLayers.Layer.WMS.Untiled layer, using
-        a default ratio value of 1.5.
-    <p> The second layer is an OpenLayers.Layer.WMS layer with singleTile set
-        to true, and with a ratio of 1.
-  </body>
-</html>
Modified: sandbox/august/trunk/examples/proxy.cgi
--- sandbox/august/trunk/examples/proxy.cgi	2010-12-01 22:47:34 UTC (rev 10940)
+++ sandbox/august/trunk/examples/proxy.cgi	2010-12-03 06:40:11 UTC (rev 10941)
@@ -20,7 +20,7 @@
                 'prototype.openmnnd.org', 'geo.openplans.org',
                 'sigma.openplans.org', 'demo.opengeo.org',
                 'www.openstreetmap.org', 'sample.azavea.com',
-                'v-swe.uni-muenster.de:8080',
+                'v2.suite.opengeo.org', 'v-swe.uni-muenster.de:8080',
                 'vmap0.tiles.osgeo.org']
 method = os.environ["REQUEST_METHOD"]
Copied: sandbox/august/trunk/examples/single-tile.html (from rev 10940, trunk/openlayers/examples/single-tile.html)
--- sandbox/august/trunk/examples/single-tile.html	                        (rev 0)
+++ sandbox/august/trunk/examples/single-tile.html	2010-12-03 06:40:11 UTC (rev 10941)
@@ -0,0 +1,30 @@
+<!DOCTYPE html>
+<html>
+    <head>
+        <title>OpenLayers: Single Tile</title>
+    </head>
+    <body>
+        <h1 id="title">Single Tile Example</h1>
+        <div id="tags">tile, ratio, singleTile, performance</div>
+            Use the singleTile option on gridded layers to request a single tile.
+        </p>
+        <div id="mapDiv" class="smallmap"></div>
+        <div id="docs">
+            <p>
+                This map demonstrates the use of the singleTile property as an
+                alternative to the default tiled behavior of layers.  The first
+                layer in the map is a WMS layer with the singleTile option set
+                true.  The second layer is a WMS layer with the default options.
+            </p>
+            <p>
+                View the <a href="single-tile.js" target="_blank">single-tile.js</a>
+            </p>
+        </div>
+        <script src="single-tile.js"></script>
+    </body>
+</html>
Copied: sandbox/august/trunk/examples/single-tile.js (from rev 10940, trunk/openlayers/examples/single-tile.js)
--- sandbox/august/trunk/examples/single-tile.js	                        (rev 0)
+++ sandbox/august/trunk/examples/single-tile.js	2010-12-03 06:40:11 UTC (rev 10941)
@@ -0,0 +1,20 @@
+    div: "mapDiv",
+    layers: [
+            "Single Tile",
+            "http://vmap0.tiles.osgeo.org/wms/vmap0",
+            {layers: "basic"},
+            {singleTile: true, ratio: 1}
+            "Multiple Tiles",
+            {layers: "basic"}
+    center: new OpenLayers.LonLat(6.5, 40.5),
+    zoom: 4
+map.addControl(new OpenLayers.Control.LayerSwitcher());
Modified: sandbox/august/trunk/examples/snapping.html
--- sandbox/august/trunk/examples/snapping.html	2010-12-01 22:47:34 UTC (rev 10940)
+++ sandbox/august/trunk/examples/snapping.html	2010-12-03 06:40:11 UTC (rev 10941)
@@ -164,7 +164,7 @@
                 poly, OpenLayers.Handler.Polygon,
-                {displayClass: "olControlDrawFeaturePoint", title: "Draw Features"}
+                {displayClass: "olControlDrawFeaturePoint", title: "Draw Features", handlerOptions: {holeModifier: "altKey"}}
             modify = new OpenLayers.Control.ModifyFeature(
                 poly, {displayClass: "olControlModifyFeature", title: "Modify Features"}
Modified: sandbox/august/trunk/examples/sos.html
--- sandbox/august/trunk/examples/sos.html	2010-12-01 22:47:34 UTC (rev 10940)
+++ sandbox/august/trunk/examples/sos.html	2010-12-03 06:40:11 UTC (rev 10941)
@@ -133,7 +133,7 @@
                         responseMode: 'inline',
                         procedure: feature.attributes.id,
                         offering: name,
-                        observedProperty: offering.observedProperties[0],
+                        observedProperties: offering.observedProperties,
                         responseFormat: this.responseFormat
                     OpenLayers.Request.POST({
Copied: sandbox/august/trunk/examples/strategy-cluster-extended.html (from rev 10940, trunk/openlayers/examples/strategy-cluster-extended.html)
--- sandbox/august/trunk/examples/strategy-cluster-extended.html	                        (rev 0)
+++ sandbox/august/trunk/examples/strategy-cluster-extended.html	2010-12-03 06:40:11 UTC (rev 10941)
@@ -0,0 +1,122 @@
+<!DOCTYPE html>
+<html>
+    <head>
+        <title>Extended clustering example</title>
+        <style type="text/css">
+            label {
+                cursor: pointer
+            #wrap {
+                width: 925px;
+                margin: 10px;
+            #strategy-chooser, #generalinfo, #info {
+                width: 400px;
+                padding: 0;
+                float: right;
+                clear: right;
+                margin-bottom: 4px;
+            #map {
+                float: left;
+        </style>
+    </head>
+    <body>
+        <h1 id="title">Extended clustering</h1>
+        <div id="tags">
+            cluster, advanced
+        </div>
+            Shows the usage of custom classes for a fine grained control about
+            the clustering behaviour.
+        </p>
+        <div id="wrap">
+            </div>
+            <div id="strategy-chooser">
+                <p>
+                    Select the desired clustering strategy:
+                </p>
+                <label>
+                    <input type="radio" name="strategy" value="none" id="no-strategy" checked="checked">No strategy
+                </label>
+                <br/>
+                <label>
+                    <input type="radio" name="strategy" value="cluster" id="cluster-strategy">Simple cluster-strategy
+                </label>
+                <br/>
+                <label>
+                    <input type="radio" name="strategy" value="attribute-cluster" id="attributive-cluster-strategy">Attributive cluster-strategy
+                </label>
+                <br/>
+                <label>
+                    <input type="radio" name="strategy" value="rule-cluster" id="rulebased-cluster-strategy">Rulebased cluster-strategy
+                </label>
+            </div>
+            <div id="generalinfo">
+            </div>
+            <div id="info">
+            </div>
+        </div>
+        <div id="docs" style="clear: both; padding-top: 10px">
+            <p>
+                The vectorlayer in this example contains random data with an
+                attribute "clazz" that can take the values 1, 2, 3 and 4. The
+                features with clazz = 4 are considered more important than the
+                others.
+            </p>
+            <p>
+                The radiobuttons on the right of the map control the
+                cluster strategy to be applied to the features.
+            </p>
+            <ul>
+                <li>
+                    <strong>No strategy</strong>
+                    means that all features are
+                    rendered, no clustering shall be applied
+                </li>
+                <li>
+                    <strong>Simple cluster-strategy</strong>
+                    applies the cluster
+                    strategy with default options to the layer. You should notice
+                    that many of the important features with clazz = 4 are getting
+                    lost, since clustering happens regardless of feature attributes
+                </li>
+                <li>
+                    <strong>Attributive cluster-strategy</strong>
+                    uses a
+                    customized cluster strategy. This strategy is configured to
+                    cluster features of the same clazz only. You should be able to see all
+                    red points (clazz = 4) even though the data is clustered. A
+                    cluster now contains only features of the same clazz.
+                </li>
+                <li>
+                    <strong>Rulebased cluster-strategy</strong>
+                    uses another
+                    cluster features that follow a certain rule only. In this case only
+                    features with a clazz different from 4 are considered as
+                    candidates for clustering. That means that usually you have fewer
+                    clusters on the map, yet all with clazz = 4 are easily
+                    distinguishable
+                </li>
+            </ul>
+            <p>
+                Hover over the features to get a short infomation about the
+                feature or cluster of features.
+            </p>
+        </div>
+        <p>
+            View the <a href="strategy-cluster-extended.js" target="_blank">strategy-cluster-extended.js</a>
+        </p>
+        <script type="text/javascript" src="../lib/OpenLayers.js"></script>
+        <script type="text/javascript" src="strategy-cluster-extended.js"></script>
+    </body>
+</html>
Copied: sandbox/august/trunk/examples/strategy-cluster-extended.js (from rev 10940, trunk/openlayers/examples/strategy-cluster-extended.js)
--- sandbox/august/trunk/examples/strategy-cluster-extended.js	                        (rev 0)
+++ sandbox/august/trunk/examples/strategy-cluster-extended.js	2010-12-03 06:40:11 UTC (rev 10941)
@@ -0,0 +1,247 @@
+ * Class: OpenLayers.Strategy.AttributeCluster
+ * Strategy for vector feature clustering based on feature attributes.
+ * Inherits from:
+ *  - <OpenLayers.Strategy.Cluster>
+OpenLayers.Strategy.AttributeCluster = OpenLayers.Class(OpenLayers.Strategy.Cluster, {
+     * the attribute to use for comparison
+    attribute: null,
+     * Method: shouldCluster
+     * Determine whether to include a feature in a given cluster.
+     * Parameters:
+     * cluster - {<OpenLayers.Feature.Vector>} A cluster.
+     * feature - {<OpenLayers.Feature.Vector>} A feature.
+     * Returns:
+     * {Boolean} The feature should be included in the cluster.
+    shouldCluster: function(cluster, feature) {
+        var cc_attrval = cluster.cluster[0].attributes[this.attribute];
+        var fc_attrval = feature.attributes[this.attribute];
+        var superProto = OpenLayers.Strategy.Cluster.prototype;
+        return cc_attrval === fc_attrval &&
+               superProto.shouldCluster.apply(this, arguments);
+    CLASS_NAME: "OpenLayers.Strategy.AttributeCluster"
+ * Class: OpenLayers.Strategy.RuleCluster
+ * Strategy for vector feature clustering according to a given rule.
+ * Inherits from:
+OpenLayers.Strategy.RuleCluster = OpenLayers.Class(OpenLayers.Strategy.Cluster, {
+     * the rule to use for comparison
+    rule: null,
+     * Parameters:
+     * Returns:
+        return this.rule.evaluate(cluster.cluster[0]) &&
+               this.rule.evaluate(feature) &&
+    CLASS_NAME: "OpenLayers.Strategy.RuleCluster"
+// global variables
+var map, vectorlayer, features, stylemap, select;
+// wrap the instanciation code in an anonymous function that gets executed
+// immeadeately
+(function(){
+    // The function that gets called on feature selection: shows information
+    // about the feature/cluser in a div on the page
+	var showInformation = function(evt){
+        var feature = evt.feature;
+		var info = 'Last hovered feature:<br>';
+		if (feature.cluster) {
+			info += '&nbsp;&nbsp;Cluster of ' + feature.attributes.count + ' features:';
+			var clazzes = {
+				'1': 0,
+				'2': 0,
+				'3': 0,
+				'4': 0
+			for (var i = 0; i < feature.attributes.count; i++) {
+				var feat = feature.cluster[i];
+				clazzes[feat.attributes.clazz]++;
+			for (var j=1; j<=4; j++) {
+				var plural_s = (clazzes[j] !== 1) ? 's' : '';
+				info += '<br>&nbsp;&nbsp;&nbsp;&nbsp;&bull;&nbsp;clazz ' + j + ': ' + clazzes[j] + ' feature' + plural_s;
+		} else {
+			info += '&nbsp;&nbsp;Single feature of clazz = ' + feature.attributes.clazz;
+		$('info').innerHTML = info;
+	// The function that gets called on feature selection. Shows information
+    // about the number of "points" on the map.
+	var updateGeneralInformation = function() {
+		var info = 'Currently ' + vectorlayer.features.length + ' points are shown on the map.';
+		$('generalinfo').innerHTML = info;
+	// instanciate the map
+	map = new OpenLayers.Map("map");
+	// background WMS
+    var ol_wms = new OpenLayers.Layer.WMS("OpenLayers WMS", "http://vmap0.tiles.osgeo.org/wms/vmap0", {
+        layers: "basic"
+	// context to style the vectorlayer
+    var context = {
+        getColor: function(feature){
+            var color = '#aaaaaa';
+			if (feature.attributes.clazz && feature.attributes.clazz === 4) {
+				color = '#ee0000';
+			} else if(feature.cluster) {
+				var onlyFour = true;
+				for (var i = 0; i < feature.cluster.length; i++) {
+					if (onlyFour && feature.cluster[i].attributes.clazz !== 4) {
+						onlyFour = false;
+				if (onlyFour === true) {
+			return color;
+    // style the vectorlayer
+    stylemap = new OpenLayers.StyleMap({
+        'default': new OpenLayers.Style({
+            pointRadius: 5,
+            fillColor: "${getColor}",
+            fillOpacity: 0.7,
+            strokeColor: "#666666",
+            strokeWidth: 1,
+            strokeOpacity: 1,
+			graphicZIndex: 1
+            context: context
+		'select' : new OpenLayers.Style({
+            pointRadius: 5,
+            fillColor: "#ffff00",
+            fillOpacity: 1,
+            strokeWidth: 1,
+            strokeOpacity: 1,
+			graphicZIndex: 2
+    // the vectorlayer
+    vectorlayer = new OpenLayers.Layer.Vector('Vectorlayer', {styleMap: stylemap, strategies: []});
+	// the select control
+	select = new OpenLayers.Control.SelectFeature(
+        vectorlayer, {hover: true}
+    map.addControl(select);
+    select.activate();
+    vectorlayer.events.on({"featureselected": showInformation});
+    map.addLayers([ol_wms, vectorlayer]);
+    map.addControl(new OpenLayers.Control.LayerSwitcher());
+    map.zoomToMaxExtent();
+    features = [];
+    // adding lots of features:
+    for (var i = 0; i < 700; i++) {
+        var r1 = Math.random();
+        var r2 = Math.random();
+        var r3 = Math.random();
+        var r4 = Math.random();
+        var px = r1 * 180 * ((r2 < 0.5) ? -1 : 1);
+        var py = r3 * 90 * ((r4 < 0.5) ? -1 : 1);
+        var p = new OpenLayers.Geometry.Point(px, py);
+        var clazz = (i % 10 === 0) ? 4 : Math.ceil(r4 * 3);
+        var f = new OpenLayers.Feature.Vector(p, {clazz: clazz});
+        features.push(f);
+    vectorlayer.addFeatures(features);
+    updateGeneralInformation();
+    // the behaviour and methods for the radioboxes
+    var changeStrategy = function() {
+        var strategies = [];
+        // this is the checkbox
+        switch(this.value) {
+            case 'cluster':
+                // standard clustering
+				strategies.push(new OpenLayers.Strategy.Cluster());
+                break;
+            case 'attribute-cluster':
+                // use the custom class: only cluster features of the same clazz
+				strategies.push(new OpenLayers.Strategy.AttributeCluster({
+                    attribute:'clazz'
+                break;
+            case 'rule-cluster':
+                // use the custom class: only cluster features that have a
+				// clazz smaller than 4
+				strategies.push(new OpenLayers.Strategy.RuleCluster({
+                    rule: new OpenLayers.Rule({
+                        filter: new OpenLayers.Filter.Comparison({
+                            type: OpenLayers.Filter.Comparison.LESS_THAN,
+                            property: "clazz",
+                            value: 4
+                break;
+		// remove layer and control
+        map.removeLayer(vectorlayer);
+		map.removeControl(select);
+		// rebuild layer
+        vectorlayer = new OpenLayers.Layer.Vector('Vectorlayer', {styleMap: stylemap, strategies: strategies});
+        map.addLayer( vectorlayer );
+        // rebuild select control
+		// update meta information
+	// bind the behviour to the radios
+    var inputs = document.getElementsByTagName('input');
+    for( var cnt = 0; cnt < inputs.length; cnt++) {
+      var input = inputs[cnt];
+      if (input.name === 'strategy') {
+         input.onclick = changeStrategy;
Modified: sandbox/august/trunk/examples/strategy-cluster.html
--- sandbox/august/trunk/examples/strategy-cluster.html	2010-12-01 22:47:34 UTC (rev 10940)
+++ sandbox/august/trunk/examples/strategy-cluster.html	2010-12-03 06:40:11 UTC (rev 10941)
@@ -66,7 +66,6 @@
         <script src="animator.js"></script>
             var map, template;
             OpenLayers.ProxyHost = (window.location.host == "localhost") ?
                 "/cgi-bin/proxy.cgi?url=" : "proxy.cgi?url=";
@@ -135,7 +134,7 @@
                 map.setCenter(new OpenLayers.LonLat(0, 0), 1);
                 // template setup
Modified: sandbox/august/trunk/examples/sundials-spherical-mercator.html
--- sandbox/august/trunk/examples/sundials-spherical-mercator.html	2010-12-01 22:47:34 UTC (rev 10940)
+++ sandbox/august/trunk/examples/sundials-spherical-mercator.html	2010-12-03 06:40:11 UTC (rev 10941)
@@ -31,15 +31,7 @@
                                                  20037508.34, 20037508.34)
             map = new OpenLayers.Map('map', options);
-            var mapnik = new OpenLayers.Layer.TMS(
-                "OpenStreetMap (Mapnik)",
-                "http://tile.openstreetmap.org/",
-                    type: 'png', getURL: osm_getTileURL,
-                    displayOutsideMaxExtent: true,
-                    attribution: '<a href="http://www.openstreetmap.org/">OpenStreetMap</a>'
+            var mapnik = new OpenLayers.Layer.OSM("OpenStreetMap (Mapnik)");
             var gmap = new OpenLayers.Layer.Google("Google", {sphericalMercator:true});
             var sundials = new OpenLayers.Layer.Vector("KML", {
                 projection: map.displayProjection,
@@ -96,20 +88,6 @@
                 delete feature.popup;
-        function osm_getTileURL(bounds) {
-            var res = this.map.getResolution();
-            var x = Math.round((bounds.left - this.maxExtent.left) / (res * this.tileSize.w));
-            var y = Math.round((this.maxExtent.top - bounds.top) / (res * this.tileSize.h));
-            var z = this.map.getZoom();
-            var limit = Math.pow(2, z);
-            if (y < 0 || y >= limit) {
-                return OpenLayers.Util.getImagesLocation() + "404.png";
-            } else {
-                x = ((x % limit) + limit) % limit;
-                return this.url + z + "/" + x + "/" + y + "." + this.type;
     </script>
   </head>
Modified: sandbox/august/trunk/examples/vector-features.html
--- sandbox/august/trunk/examples/vector-features.html	2010-12-01 22:47:34 UTC (rev 10940)
+++ sandbox/august/trunk/examples/vector-features.html	2010-12-03 06:40:11 UTC (rev 10941)
@@ -1,3 +1,4 @@
+<!DOCTYPE html>
   <head>
     <title>OpenLayers: Vector Features</title>
Modified: sandbox/august/trunk/lib/OpenLayers/BaseTypes/Class.js
--- sandbox/august/trunk/lib/OpenLayers/BaseTypes/Class.js	2010-12-01 22:47:34 UTC (rev 10940)
+++ sandbox/august/trunk/lib/OpenLayers/BaseTypes/Class.js	2010-12-03 06:40:11 UTC (rev 10941)
@@ -23,49 +23,22 @@
 OpenLayers.Class = function() {
-    var Class = function() {
-         * This following condition can be removed at 3.0 - this is only for
-         * backwards compatibility while the Class.inherit method is still
-         * in use.  So at 3.0, the following three lines would be replaced with
-         * simply:
-         * this.initialize.apply(this, arguments);
-        if (arguments && arguments[0] != OpenLayers.Class.isPrototype) {
-            this.initialize.apply(this, arguments);
-    var extended = {};
-    var parent, initialize, Type;
-    for(var i=0, len=arguments.length; i<len; ++i) {
-        Type = arguments[i];
-        if(typeof Type == "function") {
-            // make the class passed as the first argument the superclass
-            if(i == 0 && len > 1) {
-                initialize = Type.prototype.initialize;
-                // replace the initialize method with an empty function,
-                // because we do not want to create a real instance here
-                Type.prototype.initialize = function() {};
-                // the line below makes sure that the new class has a
-                // superclass
-                extended = new Type();
-                // restore the original initialize method
-                if(initialize === undefined) {
-                    delete Type.prototype.initialize;
-                } else {
-                    Type.prototype.initialize = initialize;
-            // get the prototype of the superclass
-            parent = Type.prototype;
-        } else {
-            // in this case we're extending with the prototype
-            parent = Type;
-        OpenLayers.Util.extend(extended, parent);
+    var len = arguments.length;
+    var P = arguments[0];
+    var F = arguments[len-1];
+    var C = typeof F.initialize == "function" ?
+        F.initialize :
+        function(){ P.apply(this, arguments); };
+    if (len > 1) {
+        var newArgs = [C, P].concat(
+                Array.prototype.slice.call(arguments).slice(1, len-1), F);
+        OpenLayers.inherit.apply(null, newArgs);
+    } else {
+        C.prototype = F;
-    Class.prototype = extended;
-    return Class;
+    return C;
@@ -90,7 +63,6 @@
  * APIFunction: inherit
  * *Deprecated*.  Old method to inherit from one or more OpenLayers style
@@ -102,15 +74,35 @@
  * Returns:
  * An object prototype
-OpenLayers.Class.inherit = function () {
-    var superClass = arguments[0];
-    var proto = new superClass(OpenLayers.Class.isPrototype);
-    for (var i=1, len=arguments.length; i<len; i++) {
-        if (typeof arguments[i] == "function") {
-            var mixin = arguments[i];
-            arguments[i] = new mixin(OpenLayers.Class.isPrototype);
-        OpenLayers.Util.extend(proto, arguments[i]);
-    return proto;
+OpenLayers.Class.inherit = function (P) {
+    var C = function() {
+       P.call(this);
+    var newArgs = [C].concat(Array.prototype.slice.call(arguments));
+    return C.prototype;
+ * Function: OpenLayers.inherit
+ * Parameters:
+ * C - {Object} the class that inherits
+ * P - {Object} the superclass to inherit from
+ * In addition to the mandatory C and P parameters, an arbitrary number of
+ * objects can be passed, which will extend C.
