[OpenLayers-Commits] r10943 - in sandbox/august/trunk/playground:
outofbox wmts
commits-20090109 at openlayers.org
Fri Dec 3 01:53:55 EST 2010
Author: augusttown
Date: 2010-12-02 22:53:55 -0800 (Thu, 02 Dec 2010)
New Revision: 10943
Added:
sandbox/august/trunk/playground/outofbox/wmts-capabilities.html
sandbox/august/trunk/playground/outofbox/wmts-capabilities.js
sandbox/august/trunk/playground/outofbox/wmts.html
sandbox/august/trunk/playground/outofbox/wmts.js
sandbox/august/trunk/playground/wmts/jsapi-wmts-customized-tilingschema.html
sandbox/august/trunk/playground/wmts/jsapi-wmts-epsg3857.html
sandbox/august/trunk/playground/wmts/jsapi-wmts-wgs84.html
sandbox/august/trunk/playground/wmts/wmts-geowebcache-customized-tilingschema.html
sandbox/august/trunk/playground/wmts/wmts-geowebcache-customized-tilingschema.js
sandbox/august/trunk/playground/wmts/wmts-geowebcache-epsg3857.html
sandbox/august/trunk/playground/wmts/wmts-geowebcache-epsg3857.js
sandbox/august/trunk/playground/wmts/wmts-geowebcache-wgs84.html
sandbox/august/trunk/playground/wmts/wmts-geowebcache-wgs84.js
sandbox/august/trunk/playground/wmts/wmts2tileinfo.css
sandbox/august/trunk/playground/wmts/wmts2tileinfo.html
sandbox/august/trunk/playground/wmts/wmts2tileinfo.js
Removed:
sandbox/august/trunk/playground/wmts/wmts.html
sandbox/august/trunk/playground/wmts/wmts.js
Add new WMTS related samples and also delete deprecated ones.
Added: sandbox/august/trunk/playground/outofbox/wmts-capabilities.html
--- sandbox/august/trunk/playground/outofbox/wmts-capabilities.html (rev 0)
+++ sandbox/august/trunk/playground/outofbox/wmts-capabilities.html 2010-12-03 06:53:55 UTC (rev 10943)
@@ -0,0 +1,38 @@
+<!DOCTYPE html>
+<html>
+ <head>
+ <title>OpenLayers WMTS Capabilities Example</title>
+ <link rel="stylesheet" href="../../theme/default/style.css" type="text/css"/>
+ <link rel="stylesheet" href="../style.css" type="text/css" />
+ <script src="../../lib/Firebug/firebug.js"></script>
+ <script src="../../lib/OpenLayers.js"></script>
+ <script src="wmts-capabilities.js"></script>
+ <style>
+ .olControlAttribution {
+ bottom: 5px;
+ </style>
+ </head>
+ <body onload="init();">
+ <h1 id="title">Web Map Tile Service (WMTS) Capabilities Parsing</h1>
+ <p id="shortdesc">
+ The WMTS Capabilities format allows for parsing of capabilities
+ documents from OGC Web Map Tile Service (WMTS) version 1.0.0
+ implementations.
+ </p>
+ <div id="map" class="smallmap"></div>
+ <div id="docs">
+ <p>
+ This example creates an OpenLayers.Layer.WMTS layer to based
+ on the results of parsing a capabilities doc with the
+ OpenLayers.Format.WMTSCapabilities parser.
+ </p><p>
+ See the <a href="wmts-capabilities.js" target="_blank">
+ wmts-capabilities.js source</a> to see how this is done.