+OpenLayers.inherit = function(C, P) {
+   var F = function() {};
+   F.prototype = P.prototype;
+   C.prototype = new F;
+   var i, l, o;
+   for(i=2, l=arguments.length; i<l; i++) {
+       o = arguments[i];
+       if(typeof o === "function") {
+           o = o.prototype;
+       OpenLayers.Util.extend(C.prototype, o);
Modified: sandbox/august/trunk/lib/OpenLayers/BaseTypes.js
--- sandbox/august/trunk/lib/OpenLayers/BaseTypes.js	2010-12-01 22:47:34 UTC (rev 10940)
+++ sandbox/august/trunk/lib/OpenLayers/BaseTypes.js	2010-12-03 06:40:11 UTC (rev 10941)
@@ -593,7 +593,7 @@
         if ("toISOString" in Date.prototype) {
             return function(date) {
                 return date.toISOString();
         } else {
             function pad(num, len) {
                 var str = num + "";
@@ -619,7 +619,7 @@
                         pad(date.getUTCMilliseconds(), 3) + "Z";
                 return str;
@@ -649,7 +649,6 @@
             date = new Date(elapsed);
         } else {
             var match = str.match(/^(?:(\d{4})(?:-(\d{2})(?:-(\d{2}))?)?)?(?:T(\d{1,2}):(\d{2}):(\d{2}(?:\.\d+)?)(Z|(?:[+-]\d{1,2}(?::(\d{2}))?)))?$/);
-            var date;
             if (match && (match[1] || match[7])) { // must have at least year or time
                 var year = parseInt(match[1], 10) || 0;
                 var month = (parseInt(match[2], 10) - 1) || 0;
@@ -679,4 +678,4 @@
         return date;
Modified: sandbox/august/trunk/lib/OpenLayers/Control/GetFeature.js
--- sandbox/august/trunk/lib/OpenLayers/Control/GetFeature.js	2010-12-01 22:47:34 UTC (rev 10940)
+++ sandbox/august/trunk/lib/OpenLayers/Control/GetFeature.js	2010-12-03 06:40:11 UTC (rev 10941)
@@ -207,7 +207,8 @@
      * Parameters:
      * options - {Object} A configuration object which at least has to contain
-     *     a <protocol> property
+     *     a <protocol> property (if not, it has to be set before a request is
+     *     made)
     initialize: function(options) {
         // concatenate events specific to vector with those from the base
Modified: sandbox/august/trunk/lib/OpenLayers/Control/Measure.js
--- sandbox/august/trunk/lib/OpenLayers/Control/Measure.js	2010-12-01 22:47:34 UTC (rev 10940)
+++ sandbox/august/trunk/lib/OpenLayers/Control/Measure.js	2010-12-03 06:40:11 UTC (rev 10941)
@@ -33,7 +33,8 @@
      *      will receive an event with measure, units, order, and geometry
      *      properties.
      * measurepartial - Triggered when a new point is added to the
-     *      measurement sketch.  Listeners receive an event with measure,
+     *      measurement sketch or if the <immediate> property is true and the
+     *      measurement sketch is modified.  Listeners receive an event with measure,
      *      units, order, and geometry.
     EVENT_TYPES: ['measure', 'measurepartial'],
@@ -104,6 +105,14 @@
     persist: false,
+     * APIProperty: immediate
+     * {Boolean} Activates the immediate measurement so that the "measurepartial"
+     *     event is also fired once the measurement sketch is modified.
+     *     Default is false.
+    immediate : false,
      * Constructor: OpenLayers.Control.Measure
      * Parameters:
@@ -117,10 +126,12 @@
             OpenLayers.Control.prototype.EVENT_TYPES
         OpenLayers.Control.prototype.initialize.apply(this, [options]);
-        this.callbacks = OpenLayers.Util.extend(
-            {done: this.measureComplete, point: this.measurePartial},
-            this.callbacks
+        var callbacks = {done: this.measureComplete,
+            point: this.measurePartial};
+        if (this.immediate){
+            callbacks.modify = this.measureImmediate;
+        this.callbacks = OpenLayers.Util.extend(callbacks, this.callbacks);
         // let the handler options override, so old code that passes 'persist'
         // directly to the handler does not need an update
@@ -147,6 +158,20 @@
         this.cancelDelay();
         this.handler.cancel();
+     * APIMethod: setImmediate
+     * Sets the <immediate> property. Changes the activity of immediate
+     * measurement.
+    setImmediate: function(immediate) {
+        this.immediate = immediate;
+            this.callbacks.modify = this.measureImmediate;
+        } else {
+            delete this.callbacks.modify;
      * Method: updateHandler
@@ -206,6 +231,20 @@
+     * Method: measureImmediate
+     * Called each time the measurement sketch is modified.
+     * Parameters: point - {<OpenLayers.Geometry.Point>} The point at the
+     * mouseposition. feature - {<OpenLayers.Feature.Vector>} The sketch feature.
+    measureImmediate : function(point, feature) {
+        if (this.delayedTrigger === null &&
+                                !this.handler.freehandMode(this.handler.evt)) {
+            this.measure(feature.geometry, "measurepartial");
      * Method: cancelDelay
      * Cancels the delay measurement that measurePartial began.
Modified: sandbox/august/trunk/lib/OpenLayers/Control/ModifyFeature.js
--- sandbox/august/trunk/lib/OpenLayers/Control/ModifyFeature.js	2010-12-01 22:47:34 UTC (rev 10940)
+++ sandbox/august/trunk/lib/OpenLayers/Control/ModifyFeature.js	2010-12-03 06:40:11 UTC (rev 10941)
@@ -113,6 +113,15 @@
      * {Object} A symbolizer to be used for virtual vertices.
     virtualStyle: null,
+     * APIProperty: vertexRenderIntent
+     * {String} The renderIntent to use for vertices. If no <virtualStyle> is
+     * provided, this renderIntent will also be used for virtual vertices, with
+     * a fillOpacity and strokeOpacity of 0.3. Default is null, which means
+     * that the layer's default style will be used for vertices.
+    vertexRenderIntent: null,
      * APIProperty: mode
@@ -193,11 +202,14 @@
      *     control.
     initialize: function(layer, options) {
+        options = options || {};
         this.layer = layer;
         this.vertices = [];
         this.virtualVertices = [];
         this.virtualStyle = OpenLayers.Util.extend({},
-            this.layer.style || this.layer.styleMap.createSymbolizer());
+            this.layer.style ||
+            this.layer.styleMap.createSymbolizer(null, options.vertexRenderIntent)
         this.virtualStyle.fillOpacity = 0.3;
         this.virtualStyle.strokeOpacity = 0.3;
         this.deleteCodes = [46, 68];
@@ -622,6 +634,7 @@
             if(geometry.CLASS_NAME == "OpenLayers.Geometry.Point") {
                 vertex = new OpenLayers.Feature.Vector(geometry);
                 vertex._sketch = true;
+                vertex.renderIntent = control.vertexRenderIntent;
                 control.vertices.push(vertex);
             } else {
                 var numVert = geometry.components.length;
@@ -633,6 +646,7 @@
                     if(component.CLASS_NAME == "OpenLayers.Geometry.Point") {
                         vertex = new OpenLayers.Feature.Vector(component);
                     } else {
                         collectComponentVertices(component);
Modified: sandbox/august/trunk/lib/OpenLayers/Control/OverviewMap.js
--- sandbox/august/trunk/lib/OpenLayers/Control/OverviewMap.js	2010-12-01 22:47:34 UTC (rev 10940)
+++ sandbox/august/trunk/lib/OpenLayers/Control/OverviewMap.js	2010-12-03 06:40:11 UTC (rev 10941)
@@ -157,7 +157,7 @@
             this.handlers.drag.destroy();
-        this.mapDiv.removeChild(this.extentRectangle);
+        this.ovmap && this.ovmap.viewPortDiv.removeChild(this.extentRectangle);
         this.extentRectangle = null;
         if (this.rectEvents) {
@@ -229,7 +229,6 @@
         this.extentRectangle.style.position = 'absolute';
         this.extentRectangle.style.zIndex = 1000;  //HACK
         this.extentRectangle.className = this.displayClass+'ExtentRectangle';
-        this.mapDiv.appendChild(this.extentRectangle);
         this.element.appendChild(this.mapDiv);
@@ -490,6 +489,7 @@
                         {controls: [], maxResolution: 'auto',
                          fallThrough: false}, this.mapOptions);
         this.ovmap = new OpenLayers.Map(this.mapDiv, options);
+        this.ovmap.viewPortDiv.appendChild(this.extentRectangle);
         // prevent ovmap from being destroyed when the page unloads, because
         // the OverviewMap control has to do this (and does it).
Modified: sandbox/august/trunk/lib/OpenLayers/Control/PanZoomBar.js
--- sandbox/august/trunk/lib/OpenLayers/Control/PanZoomBar.js	2010-12-01 22:47:34 UTC (rev 10940)
+++ sandbox/august/trunk/lib/OpenLayers/Control/PanZoomBar.js	2010-12-03 06:40:11 UTC (rev 10941)
@@ -286,9 +286,7 @@
         if (!OpenLayers.Event.isLeftClick(evt)) {
             return;
-        var y = evt.xy.y;
-        var top = OpenLayers.Util.pagePosition(evt.object)[1];
-        var levels = (y - top)/this.zoomStopHeight;
+        var levels = evt.xy.y / this.zoomStopHeight;
         if(this.forceFixedZoomLevel || !this.map.fractionalZoom) {
             levels = Math.floor(levels);
Modified: sandbox/august/trunk/lib/OpenLayers/Control/Panel.js
--- sandbox/august/trunk/lib/OpenLayers/Control/Panel.js	2010-12-01 22:47:34 UTC (rev 10940)
+++ sandbox/august/trunk/lib/OpenLayers/Control/Panel.js	2010-12-03 06:40:11 UTC (rev 10941)
@@ -95,7 +95,6 @@
      * APIMethod: destroy
     destroy: function() {
-        this.deactivate();
         OpenLayers.Control.prototype.destroy.apply(this, arguments);
         for(var i = this.controls.length - 1 ; i >= 0; i--) {
             if(this.controls[i].events) {
Modified: sandbox/august/trunk/lib/OpenLayers/Control/SLDSelect.js
--- sandbox/august/trunk/lib/OpenLayers/Control/SLDSelect.js	2010-12-01 22:47:34 UTC (rev 10940)
+++ sandbox/august/trunk/lib/OpenLayers/Control/SLDSelect.js	2010-12-03 06:40:11 UTC (rev 10941)
@@ -5,7 +5,7 @@
  * @requires OpenLayers/Control.js
- * @requires OpenLayers/Layer/WMS/Post.js
+ * @requires OpenLayers/Layer/WMS.js
  * @requires OpenLayers/Handler/RegularPolygon.js
  * @requires OpenLayers/Handler/Polygon.js
  * @requires OpenLayers/Handler/Path.js
@@ -119,7 +119,7 @@
      * APIProperty: layerCache
      * {Object} Cache to use for storing references to the selection layers.
      *     Normally each source layer will have exactly 1 selection layer of
-     *     type OpenLayers.Layer.WMS.Post. If not provided, layers will
+     *     type OpenLayers.Layer.WMS. If not provided, layers will
      *     be cached on the prototype. Note that if <clearOnDeactivate> is
      *     true, the layer will no longer be cached after deactivating the
      *     control.
@@ -158,7 +158,8 @@
             click: this.select}, this.callbacks);
         this.handlerOptions = this.handlerOptions || {};
         this.layerOptions = OpenLayers.Util.applyDefaults(this.layerOptions, {
-            displayInLayerSwitcher: false
+            displayInLayerSwitcher: false,
+            tileOptions: {maxGetUrlLength: 2048}
         if (this.sketchStyle) {
             this.handlerOptions.layerOptions = OpenLayers.Util.applyDefaults(
@@ -207,14 +208,14 @@
      *     is performed.
      * Returns:
-     * {<OpenLayers.Layer.WMS.Post>} A WMS Post layer since SLD selections can
-     *     easily get quite long.
+     * {<OpenLayers.Layer.WMS>} A WMS layer with maxGetUrlLength configured to 2048
+     *     since SLD selections can easily get quite long.
     createSelectionLayer: function(source) {
         // check if we already have a selection layer for the source layer
         var selectionLayer;
         if (!this.layerCache[source.id]) {
-            selectionLayer = new OpenLayers.Layer.WMS.Post(source.name,
+            selectionLayer = new OpenLayers.Layer.WMS(source.name,
                 source.url, source.params,
                     this.layerOptions,
@@ -567,4 +568,4 @@
     CLASS_NAME: "OpenLayers.Control.SLDSelect"
\ No newline at end of file
Modified: sandbox/august/trunk/lib/OpenLayers/Control/WMTSGetFeatureInfo.js
--- sandbox/august/trunk/lib/OpenLayers/Control/WMTSGetFeatureInfo.js	2010-12-01 22:47:34 UTC (rev 10940)
+++ sandbox/august/trunk/lib/OpenLayers/Control/WMTSGetFeatureInfo.js	2010-12-03 06:40:11 UTC (rev 10941)
@@ -213,35 +213,6 @@
-     * Method: activate
-     * Activates the control.
-     * Returns:
-     * {Boolean} The control was effectively activated.
-    activate: function () {
-        if (!this.active) {
-            this.handler.activate();
-        return OpenLayers.Control.prototype.activate.apply(
-            this, arguments
-     * Method: deactivate
-     * Deactivates the control.
-     * Returns:
-     * {Boolean} The control was effectively deactivated.
-    deactivate: function () {
-        return OpenLayers.Control.prototype.deactivate.apply(
-            this, arguments
      * Method: getInfoForClick
      * Called on click
@@ -425,18 +396,6 @@
-     * Method: setMap
-     * Set the map property for the control.
-     * Parameters:
-     * map - {<OpenLayers.Map>}
-    setMap: function(map) {
-        this.handler.setMap(map);
-        OpenLayers.Control.prototype.setMap.apply(this, arguments);
     CLASS_NAME: "OpenLayers.Control.WMTSGetFeatureInfo"
Modified: sandbox/august/trunk/lib/OpenLayers/Events.js
--- sandbox/august/trunk/lib/OpenLayers/Events.js	2010-12-01 22:47:34 UTC (rev 10940)
+++ sandbox/august/trunk/lib/OpenLayers/Events.js	2010-12-03 06:40:11 UTC (rev 10941)
@@ -449,8 +449,8 @@
      * Construct an OpenLayers.Events object.
      * Parameters:
-     * object - {Object} The js object to which this Events object  is being
-     * added element - {DOMElement} A dom element to respond to browser events
+     * object - {Object} The js object to which this Events object  is being added
+     * element - {DOMElement} A dom element to respond to browser events
      * eventTypes - {Array(String)} Array of custom application events
      * fallThrough - {Boolean} Allow events to fall through after these have
      *                         been handled?
@@ -786,10 +786,15 @@
      * evt - {Event}
     handleBrowserEvent: function (evt) {
+        var type = evt.type, listeners = this.listeners[type];
+        if(!listeners || listeners.length == 0) {
+            // noone's listening, bail out
+            return;
         if (this.includeXY) {
             evt.xy = this.getMousePosition(evt);
-        this.triggerEvent(evt.type, evt);
+        this.triggerEvent(type, evt);
@@ -823,11 +828,10 @@
         if (!this.element.scrolls) {
+            var viewportElement = OpenLayers.Util.getViewportElement();
             this.element.scrolls = [
-                (document.documentElement.scrollLeft
-                         || document.body.scrollLeft),
-                (document.documentElement.scrollTop
-                         || document.body.scrollTop)
+                viewportElement.scrollLeft,
+                viewportElement.scrollTop
@@ -840,8 +844,6 @@
         if (!this.element.offsets) {
             this.element.offsets = OpenLayers.Util.pagePosition(this.element);
-            this.element.offsets[0] += this.element.scrolls[0];
-            this.element.offsets[1] += this.element.scrolls[1];
         return new OpenLayers.Pixel(
             (evt.clientX + this.element.scrolls[0]) - this.element.offsets[0]
Modified: sandbox/august/trunk/lib/OpenLayers/Format/OWSCommon/v1.js
--- sandbox/august/trunk/lib/OpenLayers/Format/OWSCommon/v1.js	2010-12-01 22:47:34 UTC (rev 10940)
+++ sandbox/august/trunk/lib/OpenLayers/Format/OWSCommon/v1.js	2010-12-03 06:40:11 UTC (rev 10941)
@@ -247,6 +247,28 @@
                 var node = this.createElementNSPlus("ows:OutputFormat", {
                     value: format });
                 return node;
+            "Identifier": function(identifier) {
+                var node = this.createElementNSPlus("ows:Identifier",
+                		attributes: {
+                			// TODO: attribute codeSpace
+                		value: identifier
+                return node;
+            "Version": function(version) {
+            	var node = this.createElementNSPlus("ows:Version",
+                		attributes: {
+                		value: version
+                return node;
Modified: sandbox/august/trunk/lib/OpenLayers/Format/SLD/v1.js
--- sandbox/august/trunk/lib/OpenLayers/Format/SLD/v1.js	2010-12-01 22:47:34 UTC (rev 10940)
+++ sandbox/august/trunk/lib/OpenLayers/Format/SLD/v1.js	2010-12-03 06:40:11 UTC (rev 10941)
@@ -155,7 +155,7 @@
             "NamedStyle": function(node, layer) {
                 layer.namedStyles.push(
-                    this.getChildName(node.firstChild)
+                    this.getChildValue(node.firstChild)
             "UserStyle": function(node, layer) {
Modified: sandbox/august/trunk/lib/OpenLayers/Format/SOSGetObservation.js
--- sandbox/august/trunk/lib/OpenLayers/Format/SOSGetObservation.js	2010-12-01 22:47:34 UTC (rev 10940)
+++ sandbox/august/trunk/lib/OpenLayers/Format/SOSGetObservation.js	2010-12-03 06:40:11 UTC (rev 10941)
@@ -2,261 +2,304 @@
  * full list of contributors). Published under the Clear BSD license.
  * See http://svn.openlayers.org/trunk/openlayers/license.txt for the
  * full text of the license. */
- * @requires OpenLayers/Format/XML.js
- * @requires OpenLayers/Format/GML.js
- * @requires OpenLayers/Format/GML/v3.js
- * Class: OpenLayers.Format.SOSGetObservation
- * Read and write SOS GetObersation (to get the actual values from a sensor)
- *     version 1.0.0
- * Inherits from:
- *  - <OpenLayers.Format.XML>
-OpenLayers.Format.SOSGetObservation = OpenLayers.Class(OpenLayers.Format.XML, {
-     * Property: namespaces
-     * {Object} Mapping of namespace aliases to namespace URIs.
-    namespaces: {
-        ows: "http://www.opengis.net/ows",
-        gml: "http://www.opengis.net/gml",
-        sos: "http://www.opengis.net/sos/1.0",
-        ogc: "http://www.opengis.net/ogc",
-        om: "http://www.opengis.net/om/1.0",
-        xlink: "http://www.w3.org/1999/xlink",
-        xsi: "http://www.w3.org/2001/XMLSchema-instance"
-     * Property: regExes
-     * Compiled regular expressions for manipulating strings.
-    regExes: {
-        trimSpace: (/^\s*|\s*$/g),
-        removeSpace: (/\s*/g),
-        splitSpace: (/\s+/),
-        trimComma: (/\s*,\s*/g)
-     * Constant: VERSION
-     * {String} 1.0.0
-    VERSION: "1.0.0",
-     * Property: schemaLocation
-     * {String} Schema location
-    schemaLocation: "http://www.opengis.net/sos/1.0 http://schemas.opengis.net/sos/1.0.0/sosGetObservation.xsd",
-     * Property: defaultPrefix
-    defaultPrefix: "sos",
-     * Constructor: OpenLayers.Format.SOSGetObservation
-     * Parameters:
-     * options - {Object} An optional object whose properties will be set on
-     *     this instance.
-    initialize: function(options) {
-        OpenLayers.Format.XML.prototype.initialize.apply(this, [options]);
-     * Method: read
-     * Parameters:
-     * data - {String} or {DOMElement} data to read/parse.
-     * Returns:
-     * {Object} An object containing the measurements
-    read: function(data) {
-        if(typeof data == "string") {
-            data = OpenLayers.Format.XML.prototype.read.apply(this, [data]);
-        if(data && data.nodeType == 9) {
-            data = data.documentElement;
-        var info = {measurements: []};
-        this.readNode(data, info);
-        return info;
-     * Method: write
-     * Parameters:
-     * options - {Object} Optional object.
-     * Returns:
-     * {String} An SOS GetObservation request XML string.
-    write: function(options) {
-        var node = this.writeNode("sos:GetObservation", options);
+ * @requires OpenLayers/Format/XML.js
+ * @requires OpenLayers/Format/SOSGetFeatureOfInterest.js
+ * Class: OpenLayers.Format.SOSGetObservation
+ * Read and write SOS GetObersation (to get the actual values from a sensor)
+ *     version 1.0.0
+ * Inherits from:
+ *  - <OpenLayers.Format.XML>
+OpenLayers.Format.SOSGetObservation = OpenLayers.Class(OpenLayers.Format.XML, {
+     * Property: namespaces
+     * {Object} Mapping of namespace aliases to namespace URIs.
+    namespaces: {
+        ows: "http://www.opengis.net/ows",
+        gml: "http://www.opengis.net/gml",
+        sos: "http://www.opengis.net/sos/1.0",
+        ogc: "http://www.opengis.net/ogc",
+        om: "http://www.opengis.net/om/1.0",
+        sa: "http://www.opengis.net/sampling/1.0",
+        xlink: "http://www.w3.org/1999/xlink",
+        xsi: "http://www.w3.org/2001/XMLSchema-instance"
+     * Property: regExes
+     * Compiled regular expressions for manipulating strings.
+    regExes: {
+        trimSpace: (/^\s*|\s*$/g),
+        removeSpace: (/\s*/g),
+        splitSpace: (/\s+/),
+        trimComma: (/\s*,\s*/g)
+     * Constant: VERSION
+     * {String} 1.0.0
+    VERSION: "1.0.0",
+     * Property: schemaLocation
+     * {String} Schema location
+    schemaLocation: "http://www.opengis.net/sos/1.0 http://schemas.opengis.net/sos/1.0.0/sosGetObservation.xsd",
+     * Property: defaultPrefix
+    defaultPrefix: "sos",
+     * Constructor: OpenLayers.Format.SOSGetObservation
+     * Parameters:
+     * options - {Object} An optional object whose properties will be set on
+     *     this instance.
+    initialize: function(options) {
+        OpenLayers.Format.XML.prototype.initialize.apply(this, [options]);
+     * Method: read
+     * Parameters:
+     * data - {String} or {DOMElement} data to read/parse.
+     * Returns:
+     * {Object} An object containing the measurements
+    read: function(data) {
+        if(typeof data == "string") {
+            data = OpenLayers.Format.XML.prototype.read.apply(this, [data]);
+        if(data && data.nodeType == 9) {
+            data = data.documentElement;
+        var info = {measurements: [], observations: []};
+        this.readNode(data, info);
+        return info;
+     * Method: write
+     * Parameters:
+     * options - {Object} Optional object.
+     * Returns:
+     * {String} An SOS GetObservation request XML string.