+ </p>
+ </div>
+ </body>
+</html>
Added: sandbox/august/trunk/playground/outofbox/wmts-capabilities.js
--- sandbox/august/trunk/playground/outofbox/wmts-capabilities.js (rev 0)
+++ sandbox/august/trunk/playground/outofbox/wmts-capabilities.js 2010-12-03 06:53:55 UTC (rev 10943)
@@ -0,0 +1,88 @@
+OpenLayers.ProxyHost = "/proxy/?url=";
+var map, format;
+function init() {
+ format = new OpenLayers.Format.WMTSCapabilities();
+ OpenLayers.Request.GET({
+ url: "http://v2.suite.opengeo.org/geoserver/gwc/service/wmts",
+ params: {
+ SERVICE: "WMTS",
+ VERSION: "1.0.0",
+ REQUEST: "GetCapabilities"
+ success: function(request) {
+ var doc = request.responseXML;
+ if (!doc || !doc.documentElement) {
+ doc = request.responseText;
+ var capabilities = format.read(doc);
+ var layer = createLayer(capabilities, {
+ layer: "medford:buildings",
+ matrixSet: "EPSG:900913",
+ format: "image/png",
+ opacity: 0.7,
+ isBaseLayer: false
+ map.addLayer(layer);
+ failure: function() {
+ alert("Trouble getting capabilities doc");
+ OpenLayers.Console.error.apply(OpenLayers.Console, arguments);
+ map = new OpenLayers.Map({
+ div: "map",
+ projection: "EPSG:900913",
+ units: "m",
+ maxExtent: new OpenLayers.Bounds(
+ -20037508.34, -20037508.34, 20037508.34, 20037508.34
+ maxResolution: 156543.0339
+ var osm = new OpenLayers.Layer.OSM();
+ map.addLayer(osm);
+ map.addControl(new OpenLayers.Control.LayerSwitcher());
+ map.setCenter(new OpenLayers.LonLat(-13677832, 5213272), 13);
+function createLayer(capabilities, config) {
+ var contents = capabilities.contents;
+ var matrixSet = contents.tileMatrixSets[config.matrixSet];
+ // find the layer definition with the given identifier
+ var layers = contents.layers;
+ var layer;
+ for (var i=0, ii=layers.length; i<ii; ++i) {
+ if (layers[i].identifier === config.layer) {
+ layer = layers[i];
+ break;
+ // get the default style for the layer
+ var style;
+ for (var i=0, ii=layer.styles.length; i<ii; ++i) {
+ style = layer.styles[i];
+ if (style.isDefault === "true") { // TODO: change this to boolean
+ break;
+ // create the layer
+ return new OpenLayers.Layer.WMTS(
+ OpenLayers.Util.applyDefaults(config, {
+ url: capabilities.operationsMetadata.GetTile.dcp.http.get,
+ name: layer.title,
+ style: style,
+ matrixIds: matrixSet.matrixIds
Added: sandbox/august/trunk/playground/outofbox/wmts.html
--- sandbox/august/trunk/playground/outofbox/wmts.html (rev 0)
+++ sandbox/august/trunk/playground/outofbox/wmts.html 2010-12-03 06:53:55 UTC (rev 10943)
@@ -0,0 +1,36 @@
+<!DOCTYPE html>
+<html>
+ <head>
+ <title>OpenLayers WMTS Example</title>
+ <script src="wmts.js"></script>
+ <style>
+ bottom: 5px;
+ </style>
+ </head>
+ <h1 id="title">Web Map Tile Service (WMTS) Layer</h1>
+ The WMTS layer allows viewing of tiles from a server implementing
+ the OGC Web Map Tile Service (WMTS) standard version 1.0.0.
+ </p>
+ <div id="map" class="bigmap"></div>
+ <div id="docs">
+ <p>
+ This example uses an OpenLayers.Layer.WMTS layer to display
+ cached tiles over an OSM layer in spherical mercator coordinates.
+ </p><p>
+ See the <a href="wmts.js" target="_blank">
+ wmts.js source</a> to see how this is done.
+ </p>
+ </div>
+ </body>
+</html>
Added: sandbox/august/trunk/playground/outofbox/wmts.js
--- sandbox/august/trunk/playground/outofbox/wmts.js (rev 0)
+++ sandbox/august/trunk/playground/outofbox/wmts.js 2010-12-03 06:53:55 UTC (rev 10943)
@@ -0,0 +1,40 @@
+var map;
+function init() {
+ div: "map",
+ units: "m",
+ // If tile matrix identifiers differ from zoom levels (0, 1, 2, ...)
+ // then they must be explicitly provided.
+ var matrixIds = new Array(26);
+ for (var i=0; i<26; ++i) {
+ matrixIds[i] = "EPSG:900913:" + i;
+ var wmts = new OpenLayers.Layer.WMTS({
+ name: "Medford Buildings",
+ url: "http://v2.suite.opengeo.org/geoserver/gwc/service/wmts/",
+ matrixIds: matrixIds,
+ style: "_null",
+ opacity: 0.7,
+ map.addLayers([osm, wmts]);
Added: sandbox/august/trunk/playground/wmts/jsapi-wmts-customized-tilingschema.html
--- sandbox/august/trunk/playground/wmts/jsapi-wmts-customized-tilingschema.html (rev 0)
+++ sandbox/august/trunk/playground/wmts/jsapi-wmts-customized-tilingschema.html 2010-12-03 06:53:55 UTC (rev 10943)
@@ -0,0 +1,112 @@
+<!DOCTYPE html PUBLIC "-//W3C//DTD HTML 4.01//EN" "http://www.w3.org/TR/html4/strict.dtd">
+<html lang="en">
+ <head>
+ <meta http-equiv="Content-Type" content="text/html; charset=utf-8">
+ <meta http-equiv="X-UA-Compatible" content="IE=7" />
+ <!--The viewport meta tag is used to improve the presentation and behavior of the samples on iOS devices-->
+ <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no" />
+ <title>Portland Tile Server</title>
+ <link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/2.1/js/dojo/dijit/themes/claro/claro.css">
+ <script type="text/javascript" src="http://serverapi.arcgisonline.com/jsapi/arcgis/?v=2.1"></script>
+ <script type="text/javascript">
+ dojo.require("esri.map");
+ function init() {
+ initLayer();
+ var map = new esri.Map("map");
+ map.addLayer(new ogc.WMTSLayer());
+ var lon = 7647130.2520;
+ var lat = 669087.0178;
+ var zoom = 1;
+ var crs = new esri.SpatialReference({wkid:2913});
+ map.centerAndZoom(
+ new esri.geometry.Point(lon, lat, crs),
+ zoom
+ function initLayer(){
+ dojo.declare("ogc.WMTSLayer", esri.layers.TiledMapServiceLayer, { // create WMTSLayer by extending esri.layers.TiledMapServiceLayer
+ constructor: function() {
+ this.spatialReference = new esri.SpatialReference({wkid:2913});
+ this.initialExtent = new esri.geometry.Extent(7241196.8729, 128656.7859, 9265592.9584, 981999.6828, this.spatialReference);
+ this.fullExtent = new esri.geometry.Extent(7241196.8729, 128656.7859, 9265592.9584, 981999.6828, this.spatialReference);
+ this.tileInfo = new esri.layers.TileInfo({
+ "rows": 256,
+ "cols": 256,
+ "dpi" : 96,
+ "format": "PNG",
+ "compressionQuality": 0,
+ "origin" : {
+ "x" : 7241196.8729,
+ "y" : 981999.6828
+ "spatialReference": {
+ "wkid" : 2913
+ "lods" : [
+ {"level" : 0, "resolution" : 2048000/(96*12), "scale" : 2048000.0},
+ {"level" : 1, "resolution" : 1024000/(96*12), "scale" : 1024000.0},
+ {"level" : 2, "resolution" : 512000/(96*12), "scale" : 512000.0},
+ {"level" : 3, "resolution" : 256000/(96*12), "scale" : 256000.0},
+ {"level" : 4, "resolution" : 128000/(96*12), "scale" : 128000.0},
+ {"level" : 5, "resolution" : 64000/(96*12), "scale" : 64000.0},
+ {"level" : 6, "resolution" : 32000/(96*12), "scale" : 32000.0},
+ {"level" : 7, "resolution" : 16000/(96*12), "scale" : 16000.0},
+ {"level" : 8, "resolution" : 8000/(96*12), "scale" : 8000.0},
+ {"level" : 9, "resolution" : 4000/(96*12), "scale" : 4000.0},
+ {"level" : 10,"resolution" : 2000/(96*12), "scale" : 2000.0},
+ {"level" : 0, "scale" : 2048000.0},
+ {"level" : 1, "scale" : 1024000.0},
+ {"level" : 2, "scale" : 512000.0},
+ {"level" : 3, "scale" : 256000.0},
+ {"level" : 4, "scale" : 128000.0},
+ {"level" : 5, "scale" : 64000.0},
+ {"level" : 6, "scale" : 32000.0},
+ {"level" : 7, "scale" : 16000.0},
+ {"level" : 8, "scale" : 8000.0},
+ {"level" : 9, "scale" : 4000.0},
+ {"level" : 10,"scale" : 2000.0},
+ {"level" : 0, "resolution" : 2048000/(96*12)},
+ {"level" : 1, "resolution" : 1024000/(96*12)},
+ {"level" : 2, "resolution" : 512000/(96*12)},
+ {"level" : 3, "resolution" : 256000/(96*12)},
+ {"level" : 4, "resolution" : 128000/(96*12)},
+ {"level" : 5, "resolution" : 64000/(96*12)},
+ {"level" : 6, "resolution" : 32000/(96*12)},
+ {"level" : 7, "resolution" : 16000/(96*12)},
+ {"level" : 8, "resolution" : 8000/(96*12)},
+ {"level" : 9, "resolution" : 4000/(96*12)},
+ {"level" : 10,"resolution" : 2000/(96*12)}