+    write: function(options) {
+        var node = this.writeNode("sos:GetObservation", options);
         node.setAttribute("xmlns:om", this.namespaces.om);
-        this.setAttributeNS(
-            node, this.namespaces.xsi,
-            "xsi:schemaLocation", this.schemaLocation
-        return OpenLayers.Format.XML.prototype.write.apply(this, [node]);
-     * Property: readers
-     * Contains public functions, grouped by namespace prefix, that will
-     *     be applied when a namespaced node is found matching the function
-     *     name.  The function will be applied in the scope of this parser
-     *     with two arguments: the node being read and a context object passed
-     *     from the parent.
-    readers: {
-        "om": {
-            "ObservationCollection": function(node, obj) {
-                obj.id = this.getAttributeNS(node, this.namespaces.gml, "id");
-                this.readChildNodes(node, obj);
-            "member": function(node, observationCollection) {
-                this.readChildNodes(node, observationCollection);
-            "Measurement": function(node, observationCollection) {
-                var measurement = {};
-                observationCollection.measurements.push(measurement);
-                this.readChildNodes(node, measurement);
-            "samplingTime": function(node, measurement) {
-                var samplingTime = {};
-                measurement.samplingTime = samplingTime;
-                this.readChildNodes(node, samplingTime);
-            "observedProperty": function(node, measurement) {
-                measurement.observedProperty =
-                    this.getAttributeNS(node, this.namespaces.xlink, "href");
-            "procedure": function(node, measurement) {
-                measurement.procedure =
-            "result": function(node, measurement) {
-                var result = {};
-                measurement.result = result;
-                if (this.getChildValue(node) !== '') {
-                    result.value = this.getChildValue(node);
-                    result.uom = node.getAttribute("uom");
-                } else {
-                    this.readChildNodes(node, result);
-        "gml": OpenLayers.Util.applyDefaults({
-            "TimeInstant": function(node, samplingTime) {
-               var timeInstant = {};
-                samplingTime.timeInstant = timeInstant;
-                this.readChildNodes(node, timeInstant);
-            "timePosition": function(node, timeInstant) {
-                timeInstant.timePosition = this.getChildValue(node);
-        }, OpenLayers.Format.GML.v3.prototype.readers.gml)
-     * Property: writers
-     * As a compliment to the readers property, this structure contains public
-     *     writing functions grouped by namespace alias and named like the
-     *     node names they produce.
-    writers: {
-        "sos": {
-            "GetObservation": function(options) {
-                var node = this.createElementNSPlus("GetObservation", {
-                    attributes: {
-                        version: this.VERSION,
-                        service: 'SOS'
-                this.writeNode("offering", options, node);
-                this.writeNode("eventTime", options, node);
-                this.writeNode("procedure", options, node);
-                this.writeNode("observedProperty", options, node);
-                this.writeNode("responseFormat", options, node);
-                this.writeNode("resultModel", options, node);
-                this.writeNode("responseMode", options, node);
-                return node;
-            "responseFormat": function(options) {
-                return this.createElementNSPlus("responseFormat",
-                    {value: options.responseFormat});
-            "procedure": function(options) {
-                return this.createElementNSPlus("procedure",
-                    {value: options.procedure});
-            "offering": function(options) {
-                return this.createElementNSPlus("offering", {value:
-                    options.offering});
-            "observedProperty": function(options) {
-                return this.createElementNSPlus("observedProperty",
-                    {value: options.observedProperty});
-            "eventTime": function(options) {
-                var node = this.createElementNSPlus("eventTime");
-                if (options.eventTime === 'latest') {
-                    this.writeNode("ogc:TM_Equals", options, node);
-                return node;
-            "resultModel": function(options) {
-                return this.createElementNSPlus("resultModel", {value:
-                    options.resultModel});
-            "responseMode": function(options) {
-                return this.createElementNSPlus("responseMode", {value:
-                    options.responseMode});
-        "ogc": {
-            "TM_Equals": function(options) {
-                var node = this.createElementNSPlus("ogc:TM_Equals");
-                this.writeNode("ogc:PropertyName", {property:
-                    "urn:ogc:data:time:iso8601"}, node);
-                    this.writeNode("gml:TimeInstant", {value: 'latest'}, node);
-                return node;
-            "PropertyName": function(options) {
-                return this.createElementNSPlus("ogc:PropertyName",
-                    {value: options.property});
-        "gml": {
-            "TimeInstant": function(options) {
-                var node = this.createElementNSPlus("gml:TimeInstant");
-                this.writeNode("gml:timePosition", options, node);
-                return node;
-            "timePosition": function(options) {
-                var node = this.createElementNSPlus("gml:timePosition",
-                    {value: options.value});
-                return node;
-    CLASS_NAME: "OpenLayers.Format.SOSGetObservation"
+        node.setAttribute("xmlns:ogc", this.namespaces.ogc);
+        this.setAttributeNS(
+            node, this.namespaces.xsi,
+            "xsi:schemaLocation", this.schemaLocation
+        return OpenLayers.Format.XML.prototype.write.apply(this, [node]);
+     * Property: readers
+     * Contains public functions, grouped by namespace prefix, that will
+     *     be applied when a namespaced node is found matching the function
+     *     name.  The function will be applied in the scope of this parser
+     *     with two arguments: the node being read and a context object passed
+     *     from the parent.
+    readers: {
+        "om": {
+            "ObservationCollection": function(node, obj) {
+                obj.id = this.getAttributeNS(node, this.namespaces.gml, "id");
+                this.readChildNodes(node, obj);
+            "member": function(node, observationCollection) {
+                this.readChildNodes(node, observationCollection);
+            "Measurement": function(node, observationCollection) {
+                var measurement = {};
+                observationCollection.measurements.push(measurement);
+                this.readChildNodes(node, measurement);
+            "Observation": function(node, observationCollection) {
+                var observation = {};
+                observationCollection.observations.push(observation);
+                this.readChildNodes(node, observation);
+            "samplingTime": function(node, measurement) {
+                var samplingTime = {};
+                measurement.samplingTime = samplingTime;
+                this.readChildNodes(node, samplingTime);
+            "observedProperty": function(node, measurement) {
+                measurement.observedProperty =
+                    this.getAttributeNS(node, this.namespaces.xlink, "href");
+            "procedure": function(node, measurement) {
+                measurement.procedure =
+            "featureOfInterest": function(node, observation) {
+                var foi = {features: []};
+                observation.fois = [];
+                observation.fois.push(foi);
+                this.readChildNodes(node, foi);
+                // postprocessing to get actual features
+                var features = [];
+                for (var i=0, len=foi.features.length; i<len; i++) {
+                    var feature = foi.features[i];
+                    features.push(new OpenLayers.Feature.Vector(
+                        feature.components[0], feature.attributes));
+                foi.features = features;
+            "result": function(node, measurement) {
+                var result = {};
+                measurement.result = result;
+                if (this.getChildValue(node) !== '') {
+                    result.value = this.getChildValue(node);
+                    result.uom = node.getAttribute("uom");
+                } else {
+                    this.readChildNodes(node, result);
+        "sa": OpenLayers.Format.SOSGetFeatureOfInterest.prototype.readers.sa,
+        "gml": OpenLayers.Util.applyDefaults({
+            "TimeInstant": function(node, samplingTime) {
+               var timeInstant = {};
+                samplingTime.timeInstant = timeInstant;
+                this.readChildNodes(node, timeInstant);
+            "timePosition": function(node, timeInstant) {
+                timeInstant.timePosition = this.getChildValue(node);
+        }, OpenLayers.Format.SOSGetFeatureOfInterest.prototype.readers.gml)
+     * Property: writers
+     * As a compliment to the readers property, this structure contains public
+     *     writing functions grouped by namespace alias and named like the
+     *     node names they produce.
+    writers: {
+        "sos": {
+            "GetObservation": function(options) {
+                var node = this.createElementNSPlus("GetObservation", {
+                    attributes: {
+                        version: this.VERSION,
+                        service: 'SOS'
+                this.writeNode("offering", options, node);
+                if (options.eventTime) {
+                    this.writeNode("eventTime", options, node);
+                for (var procedure in options.procedures) {
+                    this.writeNode("procedure", options.procedures[procedure], node);
+                for (var observedProperty in options.observedProperties) {
+                    this.writeNode("observedProperty", options.observedProperties[observedProperty], node);
+                if (options.foi) {
+                    this.writeNode("featureOfInterest", options.foi, node);
+                this.writeNode("responseFormat", options, node);
+                if (options.resultModel) {
+                    this.writeNode("resultModel", options, node);
+                if (options.responseMode) {
+                    this.writeNode("responseMode", options, node);
+                return node;
+            "featureOfInterest": function(foi) {
+                var node = this.createElementNSPlus("featureOfInterest");
+                this.writeNode("ObjectID", foi.objectId, node);
+                return node;
+            "ObjectID": function(options) {
+                return this.createElementNSPlus("ObjectID",
+                    {value: options});
+            "responseFormat": function(options) {
+                return this.createElementNSPlus("responseFormat",
+                    {value: options.responseFormat});
+            "procedure": function(procedure) {
+                return this.createElementNSPlus("procedure",
+                    {value: procedure});
+            "offering": function(options) {
+                return this.createElementNSPlus("offering", {value:
+                    options.offering});
+            "observedProperty": function(observedProperty) {
+                return this.createElementNSPlus("observedProperty",
+                    {value: observedProperty});
+            "eventTime": function(options) {
+                var node = this.createElementNSPlus("eventTime");
+                if (options.eventTime === 'latest') {
+                    this.writeNode("ogc:TM_Equals", options, node);
+                return node;
+            "resultModel": function(options) {
+                return this.createElementNSPlus("resultModel", {value:
+                    options.resultModel});
+            "responseMode": function(options) {
+                return this.createElementNSPlus("responseMode", {value:
+                    options.responseMode});
+        "ogc": {
+            "TM_Equals": function(options) {
+                var node = this.createElementNSPlus("ogc:TM_Equals");
+                this.writeNode("ogc:PropertyName", {property:
+                    "urn:ogc:data:time:iso8601"}, node);
+                    this.writeNode("gml:TimeInstant", {value: 'latest'}, node);
+                return node;
+            "PropertyName": function(options) {
+                return this.createElementNSPlus("ogc:PropertyName",
+                    {value: options.property});
+        "gml": {
+            "TimeInstant": function(options) {
+                var node = this.createElementNSPlus("gml:TimeInstant");
+                this.writeNode("gml:timePosition", options, node);
+                return node;
+            "timePosition": function(options) {
+                var node = this.createElementNSPlus("gml:timePosition",
+                    {value: options.value});
+                return node;
+    CLASS_NAME: "OpenLayers.Format.SOSGetObservation"
Modified: sandbox/august/trunk/lib/OpenLayers/Handler/Box.js
--- sandbox/august/trunk/lib/OpenLayers/Handler/Box.js	2010-12-01 22:47:34 UTC (rev 10940)
+++ sandbox/august/trunk/lib/OpenLayers/Handler/Box.js	2010-12-03 06:40:11 UTC (rev 10941)
@@ -206,7 +206,7 @@
                 "border-top-width")) + parseInt(OpenLayers.Element.getStyle(
                 this.zoomBox, "border-bottom-width")) + 1;
             // all browsers use the new box model, except IE in quirks mode
-            var newBoxModel = OpenLayers.Util.getBrowserName() == "msie" ?
+            var newBoxModel = OpenLayers.BROWSER_NAME == "msie" ?
                 document.compatMode != "BackCompat" : true;
             this.boxCharacteristics = {
                 xOffset: xOffset,
Modified: sandbox/august/trunk/lib/OpenLayers/Handler/Drag.js
--- sandbox/august/trunk/lib/OpenLayers/Handler/Drag.js	2010-12-01 22:47:34 UTC (rev 10940)
+++ sandbox/august/trunk/lib/OpenLayers/Handler/Drag.js	2010-12-03 06:40:11 UTC (rev 10941)
@@ -397,7 +397,7 @@
      * evt - {Object}
     adjustXY: function(evt) {
-        var pos = OpenLayers.Util.pagePosition(this.map.div);
+        var pos = OpenLayers.Util.pagePosition(this.map.viewPortDiv);
         evt.xy.x -= pos[0];
         evt.xy.y -= pos[1];
Modified: sandbox/august/trunk/lib/OpenLayers/Handler/Path.js
--- sandbox/august/trunk/lib/OpenLayers/Handler/Path.js	2010-12-01 22:47:34 UTC (rev 10940)
+++ sandbox/august/trunk/lib/OpenLayers/Handler/Path.js	2010-12-03 06:40:11 UTC (rev 10941)
@@ -276,11 +276,21 @@
         return true;
+     * APIMethod: finishGeometry
+     * Finish the geometry and send it back to the control.
+    finishGeometry: function() {
+        var index = this.line.geometry.components.length - 1;
+        this.line.geometry.removeComponent(this.line.geometry.components[index]);
+        this.removePoint();
+        this.finalize();
      * Method: dblclick
-     * Handle double-clicks.  Finish the geometry and send it back
-     * to the control.
+     * Handle double-clicks.
      * Parameters:
      * evt - {Event} The browser event
@@ -290,10 +300,7 @@
     dblclick: function(evt) {
         if(!this.freehandMode(evt)) {
-            var index = this.line.geometry.components.length - 1;
-            this.line.geometry.removeComponent(this.line.geometry.components[index]);
-            this.removePoint();
-            this.finalize();
+            this.finishGeometry();
         return false;
Modified: sandbox/august/trunk/lib/OpenLayers/Handler/Polygon.js
--- sandbox/august/trunk/lib/OpenLayers/Handler/Polygon.js	2010-12-01 22:47:34 UTC (rev 10940)
+++ sandbox/august/trunk/lib/OpenLayers/Handler/Polygon.js	2010-12-03 06:40:11 UTC (rev 10941)
@@ -20,7 +20,21 @@
 OpenLayers.Handler.Polygon = OpenLayers.Class(OpenLayers.Handler.Path, {
+     * APIProperty: holeModifier
+     * {String} Key modifier to trigger hole digitizing.  Acceptable values are
+     *     "altKey", "shiftKey", or "ctrlKey".  If not set, no hole digitizing
+     *     will take place.  Default is null.
+    holeModifier: null,
+     * Property: drawingHole
+     * {Boolean} Currently drawing an interior ring.
+    drawingHole: false,
      * Parameter: polygon
      * {<OpenLayers.Feature.Vector>}
@@ -68,15 +82,152 @@
         this.line = new OpenLayers.Feature.Vector(
             new OpenLayers.Geometry.LinearRing([this.point.geometry])
-        this.polygon = new OpenLayers.Feature.Vector(
-            new OpenLayers.Geometry.Polygon([this.line.geometry])
+        // check for hole digitizing
+        var polygon;
+        if (this.holeModifier && (this.evt[this.holeModifier])) {
+            var geometry = this.point.geometry;
+            var features = this.control.layer.features;
+            var candidate;
+            // look for intersections, last drawn gets priority
+            for (var i=features.length-1; i>=0; --i) {
+                candidate = features[i].geometry;
+                if ((candidate instanceof OpenLayers.Geometry.Polygon ||
+                    candidate instanceof OpenLayers.Geometry.MultiPolygon) &&
+                    candidate.intersects(geometry)) {
+                    polygon = features[i];
+                    this.control.layer.removeFeatures([polygon], {silent: true});
+                    this.control.layer.events.registerPriority(
+                        "sketchcomplete", this, this.finalizeInteriorRing
+                        "sketchmodified", this, this.enforceTopology
+                    polygon.geometry.addComponent(this.line.geometry);
+                    this.polygon = polygon;
+                    this.drawingHole = true;
+                    break;
+        if (!polygon) {
+            this.polygon = new OpenLayers.Feature.Vector(
+                new OpenLayers.Geometry.Polygon([this.line.geometry])
         this.callback("create", [this.point.geometry, this.getSketch()]);
         this.point.geometry.clearBounds();
         this.layer.addFeatures([this.polygon, this.point], {silent: true});
+     * Method: enforceTopology
+     * Simple topology enforcement for drawing interior rings.  Ensures vertices
+     *     of interior rings are contained by exterior ring.  Other topology
+     *     rules are enforced in <finalizeInteriorRing> to allow drawing of
+     *     rings that intersect only during the sketch (e.g. a "C" shaped ring
+     *     that nearly encloses another ring).
+    enforceTopology: function(event) {
+        var point = event.vertex;
+        var components = this.line.geometry.components;
+        // ensure that vertices of interior ring are contained by exterior ring
+        if (!this.polygon.geometry.intersects(point)) {
+            var last = components[components.length-3];
+            point.x = last.x;
+            point.y = last.y;
+     * Method: finalizeInteriorRing
+     * Enforces that new ring has some area and doesn't contain vertices of any
+     *     other rings.
+    finalizeInteriorRing: function() {
+        var ring = this.line.geometry;
+        // ensure that ring has some area
+        var modified = (ring.getArea() !== 0);
+        if (modified) {
+            // ensure that new ring doesn't intersect any other rings
+            var rings = this.polygon.geometry.components;
+            for (var i=rings.length-2; i>=0; --i) {
+                if (ring.intersects(rings[i])) {
+                    modified = false;
+                    break;
+            if (modified) {
+                // ensure that new ring doesn't contain any other rings
+                var target;
+                outer: for (var i=rings.length-2; i>0; --i) {
+                    points = rings[i].components;
+                    for (var j=0, jj=points.length; j<jj; ++j) {
+                        if (ring.containsPoint(points[j])) {
+                            modified = false;
+                            break outer;
+        if (modified) {
+            if (this.polygon.state !== OpenLayers.State.INSERT) {
+                this.polygon.state = OpenLayers.State.UPDATE;
+        } else {
+            this.polygon.geometry.removeComponent(ring);
+        this.restoreFeature();
+        return false;
+     * APIMethod: cancel
+     * Finish the geometry and call the "cancel" callback.
+    cancel: function() {
+        if (this.drawingHole) {
+            this.polygon.geometry.removeComponent(this.line.geometry);
+            this.restoreFeature(true);
+        return OpenLayers.Handler.Path.prototype.cancel.apply(this, arguments);
+     * Method: restoreFeature
+     * Move the feature from the sketch layer to the target layer.
+     * Properties:
+     * cancel - {Boolean} Cancel drawing.  If falsey, the "sketchcomplete" event
+     *     will be fired.
+    restoreFeature: function(cancel) {
+        this.control.layer.events.unregister(
+        this.layer.removeFeatures([this.polygon], {silent: true});
+        this.control.layer.addFeatures([this.polygon], {silent: true});
+        this.drawingHole = false;
+        if (!cancel) {
+            // Re-trigger "sketchcomplete" so other listeners can do their
+            // business.  While this is somewhat sloppy (if a listener is
+            // registered with registerPriority - not common - between the start
+            // and end of a single ring drawing - very uncommon - it will be
+            // called twice).
+            // TODO: In 3.0, collapse sketch handlers into geometry specific
+            // drawing controls.
+            this.control.layer.events.triggerEvent(
+                "sketchcomplete", {feature : this.polygon}
      * Method: destroyFeature
      * Destroy temporary geometries
Modified: sandbox/august/trunk/lib/OpenLayers/Lang.js
--- sandbox/august/trunk/lib/OpenLayers/Lang.js	2010-12-01 22:47:34 UTC (rev 10940)
+++ sandbox/august/trunk/lib/OpenLayers/Lang.js	2010-12-03 06:40:11 UTC (rev 10941)
@@ -58,7 +58,7 @@
     setCode: function(code) {
         var lang;
         if(!code) {
-            code = (OpenLayers.Util.getBrowserName() == "msie") ?
+            code = (OpenLayers.BROWSER_NAME == "msie") ?
                 navigator.userLanguage : navigator.language;
         var parts = code.split('-');
Modified: sandbox/august/trunk/lib/OpenLayers/Layer/AgsTiled.js
--- sandbox/august/trunk/lib/OpenLayers/Layer/AgsTiled.js	2010-12-01 22:47:34 UTC (rev 10940)
+++ sandbox/august/trunk/lib/OpenLayers/Layer/AgsTiled.js	2010-12-03 06:40:11 UTC (rev 10941)
@@ -106,7 +106,7 @@
     getURL: function (bounds) {
         bounds = this.adjustBounds(bounds);
+        //OpenLayers.Console.debug(bounds.toString());
         var path = null;
@@ -161,6 +161,7 @@
      * {<OpenLayers.Tile.Image>} The added OpenLayers.Tile.Image
     addTile:function(bounds,position) {
+    	//OpenLayers.Console.debug(position.toString());
         return new OpenLayers.Tile.Image(this, position, bounds,
                                          null, this.tileSize);
Modified: sandbox/august/trunk/lib/OpenLayers/Layer/EventPane.js
--- sandbox/august/trunk/lib/OpenLayers/Layer/EventPane.js	2010-12-01 22:47:34 UTC (rev 10940)
+++ sandbox/august/trunk/lib/OpenLayers/Layer/EventPane.js	2010-12-03 06:40:11 UTC (rev 10941)
@@ -102,7 +102,7 @@
         this.pane.style.display = this.div.style.display;
         this.pane.style.width="100%";
         this.pane.style.height="100%";
-        if (OpenLayers.Util.getBrowserName() == "msie") {
+        if (OpenLayers.BROWSER_NAME == "msie") {
             this.pane.style.background =
                 "url(" + OpenLayers.Util.getImagesLocation() + "blank.gif)";
Modified: sandbox/august/trunk/lib/OpenLayers/Layer/Google/v3.js
--- sandbox/august/trunk/lib/OpenLayers/Layer/Google/v3.js	2010-12-01 22:47:34 UTC (rev 10940)
+++ sandbox/august/trunk/lib/OpenLayers/Layer/Google/v3.js	2010-12-03 06:40:11 UTC (rev 10941)
@@ -90,7 +90,8 @@
                 keyboardShortcuts: false,
                 draggable: false,
                 disableDoubleClickZoom: true,
-                scrollwheel: false
+                scrollwheel: false,
+                streetViewControl: false
             // cache elements for use by any other google layers added to
Modified: sandbox/august/trunk/lib/OpenLayers/Layer/SphericalMercator.js
--- sandbox/august/trunk/lib/OpenLayers/Layer/SphericalMercator.js	2010-12-01 22:47:34 UTC (rev 10940)
+++ sandbox/august/trunk/lib/OpenLayers/Layer/SphericalMercator.js	2010-12-03 06:40:11 UTC (rev 10941)
@@ -186,11 +186,32 @@
- * Note: Two transforms declared
- * Transforms from EPSG:4326 to EPSG:900913 and from EPSG:900913 to EPSG:4326
- *     are set by this class.