+ this.loaded = true;
+ this.onLoad(this);
+ getTileUrl: function(level, row, col) {
+ return "http://sazabiii:8080/geowebcache.10012010.snapshot/service/wmts"
+ + "?SERVICE=WMTS&VERSION=1.0.0&REQUEST=GetTile"
+ + "&LAYER=sazabiii.portland"
+ + "&STYLE="
+ + "&FORMAT=image/png"
+ + "&TILEMATRIXSET=sazabiii.portland.epsg2913"
+ + "&TILEMATRIX=sazabiii.portland.epsg2913." + level
+ + "&TILEROW=" + row
+ + "&TILECOL=" + col;
+ dojo.addOnLoad(init);
+ </script>
+ </head>
+ <body>
+ <div id="map" class="claro" style="width:512px;height:512px;border:1px solid #000;"></div>
+ </body>
+</html>
Added: sandbox/august/trunk/playground/wmts/jsapi-wmts-epsg3857.html
--- sandbox/august/trunk/playground/wmts/jsapi-wmts-epsg3857.html (rev 0)
+++ sandbox/august/trunk/playground/wmts/jsapi-wmts-epsg3857.html 2010-12-03 06:53:55 UTC (rev 10943)
@@ -0,0 +1,268 @@
+<html lang="en">
+ <head>
+ function init() {
+ initLayer();
+ this.spatialReference = new esri.SpatialReference({wkid:3857});
+ this.initialExtent = new esri.geometry.Extent(-20037508.342789, -20037508.342789, 20037508.342789, 20037508.342789, this.spatialReference);
+ this.fullExtent = new esri.geometry.Extent(-20037508.342789, -20037508.342789, 20037508.342789, 20037508.342789, this.spatialReference);
+ "rows": 256,
+ "cols": 256,
+ "dpi" : 96,
+ "format": "PNG",
+ "origin" : {
+ "x" : -20037508.342789,
+ "y" : 20037508.342789
+ "wkid" : 3857
+ "lods" : [
+ {"level" : 0, "resolution" : 156543.0339, "scale" : 5.590822639508929E8},
+ {"level" : 1, "resolution" : 78271.51695, "scale" : 2.7954113197544646E8},
+ {"level" : 2, "resolution" : 39135.758475, "scale" : 1.3977056598772323E8},
+ {"level" : 3, "resolution" : 19567.8792375, "scale" : 6.988528299386162E7},
+ {"level" : 4, "resolution" : 9783.93961875, "scale" : 3.494264149693081E7},
+ {"level" : 5, "resolution" : 4891.969809375, "scale" : 1.7471320748465404E7},
+ {"level" : 6, "resolution" : 2445.9849046875, "scale" : 8735660.374232702},
+ {"level" : 7, "resolution" : 1222.99245234375, "scale" : 4367830.187116351},
+ {"level" : 8, "resolution" : 611.496226171875, "scale" : 2183915.0935581755},
+ {"level" : 9, "resolution" : 305.7481130859375, "scale" : 1091957.5467790877},
+ {"level" : 10, "resolution" : 152.8740565429688, "scale" : 545978.7733895439},
+ {"level" : 11, "resolution" : 76.43702827148438, "scale" : 272989.38669477194},
+ {"level" : 12, "resolution" : 38.21851413574219, "scale" : 136494.69334738597},
+ {"level" : 13, "resolution" : 19.10925706787109, "scale" : 68247.34667369298},
+ {"level" : 14, "resolution" : 9.554628533935547, "scale" : 34123.67333684649},
+ {"level" : 15, "resolution" : 4.777314266967773, "scale" : 17061.836668423246},
+ {"level" : 16, "resolution" : 2.388657133483887, "scale" : 8530.918334211623}
+ // use tileinfo object generated by wmts2tileinfo
+ "dpi": "90.71428571427429",
+ "format": "image/png",
+ "wkid": "3857"
+ "rows": 256,
+ "cols": 256,
+ "origin": {
+ "x": -20037508.34,
+ "y": 20037508.34
+ "lods": [
+ "level": 0,
+ "scale": 559082263.9508929,
+ "resolution": 156543.0339062697
+ "level": 1,
+ "scale": 279541131.97544646,
+ "resolution": 78271.51695313485
+ "level": 2,
+ "scale": 139770565.98772323,
+ "resolution": 39135.758476567426
+ "level": 3,
+ "scale": 69885282.99386162,
+ "resolution": 19567.879238283713
+ "level": 4,
+ "scale": 34942641.49693081,
+ "resolution": 9783.939619141856
+ "level": 5,
+ "scale": 17471320.748465404,
+ "resolution": 4891.969809570928
+ "level": 6,
+ "scale": 8735660.374232702,
+ "resolution": 2445.984904785464
+ "level": 7,
+ "scale": 4367830.187116351,
+ "resolution": 1222.992452392732
+ "level": 8,
+ "scale": 2183915.0935581755,
+ "resolution": 611.496226196366
+ "level": 9,
+ "scale": 1091957.5467790877,
+ "resolution": 305.748113098183
+ "level": 10,
+ "scale": 545978.7733895439,
+ "resolution": 152.8740565490915
+ "level": 11,
+ "scale": 272989.38669477194,
+ "resolution": 76.43702827454575
+ "level": 12,
+ "scale": 136494.69334738597,
+ "resolution": 38.21851413727288
+ "level": 13,
+ "scale": 68247.34667369298,
+ "resolution": 19.10925706863644
+ "level": 14,
+ "scale": 34123.67333684649,
+ "resolution": 9.55462853431822
+ "level": 15,
+ "scale": 17061.836668423246,
+ "resolution": 4.77731426715911
+ "level": 16,
+ "scale": 8530.918334211623,
+ "resolution": 2.388657133579555
+ "level": 17,
+ "scale": 4265.4591671058115,
+ "resolution": 1.1943285667897774
+ "level": 18,
+ "scale": 2132.7295835529058,
+ "resolution": 0.5971642833948887
+ "level": 19,
+ "scale": 1066.3647917764529,
+ "resolution": 0.29858214169744435
+ "level": 20,
+ "scale": 533.1823958882264,
+ "resolution": 0.14929107084872217
+ "level": 21,
+ "scale": 266.5911979441132,
+ "resolution": 0.07464553542436109
+ "level": 22,
+ "scale": 133.2955989720566,
+ "resolution": 0.03732276771218054
+ "level": 23,
+ "scale": 66.6477994860283,
+ "resolution": 0.01866138385609027
+ "level": 24,
+ "scale": 33.32389974301415,
+ "resolution": 0.009330691928045136
+ "level": 25,
+ "scale": 16.661949871507076,
+ "resolution": 0.004665345964022568
+ "level": 26,
+ "scale": 8.330974935753538,
+ "resolution": 0.002332672982011284
+ "level": 27,
+ "scale": 4.165487467876769,
+ "resolution": 0.001166336491005642
+ "level": 28,
+ "scale": 2.0827437339383845,
+ "resolution": 0.000583168245502821
+ "level": 29,
+ "scale": 1.0413718669691923,
+ "resolution": 0.0002915841227514105
+ "level": 30,
+ "scale": 0.5206859334845961,
+ "resolution": 0.00014579206137570525
+ + "&LAYER=sazabiii.bluemarble"
+ + "&STYLE="
+ + "&TILEMATRIXSET=arcgisonline.epsg3857"
+ + "&TILEMATRIX=arcgisonline.epsg3857." + level
+ + "&STYLE="
+ + "&TILEMATRIX=arcgisonline.epsg3857."+ level
+ + "&TILEROW="+ row
+ + "&TILECOL="+ col;
+ </script>
+ </head>
+ <body>
+ <div id="map" class="claro" style="width:1024px;height:512px;border:1px solid #000;"></div>
+ </body>
+</html>
Added: sandbox/august/trunk/playground/wmts/jsapi-wmts-wgs84.html
--- sandbox/august/trunk/playground/wmts/jsapi-wmts-wgs84.html (rev 0)
+++ sandbox/august/trunk/playground/wmts/jsapi-wmts-wgs84.html 2010-12-03 06:53:55 UTC (rev 10943)
@@ -0,0 +1,145 @@
+<html lang="en">
+ <head>
+ function init() {
+ initLayer();
+ this.spatialReference = new esri.SpatialReference({wkid:4326});
+ this.initialExtent = new esri.geometry.Extent(-180.0, -90.0, 180.0, 90.0, this.spatialReference);
+ this.fullExtent = new esri.geometry.Extent(-180.0, -90.0, 180.0, 90.0, this.spatialReference);
+ "rows": 256,
+ "cols": 256,
+ "dpi" : 96,
+ "format": "PNG",
+ "origin" : {
+ "x" : -180.0,
+ "y" : 90.0
+ "wkid" : 4326
+ "lods" : [
+ {"level" : 0, "resolution" : 0.703125, "scale" : 295497598.570834},
+ {"level" : 1, "resolution" : 0.351562499999999, "scale" : 147748799.285417},
+ {"level" : 2, "resolution" : 0.17578125, "scale" : 73874399.6427087},
+ {"level" : 3, "resolution" : 0.0878906250000001, "scale" : 36937199.8213544},
+ {"level" : 4, "resolution" : 0.0439453125, "scale" : 18468599.9106772},
+ {"level" : 5, "resolution" : 0.02197265625, "scale" : 9234299.95533859},
+ {"level" : 6, "resolution" : 0.010986328125, "scale" : 4617149.97766929},
+ {"level" : 7, "resolution" : 0.0054931640625, "scale" : 2308574.98883465},
+ {"level" : 8, "resolution" : 0.00274658203124999, "scale" : 1154287.49441732},
+ {"level" : 9, "resolution" : 0.001373291015625, "scale" : 577143.747208662},
+ {"level" : 10, "resolution" : 0.0006866455078125, "scale" : 288571.873604331},
+ {"level" : 11, "resolution" : 0.000343322753906249, "scale" : 144285.936802165},
+ {"level" : 12, "resolution" : 0.000171661376953125, "scale" : 72142.9684010827},