+ * Note: Transforms for web mercator <-> EPSG:4326
+ * OpenLayers recognizes EPSG:3857, EPSG:900913, EPSG:102113 and EPSG:102100.
+ * OpenLayers originally started referring to EPSG:900913 as web mercator.
+ * The EPSG has declared EPSG:3857 to be web mercator.
+ * ArcGIS 10 recognizes the EPSG:3857, EPSG:102113, and EPSG:102100 as
+ * equivalent.  See http://blogs.esri.com/Dev/blogs/arcgisserver/archive/2009/11/20/ArcGIS-Online-moving-to-Google-_2F00_-Bing-tiling-scheme_3A00_-What-does-this-mean-for-you_3F00_.aspx#12084
-OpenLayers.Projection.addTransform("EPSG:4326", "EPSG:900913",
-    OpenLayers.Layer.SphericalMercator.projectForward);
-OpenLayers.Projection.addTransform("EPSG:900913", "EPSG:4326",
-    OpenLayers.Layer.SphericalMercator.projectInverse);
+(function() {
+    // list of equivalent codes for web mercator
+    var codes = ["EPSG:900913", "EPSG:3857", "EPSG:102113", "EPSG:102100"];
+    var add = OpenLayers.Projection.addTransform;
+    var merc = OpenLayers.Layer.SphericalMercator;
+    var same = OpenLayers.Projection.nullTransform;
+    var i, len, code, other, j;
+    for (i=0, len=codes.length; i<len; ++i) {
+        code = codes[i];
+        add("EPSG:4326", code, merc.projectForward);
+        add(code, "EPSG:4326", merc.projectInverse);
+        for (j=i+1; j<len; ++j) {
+            other = codes[j];
+            add(code, other, same);
+            add(other, code, same);
Modified: sandbox/august/trunk/lib/OpenLayers/Layer/TileCache.js
--- sandbox/august/trunk/lib/OpenLayers/Layer/TileCache.js	2010-12-01 22:47:34 UTC (rev 10940)
+++ sandbox/august/trunk/lib/OpenLayers/Layer/TileCache.js	2010-12-03 06:40:11 UTC (rev 10941)
@@ -6,6 +6,7 @@
  * @requires OpenLayers/Layer/Grid.js
+ * @requires OpenLayers/Tile/Image.js
Modified: sandbox/august/trunk/lib/OpenLayers/Layer/Vector.js
--- sandbox/august/trunk/lib/OpenLayers/Layer/Vector.js	2010-12-01 22:47:34 UTC (rev 10940)
+++ sandbox/august/trunk/lib/OpenLayers/Layer/Vector.js	2010-12-03 06:40:11 UTC (rev 10941)
@@ -64,6 +64,10 @@
      * featuresremoved - Triggered after features are removed. The event
      *      object passed to listeners will have a *features* property with a
      *      reference to an array of removed features.
+     * beforefeatureselected - Triggered after a feature is selected.  Listeners
+     *      will receive an object with a *feature* property referencing the
+     *      feature to be selected. To stop the feature from being selectd, a
+     *      listener should return false.
      * featureselected - Triggered after a feature is selected.  Listeners
      *      selected feature.
@@ -123,12 +127,6 @@
     isFixed: false,
-     * APIProperty: isVector
-     * {Boolean} Whether the layer is a vector layer.
-    isVector: true,
      * APIProperty: features
      * {Array(<OpenLayers.Feature.Vector>)}
@@ -482,7 +480,7 @@
             // Force a reflow on gecko based browsers to prevent jump/flicker.
             // This seems to happen on only certain configurations; it was originally
             // noticed in FF 2.0 and Linux.
-            if (navigator.userAgent.toLowerCase().indexOf("gecko") != -1) {
+            if (OpenLayers.IS_GECKO === true) {
                 this.div.scrollLeft = this.div.scrollLeft;
Modified: sandbox/august/trunk/lib/OpenLayers/Layer/WMS/Post.js
--- sandbox/august/trunk/lib/OpenLayers/Layer/WMS/Post.js	2010-12-01 22:47:34 UTC (rev 10940)
+++ sandbox/august/trunk/lib/OpenLayers/Layer/WMS/Post.js	2010-12-03 06:40:11 UTC (rev 10941)
@@ -33,7 +33,7 @@
      * effects of viewport-shaking when panning the map. Both browsers, Opera
      * and Firefox/Mozilla, have no problem with long urls, which is the reason
      * for using POST instead of GET. The strings to pass to this array are
-     * the ones returned by <OpenLayers.Util.getBrowserName()>.
+     * the ones returned by <OpenLayers.BROWSER_NAME>.
     unsupportedBrowsers: ["mozilla", "firefox", "opera"],
@@ -77,7 +77,7 @@
         OpenLayers.Layer.WMS.prototype.initialize.apply(this, newArguments);
         this.usePost = OpenLayers.Util.indexOf(
-            this.unsupportedBrowsers, OpenLayers.Util.getBrowserName()) == -1;
+            this.unsupportedBrowsers, OpenLayers.BROWSER_NAME) == -1;
Modified: sandbox/august/trunk/lib/OpenLayers/Layer/WMS.js
--- sandbox/august/trunk/lib/OpenLayers/Layer/WMS.js	2010-12-01 22:47:34 UTC (rev 10940)
+++ sandbox/august/trunk/lib/OpenLayers/Layer/WMS.js	2010-12-03 06:40:11 UTC (rev 10941)
@@ -188,7 +188,7 @@
         var imageSize = this.getImageSize();
         var newParams = {};
         // WMS 1.3 introduced axis order
@@ -214,6 +214,7 @@
                                          null, this.tileSize, this.tileOptions);
@@ -252,7 +253,10 @@
      * {String}
     getFullRequestString:function(newParams, altUrl) {
-        var projectionCode = this.map.getProjection();
+        var mapProjection = this.map.getProjectionObject();
+        var projectionCode = this.projection.equals(mapProjection) ?
+            this.projection.getCode() :
+            mapProjection.getCode();
         var value = (projectionCode == "none") ? null : projectionCode
 		if (parseFloat(this.params.VERSION) >= 1.3) {
 			this.params.CRS = this.params.CRS || value;
Modified: sandbox/august/trunk/lib/OpenLayers/Layer/XYZ.js
--- sandbox/august/trunk/lib/OpenLayers/Layer/XYZ.js	2010-12-01 22:47:34 UTC (rev 10940)
+++ sandbox/august/trunk/lib/OpenLayers/Layer/XYZ.js	2010-12-03 06:40:11 UTC (rev 10941)
@@ -40,11 +40,20 @@
      *     for a requested tile.  For example, if you supply a zoomOffset
      *     of 3, when the map is at the zoom 0, tiles will be requested from
      *     level 3 of your cache.  Default is 0 (assumes cache level and map
-     *     zoom are equivalent).
+     *     zoom are equivalent).  Using <zoomOffset> is an alternative to
+     *     setting <serverResolutions> if you only want to expose a subset
+     *     of the server resolutions.
     zoomOffset: 0,
+     * APIProperty: serverResolutions
+     * {Array} A list of all resolutions available on the server.  Only set this
+     *     property if the map resolutions differs from the server.
+    serverResolutions: null,
      * Constructor: OpenLayers.Layer.XYZ
      * Parameters:
@@ -114,7 +123,9 @@
-        var z = this.map.getZoom() + this.zoomOffset;
+        var z = this.serverResolutions != null ?
+            OpenLayers.Util.indexOf(this.serverResolutions, res) :
+            this.map.getZoom() + this.zoomOffset;
         var url = this.url;
         var s = '' + x + y + z;
Modified: sandbox/august/trunk/lib/OpenLayers/Layer.js
--- sandbox/august/trunk/lib/OpenLayers/Layer.js	2010-12-01 22:47:34 UTC (rev 10940)
+++ sandbox/august/trunk/lib/OpenLayers/Layer.js	2010-12-03 06:40:11 UTC (rev 10941)
@@ -704,7 +704,9 @@
      * APIMethod: display
-     * Hide or show the Layer
+     * Hide or show the Layer. This is designed to be used internally, and
+     *     is not generally the way to enable or disable the layer. For that,
+     *     use the setVisibility function instead..
      * Parameters:
      * display - {Boolean}
Modified: sandbox/august/trunk/lib/OpenLayers/Map.js
--- sandbox/august/trunk/lib/OpenLayers/Map.js	2010-12-01 22:47:34 UTC (rev 10940)
+++ sandbox/august/trunk/lib/OpenLayers/Map.js	2010-12-03 06:40:11 UTC (rev 10941)
@@ -513,7 +513,7 @@
         this.viewPortDiv.appendChild(this.layerContainerDiv);
         this.events = new OpenLayers.Events(this,
-                                            this.div,
+                                            this.viewPortDiv,
                                             this.EVENT_TYPES,
                                             this.fallThrough,
                                             {includeXY: true});
@@ -610,7 +610,6 @@
     render: function(div) {
         this.div = OpenLayers.Util.getElement(div);
         OpenLayers.Element.addClass(this.div, 'olMap');
-        this.events.attachToElement(this.div);
         this.viewPortDiv.parentNode.removeChild(this.viewPortDiv);
         this.div.appendChild(this.viewPortDiv);
         this.updateSize();
Modified: sandbox/august/trunk/lib/OpenLayers/Popup/Anchored.js
--- sandbox/august/trunk/lib/OpenLayers/Popup/Anchored.js	2010-12-01 22:47:34 UTC (rev 10940)
+++ sandbox/august/trunk/lib/OpenLayers/Popup/Anchored.js	2010-12-03 06:40:11 UTC (rev 10941)
@@ -186,10 +186,10 @@
         var size = this.size || this.contentSize;
         var top = (this.relativePosition.charAt(0) == 't');
-        newPx.y += (top) ? -(size.h + this.anchor.size.h) : this.anchor.size.h;
+        newPx.y += (top) ? -size.h : this.anchor.size.h;
         var left = (this.relativePosition.charAt(1) == 'l');
-        newPx.x += (left) ? -(size.w + this.anchor.size.w) : this.anchor.size.w;
+        newPx.x += (left) ? -size.w : this.anchor.size.w;
         return newPx;
Modified: sandbox/august/trunk/lib/OpenLayers/Popup.js
--- sandbox/august/trunk/lib/OpenLayers/Popup.js	2010-12-01 22:47:34 UTC (rev 10940)
+++ sandbox/august/trunk/lib/OpenLayers/Popup.js	2010-12-03 06:40:11 UTC (rev 10941)
@@ -337,7 +337,7 @@
         //listen to movestart, moveend to disable overflow (FF bug)
-        if (!this.disableFirefoxOverflowHack && OpenLayers.Util.getBrowserName() == 'firefox') {
+        if (!this.disableFirefoxOverflowHack && OpenLayers.BROWSER_NAME == 'firefox') {
             this.map.events.register("movestart", this, function() {
                 var style = document.defaultView.getComputedStyle(
                     this.contentDiv, null
@@ -478,7 +478,7 @@
         //now if our browser is IE, we need to actually make the contents
         // div itself bigger to take its own padding into effect. this makes
         // me want to shoot someone, but so it goes.
             this.contentSize.w +=
                 contentDivPadding.left + contentDivPadding.right;
             this.contentSize.h +=
Modified: sandbox/august/trunk/lib/OpenLayers/Projection.js
--- sandbox/august/trunk/lib/OpenLayers/Projection.js	2010-12-01 22:47:34 UTC (rev 10940)
+++ sandbox/august/trunk/lib/OpenLayers/Projection.js	2010-12-03 06:40:11 UTC (rev 10941)
@@ -26,6 +26,12 @@
      * {String}
     projCode: null,
+     * Property: titleRegEx
+     * {RegEx} regular expression to strip the title from a proj4js definition
+    titleRegEx: /\+title=[^\+]*/,
      * Constructor: OpenLayers.Projection
@@ -92,11 +98,20 @@
      * {Boolean} The two projections are equivalent.
     equals: function(projection) {
-        if (projection && projection.getCode) {
-            return this.getCode() == projection.getCode();
-        } else {
-            return false;
+        var p = projection, equals = false;
+        if (p) {
+            if (window.Proj4js && this.proj.defData && p.proj.defData) {
+                equals = this.proj.defData.replace(this.titleRegEx, "") ==
+                    p.proj.defData.replace(this.titleRegEx, "");
+            } else if (p.getCode) {
+                var source = this.getCode(), target = p.getCode();
+                equals = source == target ||
+                    !!OpenLayers.Projection.transforms[source] &&
+                    OpenLayers.Projection.transforms[source][target] ===
+                        OpenLayers.Projection.nullTransform;
+        return equals;
     /* Method: destroy
@@ -176,3 +191,23 @@
     return point;
+ * APIFunction: nullTransform
+ * A null transformation - useful for defining projection aliases when
+ * proj4js is not available:
+ * (code)
+ * OpenLayers.Projection.addTransform("EPSG:4326", "EPSG:3857",
+ *     OpenLayers.Layer.SphericalMercator.projectForward);
+ * OpenLayers.Projection.addTransform("EPSG:3857", "EPSG:3857",
+ *     OpenLayers.Layer.SphericalMercator.projectInverse);
+ * OpenLayers.Projection.addTransform("EPSG:3857", "EPSG:900913",
+ *     OpenLayers.Projection.nullTransform);
+ * OpenLayers.Projection.addTransform("EPSG:900913", "EPSG:3857",
+ * (end)
+OpenLayers.Projection.nullTransform = function(point) {
+    return point;
Modified: sandbox/august/trunk/lib/OpenLayers/Renderer/Canvas.js
--- sandbox/august/trunk/lib/OpenLayers/Renderer/Canvas.js	2010-12-01 22:47:34 UTC (rev 10940)
+++ sandbox/august/trunk/lib/OpenLayers/Renderer/Canvas.js	2010-12-03 06:40:11 UTC (rev 10941)
@@ -68,22 +68,6 @@
-     * Method: setExtent
-     * Set the visible part of the layer.
-     * Resolution has probably changed, so we nullify the resolution
-     * cache (this.resolution), then redraw.
-     * Parameters:
-     * extent - {<OpenLayers.Bounds>}
-    setExtent: function(extent) {
-        this.extent = extent.clone();
-        this.resolution = null;
-        this.redraw();
      * Method: setSize
      * Sets the size of the drawing surface.
Modified: sandbox/august/trunk/lib/OpenLayers/Renderer/Elements.js
--- sandbox/august/trunk/lib/OpenLayers/Renderer/Elements.js	2010-12-01 22:47:34 UTC (rev 10940)
+++ sandbox/august/trunk/lib/OpenLayers/Renderer/Elements.js	2010-12-03 06:40:11 UTC (rev 10941)
@@ -509,10 +509,13 @@
         rendered = false;
+        var removeBackground = false;
         if (style.display != "none") {
             if (style.backgroundGraphic) {
                 this.redrawBackgroundNode(geometry.id, geometry, style,
                     featureId);
+            } else {
+                removeBackground = true;
             rendered = this.redrawNode(geometry.id, geometry, style,
                 featureId);
@@ -521,12 +524,18 @@
             var node = document.getElementById(geometry.id);
             if (node) {
                 if (node._style.backgroundGraphic) {
-                    node.parentNode.removeChild(document.getElementById(
-                        geometry.id + this.BACKGROUND_ID_SUFFIX));
                 node.parentNode.removeChild(node);
+        if (removeBackground) {
+            var node = document.getElementById(
+                geometry.id + this.BACKGROUND_ID_SUFFIX);
+            if (node) {
+                node.parentNode.removeChild(node);
         return rendered;
Modified: sandbox/august/trunk/lib/OpenLayers/Renderer/SVG.js
--- sandbox/august/trunk/lib/OpenLayers/Renderer/SVG.js	2010-12-01 22:47:34 UTC (rev 10940)
+++ sandbox/august/trunk/lib/OpenLayers/Renderer/SVG.js	2010-12-03 06:40:11 UTC (rev 10941)
@@ -50,12 +50,6 @@
     symbolMetrics: null,
-     * Property: isGecko
-     * {Boolean}
-    isGecko: null,
      * Property: supportUse
      * {Boolean} true if defs/use is supported - known to not work as expected
      * at least in some applewebkit/5* builds.
@@ -77,7 +71,6 @@
        arguments);
         this.translationParameters = {x: 0, y: 0};
         this.supportUse = (navigator.userAgent.toLowerCase().indexOf("applewebkit/5") == -1);
-        this.isGecko = (navigator.userAgent.toLowerCase().indexOf("gecko/") != -1);
         this.symbolMetrics = {};
@@ -735,7 +728,7 @@
         label.setAttributeNS(null, "text-anchor",
             OpenLayers.Renderer.SVG.LABEL_ALIGN[align[0]] || "middle");
-        if (this.isGecko) {
             label.setAttributeNS(null, "dominant-baseline",
                 OpenLayers.Renderer.SVG.LABEL_ALIGN[align[1]] || "central");
         } else {
Modified: sandbox/august/trunk/lib/OpenLayers/Renderer/VML.js
--- sandbox/august/trunk/lib/OpenLayers/Renderer/VML.js	2010-12-01 22:47:34 UTC (rev 10940)
+++ sandbox/august/trunk/lib/OpenLayers/Renderer/VML.js	2010-12-03 06:40:11 UTC (rev 10941)
@@ -751,21 +751,43 @@
         var resolution = this.getResolution();
         var path = [];
-        var linearRing, i, j, len, ilen, comp, x, y;
-        for (j = 0, len=geometry.components.length; j<len; j++) {
-            linearRing = geometry.components[j];
+        var j, jj, points, area, first, second, i, ii, comp, pathComp, x, y;
+        for (j=0, jj=geometry.components.length; j<jj; j++) {
             path.push("m");
-            for (i=0, ilen=linearRing.components.length; i<ilen; i++) {
-                comp = linearRing.components[i];
+            points = geometry.components[j].components;
+            // we only close paths of interior rings with area
+            area = (j === 0);
+            first = null;
+            second = null;
+            for (i=0, ii=points.length; i<ii; i++) {
+                comp = points[i];
                 x = (comp.x / resolution - this.offset.x) | 0;
                 y = (comp.y / resolution - this.offset.y) | 0;
-                path.push(" " + x + "," + y);
+                pathComp = " " + x + "," + y;
+                path.push(pathComp)
                 if (i==0) {
                     path.push(" l");
+                if (!area) {
+                    // IE improperly renders sub-paths that have no area.
+                    // Instead of checking the area of every ring, we confirm
+                    // the ring has at least three distinct points.  This does
+                    // not catch all non-zero area cases, but it greatly improves
+                    // interior ring digitizing and is a minor performance hit
+                    // when rendering rings with many points.
+                    if (!first) {
+                        first = pathComp;
+                    } else if (first != pathComp) {
+                        if (!second) {
+                            second = pathComp;
+                        } else if (second != pathComp) {
+                            // stop looking
+                            area = true;
-            path.push(" x ");
+            path.push(area ? " x " : " ");
         path.push("e");
         node.path = path.join("");
Modified: sandbox/august/trunk/lib/OpenLayers/SingleFile.js
--- sandbox/august/trunk/lib/OpenLayers/SingleFile.js	2010-12-01 22:47:34 UTC (rev 10940)
+++ sandbox/august/trunk/lib/OpenLayers/SingleFile.js	2010-12-03 06:40:11 UTC (rev 10941)
@@ -4,7 +4,40 @@
 var OpenLayers = {
-    singleFile: true
+     * Constant: VERSION_NUMBER
+    VERSION_NUMBER: "$Revision$",
+     * Constant: singleFile
+     * TODO: remove this in 3.0 when we stop supporting build profiles that
+     * include OpenLayers.js
+    singleFile: true,
+     * Method: _getScriptLocation
+     * Return the path to this script. This is also implemented in
+     * OpenLayers.js
+     * Returns:
+     * {String} Path to this script
+    _getScriptLocation: (function() {
+        var r = new RegExp("(^|(.*?\\/))(OpenLayers\.js)(\\?|$)"),
+            s = document.getElementsByTagName('script'),
+            src, m, l = "";
+        for(var i=0, len=s.length; i<len; i++) {
+            src = s[i].getAttribute('src');
+            if(src) {
+                var m = src.match(r);
+                if(m) {
+                    l = m[1];
+                    break;
+        return (function() { return l; });
Property changes on: sandbox/august/trunk/lib/OpenLayers/SingleFile.js
___________________________________________________________________
Added: svn:keywords
   + Revision
Modified: sandbox/august/trunk/lib/OpenLayers/Strategy/Filter.js
--- sandbox/august/trunk/lib/OpenLayers/Strategy/Filter.js	2010-12-01 22:47:34 UTC (rev 10940)
+++ sandbox/august/trunk/lib/OpenLayers/Strategy/Filter.js	2010-12-03 06:40:11 UTC (rev 10941)
@@ -45,14 +45,10 @@
      * Parameters:
      * options - {Object} Optional object whose properties will be set on the
-     *     instance.  Strategy must be constructed with at least a <filter>
-     *     property.
+     *     instance.
         OpenLayers.Strategy.prototype.initialize.apply(this, [options]);
-        if (!this.filter || !(this.filter instanceof OpenLayers.Filter)) {
-            throw new Error("Filter strategy must be constructed with a filter");
@@ -102,7 +98,7 @@
      * Method: handleAdd
     handleAdd: function(event) {
-        if (!this.caching) {
+        if (!this.caching && this.filter) {
             var features = event.features;
             event.features = [];
             var feature;
Modified: sandbox/august/trunk/lib/OpenLayers/Tile/Image/IFrame.js
--- sandbox/august/trunk/lib/OpenLayers/Tile/Image/IFrame.js	2010-12-01 22:47:34 UTC (rev 10940)
+++ sandbox/august/trunk/lib/OpenLayers/Tile/Image/IFrame.js	2010-12-03 06:40:11 UTC (rev 10941)
@@ -84,7 +84,7 @@
             if (this.imgDiv == null) {
                 var eventPane = document.createElement("div");
-                if(OpenLayers.Util.getBrowserName() == "msie") {
+                if(OpenLayers.BROWSER_NAME == "msie") {
                     // IE cannot handle events on elements without backgroundcolor.
                     // So we use this little hack to make elements transparent
                     eventPane.style.backgroundColor = '#FFFFFF';
@@ -131,7 +131,7 @@
     createIFrame: function() {
         var id = this.id+'_iFrame';
         var iframe;
             // InternetExplorer does not set the name attribute of an iFrame
             // properly via DOM manipulation, so we need to do it on our own with
             // this hack.