+ {"level" : 13, "resolution" : 8.58306884765626E-05, "scale" : 36071.4842005414},
+ {"level" : 14, "resolution" : 4.29153442382813E-05, "scale" : 18035.7421002707},
+ {"level" : 15, "resolution" : 2.14576721191406E-05, "scale" : 9017.87105013534},
+ {"level" : 16, "resolution" : 1.07288360595703E-05, "scale" : 4508.93552506767}
+ // use the tileinfo object generated by wmts2tileinfo
+ "format": "PNG",
+ "wkid": "4326"
+ "rows": 256,
+ "cols": 256,
+ "origin": {
+ "x": -180,
+ "y": 90
+ "lods": [
+ "level": 0,
+ "scale": 279542134.48660713,
+ "resolution": 0.7031250070181514
+ "level": 1,
+ "scale": 139771067.24330357,
+ "resolution": 0.3515625035090757
+ "level": 2,
+ "scale": 69885533.62165178,
+ "resolution": 0.17578125175453785
+ "level": 3,
+ "scale": 34942766.81082589,
+ "resolution": 0.08789062587726892
+ "level": 4,
+ "scale": 17471383.405412946,
+ "resolution": 0.04394531293863446
+ "level": 5,
+ "scale": 8735691.702706473,
+ "resolution": 0.02197265646931723
+ "level": 6,
+ "scale": 4367845.8513532365,
+ "resolution": 0.010986328234658616
+ "level": 7,
+ "scale": 2183922.9256766182,
+ "resolution": 0.005493164117329308
+ + "&STYLE="
+ + "&TILEMATRIXSET=arcgisonline.epsg4326"
+ + "&TILEMATRIX=arcgisonline.epsg4326:" + level
+ </script>
+ </head>
+ <body>
+ </body>
+</html>
Added: sandbox/august/trunk/playground/wmts/wmts-geowebcache-customized-tilingschema.html
--- sandbox/august/trunk/playground/wmts/wmts-geowebcache-customized-tilingschema.html (rev 0)
+++ sandbox/august/trunk/playground/wmts/wmts-geowebcache-customized-tilingschema.html 2010-12-03 06:53:55 UTC (rev 10943)
@@ -0,0 +1,15 @@
+<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Strict//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-strict.dtd">
+<html xmlns="http://www.w3.org/1999/xhtml">
+ <head>
+ <title>OpenLayers (GeoWebCache) WMTS Example</title>
+ <script type="text/javascript" src="../../lib/Firebug/firebug.js"></script>
+ <script type="text/javascript" src="../../lib/OpenLayers.js"></script>
+ <script type="text/javascript" src="wmts-geowebcache-customized-tilingschema.js"></script>
+ </head>
+ <div id="map" class="mediummap"></div>
+ </body>
+</html>
Added: sandbox/august/trunk/playground/wmts/wmts-geowebcache-customized-tilingschema.js
--- sandbox/august/trunk/playground/wmts/wmts-geowebcache-customized-tilingschema.js (rev 0)
+++ sandbox/august/trunk/playground/wmts/wmts-geowebcache-customized-tilingschema.js 2010-12-03 06:53:55 UTC (rev 10943)
@@ -0,0 +1,223 @@
+var map = null;
+function init() {
+ OpenLayers.ProxyHost= function(url) {
+ return "/openlayers-trunk/ApacheProxyServlet?url=" + url;
+ // Portland
+ //var lon = -122.838493;
+ //var lat = 45.432976;
+ //var zoom = 9;
+ // Portland in EPSG:2913
+ var zoom = 1;
+ var options = {
+ //panMethod: null, // set 'panMethod' to null to disable animated panning
+ controls: [
+ new OpenLayers.Control.LayerSwitcher(),
+ new OpenLayers.Control.PanZoomBar(),
+ new OpenLayers.Control.Navigation(),
+ new OpenLayers.Control.MousePosition()
+ projection: "EPSG:2913",
+ units: "ft",
+ maxResolution: 2048000/(96*12),
+ numZoomLevels: 11, // default allowed zoom levels is 16 so change it to 20
+ maxExtent: new OpenLayers.Bounds(7241196.8729, 128656.7859, 9265592.9584, 981999.6828)
+ map = new OpenLayers.Map('map', options);
+ var url = "http://sazabiii:8080/geowebcache.10012010.snapshot/service/wmts";
+ //var url = "http://sazabi:8080/geowebcache-1.2.2/service/wmts";
+ //var url = "http://v2.suite.opengeo.org/geoserver/gwc/service/wmts/";
+ OpenLayers.loadURL(
+ url,
+ request: "GetCapabilities",
+ service: "WMTS",
+ version: "1.0.0"
+ this,
+ function(request) { // parse WMTS capabilities XML and create WMTS layer
+ // add the WMS layer as base layer, WMTS and AgsTiled are overlay on top to see if match
+ // GeoWebCacge WMTS layer actually points to the same WMS at back-end