Modified: sandbox/august/trunk/lib/OpenLayers/Tile/Image.js
--- sandbox/august/trunk/lib/OpenLayers/Tile/Image.js	2010-12-01 22:47:34 UTC (rev 10940)
+++ sandbox/august/trunk/lib/OpenLayers/Tile/Image.js	2010-12-03 06:40:11 UTC (rev 10941)
@@ -589,7 +589,7 @@
         // before continuing execution.
         if (OpenLayers.Util.indexOf(this.layer.SUPPORTED_TRANSITIONS,
                 this.layer.transitionEffect) != -1) {
                 this.frame.scrollLeft = this.frame.scrollLeft;
@@ -608,5 +608,5 @@
 OpenLayers.Tile.Image.useBlankTile = (
-    OpenLayers.Util.getBrowserName() == "safari" ||
-    OpenLayers.Util.getBrowserName() == "opera");
+    OpenLayers.BROWSER_NAME == "safari" ||
+    OpenLayers.BROWSER_NAME == "opera");
Modified: sandbox/august/trunk/lib/OpenLayers/Util.js
--- sandbox/august/trunk/lib/OpenLayers/Util.js	2010-12-01 22:47:34 UTC (rev 10940)
+++ sandbox/august/trunk/lib/OpenLayers/Util.js	2010-12-03 06:40:11 UTC (rev 10941)
@@ -1336,51 +1336,142 @@
  * Function: pagePositon
- * Calculates the position of an element on the page.
+ * Calculates the position of an element on the page (see
+ * http://code.google.com/p/doctype/wiki/ArticlePageOffset)
+ * OpenLayers.Util.pagePosition is based on Yahoo's getXY method, which is
+ * Copyright (c) 2006, Yahoo! Inc.
+ * All rights reserved.
+ * Redistribution and use of this software in source and binary forms, with or
+ * without modification, are permitted provided that the following conditions
+ * are met:
+ * * Redistributions of source code must retain the above copyright notice,
+ *   this list of conditions and the following disclaimer.
+ * * Redistributions in binary form must reproduce the above copyright notice,
+ *   this list of conditions and the following disclaimer in the documentation
+ *   and/or other materials provided with the distribution.
+ * * Neither the name of Yahoo! Inc. nor the names of its contributors may be
+ *   used to endorse or promote products derived from this software without
+ *   specific prior written permission of Yahoo! Inc.
+ * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
+ * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+ * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
+ * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
+ * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
+ * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
+ * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
+ * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
+ * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
+ * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
+ * POSSIBILITY OF SUCH DAMAGE.
  * Parameters:
  * forElement - {DOMElement}
  * Returns:
- * {Array} two item array, L value then T value.
+ * {Array} two item array, Left value then Top value.
-OpenLayers.Util.pagePosition = function(forElement) {
-    var valueT = 0, valueL = 0;
+OpenLayers.Util.pagePosition =  function(forElement) {
+    // NOTE: If element is hidden (display none or disconnected or any the
+    // ancestors are hidden) we get (0,0) by default but we still do the
+    // accumulation of scroll position.
-    var element = forElement;
-    var child = forElement;
-    while(element) {
+    var pos = [0, 0];
+    if (!forElement || forElement == window || forElement == viewportElement) {
+        // viewport is always at 0,0 as that defined the coordinate system for
+        // this function - this avoids special case checks in the code below
+        return pos;
-        if(element == document.body) {
-            if(OpenLayers.Element.getStyle(child, 'position') == 'absolute') {
-                break;
+    // Gecko browsers normally use getBoxObjectFor to calculate the position.
+    // When invoked for an element with an implicit absolute position though it
+    // can be off by one. Therefore the recursive implementation is used in
+    // those (relatively rare) cases.
+    var BUGGY_GECKO_BOX_OBJECT =
+        OpenLayers.IS_GECKO && document.getBoxObjectFor &&
+        OpenLayers.Element.getStyle(forElement, 'position') == 'absolute' &&
+        (forElement.style.top == '' || forElement.style.left == '');
+    var parent = null;
+    var box;
+    if (forElement.getBoundingClientRect) { // IE
+        box = forElement.getBoundingClientRect();
+        var scrollTop = viewportElement.scrollTop;
+        var scrollLeft = viewportElement.scrollLeft;
+        pos[0] = box.left + scrollLeft;
+        pos[1] = box.top + scrollTop;
+    } else if (document.getBoxObjectFor && !BUGGY_GECKO_BOX_OBJECT) { // gecko
+        // Gecko ignores the scroll values for ancestors, up to 1.9.  See:
+        // https://bugzilla.mozilla.org/show_bug.cgi?id=328881 and
+        // https://bugzilla.mozilla.org/show_bug.cgi?id=330619
+        box = document.getBoxObjectFor(forElement);
+        var vpBox = document.getBoxObjectFor(viewportElement);
+        pos[0] = box.screenX - vpBox.screenX;
+        pos[1] = box.screenY - vpBox.screenY;
+    } else { // safari/opera
+        pos[0] = forElement.offsetLeft;
+        pos[1] = forElement.offsetTop;
+        parent = forElement.offsetParent;
+        if (parent != forElement) {
+            while (parent) {
+                pos[0] += parent.offsetLeft;
+                pos[1] += parent.offsetTop;
+                parent = parent.offsetParent;
-        valueT += element.offsetTop  || 0;
-        valueL += element.offsetLeft || 0;
-        child = element;
-        try {
-            // wrapping this in a try/catch because IE chokes on the offsetParent
-            element = element.offsetParent;
-        } catch(e) {
-            OpenLayers.Console.error(OpenLayers.i18n(
-                                  "pagePositionFailed",{'elemId':element.id}));
-            break;
+        var browser = OpenLayers.BROWSER_NAME;
+        // opera & (safari absolute) incorrectly account for body offsetTop
+        if (browser == "opera" || (browser == "safari" &&
+              OpenLayers.Element.getStyle(forElement, 'position') == 'absolute')) {
+            pos[1] -= document.body.offsetTop;
-    element = forElement;
-    while(element) {
-        valueT -= element.scrollTop  || 0;
-        valueL -= element.scrollLeft || 0;
-        element = element.parentNode;
+        // accumulate the scroll positions for everything but the body element
+        while (parent && parent != document.body) {
+            pos[0] -= parent.scrollLeft;
+            // see https://bugs.opera.com/show_bug.cgi?id=249965
+            if (browser != "opera" || parent.tagName != 'TR') {
+                pos[1] -= parent.scrollTop;
-    return [valueL, valueT];
+    return pos;
+ * Function: getViewportElement
+ * Returns die viewport element of the document. The viewport element is
+ * usually document.documentElement, except in IE,where it is either
+ * document.body or document.documentElement, depending on the document's
+ * compatibility mode (see
+ * http://code.google.com/p/doctype/wiki/ArticleClientViewportElement)
+OpenLayers.Util.getViewportElement = function() {
+    var viewportElement = arguments.callee.viewportElement;
+    if (viewportElement == undefined) {
+        viewportElement = (OpenLayers.BROWSER_NAME == "msie" &&
+            document.compatMode != 'CSS1Compat') ? document.body :
+            document.documentElement;
+        arguments.callee.viewportElement = viewportElement;
+    return viewportElement;
  * Function: isEquivalentUrl
@@ -1540,8 +1631,46 @@
     return head;
+ * Constant: IS_GECKO
+ * {Boolean} True if the userAgent reports the browser to use the Gecko engine
+OpenLayers.IS_GECKO = (function() {
+    var ua = navigator.userAgent.toLowerCase();
+    return ua.indexOf("webkit") == -1 && ua.indexOf("gecko") != -1;
+ * Constant: BROWSER_NAME
+ * {String}
+ * A substring of the navigator.userAgent property.  Depending on the userAgent
+ *     property, this will be the empty string or one of the following:
+ *     * "opera" -- Opera
+ *     * "msie"  -- Internet Explorer
+ *     * "safari" -- Safari
+ *     * "firefox" -- FireFox
+ *     * "mozilla" -- Mozilla
+OpenLayers.BROWSER_NAME = (function() {
+    var name = "";
+    if (ua.indexOf("opera") != -1) {
+        name = "opera";
+    } else if (ua.indexOf("msie") != -1) {
+        name = "msie";
+    } else if (ua.indexOf("safari") != -1) {
+        name = "safari";
+    } else if (ua.indexOf("mozilla") != -1) {
+        if (ua.indexOf("firefox") != -1) {
+            name = "firefox";
+        } else {
+            name = "mozilla";
+    return name;
  * Function: getBrowserName
  * Returns:
@@ -1559,29 +1688,9 @@
  *           return an empty string.
 OpenLayers.Util.getBrowserName = function() {
-    var browserName = "";
-    var ua = navigator.userAgent.toLowerCase();
-    if ( ua.indexOf( "opera" ) != -1 ) {
-        browserName = "opera";
-    } else if ( ua.indexOf( "msie" ) != -1 ) {
-        browserName = "msie";
-    } else if ( ua.indexOf( "safari" ) != -1 ) {
-        browserName = "safari";
-    } else if ( ua.indexOf( "mozilla" ) != -1 ) {
-        if ( ua.indexOf( "firefox" ) != -1 ) {
-            browserName = "firefox";
-        } else {
-            browserName = "mozilla";
-    return browserName;
+    return OpenLayers.BROWSER_NAME;
  * Method: getRenderedDimensions
  * Renders the contentHTML offscreen to determine actual dimensions for
Modified: sandbox/august/trunk/lib/OpenLayers.js
--- sandbox/august/trunk/lib/OpenLayers.js	2010-12-01 22:47:34 UTC (rev 10940)
+++ sandbox/august/trunk/lib/OpenLayers.js	2010-12-03 06:40:11 UTC (rev 10941)
@@ -7,62 +7,58 @@
  * @requires OpenLayers/BaseTypes.js
  * @requires OpenLayers/Lang/en.js
  * @requires OpenLayers/Console.js
+ * TODO: In 3.0, we will stop supporting build profiles that include
+ * OpenLayers.js. This means we will not need the singleFile and scriptFile
+ * variables, because we don't have to handle the singleFile case any more.
 (function() {
      * Before creating the OpenLayers namespace, check to see if
      * OpenLayers.singleFile is true.  This occurs if the
      * OpenLayers/SingleFile.js script is included before this one - as is the
-     * case with single file builds.
+     * case with old single file build profiles that included both
+     * OpenLayers.js and OpenLayers/SingleFile.js.
     var singleFile = (typeof OpenLayers == "object" && OpenLayers.singleFile);
-     * Cache for the script location returned from
-     * OpenLayers._getScriptLocation
+     * Relative path of this script.
-    var scriptLocation;
+    var scriptName = (!singleFile) ? "lib/OpenLayers.js" : "OpenLayers.js";
      * Namespace: OpenLayers
      * The OpenLayers object provides a namespace for all things OpenLayers
     window.OpenLayers = {
-         * Property: _scriptName
-         * {String} Relative path of this script.
-        _scriptName: (!singleFile) ? "lib/OpenLayers.js" : "OpenLayers.js",
-         * Function: _getScriptLocation
-         * Return the path to this script.
+         * OpenLayers/SingleFile.js
          * Returns:
-        _getScriptLocation: function () {
-            if (scriptLocation != undefined) {
-                return scriptLocation;
-            scriptLocation = "";
-            var isOL = new RegExp("(^|(.*?\\/))(" + OpenLayers._scriptName + ")(\\?|$)");
-            var scripts = document.getElementsByTagName('script');
-            for (var i=0, len=scripts.length; i<len; i++) {
-                var src = scripts[i].getAttribute('src');
-                if (src) {
-                    var match = src.match(isOL);
-                    if(match) {
-                        scriptLocation = match[1];
+            var r = new RegExp("(^|(.*?\\/))(" + scriptName + ")(\\?|$)"),
+                src, m, l = "";
+                if(src) {
+                    if(m) {
+                        l = m[1];
                         break;
      * OpenLayers.singleFile is a flag indicating this file is being included
@@ -73,7 +69,7 @@
      * When we *are* part of a SFL build we do not dynamically include the
      * OpenLayers library code as it will be appended at the end of this file.
     if(!singleFile) {
         var jsfiles = new Array(
             "OpenLayers/Util.js",
@@ -316,16 +312,14 @@
             "OpenLayers/Format/WMSGetFeatureInfo.js",
             "OpenLayers/Format/SOSCapabilities.js",
             "OpenLayers/Format/SOSCapabilities/v1_0_0.js",
-            "OpenLayers/Format/SOSGetObservation.js",
             "OpenLayers/Format/SOSGetFeatureOfInterest.js",
+            "OpenLayers/Format/SOSGetObservation.js",
             "OpenLayers/Format/OWSContext.js",
             "OpenLayers/Format/OWSContext/v0_3_1.js",
             "OpenLayers/Format/WMTSCapabilities.js",
             "OpenLayers/Format/WMTSCapabilities/v1_0_0.js",
-            "OpenLayers/Format/WPSCapabilities.js",
-            "OpenLayers/Format/WPSCapabilities/v1_0_0.js",
-            "OpenLayers/Format/WPSDescribeProcess.js",
-            "OpenLayers/Format/WPSDescribeProcess/v1_0_0.js",
+            "OpenLayers/Format/WPSCommon.js",
+            "OpenLayers/Format/WPSCommon/v1_0_0.js",
             "OpenLayers/Layer/WFS.js",
             "OpenLayers/Control/GetFeature.js",
             "OpenLayers/Control/MouseToolbar.js",
@@ -342,6 +336,8 @@
             "OpenLayers/Symbolizer/Polygon.js",
             "OpenLayers/Symbolizer/Text.js",
             "OpenLayers/Symbolizer/Raster.js",
+            "OpenLayers/Process.js",
+            "OpenLayers/Process/WPS.js",
             "OpenLayers/Lang.js",
             "OpenLayers/Lang/en.js"
         ); // etc.
Modified: sandbox/august/trunk/readme.txt
--- sandbox/august/trunk/readme.txt	2010-12-01 22:47:34 UTC (rev 10940)
+++ sandbox/august/trunk/readme.txt	2010-12-03 06:40:11 UTC (rev 10941)
@@ -31,7 +31,7 @@
 As an example, using bash (with the release files in ~/openlayers ):
 $ cd /var/www/html
-$ cp ~/openlayers/build/OpenLayers.js ./
+$ cp ~/openlayers/OpenLayers.js ./
 $ cp -R ~/openlayers/theme ./
 $ cp -R ~/openlayers/img ./
Modified: sandbox/august/trunk/release-license.txt
--- sandbox/august/trunk/release-license.txt	2010-12-01 22:47:34 UTC (rev 10940)
+++ sandbox/august/trunk/release-license.txt	2010-12-03 06:40:11 UTC (rev 10941)
@@ -1,3 +1,3 @@
 This license information is now available at:
Modified: sandbox/august/trunk/tests/BaseTypes/Element.html
--- sandbox/august/trunk/tests/BaseTypes/Element.html	2010-12-01 22:47:34 UTC (rev 10940)
+++ sandbox/august/trunk/tests/BaseTypes/Element.html	2010-12-03 06:40:11 UTC (rev 10941)
@@ -212,7 +212,7 @@
         style = "chickenHead";
         t.ok(OpenLayers.Element.getStyle(elem, style) == null, "get style on 'auto' style returns null");
-        if (OpenLayers.Util.getBrowserName() == "opera") {
+        if (OpenLayers.BROWSER_NAME == "opera") {
             elem.style.top = "15px";
             style = "top";
Modified: sandbox/august/trunk/tests/Control/LayerSwitcher.html
--- sandbox/august/trunk/tests/Control/LayerSwitcher.html	2010-12-01 22:47:34 UTC (rev 10940)
+++ sandbox/august/trunk/tests/Control/LayerSwitcher.html	2010-12-03 06:40:11 UTC (rev 10941)
@@ -71,7 +71,7 @@
     function test_Control_LayerSwitcher_redraw (t) {
-        t.plan( (OpenLayers.Util.getBrowserName() == "opera" ? 9 : 19 ) );
+        t.plan( (OpenLayers.BROWSER_NAME == "opera" ? 9 : 19 ) );
         map = new OpenLayers.Map('map');
         var layer = new OpenLayers.Layer.WMS("WMS",
@@ -98,7 +98,7 @@
         t.eq(markersInput.value, markers.name, "wms correctly valued");
         t.eq(false, control.checkRedraw(), "check redraw is false");
-        if (OpenLayers.Util.getBrowserName() != "opera") {
+        if (OpenLayers.BROWSER_NAME != "opera") {
             control = new OpenLayers.Control.LayerSwitcher();
             var myredraw = control.redraw;
             control.redraw = function() {
Modified: sandbox/august/trunk/tests/Control/Measure.html
--- sandbox/august/trunk/tests/Control/Measure.html	2010-12-01 22:47:34 UTC (rev 10940)
+++ sandbox/august/trunk/tests/Control/Measure.html	2010-12-03 06:40:11 UTC (rev 10941)
@@ -222,6 +222,142 @@
+    function test_immediate(t) {
+        t.plan(29);
+        var map = new OpenLayers.Map({
+            div: "map",
+            units: "m",
+            resolutions: [1],
+            layers: [
+                new OpenLayers.Layer(null, {
+                    isBaseLayer: true
+            center: new OpenLayers.LonLat(0, 0)
+        var log = [];
+        var control = new OpenLayers.Control.Measure(
+            OpenLayers.Handler.Path, {
+                persist: true,
+                immediate: true,
+                eventListeners: {
+                    measurepartial: function(evt) {
+                        log.push(evt);
+                    measure: function(evt){
+                        log.push(evt);
+        map.addControl(control);
+        control.activate();
+        // convenience function to trigger mouse events
+        function trigger(type, x, y) {
+            map.events.triggerEvent(type, {
+                xy: new OpenLayers.Pixel(x, y)
+        // delay in seconds
+        var delay = control.partialDelay / 1000;
+        // a) establish first point
+        trigger("mousedown", 0, 0);
+        trigger("mouseup", 0, 0);
+        // move 10 pixels
+        trigger("mousemove", 0, 10);
+        t.eq(log.length, 0, "a) no event fired yet");
+        t.delay_call(
+            delay, function() {
+                // confirm measurepartial is fired
+                t.eq(log.length, 1, "a) event logged");
+                t.eq(log[0].type, "measurepartial", "a) correct type");
+                // mousemove within the partialDelay fires no event, so the
+                // measure below is the one of the initial point
+                t.eq(log[0].measure, 0, "a) correct measure");
+                // b) move 10 pixels
+                trigger("mousemove", 0, 20);
+                // c) move 10 pixels again
+                trigger("mousemove", 0, 30);
+                // confirm measurepartial is fired 2 times
+                t.eq(log.length, 3, "b) event logged");
+                t.eq(log[1].type, "measurepartial", "b) correct type");
+                t.eq(log[1].measure, 20, "b) correct measure");
+                t.eq(log[2].type, "measurepartial", "c) correct type");
+                t.eq(log[2].measure, 30, "c) correct measure");
+                // d) switch immediate measurement off
+                control.setImmediate(false);
+                t.eq(control.immediate, false, "d) immediate is false");
+                // e) move 10 pixels and click
+                trigger("mousemove", 0, 40);
+                trigger("mousedown", 0, 40);
+                trigger("mouseup", 0, 40);
+                // confirm measurepartial is not fired before delay
+                t.eq(log.length, 3, "e) no event fired yet")
+            // wait for delay then confirm event was logged
+                t.eq(log.length, 4, "e) event logged")
+                t.eq(log[3].type, "measurepartial", "e) correct type");
+                t.eq(log[3].measure, 40, "e) correct measure");
+                // f) switch immediate measurement on
+                control.setImmediate(true);
+                t.eq(control.immediate, true, "f) immediate is true");
+                // g) move 10 pixels
+                trigger("mousemove", 0, 50);
+                t.eq(log.length, 5, "g) event logged");
+                t.eq(log[4].type, "measurepartial", "g) correct type");
+                t.eq(log[4].measure, 50, "g) correct measure");
+                // h) move 10 pixels
+                trigger("mousemove", 0, 60);
+                t.eq(log.length, 6, "h) event logged");
+                t.eq(log[5].type, "measurepartial", "h) correct type");
+                t.eq(log[5].measure, 60, "h) correct measure");
+                // i) double click to finish
+                trigger("mousedown", 0, 60);
+                trigger("mouseup", 0, 60);
+                t.eq(log.length, 6, "i) no event fired yet");
+                t.eq(log.length, 7, "i) event logged");
+                t.eq(log[6].type, "measurepartial", "i) correct type");
+                t.eq(log[6].measure, 60, "i) correct measure");
+                trigger("dblclick", 0, 60);
+                t.eq(log.length, 8, "i) event logged");
+                t.eq(log[7].type, "measure", "i) correct type");
+                t.eq(log[7].measure, 60, "i) correct measure");
+                // clear log
+                log = [];
+                // j) clean up
+                map.destroy();
+                // wait for delay and confirm event not logged
+                t.eq(log.length, 0, "j) no event fired after destroy");
   </script>
 </head>
Modified: sandbox/august/trunk/tests/Control/ModifyFeature.html
--- sandbox/august/trunk/tests/Control/ModifyFeature.html	2010-12-01 22:47:34 UTC (rev 10940)
+++ sandbox/august/trunk/tests/Control/ModifyFeature.html	2010-12-03 06:40:11 UTC (rev 10941)
@@ -473,9 +473,13 @@
     function test_onModificationStart(t) {
-        t.plan(1);
+        t.plan(5);
         var map = new OpenLayers.Map("map");
-        var layer = new OpenLayers.Layer.Vector();
+        var layer = new OpenLayers.Layer.Vector(null, {
+            styleMap: new OpenLayers.StyleMap({
+                "vertex": new OpenLayers.Style({foo: "bar"})
+            }, {extendDefault: false})
         map.addLayer(layer);
         var control = new OpenLayers.Control.ModifyFeature(layer);
@@ -483,14 +487,38 @@
         // make sure onModificationStart is called on feature selection
         var testFeature = new OpenLayers.Feature.Vector(
-            new OpenLayers.Geometry.Point(Math.random(), Math.random())
+            OpenLayers.Geometry.fromWKT("LINESTRING(3 4,10 50,20 25)")
+        layer.addFeatures([testFeature]);
         control.onModificationStart = function(feature) {
             t.eq(feature.id, testFeature.id,
                  "onModificationStart called with the right feature");
         control.selectFeature(testFeature);
+        // make sure styles are set correctly from default style
+        t.eq(control.virtualStyle, OpenLayers.Util.applyDefaults({
+            strokeOpacity: 0.3,
+            fillOpacity: 0.3
+        }, OpenLayers.Feature.Vector.style["default"]), "virtual style set correctly");
+        var vertex = layer.features[layer.features.length-1];
+        t.eq(vertex.renderIntent, null, "vertex style set correctly - uses default style");
+        control.unselectFeature(testFeature);