+ var agsWmsLayer = new OpenLayers.Layer.WMS(
+ "arcgisserver wms",
+ "http://sazabiii/arcgis/services/playground/portland2913/MapServer/WMSServer?",
+ layers: '1,2,3,5,6,7,8,10,11,12,13,15,16,17,18,19,20,21,22,24,25,26,27,28,29',
+ styles: "",
+ transparency: false
+ singleTile: false,
+ isBaseLayer: true,
+ buffer: 0,
+ tileSize: new OpenLayers.Size(256, 256)
+ //tileOrigin: new OpenLayers.LonLat(7241196.8729, 981999.6828)
+ //agsWmsLayer.setOpacity(0.72);
+ //agsWmsLayer.setVisibility(false);
+ map.addLayer(agsWmsLayer);
+ // parse WMTS capabilities and add a WMTS layer in the same map
+ var format = new OpenLayers.Format.WMTSCapabilities();
+ var capabilities = format.read(request.responseXML || request.responseText);
+ var tileMatrixSet = "sazabiii.portland.epsg2913";
+ // collect identifiers of tileMatrix from a tileMatrixSet
+ var matrixIds = [];
+ var numOfTileMatrixSet = capabilities.contents.tileMatrixSets[tileMatrixSet].matrixIds.length;
+ for (var i=0; i<numOfTileMatrixSet; ++i) {
+ matrixIds[i] = capabilities.contents.tileMatrixSets[tileMatrixSet].matrixIds[i].identifier;
+ var gwcWmtsLayer = new OpenLayers.Layer.WMTS({
+ // general Grid layer options
+ name: "geowebcache wmts",
+ url: url,
+ isBaseLayer: false,
+ // WMTS layer options
+ layer: "sazabiii.portland",
+ style: "_null",
+ matrixSet: tileMatrixSet,
+ requestEncoding: "KVP",
+ tileSize: new OpenLayers.Size(256, 256),
+ // optional
+ tileFullExtent: new OpenLayers.Bounds(7241196.8729, 128656.7859, 9265592.9584, 981999.6828),
+ // optional
+ tileOrigin: new OpenLayers.LonLat(7241196.8729, 981999.6828)
+ gwcWmtsLayer.setOpacity(0.72);
+ gwcWmtsLayer.setVisibility(false);
+ map.addLayer(gwcWmtsLayer);
+ map.setCenter(new OpenLayers.LonLat(lon, lat), zoom);
+ // add the AgsTiled layer from the same ArcGIS Server map service on which the base WMS layer is from
+ var agsTiledlayer = new OpenLayers.Layer.AgsTiled(
+ "ags tiled",
+ "http://sazabiii/ArcGIS/rest/services/playground/portland2913tiled/MapServer/tile/",
+ tileFormat:'png',
+ tileOrigin: new OpenLayers.LonLat(7241196.8729, 981999.6828),
+ buffer: 0,
+ singleTile: false
+ agsTiledlayer.setOpacity(0.72);
+ agsTiledlayer.setVisibility(false);
+ map.addLayer(agsTiledlayer);
+// the same map and layers but in EPSG:2838 which is basically EPSG:2913 in meter instead of feet
+var map = null;
+function init() {
+ // Portland
+ //var zoom = 9;
+ //var lon = 7647130.2520;
+ //var lat = 669087.0178;
+ //var zoom = 0;
+ // Portland in EPSG:2838
+ var lon = 7647130.2520*0.3048;
+ var lat = 669087.0178*0.3048;
+ var zoom = 3;
+ var options = {
+ controls: [
+ projection: "EPSG:2838",
+ units: "m",
+ maxResolution: (0.3048*2048000)/(96*12),
+ maxExtent: new OpenLayers.Bounds(2207116.806860, 39214.588342, 2824152.733720, 299313.503317)
+ url,
+ service: "WMTS",
+ version: "1.0.0"
+ this,
+ var tileMatrixSet = "sazabiii.portland.epsg2838";
+ url: url,
+ style: "_null",
+ // optional
+ tileFullExtent: new OpenLayers.Bounds(2207116.806860, 39214.588342, 2824152.733720, 299313.503317),
+ // optional
+ tileOrigin: new OpenLayers.LonLat(2207116.806860, 299313.503317)
+ //gwcWmtsLayer.setOpacity(0.8);
Added: sandbox/august/trunk/playground/wmts/wmts-geowebcache-epsg3857.html
--- sandbox/august/trunk/playground/wmts/wmts-geowebcache-epsg3857.html (rev 0)
+++ sandbox/august/trunk/playground/wmts/wmts-geowebcache-epsg3857.html 2010-12-03 06:53:55 UTC (rev 10943)
@@ -0,0 +1,15 @@
+ <head>
+ <script type="text/javascript" src="wmts-geowebcache-epsg3857.js"></script>
+ </head>
+ </body>
+</html>
Added: sandbox/august/trunk/playground/wmts/wmts-geowebcache-epsg3857.js
--- sandbox/august/trunk/playground/wmts/wmts-geowebcache-epsg3857.js (rev 0)
+++ sandbox/august/trunk/playground/wmts/wmts-geowebcache-epsg3857.js 2010-12-03 06:53:55 UTC (rev 10943)