+        // make sure styles are set correctly with vertexRenderIntent
+        control = new OpenLayers.Control.ModifyFeature(layer, {vertexRenderIntent: "vertex"});
+        control.selectFeature(testFeature);
+        t.eq(control.virtualStyle, {
+            fillOpacity: 0.3,
+            foo: "bar"
+        }, "virtual style set correctly");
+        t.eq(vertex.renderIntent, "vertex", "vertex style set correctly - uses 'vertex' renderIntent");
         map.destroy();
Modified: sandbox/august/trunk/tests/Control/PanZoom.html
--- sandbox/august/trunk/tests/Control/PanZoom.html	2010-12-01 22:47:34 UTC (rev 10940)
+++ sandbox/august/trunk/tests/Control/PanZoom.html	2010-12-03 06:40:11 UTC (rev 10941)
@@ -43,7 +43,7 @@
     function test_Control_PanZoom_control_events (t) {
-        if ( !window.document.createEvent || OpenLayers.Util.getBrowserName() == "opera" || !t.open_window) {
+        if ( !window.document.createEvent || OpenLayers.BROWSER_NAME == "opera" || !t.open_window) {
             //ie can't simulate mouseclicks
             t.plan(0);
             t.debug_print("FIXME: This browser does not support the PanZoom test at this time.");
Modified: sandbox/august/trunk/tests/Control/Panel.html
--- sandbox/august/trunk/tests/Control/Panel.html	2010-12-01 22:47:34 UTC (rev 10940)
+++ sandbox/august/trunk/tests/Control/Panel.html	2010-12-03 06:40:11 UTC (rev 10941)
@@ -227,8 +227,8 @@
         t.ok(!controlNoDeactive.active, "Tool control autoActivate:true is not active");
-    function test_Control_Panel_dectivate (t) {
-        t.plan(3);
+    function test_Control_Panel_deactivate (t) {
+        t.plan(2);
         var map = new OpenLayers.Map('map');
         var control = new OpenLayers.Control();
         var panel = new OpenLayers.Control.Panel();
@@ -239,12 +239,7 @@
         panel.deactivate();
         t.ok(panel.div.innerHTML == "",
             "Panel is not displayed after deactivate without any active control");
-        panel.activate();
-        var div = panel.div;
-        panel.destroy();
-        t.ok(panel.div.innerHTML == "",
-            "Panel is not displayed after destroy without any active control");
         map.destroy();
   </script>
Modified: sandbox/august/trunk/tests/Control/SLDSelect.html
--- sandbox/august/trunk/tests/Control/SLDSelect.html	2010-12-01 22:47:34 UTC (rev 10940)
+++ sandbox/august/trunk/tests/Control/SLDSelect.html	2010-12-03 06:40:11 UTC (rev 10941)
@@ -31,7 +31,7 @@
     function test_select(t) {
-        t.plan(8);
+        t.plan(9);
         var parser = new OpenLayers.Format.WFSDescribeFeatureType();
         var layer = new OpenLayers.Layer.WMS('Foo', 'http://foo', {LAYERS: 'AAA64'});
@@ -80,7 +80,8 @@
         control.select(geometry);
         control.events.unregister("selected", this, testEvent);
         t.eq(map.layers.length, 2, "Selection layer has been created and added to the map");
-        t.eq(map.layers[1] instanceof OpenLayers.Layer.WMS.Post, true, "A WMS Post layer has been created as the selection layer");
+        t.eq(map.layers[1] instanceof OpenLayers.Layer.WMS, true, "A WMS layer has been created as the selection layer");
+        t.eq(map.layers[1].tileOptions.maxGetUrlLength, 2048, "Selection layer will automatically switch to HTTP Post if content gets longer than 2048");
         var expected_sld = '<sld:StyledLayerDescriptor xmlns:sld="http://www.opengis.net/sld" version="1.0.0" xsi:schemaLocation="http://www.opengis.net/sld http://schemas.opengis.net/sld/1.0.0/StyledLayerDescriptor.xsd" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:ogc="http://www.opengis.net/ogc" xmlns:gml="http://www.opengis.net/gml"><sld:NamedLayer><sld:Name>AAA64</sld:Name><sld:UserStyle><sld:Name>default</sld:Name><sld:FeatureTypeStyle><sld:Rule><ogc:Filter xmlns:ogc="http://www.opengis.net/ogc"><ogc:BBOX><ogc:PropertyName>geometry</ogc:PropertyName><gml:Box xmlns:gml="http://www.opengis.net/gml"><gml:coordinates decimal="." cs="," ts=" ">-3.5355339059327,-3.5355339059327 3.5355339059327,3.5355339059327</gml:coordinates></gml:Box></ogc:BBOX></ogc:Filter><sld:LineSymbolizer><sld:Stroke><sld:CssParameter name="stroke">#FF0000</sld:CssParameter><sld:CssParameter name="stroke-width">2</sld:CssParameter></sld:Stroke></sld:LineSymbolizer></sld:Rule></sld:Featur
 eTypeStyle></sld:UserStyle></sld:NamedLayer></sld:StyledLayerDescriptor>';
         t.xml_eq(map.layers[1].params.SLD_BODY, expected_sld, "SLD generated correctly");
Modified: sandbox/august/trunk/tests/Feature.html
--- sandbox/august/trunk/tests/Feature.html	2010-12-01 22:47:34 UTC (rev 10940)
+++ sandbox/august/trunk/tests/Feature.html	2010-12-03 06:40:11 UTC (rev 10941)
@@ -43,7 +43,7 @@
         feature = new OpenLayers.Feature(layer, lonlat, data);
         popup = feature.createPopup();
         //Safari 3 separates style overflow into overflow-x and overflow-y
-        var prop = (OpenLayers.Util.getBrowserName() == 'safari') ? 'overflowX' : 'overflow';
+        var prop = (OpenLayers.BROWSER_NAME == 'safari') ? 'overflowX' : 'overflow';
         t.eq(popup.contentDiv.style[prop], "auto", 'overflow on popup is correct');
     function test_Feature_createMarker (t) {
Modified: sandbox/august/trunk/tests/Format/GML.html
--- sandbox/august/trunk/tests/Format/GML.html	2010-12-01 22:47:34 UTC (rev 10940)
+++ sandbox/august/trunk/tests/Format/GML.html	2010-12-03 06:40:11 UTC (rev 10941)
@@ -411,7 +411,7 @@
     var shell_start = '<wfs:FeatureCollection xmlns:wfs="http://www.opengis.net/wfs"><gml:featureMember xmlns:gml="http://www.opengis.net/gml"><feature:features xmlns:feature="http://mapserver.gis.umn.edu/mapserver" fid="221"><feature:geometry>';
         shell_start = '<wfs:FeatureCollection xmlns:wfs="http://www.opengis.net/wfs"><gml:featureMember xmlns:gml="http://www.opengis.net/gml"><feature:features fid="221" xmlns:feature="http://mapserver.gis.umn.edu/mapserver"><feature:geometry>';
     var shell_end = '</feature:geometry></feature:features></gml:featureMember></wfs:FeatureCollection>';
Modified: sandbox/august/trunk/tests/Format/SOSGetObservation.html
--- sandbox/august/trunk/tests/Format/SOSGetObservation.html	2010-12-01 22:47:34 UTC (rev 10940)
+++ sandbox/august/trunk/tests/Format/SOSGetObservation.html	2010-12-03 06:40:11 UTC (rev 10941)
@@ -4,7 +4,7 @@
     <script type="text/javascript">
     function test_read_SOSGetObservation(t) {
-        t.plan(7);
+        t.plan(13);
         var parser = new OpenLayers.Format.SOSGetObservation();
         var text =
@@ -49,16 +49,131 @@
         t.eq(measurement.result.uom, "Cel", "Units of measurement correctly parsed");
         t.eq(measurement.result.value, "4.9", "Value correctly parsed");
         t.eq(measurement.samplingTime.timeInstant.timePosition, "2009-12-02T10:35:00.000+01:00", "Sampling time correctly parsed");
+        var response = [];
+        response.push('<?xml version="1.0" encoding="UTF-8"?>',
+'<om:ObservationCollection gml:id="oc_0" xsi:schemaLocation="http://www.opengis.net/om/1.0 http://schemas.opengis.net/om/1.0.0/om.xsd http://www.opengis.net/sampling/1.0 http://schemas.opengis.net/sampling/1.0.0/sampling.xsd" xmlns:om="http://www.opengis.net/om/1.0" xmlns:gml="http://www.opengis.net/gml" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xlink="http://www.w3.org/1999/xlink" xmlns:swe="http://www.opengis.net/swe/1.0.1" xmlns:sa="http://www.opengis.net/sampling/1.0">',
+'  <gml:boundedBy>',
+'    <gml:Envelope srsName="urn:ogc:def:crs:EPSG:4326">',
+'      <gml:lowerCorner>46.611644 7.6103</gml:lowerCorner>',
+'      <gml:upperCorner>51.9412 13.883498</gml:upperCorner>',
+'    </gml:Envelope>',
+'  </gml:boundedBy>',
+'  <om:member>',
+'    <om:Observation gml:id="ot_583227">',
+'      <om:samplingTime>',
+'        <gml:TimePeriod xsi:type="gml:TimePeriodType">',
+'          <gml:beginPosition>2009-09-28T13:45:00.000+02:00</gml:beginPosition>',
+'          <gml:endPosition>2009-09-28T13:45:00.000+02:00</gml:endPosition>',
+'        </gml:TimePeriod>',
+'      </om:samplingTime>',
+'      <om:procedure xlink:href="urn:ogc:object:feature:OSIRIS-HWS:efeb807b-bd24-4128-a920-f6729bcdd111"/>',
+'      <om:observedProperty>',
+'        <swe:CompositePhenomenon gml:id="cpid0" dimension="1">',
+'          <gml:name>resultComponents</gml:name>',
+'          <swe:component xlink:href="urn:ogc:data:time:iso8601"/>',
+'          <swe:component xlink:href="urn:ogc:def:property:OGC::Precipitation1Hour"/>',
+'        </swe:CompositePhenomenon>',
+'      </om:observedProperty>',
+'      <om:featureOfInterest>',
+'        <gml:FeatureCollection>',
+'          <gml:featureMember>',
+'            <sa:SamplingPoint gml:id="urn:ogc:object:feature:OSIRIS-HWS:efeb807b-bd24-4128-a920-f6729bcdd111" xsi:schemaLocation=" http://www.opengis.net/sampling/1.0 http://schemas.opengis.net/sampling/1.0.0/sampling.xsd">',
+'              <gml:name>waether @ roof of the FH Kaernten, Villach, Austria</gml:name>',
+'              <sa:sampledFeature xlink:href="urn:ogc:def:nil:OGC:unknown"/>',
+'              <sa:position>',
+'                <gml:Point>',
+'                  <gml:pos srsName="urn:ogc:def:crs:EPSG:4326">46.611644 13.883498</gml:pos>',
+'                </gml:Point>',
+'              </sa:position>',
+'            </sa:SamplingPoint>',
+'          </gml:featureMember>',
+'        </gml:FeatureCollection>',
+'      </om:featureOfInterest>',
+'      <om:result>',
+'        <swe:DataArray>',
+'          <swe:elementCount>',
+'            <swe:Count>',
+'              <swe:value>1</swe:value>',
+'            </swe:Count>',
+'          </swe:elementCount>',
+'          <swe:elementType name="Components">',
+'            <swe:DataRecord>',
+'              <swe:field name="Time">',
+'                <swe:Time definition="urn:ogc:data:time:iso8601"/>',
+'              </swe:field>',
+'              <swe:field name="feature">',
+'                <swe:Text definition="urn:ogc:data:feature"/>',
+'              </swe:field>',
+'              <swe:field name="urn:ogc:def:property:OGC::Precipitation1Hour">',
+'                <swe:Quantity definition="urn:ogc:def:property:OGC::Precipitation1Hour">',
+'                  <swe:uom code="mm"/>',
+'                </swe:Quantity>',
+'              </swe:field>',
+'            </swe:DataRecord>',
+'          </swe:elementType>',
+'          <swe:encoding>',
+'            <swe:TextBlock decimalSeparator="." tokenSeparator="," blockSeparator=";"/>',
+'          </swe:encoding>',
+'          <swe:values>2009-09-28T13:45:00.000+02:00,urn:ogc:object:feature:OSIRIS-HWS:efeb807b-bd24-4128-a920-f6729bcdd111,0.0;</swe:values>',
+'        </swe:DataArray>',
+'      </om:result>',
+'    </om:Observation>',
+'  </om:member>',
+'</om:ObservationCollection>');
+        text = response.join("");
+        var res = parser.read(text);
+        t.eq(res.observations.length, 1, "1 observation parsed");
+        var observation = res.observations[0];
+        t.eq(observation.procedure, "urn:ogc:object:feature:OSIRIS-HWS:efeb807b-bd24-4128-a920-f6729bcdd111", "procedure parsed correctly");
+        t.eq(observation.fois.length, 1, "One foi parsed for the observation");
+        var foi = observation.fois[0];
+        var feature = foi.features[0];
+        t.eq(feature.attributes.id, "urn:ogc:object:feature:OSIRIS-HWS:efeb807b-bd24-4128-a920-f6729bcdd111", "Foi id correctly parsed");
+        t.eq(feature.attributes.name, "waether @ roof of the FH Kaernten, Villach, Austria", "Foi name correctly parsed");
+        t.ok(feature.geometry instanceof OpenLayers.Geometry.Point, "Geometry correctly parsed");
     function test_write_SOSGetObservation(t) {
-        t.plan(1);
+        t.plan(2);
         var expect = '<GetObservation xmlns="http://www.opengis.net/sos/1.0" version="1.0.0" service="SOS" xsi:schemaLocation="http://www.opengis.net/sos/1.0 http://schemas.opengis.net/sos/1.0.0/sosGetObservation.xsd" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"><offering>TEMPERATURE</offering><eventTime><ogc:TM_Equals xmlns:ogc="http://www.opengis.net/ogc"><ogc:PropertyName>urn:ogc:data:time:iso8601</ogc:PropertyName><gml:TimeInstant xmlns:gml="http://www.opengis.net/gml"><gml:timePosition>latest</gml:timePosition></gml:TimeInstant></ogc:TM_Equals></eventTime><procedure>urn:ogc:object:feature:OSIRIS-HWS:4fc335bc-06d7-4d5e-a72a-1ac73b9f3b56</procedure><observedProperty>urn:x-ogc:def:property:OGC::Temperature</observedProperty><responseFormat>text/xml;subtype="om/1.0.0"</responseFormat><resultModel>Measurement</resultModel><responseMode>inline</responseMode></GetObservation>';
         var format = new OpenLayers.Format.SOSGetObservation();
         var output = format.write({eventTime: 'latest', resultModel: 'Measurement', responseMode: 'inline',
-            procedure: 'urn:ogc:object:feature:OSIRIS-HWS:4fc335bc-06d7-4d5e-a72a-1ac73b9f3b56', responseFormat: 'text/xml;subtype="om/1.0.0"',
-            offering: 'TEMPERATURE', observedProperty: 'urn:x-ogc:def:property:OGC::Temperature'});
+            procedures: ['urn:ogc:object:feature:OSIRIS-HWS:4fc335bc-06d7-4d5e-a72a-1ac73b9f3b56'], responseFormat: 'text/xml;subtype="om/1.0.0"',
+            offering: 'TEMPERATURE', observedProperties: ['urn:x-ogc:def:property:OGC::Temperature']});
         t.xml_eq(output, expect, "Request XML is written out correctly");
+        var expected = [];
+        expected.push('<?xml version="1.0" encoding="UTF-8"?>',
+'<GetObservation xmlns="http://www.opengis.net/sos/1.0"',
+'  xmlns:gml="http://www.opengis.net/gml"',
+'  xmlns:om="http://www.opengis.net/om/1.0"',
+'  xmlns:ogc="http://www.opengis.net/ogc"',
+'  xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"',
+'  xsi:schemaLocation="http://www.opengis.net/sos/1.0 http://schemas.opengis.net/sos/1.0.0/sosGetObservation.xsd"',
+'  service="SOS" version="1.0.0">',
+'  <offering>RAIN_GAUGE</offering>',
+'  <eventTime>',
+'    <ogc:TM_Equals>',
+'      <ogc:PropertyName>urn:ogc:data:time:iso8601</ogc:PropertyName>',
+'      <gml:TimeInstant>',
+'        <gml:timePosition>latest</gml:timePosition>',
+'      </gml:TimeInstant>',
+'    </ogc:TM_Equals>',
+'  </eventTime>',
+'  <observedProperty>urn:ogc:def:property:OGC::Precipitation1Hour</observedProperty>',
+'  <featureOfInterest>',
+'    <ObjectID>urn:ogc:object:feature:OSIRIS-HWS:3d3b239f-7696-4864-9d07-15447eae2b93</ObjectID>',
+'  </featureOfInterest>',
+'  <responseFormat>text/xml;subtype="om/1.0.0"</responseFormat>',
+'</GetObservation>');
+        expect = expected.join("");
+        var output = format.write({eventTime: 'latest', offering: 'RAIN_GAUGE',
+            observedProperties: ['urn:ogc:def:property:OGC::Precipitation1Hour'],
+            responseFormat: 'text/xml;subtype="om/1.0.0"',
+            foi: {objectId: 'urn:ogc:object:feature:OSIRIS-HWS:3d3b239f-7696-4864-9d07-15447eae2b93'}});
+        t.xml_eq(output, expect, "Request XML is written out correctly");
     </script>
Modified: sandbox/august/trunk/tests/Format/WFST/v1_1_0.html
--- sandbox/august/trunk/tests/Format/WFST/v1_1_0.html	2010-12-01 22:47:34 UTC (rev 10940)
+++ sandbox/august/trunk/tests/Format/WFST/v1_1_0.html	2010-12-03 06:40:11 UTC (rev 10941)
@@ -40,6 +40,7 @@
             featureNS: "http://www.openplans.org/topp",
             featureType: "states",
             featurePrefix: "topp",
+            srsName: "urn:ogc:def:crs:EPSG::4326",
             geometryName: "the_geom"
@@ -109,11 +110,11 @@
 </wfs:TransactionResponse>
 --></div>
 <div id="query0"><!--
-<wfs:Query xmlns:wfs="http://www.opengis.net/wfs" typeName="topp:states" xmlns:topp="http://www.openplans.org/topp">
+<wfs:Query xmlns:wfs="http://www.opengis.net/wfs" typeName="topp:states" srsName="urn:ogc:def:crs:EPSG::4326" xmlns:topp="http://www.openplans.org/topp">
         <ogc:BBOX>
             <ogc:PropertyName>the_geom</ogc:PropertyName>
-            <gml:Envelope xmlns:gml="http://www.opengis.net/gml">
+            <gml:Envelope xmlns:gml="http://www.opengis.net/gml" srsName="urn:ogc:def:crs:EPSG::4326">
                 <gml:lowerCorner>1 2</gml:lowerCorner>
                 <gml:upperCorner>3 4</gml:upperCorner>
             </gml:Envelope>
@@ -127,7 +128,7 @@
                 xsi:schemaLocation="http://www.opengis.net/wfs http://schemas.opengis.net/wfs/1.1.0/wfs.xsd">
-    <wfs:Query xmlns:wfs="http://www.opengis.net/wfs" typeName="topp:states" xmlns:topp="http://www.openplans.org/topp">
+    <wfs:Query xmlns:wfs="http://www.opengis.net/wfs" typeName="topp:states" srsName="urn:ogc:def:crs:EPSG::4326" xmlns:topp="http://www.openplans.org/topp">
         <wfs:PropertyName>STATE_NAME</wfs:PropertyName>
         <wfs:PropertyName>STATE_FIPS</wfs:PropertyName>
         <wfs:PropertyName>STATE_ABBR</wfs:PropertyName>
Modified: sandbox/august/trunk/tests/Format/WMC/v1_1_0.html
--- sandbox/august/trunk/tests/Format/WMC/v1_1_0.html	2010-12-01 22:47:34 UTC (rev 10940)
+++ sandbox/august/trunk/tests/Format/WMC/v1_1_0.html	2010-12-03 06:40:11 UTC (rev 10941)
@@ -4,7 +4,7 @@
     function test_write_wmc_Layer(t) {
-        if (OpenLayers.Util.getBrowserName() == "safari") {
+        if (OpenLayers.BROWSER_NAME == "safari") {
             t.plan(0);
             t.debug_print("Safari has wierd behavior with getElementsByTagNameNS: the result is that we can't run these tests there. Patches welcome.");
             return;
Modified: sandbox/august/trunk/tests/Format/WMC.html
--- sandbox/august/trunk/tests/Format/WMC.html	2010-12-01 22:47:34 UTC (rev 10940)
+++ sandbox/august/trunk/tests/Format/WMC.html	2010-12-03 06:40:11 UTC (rev 10941)
@@ -130,7 +130,7 @@
         // test v1.1.0
-        if(OpenLayers.Util.getBrowserName()== "opera") {
+        if(OpenLayers.BROWSER_NAME== "opera") {
             t.plan(0);
             t.debug_print("WMC writing works but is not tested in Opera");
         } else {
Modified: sandbox/august/trunk/tests/Handler/Polygon.html
--- sandbox/august/trunk/tests/Handler/Polygon.html	2010-12-01 22:47:34 UTC (rev 10940)
+++ sandbox/august/trunk/tests/Handler/Polygon.html	2010-12-03 06:40:11 UTC (rev 10941)
@@ -158,6 +158,187 @@
         map.destroy();
+    function test_rings(t) {
+        t.plan(12);
+        var log = [];
+            div: "map",
+            resolutions: [1],
+            maxExtent: new OpenLayers.Bounds(-10, -10, 10, 10),
+            layers: [
+                new OpenLayers.Layer.Vector(null, {
+                    isBaseLayer: true,
+                    eventListeners: {
+                        featureadded: function(event) {
+                            log.push(event);
+                        sketchmodified: function(event) {
+                            log.push(event);
+                        sketchcomplete: function(event) {
+                            log.push(event);
+            center: new OpenLayers.LonLat(0, 0),
+            zoom: 0
+        // create control for drawing polygons with holes
+        var draw = new OpenLayers.Control.DrawFeature(
+            map.layers[0],
+            OpenLayers.Handler.Polygon,
+            {handlerOptions: {holeModifier: "altKey"}}
+        map.addControl(draw);
+        draw.activate();
+        var event;
+        function trigger(type, event) {
+            map.events.triggerEvent(type, OpenLayers.Util.extend({}, event));
+        // a) draw a polygon
+        log = [];
+        // start at -9, 9
+        event = {xy: new OpenLayers.Pixel(-9, 9)};
+        trigger("mousedown", event);
+        trigger("mouseup", event);
+        // draw to -1, 9
+        event = {xy: new OpenLayers.Pixel(-1, 9)};
+        trigger("mousemove", event);
+        // draw to -1, 1
+        event = {xy: new OpenLayers.Pixel(-1, 1)};
+        // draw to -9, 1
+        event = {xy: new OpenLayers.Pixel(-9, 1)};
+        // finish
+        trigger("dblclick", event);
+        // make assertions
+        t.eq(log.length, 9, "a) correct number of events");
+        t.eq(log[log.length-1].type, "featureadded", "a) featureadded event last");
+        t.eq(log[log.length-1].feature.geometry.getArea(), 64, "a) correct polygon area");
+        // b) draw a hole
+        log = [];
+        // start at -6, 6
+        event = {xy: new OpenLayers.Pixel(-6, 6), altKey: true};
+        // draw to -3, 6
+        event = {xy: new OpenLayers.Pixel(-3, 6), altKey: true};
+        // draw to -3, 3
+        event = {xy: new OpenLayers.Pixel(-3, 3), altKey: true};
+        // draw to -6, 3
+        event = {xy: new OpenLayers.Pixel(-6, 3), altKey: true};
+        // finish
+        t.eq(log.length, 8, "b) correct number of events");
+        t.eq(log[log.length-1].type, "sketchcomplete", "b) sketchcomplete event last");
+        t.eq(log[log.length-1].feature.geometry.getArea(), 55, "b) correct polygon area");
+        // c) draw a polygon that overlaps the first
+        log = [];
+        // start at -2, 2
+        event = {xy: new OpenLayers.Pixel(-2, 2)};
+        // draw to 2, 2
+        event = {xy: new OpenLayers.Pixel(2, 2)};
+        // draw to 2, -2
+        event = {xy: new OpenLayers.Pixel(2, -2)};
+        // draw to -2, -2
+        event = {xy: new OpenLayers.Pixel(-2, -2)};
+        // finish
+        t.eq(log.length, 9, "c) correct number of events");
+        t.eq(log[log.length-1].type, "featureadded", "c) featureadded event last");
+        t.eq(log[log.length-1].feature.geometry.getArea(), 16, "c) correct polygon area");
+        // d) draw a hole that tries to go outside the exterior ring
+        log = [];
+        // start at -1, 1
+        event = {xy: new OpenLayers.Pixel(-1, 1), altKey: true};
+        // draw to 1, 1
+        event = {xy: new OpenLayers.Pixel(1, 1), altKey: true};
+        // try to draw to -8, 8 (ouside active polygon)
+        event = {xy: new OpenLayers.Pixel(-8, 8), altKey: true};
+        // draw to 1, -1
+        event = {xy: new OpenLayers.Pixel(1, -1), altKey: true};
+        // draw to -1, -1
+        event = {xy: new OpenLayers.Pixel(-1, -1), altKey: true};
+        // finish
+        t.eq(log.length, 11, "d) correct number of events");
+        t.eq(log[log.length-1].type, "sketchcomplete", "d) sketchcomplete event last");
+        t.eq(log[log.length-1].feature.geometry.getArea(), 12, "d) correct polygon area");
+        map.destroy();
     function test_Handler_Polygon_destroy(t) {
         t.plan(8);
Modified: sandbox/august/trunk/tests/Layer/EventPane.html
--- sandbox/august/trunk/tests/Layer/EventPane.html	2010-12-01 22:47:34 UTC (rev 10940)
+++ sandbox/august/trunk/tests/Layer/EventPane.html	2010-12-03 06:40:11 UTC (rev 10941)
@@ -57,7 +57,7 @@
 // MOUSEMOVE test does not seem to work...
 //         t.plan( 2 );
-        if (OpenLayers.Util.getBrowserName() != "firefox" && OpenLayers.Util.getBrowserName() != "mozilla") {
+        if (OpenLayers.BROWSER_NAME != "firefox" && OpenLayers.BROWSER_NAME != "mozilla") {
           t.plan(4);
         } else {
           t.plan(0);
Modified: sandbox/august/trunk/tests/Layer/GeoRSS.html
--- sandbox/august/trunk/tests/Layer/GeoRSS.html	2010-12-01 22:47:34 UTC (rev 10940)
+++ sandbox/august/trunk/tests/Layer/GeoRSS.html	2010-12-03 06:40:11 UTC (rev 10941)
@@ -172,7 +172,7 @@
     function test_Layer_GeoRSS_loadend_Event(t) {
-        var browserCode = OpenLayers.Util.getBrowserName();
+        var browserCode = OpenLayers.BROWSER_NAME;
         if (browserCode == "msie") {
             t.plan(1);
             t.ok(true, "IE fails the GeoRSS test. This could probably be fixed by someone with enough energy to fix it.");
Modified: sandbox/august/trunk/tests/Layer/MapServer.html
--- sandbox/august/trunk/tests/Layer/MapServer.html	2010-12-01 22:47:34 UTC (rev 10940)
+++ sandbox/august/trunk/tests/Layer/MapServer.html	2010-12-03 06:40:11 UTC (rev 10941)
@@ -226,7 +226,7 @@
                        (window.location.host == "localhost") ||
                        (window.location.host == "openlayers.org");
-        if (OpenLayers.Util.getBrowserName() == "opera" || OpenLayers.Util.getBrowserName() == "safari") {
+        if (OpenLayers.BROWSER_NAME == "opera" || OpenLayers.BROWSER_NAME == "safari") {
             t.plan(1);
             t.debug_print("Can't test google reprojection in Opera or Safari.");
         } else if(validkey) {
Modified: sandbox/august/trunk/tests/Layer/SphericalMercator.html
--- sandbox/august/trunk/tests/Layer/SphericalMercator.html	2010-12-01 22:47:34 UTC (rev 10940)
+++ sandbox/august/trunk/tests/Layer/SphericalMercator.html	2010-12-03 06:40:11 UTC (rev 10941)
@@ -69,7 +69,7 @@
         t.eq(strToFixed(point.toString()),
              strToFixed("POINT(10.000000828446318 20.000000618997227)"),
-             "point transforms from EPSG:4326 to Spherical Mercator");
+             "point transforms from Spherical Mercator to EPSG:4326");
     function test_SphericalMercator_addTransform(t) {
@@ -88,6 +88,48 @@
              "from EPSG:900913 to EPSG:4326 correctly defined");
+    function test_equivalence(t) {
+        var len = codes.length;
+        t.plan(len + (len * len));
+        var ggPoint = new OpenLayers.Geometry.Point(10, 20);
+        var smPoint = new OpenLayers.Geometry.Point(1113195, 2273031);
+        var gg = new OpenLayers.Projection("EPSG:4326");
+        var i, proj, forward, inverse, other, j, equiv;
+            proj = new OpenLayers.Projection(codes[i]);
+            // confirm that forward/inverse work
+            forward = ggPoint.clone().transform(gg, proj);
+            t.eq(
+                strToFixed(forward.toString()),
+                strToFixed("POINT(1113194.9077777779 2273030.9266712805)"),
+                "transforms from EPSG:4326 to " + proj
+            inverse = smPoint.clone().transform(proj, gg);
+            t.eq(
+                strToFixed(inverse.toString()),
+                strToFixed("POINT(10.000000828446318 20.000000618997227)"),
+                "transforms from " + proj + " to EPSG:4326"
+            // confirm that null transform works
+                other = new OpenLayers.Projection(codes[j]);
+                equiv = ggPoint.clone().transform(proj, other);
+                t.ok(proj.equals(other),  proj + " and " + other + " are equivalent");
+                t.ok(ggPoint.equals(equiv), "transform from " + proj + " to " + other + " preserves geometry");
   </script>
 </head>
 <body>
Modified: sandbox/august/trunk/tests/Layer/Text.html
--- sandbox/august/trunk/tests/Layer/Text.html	2010-12-01 22:47:34 UTC (rev 10940)
+++ sandbox/august/trunk/tests/Layer/Text.html	2010-12-03 06:40:11 UTC (rev 10941)
@@ -132,7 +132,7 @@
           layer.markers[1].events.triggerEvent('click', event);
           t.eq(map.popups.length, 1, "1st popup gone, 2nd Popup opened correctly");
           t.eq(map.popups[0].contentDiv.style[prop],"auto", "default Popup overflow correct");
@@ -151,12 +151,12 @@
           layer.markers[0].events.triggerEvent('click', event);
           t.eq(map.popups.length, 1, "Popup opened correctly");
           t.eq(map.popups[0].contentDiv.style[prop],"auto", "Popup overflow read from file");
           t.eq(map.popups[0].contentDiv.style[prop],"hidden", "Popup overflow read from file");
Modified: sandbox/august/trunk/tests/Layer/Vector.html
--- sandbox/august/trunk/tests/Layer/Vector.html	2010-12-01 22:47:34 UTC (rev 10940)
+++ sandbox/august/trunk/tests/Layer/Vector.html	2010-12-03 06:40:11 UTC (rev 10941)
@@ -610,7 +610,7 @@
                 feature.style = customStyle5;
                 layer.drawFeature(feature);
                 t.eq(root.firstChild.getAttributeNS(null, 'style'),
-                             'opacity: '+customStyle5.graphicOpacity.toString()+((OpenLayers.Util.getBrowserName() == "opera" || OpenLayers.Util.getBrowserName() == "safari") ? "" : ';'),
+                             'opacity: '+customStyle5.graphicOpacity.toString()+((OpenLayers.BROWSER_NAME == "opera" || OpenLayers.BROWSER_NAME == "safari") ? "" : ';'),
                              "graphicOpacity correctly set");
                 feature.style = customStyle6;
Modified: sandbox/august/trunk/tests/Layer/WMS/Post.html
--- sandbox/august/trunk/tests/Layer/WMS/Post.html	2010-12-01 22:47:34 UTC (rev 10940)
+++ sandbox/august/trunk/tests/Layer/WMS/Post.html	2010-12-03 06:40:11 UTC (rev 10941)
@@ -16,8 +16,8 @@
         t.plan( 2 );
         var url = "http://octo.metacarta.com/cgi-bin/mapserv";
-        var options = { unsupportedBrowsers: []};
-        layer = new OpenLayers.Layer.WMS.Post(name, url, params);
+        var options = {unsupportedBrowsers: []};
+        layer = new OpenLayers.Layer.WMS.Post(name, url, params, options);
         t.eq(
             layer.usePost, true,
@@ -25,7 +25,7 @@
         layer.destroy();
-        var options = { unsupportedBrowsers: [OpenLayers.Util.getBrowserName()]};
+        var options = { unsupportedBrowsers: [OpenLayers.BROWSER_NAME]};
         t.eq(
             layer.usePost, false,
@@ -55,11 +55,10 @@
         map.destroy();
-        var browserName = OpenLayers.Util.getBrowserName();
-        var options = { unsupportedBrowsers: [browserName]};
         // test the unsupported browser
-        layer = new OpenLayers.Layer.WMS.Post(name, url, params, options);
+        layer = new OpenLayers.Layer.WMS.Post(name, url, params, {
+            unsupportedBrowsers: [OpenLayers.BROWSER_NAME]
         tile  = layer.addTile(bounds, pixel);
@@ -69,8 +68,9 @@
         layer.destroy();
         // test a supported browser
-        OpenLayers.Util.getBrowserName = function () { return 'not_' + browserName };
+            unsupportedBrowsers: []
         var tile2 = layer.addTile(bounds, pixel);
         t.ok(
Modified: sandbox/august/trunk/tests/Layer/WMS.html
--- sandbox/august/trunk/tests/Layer/WMS.html	2010-12-01 22:47:34 UTC (rev 10940)
+++ sandbox/august/trunk/tests/Layer/WMS.html	2010-12-03 06:40:11 UTC (rev 10941)
@@ -230,15 +230,15 @@
     function test_Layer_WMS_getFullRequestString (t) {
-        t.plan( 2 );
+        t.plan( 3 );
         map.projection = "xx";
-        tUrl = "http://octo.metacarta.com/cgi-bin/mapserv";
-        tParams = { layers: 'basic',
+        var tUrl = "http://octo.metacarta.com/cgi-bin/mapserv";
+        var tParams = { layers: 'basic',
                    format: 'image/png'};
         var tLayer = new OpenLayers.Layer.WMS(name, tUrl, tParams);
         map.addLayer(tLayer);
-        str = tLayer.getFullRequestString();
+        var str = tLayer.getFullRequestString();
         var tParams = {
             LAYERS: "basic", FORMAT: "image/png", SERVICE: "WMS",
             VERSION: "1.1.1", REQUEST: "GetMap", STYLES: "",
@@ -257,6 +257,20 @@
              tUrl + "?" + OpenLayers.Util.getParameterString(tParams),
              "getFullRequestString() by default does *not* add SRS value if projection is 'none'");
         map.destroy();
+        map = new OpenLayers.Map("map", {projection: "EPSG:4326"});
+        var layerProj = new OpenLayers.Projection("FOO", {
+            equals: function() {return true},
+            getCode: function() {return "FOO"}
+        tLayer = new OpenLayers.Layer.WMS(name, tUrl, tParams, {projection: layerProj});
+        map.addLayer(tLayer);
+        str = tLayer.getFullRequestString();
+        tParams.SRS = "FOO";
+        t.eq(str,
+             tUrl + "?" + OpenLayers.Util.getParameterString(tParams),
+             "getFullRequestString() uses the layer projection if it equals the map projection");
+        map.destroy();
@@ -289,7 +303,7 @@
         var validkey = (window.location.protocol == "file:") ||
             t.plan(1);
Modified: sandbox/august/trunk/tests/Layer/XYZ.html
--- sandbox/august/trunk/tests/Layer/XYZ.html	2010-12-01 22:47:34 UTC (rev 10940)
+++ sandbox/august/trunk/tests/Layer/XYZ.html	2010-12-03 06:40:11 UTC (rev 10941)
@@ -148,6 +148,31 @@
         map.destroy();
+    function test_Layer_XYZ_serverResolutions(t) {
+        t.plan(2);
+        var map = new OpenLayers.Map('map', {
+            resolutions: [13,11]
+        var layer = new OpenLayers.Layer.XYZ(name, url, options);
+        map.addLayer(layer);
+        map.setCenter(new OpenLayers.LonLat(0,0), 1);
+        var tileurl = layer.getURL(new OpenLayers.Bounds(0,0,0,0));
+        var level = parseInt(tileurl.split('/')[7]);
+        t.eq(map.getZoom(), level, "Tile zoom level is correct without serverResolutions");
+        layer.serverResolutions = [14,13,12,11,10];
+        tileurl = layer.getURL(new OpenLayers.Bounds(0,0,0,0));
+        level = parseInt(tileurl.split('/')[7]);
+        var res = map.getResolution();
+        var gotLevel = OpenLayers.Util.indexOf(layer.serverResolutions, res);
+        t.eq(gotLevel, level, "Tile zoom level is correct with serverResolutions");
+        map.destroy();
     function test_zoomOffset(t) {
         t.plan(2);
Modified: sandbox/august/trunk/tests/Marker/Box.html
--- sandbox/august/trunk/tests/Marker/Box.html	2010-12-01 22:47:34 UTC (rev 10940)
+++ sandbox/august/trunk/tests/Marker/Box.html	2010-12-03 06:40:11 UTC (rev 10941)
@@ -26,7 +26,7 @@
         t.ok( box.bounds.equals(bounds), "bounds object correctly set");
         t.ok( box.div != null, "div created");
         t.eq( box.div.style[prop], "hidden", "div style overflow hidden");
         t.ok( box.events != null, "events object created");
         t.eq( g_Color, borderColor, "setBorder called with correct border color");
Deleted: sandbox/august/trunk/tests/OpenLayers.html
--- sandbox/august/trunk/tests/OpenLayers.html	2010-12-01 22:47:34 UTC (rev 10940)
+++ sandbox/august/trunk/tests/OpenLayers.html	2010-12-03 06:40:11 UTC (rev 10941)
@@ -1,31 +0,0 @@
-<html>
-<head>
-    <script src="bogus/1/OpenLayers.js-foo"></script>
-    <script src="bogus/2/foo-OpenLayers.js"></script>
-    <script id="script" src="../lib/OpenLayers.js"></script>
-    <script type="text/javascript">
-        function test_OpenLayers(t) {
-            t.plan(3);
-            var script = document.getElementById("script");
-            t.eq(OpenLayers._getScriptLocation(), "../", "Script location correctly detected.");
-            // create a clone of OpenLayers._getScriptLocation
-            eval("var getScriptLocation = " + OpenLayers._getScriptLocation.toString());
-            script.setAttribute("src", "../lib/OpenLayers.js?foo");
-            t.eq(getScriptLocation(), "../", "Script location with search string correctly detected.");
-            scriptLocation = null;
-            // now pretend we're using a built script
-            OpenLayers._scriptName = "OpenLayers.js";
-            t.eq(getScriptLocation(), "../lib/", "not fooled by bogus paths");
-    </script>
-</head>
-<body>
-</body>
-</html>
Copied: sandbox/august/trunk/tests/OpenLayers1.html (from rev 10940, trunk/openlayers/tests/OpenLayers1.html)
--- sandbox/august/trunk/tests/OpenLayers1.html	                        (rev 0)
+++ sandbox/august/trunk/tests/OpenLayers1.html	2010-12-03 06:40:11 UTC (rev 10941)
@@ -0,0 +1,16 @@
+<html>
+<head>
+    <script src="../lib/OpenLayers.js"></script>
+    <script type="text/javascript">
+        function test_OpenLayers(t) {
+            t.plan(1);
+            var script = document.getElementById("script");
+            t.eq(OpenLayers._getScriptLocation(), "../", "Script location correctly detected.");
+    </script>
+</head>
+<body>
+</body>
+</html>
Copied: sandbox/august/trunk/tests/OpenLayers2.html (from rev 10940, trunk/openlayers/tests/OpenLayers2.html)
--- sandbox/august/trunk/tests/OpenLayers2.html	                        (rev 0)
+++ sandbox/august/trunk/tests/OpenLayers2.html	2010-12-03 06:40:11 UTC (rev 10941)
@@ -0,0 +1,19 @@
+<html>
+<head>
+    <script src="bogus/1/OpenLayers.js-foo"></script>
+    <script src="bogus/2/foo-OpenLayers.js"></script>
+    <script src="../lib/OpenLayers.js?foo"></script>
+    <script src="bogus/3/after-OpenLayers.js"></script>
+            t.plan(1);
+            t.eq(OpenLayers._getScriptLocation(), "../", "Script location with search string correctly detected, and not fooled by other scripts.");
+    </script>
+</head>
+<body>
+</body>
+</html>
Copied: sandbox/august/trunk/tests/OpenLayers3.html (from rev 10940, trunk/openlayers/tests/OpenLayers3.html)
--- sandbox/august/trunk/tests/OpenLayers3.html	                        (rev 0)
+++ sandbox/august/trunk/tests/OpenLayers3.html	2010-12-03 06:40:11 UTC (rev 10941)
@@ -0,0 +1,19 @@
+<html>
+<head>
+    <script>
+    var OpenLayers = {singleFile: true};
+    </script>
+            t.plan(1);
+            t.eq(OpenLayers._getScriptLocation(), "../lib/", "Script location for single file build correctly detected.");
+    </script>
+</head>
+<body>
+</body>
+</html>
Copied: sandbox/august/trunk/tests/OpenLayers4.html (from rev 10940, trunk/openlayers/tests/OpenLayers4.html)
--- sandbox/august/trunk/tests/OpenLayers4.html	                        (rev 0)
+++ sandbox/august/trunk/tests/OpenLayers4.html	2010-12-03 06:40:11 UTC (rev 10941)
@@ -0,0 +1,18 @@
+<html>
+<head>
+	OpenLayers = {singleFile: true}; // just to make the test run faster
+        document.write('<scr'+'ipt src="../lib/OpenLayers.js"></scr'+'ipt>');
+        document.write('<scr'+'ipt src="bogus/foo-/OpenLayers.js"></scr'+'ipt>');
+    </script>
+            t.plan(1);
+                 "Script location correctly detected, and not fooled by other scripts.");
+    </script>
+</head>
+<body>
+</body>
+</html>
Modified: sandbox/august/trunk/tests/Popup/Anchored.html
--- sandbox/august/trunk/tests/Popup/Anchored.html	2010-12-01 22:47:34 UTC (rev 10940)
+++ sandbox/august/trunk/tests/Popup/Anchored.html	2010-12-03 06:40:11 UTC (rev 10941)
@@ -11,7 +11,7 @@
         popup = new OpenLayers.Popup.Anchored();
         t.ok( popup instanceof OpenLayers.Popup.Anchored, "new OpenLayers.Popup.Anchored returns Popup.Anchored object" );
-        t.ok(popup.id.startsWith("OpenLayers.Popup.Anchored"), "valid default popupid");
+        t.ok(OpenLayers.String.startsWith(popup.id, "OpenLayers.Popup.Anchored"), "valid default popupid");
         var firstID = popup.id;
         t.eq(popup.contentHTML, null, "good default popup.contentHTML");
Modified: sandbox/august/trunk/tests/Popup.html
--- sandbox/august/trunk/tests/Popup.html	2010-12-01 22:47:34 UTC (rev 10940)
+++ sandbox/august/trunk/tests/Popup.html	2010-12-03 06:40:11 UTC (rev 10941)
@@ -88,8 +88,8 @@
     function test_Popup_keepInMap(t) {
-        var gb = OpenLayers.Util.getBrowserName;
-        OpenLayers.Util.getBrowserName = function() { return "mock"; }
+        var bn = OpenLayers.BROWSER_NAME;
+        OpenLayers.BROWSER_NAME = "mock";
         t.plan(3);
         map.addLayer(new OpenLayers.Layer("", {isBaseLayer: true}));
@@ -120,7 +120,7 @@
         t.ok(safeSizePan.equals(safeSizePanKeep), "Panning means that all sizes are equal");
         t.ok(safeSize.w < safeSizePan.w, "Width of non-panning is less");
         t.ok(safeSize.h < safeSizePan.h, "Height of non-panning is less");
-        OpenLayers.Util.getBrowserName = gb;
+        OpenLayers.BROWSER_NAME = bn;
     function test_Popup_draw(t) {
         t.plan( 15 );
@@ -155,7 +155,7 @@
         t.eq(contentDiv.id, "chicken_contentDiv", "correct content div id");
         t.eq(contentDiv.style.position, "relative", "correct content div position");
         t.eq(contentDiv.style[prop], "", "correct content div overflow");
         t.eq(contentDiv.innerHTML, content, "correct content div content");
@@ -169,7 +169,7 @@
             t.eq(popup.div.style.filter, "alpha(opacity=" + opacity*100 + ")", "good default popup.opacity");
         //Safari 3 separates the border style into separate entities when reading it
-        if (OpenLayers.Util.getBrowserName() == 'safari') {
+        if (OpenLayers.BROWSER_NAME == 'safari') {
           var s = border.split(' ');
           t.ok(popup.div.style.borderTopWidth == s[0] && popup.div.style.borderTopStyle == s[1], "good default popup.border")
         } else {
Modified: sandbox/august/trunk/tests/Projection.html
--- sandbox/august/trunk/tests/Projection.html	2010-12-01 22:47:34 UTC (rev 10940)
+++ sandbox/august/trunk/tests/Projection.html	2010-12-03 06:40:11 UTC (rev 10941)
@@ -21,7 +21,47 @@
          t.eq(projection.equals(null), false, "equals on null projection returns false");
          t.eq(projection.equals({}), false, "equals on null projection object returns false (doesn't call getCode)");
+     function test_Projection_equals(t) {
+         t.plan(8);
+         var origTransforms = OpenLayers.Util.extend({}, OpenLayers.Projection.transforms);
+         OpenLayers.Projection.addTransform("EPSG:4326", "FOO", OpenLayers.Projection.nullTransform);
+         OpenLayers.Projection.addTransform("FOO", "EPSG:4326", OpenLayers.Projection.nullTransform);
+         var projection = new OpenLayers.Projection("FOO");
+         t.eq(projection.equals(new OpenLayers.Projection("EPSG:4326")), true, "EPSG:4326 and FOO are equal without proj4js");
+         t.eq(projection.equals(new OpenLayers.Projection("EPSG:900913")), false, "EPSG:900913 and FOO are not equal without proj4js");
+         t.eq(new OpenLayers.Projection("EPSG:4326").equals(new OpenLayers.Projection("EPSG:4326")), true, "EPSG:4326 and EPSG:4326 are equal without proj4js");
+         t.eq(new OpenLayers.Projection("BAR").equals(new OpenLayers.Projection("EPSG:4326")), false, "Projection.equals() returns false for unknown projections withoug proj4js");
+         OpenLayers.Projection.transforms = origTransforms;
+         var proj1 = new OpenLayers.Projection("EPSG:4326");
+         var proj2 = new OpenLayers.Projection("FOO");
+         var proj3 = new OpenLayers.Projection("EPSG:900913");
+         var proj4 = new OpenLayers.Projection("EPSG:4326");
+         var proj5 = new OpenLayers.Projection("BAR");
+         // conditionally mock up proj4js
+         var hasProj = !!window.Proj4js;
+         if (!hasProj) {
+             window.Proj4js = true;
+         proj1.proj = {defData: "+title= WGS84 +foo=bar +x=0"};
+         proj2.proj = {defData: "+title=FOO +foo=bar +x=0", srsCode: "FOO"};
+         proj3.proj = {defData: "+title=Web Mercator +foo=bar +x=0 +I=am-different"};
+         proj4.proj = proj1.proj;
+         proj5.proj = {srsCode: "BAR"};
+         t.eq(proj2.equals(proj1), true, "EPSG:4326 and FOO are equal with proj4js");
+         t.eq(proj2.equals(proj3), false, "EPSG:900913 and FOO are not equal with proj4js");
+         t.eq(proj1.equals(proj4), true, "EPSG:4326 and EPSG:4326 are equal with proj4js");
+         t.eq(proj2.equals(proj5), false, "Projection.equals() returns false for unknown projections with proj4js");
+         if (!hasProj) {
+             delete window.Proj4js
     </script>
   </head>
Modified: sandbox/august/trunk/tests/Renderer/Canvas.html
--- sandbox/august/trunk/tests/Renderer/Canvas.html	2010-12-01 22:47:34 UTC (rev 10940)
+++ sandbox/august/trunk/tests/Renderer/Canvas.html	2010-12-03 06:40:11 UTC (rev 10941)
@@ -23,7 +23,7 @@
         var extent = new OpenLayers.Bounds(1,2,3,4);
         r.resolution = 1;
-        r.setExtent(extent);
+        r.setExtent(extent, true);
         t.ok(r.extent.equals(extent), "extent is correctly set");
         t.eq(r.resolution, null, "resolution nullified");
Modified: sandbox/august/trunk/tests/Renderer/Elements.html
--- sandbox/august/trunk/tests/Renderer/Elements.html	2010-12-01 22:47:34 UTC (rev 10940)
+++ sandbox/august/trunk/tests/Renderer/Elements.html	2010-12-03 06:40:11 UTC (rev 10941)
@@ -561,8 +561,63 @@
         tearDown();
+    function test_Elements_drawGeometry_3(t) {
+        t.plan(2);
+        setUp();
+        var r = create_renderer();
+        var element = document.createElement("div");
+        r.vectorRoot = element;
+        r.nodeFactory = function(id, type) {
+            return document.createElement("div");
+        var g_Node = null;
+        var b_Node = null;
+        r.drawGeometryNode = function(node, geometry, style) {
+            g_Node = node;
+            return {node: node, complete: true};
+        r.redrawBackgroundNode = function(id, geometry, style, featureId) {
+            b_Node = r.nodeFactory();
+            b_Node.id = "foo_background";
+            element.appendChild(b_Node);
+        r.getNodeType = function(geometry, style) {
+            return "div";
+        var geometry = {
+            id: 'foo',
+            CLASS_NAME: 'bar',
+            getBounds: function() {return {bottom: 0}}
+        var style = {'backgroundGraphic': 'foo'};
+        var featureId = 'dude';
+        r.drawGeometry(geometry, style, featureId);
+        t.ok(b_Node.parentNode == element, "redrawBackgroundNode appended background node");
+        var returnNode = function(id) {
+        	return id == "foo_background" ? b_Node : g_Node;
+        var _getElement = document.getElementById;
+        document.getElementById = returnNode;
+        OpenLayers.Util.getElement = returnNode;
+        style = {};
+        t.ok(b_Node.parentNode != element, "background node correctly removed")
+        document.getElementById = _getElement;
+        tearDown();
   </script>
 </head>
 <body>
Modified: sandbox/august/trunk/tests/Renderer/VML.html
--- sandbox/august/trunk/tests/Renderer/VML.html	2010-12-01 22:47:34 UTC (rev 10940)
+++ sandbox/august/trunk/tests/Renderer/VML.html	2010-12-03 06:40:11 UTC (rev 10941)
@@ -305,7 +305,7 @@
             return;
-        t.plan(2);
+        t.plan(3);
         var r = new OpenLayers.Renderer.VML(document.body);
         r.offset = {x: 0, y: 0};
@@ -318,30 +318,16 @@
         var node = document.createElement('div');
-        var linearRing = {
-            components: [{
-                x: 1,
-                y: 2
-                x: 3,
-                y: 4
-        var linearRing2 = {
-            components: [{
-                x: 5,
-                y: 6
-                x: 7,
-                y: 8
-        var geometry = {
-            components: [linearRing, linearRing2]
+        var geometry = OpenLayers.Geometry.fromWKT(
+            "POLYGON((1 2, 3 4), (5 6, 7 8))"
         r.drawPolygon(node, geometry, true);
         t.ok(g_SetNodeDimension, "setNodeDimension is called");
-        t.eq(node.path, "m 2,4 l 6,8 x m 10,12 l 14,16 x e", "path attribute is correct");
+        t.eq(node.path, "m 2,4 l 6,8 2,4 x m 10,12 l 14,16 10,12 e", "path attribute is correct - inner ring has no area and is not closed");
+        geometry.components[1].addComponent(new OpenLayers.Geometry.Point(8, 7));
+        r.drawPolygon(node, geometry, true);
+        t.eq(node.path, "m 2,4 l 6,8 2,4 x m 10,12 l 14,16 16,14 10,12 x e", "path attribute is correct - inner ring has an area and is closed");
     function test_VML_drawrectangle(t) {
Modified: sandbox/august/trunk/tests/Request.html
--- sandbox/august/trunk/tests/Request.html	2010-12-01 22:47:34 UTC (rev 10940)
+++ sandbox/august/trunk/tests/Request.html	2010-12-03 06:40:11 UTC (rev 10941)
@@ -372,19 +372,41 @@
     function test_abort(t) {
         t.plan(0);
-        var fail = false;
-        OpenLayers.Request.XMLHttpRequest.onsend = function(args) {
-            fail = true;
+        var sendCalled;
+        // set up
+        var _open = OpenLayers.Request.XMLHttpRequest.prototype.open;
+        OpenLayers.Request.XMLHttpRequest.prototype.open = function() {
+            this.readyState = OpenLayers.Request.XMLHttpRequest.OPENED;
+        var _setRequestHeader = OpenLayers.Request.XMLHttpRequest.prototype.setRequestHeader;
+        OpenLayers.Request.XMLHttpRequest.prototype.setRequestHeader = function() {};
+        var _send = OpenLayers.Request.XMLHttpRequest.prototype.send;
+        OpenLayers.Request.XMLHttpRequest.prototype.send = function() {
+            sendCalled = true;
+        // test
+        sendCalled = false;
+        OpenLayers.Request.issue().abort();
         t.delay_call(0.5, function() {
-            if (fail === true) {
+            if (sendCalled) {
                 t.fail("Send should not be called because request is aborted");
-            OpenLayers.Request.XMLHttpRequest.onsend = null;
+            // tear down
+            OpenLayers.Request.XMLHttpRequest.prototype.open = _open;
+            OpenLayers.Request.XMLHttpRequest.prototype.setRequestHeader = _setRequestHeader;
+            OpenLayers.Request.XMLHttpRequest.prototype.send = _send;
-        var protocol = new OpenLayers.Protocol.HTTP();
-        protocol.abort(protocol.read());
     </script>
Modified: sandbox/august/trunk/tests/Strategy/Filter.html
--- sandbox/august/trunk/tests/Strategy/Filter.html	2010-12-01 22:47:34 UTC (rev 10940)
+++ sandbox/august/trunk/tests/Strategy/Filter.html	2010-12-03 06:40:11 UTC (rev 10941)
@@ -21,7 +21,7 @@
 function test_initialize(t) {
-    t.plan(3);
+    t.plan(4);
     var strategy = new OpenLayers.Strategy.Filter({filter: filter});
@@ -31,6 +31,14 @@
     t.ok(strategy.filter === filter, "has filter");
     strategy.destroy();
+    try {
+        strategy = new OpenLayers.Strategy.Filter();
+        t.ok(true, "strategy without filter works");
+    } catch (err) {
+        t.fail("strategy without filter should not throw");
Modified: sandbox/august/trunk/tests/Util.html
--- sandbox/august/trunk/tests/Util.html	2010-12-01 22:47:34 UTC (rev 10940)
+++ sandbox/august/trunk/tests/Util.html	2010-12-03 06:40:11 UTC (rev 10941)
@@ -97,7 +97,7 @@
         t.eq( div.style.position, position, "div.style.positionset correctly");
           t.ok(div.style.borderTopWidth == s[0] && div.style.borderTopStyle == s[1], "good default popup.border")
         } else {
@@ -105,11 +105,11 @@
         t.eq( div.style[prop], overflow, "div.style.overflow set correctly");
         t.eq( parseFloat(div.style.opacity), opacity, "element.style.opacity set correctly");
         //Safari 3 returns null for this value, which is okay
-        var filterString = (OpenLayers.Util.getBrowserName() == 'safari') ? null : 'alpha(opacity=' + (opacity * 100) + ')';
+        var filterString = (OpenLayers.BROWSER_NAME == 'safari') ? null : 'alpha(opacity=' + (opacity * 100) + ')';
         t.eq( div.style.filter, filterString, "element.style.filter set correctly");
         //test defaults
@@ -130,13 +130,13 @@
         t.eq( div.style.position, "absolute", "div.style.positionset correctly");
           t.ok(div.style.borderTopWidth == '' && div.style.borderTopStyle == '', "good default popup.border")
         } else {
           t.eq( div.style.border, "", "div.style.border set correctly");
         t.eq(div.style[prop], "", "div.style.overflow set correctly");
         t.ok( !div.style.opacity, "element.style.opacity set correctly");
         t.ok( !div.style.filter, "element.style.filter set correctly");
@@ -168,7 +168,7 @@
         t.eq( image.style.height, sz.h + "px", "image.style.height set correctly");
           t.ok(image.style.borderTopWidth == s[0] && image.style.borderTopStyle == s[1], "good default popup.border")
         } else {
@@ -178,7 +178,7 @@
         t.eq( image.style.position, position, "image.style.position set correctly");
         t.eq( parseFloat(image.style.opacity), opacity, "image.style.opacity set correctly");
         t.eq( image.style.filter, filterString, "element.style.filter set correctly");
         //test defaults
@@ -369,7 +369,7 @@
             filterString = "progid:DXImageTransform.Microsoft.AlphaImageLoader(src='http://www.openlayers.org/images/OpenLayers.trac.png', sizingMethod='crop') alpha(opacity=50)";
         } else {
         t.eq( imageDiv.style.filter, filterString, "element.style.filter set correctly");
@@ -385,7 +385,7 @@
         } else {
@@ -437,7 +437,7 @@
         t.eq(parseFloat(element.style.opacity), opacity,
              "element.style.opacity set correctly when opacity = " + opacity);
         t.eq(element.style.filter, filterString,
              "element.style.filter set correctly when opacity = " + opacity);
@@ -447,7 +447,7 @@
              "element.style.opacity not changed if the value is incorrect");
              "element.style.filter not changed if the value is incorrect");
@@ -457,7 +457,7 @@
@@ -468,7 +468,7 @@
         t.eq(element.style.opacity, '',
              "element.style.opacity is removed when opacity = " + opacity);
-        var filterString = (OpenLayers.Util.getBrowserName() == 'safari') ? null : '';
+        var filterString = (OpenLayers.BROWSER_NAME == 'safari') ? null : '';
              "element.style.filter is removed when opacity = " + opacity);
@@ -498,18 +498,18 @@
         t.eq( element.style.position, position, "element.style.position set correctly");
           t.ok(element.style.borderTopWidth == s[0] && element.style.borderTopStyle == s[1], "good default popup.border")
         } else {
           t.ok( (element.style.border.indexOf(border) != -1), "element.style.border set correctly");
         t.eq( element.style[prop], overflow, "element.style.overflow set correctly");
         t.eq( parseFloat(element.style.opacity), opacity, "element.style.opacity set correctly");
         t.eq( element.style.filter, filterString, "element.style.filter set correctly");
@@ -553,7 +553,7 @@
             t.ok( true, "skipping element test outside of Mozilla");
         } else {
             t.ok( image.nodeName == "IMG", "createImage creates a valid HTMLImageElement" );
@@ -563,7 +563,7 @@
         } else {
Modified: sandbox/august/trunk/tests/list-tests-2.html
--- sandbox/august/trunk/tests/list-tests-2.html	2010-12-01 22:47:34 UTC (rev 10940)
+++ sandbox/august/trunk/tests/list-tests-2.html	2010-12-03 06:40:11 UTC (rev 10941)
@@ -1,15 +1,17 @@
 <ul id="testlist">
 	<li>Format/AgsJsAdapter.html</li>
     <li>Format/AgsJsAdapter_Renderer.html</li>
     <li>Format/WMTSCapabilities.html</li>
     <li>Format/WMTSCapabilities/v1_0_0.html</li>
     <li>Format/WFSTWithLock.html</li>
     <li>Format/WFSTWithLock/v1.html</li>
     <li>Format/WFSTWithLock/v1_0_0.html</li>
-    <li>Format/WFSTWithLock/v1_1_0.html</li>
+    <li>Format/WFSTWithLock/v1_1_0.html</li>
+    <li>Format/WPSCommon.html</li>
+    <li>Format/WPSCommon/v1_0_0.html</li>
     <li>Protocol/WFSTWithLock.html</li>
     <li>Strategy/SaveWithLock.html</li>
     <li>Strategy/Lock.html</li>
Modified: sandbox/august/trunk/tests/list-tests.html
--- sandbox/august/trunk/tests/list-tests.html	2010-12-01 22:47:34 UTC (rev 10940)
+++ sandbox/august/trunk/tests/list-tests.html	2010-12-03 06:40:11 UTC (rev 10941)
@@ -156,7 +156,10 @@
     <li>Map.html</li>
     <li>Marker.html</li>
     <li>Marker/Box.html</li>
-    <li>OpenLayers.html</li>
+    <li>OpenLayers1.html</li>
+    <li>OpenLayers2.html</li>
+    <li>OpenLayers3.html</li>
+    <li>OpenLayers4.html</li>
     <li>Popup.html</li>
     <li>Popup/Anchored.html</li>
     <li>Popup/AnchoredBubble.html</li>
Copied: sandbox/august/trunk/tests/manual/page-position.html (from rev 10940, trunk/openlayers/tests/manual/page-position.html)
--- sandbox/august/trunk/tests/manual/page-position.html	                        (rev 0)
+++ sandbox/august/trunk/tests/manual/page-position.html	2010-12-03 06:40:11 UTC (rev 10941)
@@ -0,0 +1,103 @@
+<!DOCTYPE HTML>
+<html>
+    <head>
+        <title>Page Position Test</title>
+        <link rel="stylesheet" href="../../theme/default/style.css" type="text/css" />
+        <link rel="stylesheet" href="../../examples/style.css" type="text/css" />
+        <style type="text/css">
+            #mapwrap {
+                border: 10px solid red;
+                width: 532px;
+                height: 276px;
+            #map {
+                position: absolute;
+                border: 10px solid #ccc;
+                width: 512px;
+                height: 256px;
+            #controlToggle li {
+                list-style: none;
+            p {
+                width: 512px;
+            #scrollspace {
+                height: 500px;
+        </style>
+        <script src="../../lib/OpenLayers.js"></script>
+            var map, drawControls;
+            function init(){
+                map = new OpenLayers.Map('map');
+                var wmsLayer = new OpenLayers.Layer.WMS( "OpenLayers WMS",
+                    "http://vmap0.tiles.osgeo.org/wms/vmap0?", {layers: 'basic'});
+                var lineLayer = new OpenLayers.Layer.Vector("Line Layer");
+                map.addLayers([wmsLayer, lineLayer]);
+                map.addControl(new OpenLayers.Control.LayerSwitcher());
+                map.addControl(new OpenLayers.Control.MousePosition());
+                drawControl = new OpenLayers.Control.DrawFeature(lineLayer,
+                                OpenLayers.Handler.Path);
+                map.addControl(drawControl);
+                map.setCenter(new OpenLayers.LonLat(0, 0), 3);
+                document.getElementById('noneToggle').checked = true;
+            function toggleControl(element) {
+                var control = drawControl;
+                if(element.value == "draw" && element.checked) {
+                } else {
+                    control.deactivate();
+        </script>
+    </head>
+    <body onload="init()">
+        <h1 id="title">OpenLayers Page Position Test</h1>
+        <p id="shortdesc">
+            Test if borders and scroll position cause unwanted offsets on the
+            mouse positions reported by map events.
+        </p>
+        <div id="mapwrap">
+            <div id="map"></div>
+        </div>
+        <ul id="controlToggle">
+            <li>
+                <input type="radio" name="type" value="none" id="noneToggle"
+                       onclick="toggleControl(this);" checked="checked" />
+                <label for="noneToggle">navigate</label>
+            </li>
+            <li>
+                <input type="radio" name="type" value="draw" id="lineToggle" onclick="toggleControl(this);" />
+                <label for="lineToggle">draw line</label>
+            </li>
+        </ul>
+        <div id="docs">
+            <p>This map's div has a border and absolute positioning, wrapped
+                by a container which also has a border. The page is also
+                scrollable. Neither the borders nor scrolling the page should
+                result in unwanted offsets on pixel positions reported by map
+                events.</p>
+            <p>With the line drawing control active, click on the map to add a
+                point.  The point should be drawn at the exact mouse location.</p>
+            <p>With the navigation control active, shift-drag a zoom rectangle.
+                The rectangle's corner should align exactly with the mouse
+                cursor.</p>
+            <p>Scroll the page and repeat the above tests.</p>
+            <div id="scrollspace"><div>
+        </div>
+    </body>
+</html>
Modified: sandbox/august/trunk/tests/run-tests-2.html
--- sandbox/august/trunk/tests/run-tests-2.html	2010-12-01 22:47:34 UTC (rev 10940)
+++ sandbox/august/trunk/tests/run-tests-2.html	2010-12-03 06:40:11 UTC (rev 10941)
@@ -1,7 +1,8 @@
 <!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01//EN" "http://www.w3.org/TR/html4/strict.dtd">
 <html><head><title> Run the testsuite</title>
 <noscript>Javascript is disabled in your browser. This page cannot be displayed correctly without Javascript. Sorry. <br/> If you want to view this page, please change your browser settings so that Javascript is enabled.</noscript>
-<script type="text/javascript" src="Format/AgsJsAdapter_Renderer.js"></script>
+<script type="text/javascript" src="Format/WPSCommon.js"></script>
+<script type="text/javascript" src="Format/WPSCommon/v1_0_0.js"></script>
 Test.AnotherWay version 0.5
Modified: sandbox/august/trunk/theme/default/style.css
--- sandbox/august/trunk/theme/default/style.css	2010-12-01 22:47:34 UTC (rev 10940)
+++ sandbox/august/trunk/theme/default/style.css	2010-12-03 06:40:11 UTC (rev 10941)
@@ -11,6 +11,7 @@
 div.olLayerDiv {
    -moz-user-select: none;
+   -khtml-user-select: none;
 .olLayerGoogleCopyright {
@@ -322,6 +323,7 @@
 .olControlNoSelect {
 .olImageLoadError {
Modified: sandbox/august/trunk/tools/mergejs.py
--- sandbox/august/trunk/tools/mergejs.py	2010-12-01 22:47:34 UTC (rev 10940)
+++ sandbox/august/trunk/tools/mergejs.py	2010-12-03 06:40:11 UTC (rev 10941)
@@ -94,6 +94,7 @@
         [exclude]
         3rd/logger.js
+        exclude/this/dir
     All headings are required.
@@ -122,6 +123,20 @@
         self.include =  lines[lines.index("[include]") + 1:lines.index("[exclude]")]
         self.exclude =  lines[lines.index("[exclude]") + 1:]
+def undesired(filepath, excludes):
+    # exclude file if listed
+    exclude = filepath in excludes
+    if not exclude:
+        # check if directory is listed
+        for excludepath in excludes:
+            if not excludepath.endswith("/"):
+                excludepath += "/"
+            if filepath.startswith(excludepath):
+                exclude = True
+                break
+    return exclude
 def run (sourceDirectory, outputFilename = None, configFile = None):
     cfg = None
     if configFile:
@@ -138,7 +153,7 @@
                 if cfg and cfg.include:
                     if filepath in cfg.include or filepath in cfg.forceFirst:
                         allFiles.append(filepath)
-                elif (not cfg) or (filepath not in cfg.exclude):
+                elif (not cfg) or (not undesired(filepath, cfg.exclude)):
     ## Header inserted at the start of each file in the output
More information about the Commits mailing list