@@ -0,0 +1,146 @@
+var map = null;
+function init() {
+ // San Francisco
+ //var lon = -122.391667;
+ //var lat = 37.760628;
+ //var zoom = 5;
+ // Portland
+ var lon = -122.838493;
+ var lat = 45.432976;
+ var zoom = 9;
+ var options = {
+ controls: [
+ units: "m",
+ maxResolution: 156543.0339,
+ numZoomLevels: 20, // default allowed zoom levels is 16 so change it to 20
+ maxExtent: new OpenLayers.Bounds(-20037508.34, -20037508.34, 20037508.34, 20037508.34)
+ var base_layer = new OpenLayers.Layer.AgsTiled(
+ "World Topo Map",
+ "http://server.arcgisonline.com/ArcGIS/rest/services/World_Topo_Map/MapServer/tile/",
+ //"World Imagery Map",
+ //"http://server.arcgisonline.com/ArcGIS/rest/services/World_Imagery/MapServer/tile/",
+ tileSize: new OpenLayers.Size(256,256),
+ tileFormat:'jpg',
+ tileOrigin: new OpenLayers.LonLat(-20037508.342789, 20037508.342789),
+ tileFullExtent: new OpenLayers.Bounds(-20037508.34, -20037508.34, 20037508.34, 20037508.34),
+ singleTile: false
+ // OSM base layer
+ //var base_layer = new OpenLayers.Layer.OSM();
+ map.addLayer(base_layer);
+ // transform lon/lat to coordinate in EPSG:900913
+ map.setCenter(
+ new OpenLayers.LonLat(lon, lat).transform(
+ new OpenLayers.Projection("EPSG:4326"),
+ map.getProjectionObject()
+ zoom
+ // add a WMTS by manually configure the tileMatrixSet and matrixIds
+ // in this case you don't need to load and parse capabilities file
+ var _tileMatrixSet = "arcgisonline.epsg3857";
+ var _matrixIds = [];
+ for (var j=0; j<31; ++j) {
+ _matrixIds[j] = "arcgisonline.epsg3857." + j;
+ var _gwcWmtsLayer = new OpenLayers.Layer.WMTS({
+ name: "gwc wmts w/o capa",
+ url: url,
+ // you can choose different layers
+ //layer: "sazabiii.bluemarble",
+ style: "_null",
+ matrixSet: _tileMatrixSet,
+ matrixIds: _matrixIds,
+ // optional
+ // optional
+ tileOrigin: new OpenLayers.LonLat(-20037508.34, 20037508.34)
+ _gwcWmtsLayer.setOpacity(0.8);
+ _gwcWmtsLayer.setVisibility(false);
+ map.addLayer(_gwcWmtsLayer);
+ url,
+ service: "WMTS",
+ version: "1.0.0"
+ this,
+ // by parsing the capa, app developers know what tileMatrixSet are available
+ // such that people can choose one of them
+ var tileMatrixSet = "arcgisonline.epsg3857";
+ name: "gwc wmts w capa",
+ url: url,
+ style: "_null",
+ // optional
+ // optional
+ gwcWmtsLayer.setOpacity(0.8);
Added: sandbox/august/trunk/playground/wmts/wmts-geowebcache-wgs84.html
--- sandbox/august/trunk/playground/wmts/wmts-geowebcache-wgs84.html (rev 0)
+++ sandbox/august/trunk/playground/wmts/wmts-geowebcache-wgs84.html 2010-12-03 06:53:55 UTC (rev 10943)
@@ -0,0 +1,15 @@
+ <head>
+ <script type="text/javascript" src="wmts-geowebcache-wgs84.js"></script>
+ </head>
+ </body>
+</html>
Added: sandbox/august/trunk/playground/wmts/wmts-geowebcache-wgs84.js
--- sandbox/august/trunk/playground/wmts/wmts-geowebcache-wgs84.js (rev 0)
+++ sandbox/august/trunk/playground/wmts/wmts-geowebcache-wgs84.js 2010-12-03 06:53:55 UTC (rev 10943)
@@ -0,0 +1,113 @@
+var map = null;
+function init() {
+ // San Francisco
+ var lon = -122.391667;
+ var lat = 37.760628;
+ var zoom = 3;
+ var lon = 0.0;
+ var lat = 0.0;
+ var zoom = 2;
+ var options = {
+ controls: [
+ new OpenLayers.Control.PanZoom(),
+ projection: "EPSG:4326",
+ //maxResolution: 1.40625,
+ maxResolution: 0.703125,
+ maxExtent: new OpenLayers.Bounds(-180.0, -90.0, 180.0, 90.0)
+ var _tileMatrixSet = "arcgisonline.epsg4326";
+ _matrixIds[j] = "arcgisonline.epsg4326:" + j;
+ url: url,
+ layer: "sazabiii.bluemarble",
+ style: "_null",
+ // optional
+ tileFullExtent: new OpenLayers.Bounds(-180.0, -90.0, 180.0, 90.0),
+ // optional
+ tileOrigin: new OpenLayers.LonLat(-180.0, 90.0)
+ //_gwcWmtsLayer.setOpacity(0.72);
+ url,
+ service: "WMTS",
+ version: "1.0.0"
+ this,
+ var tileMatrixSet = "arcgisonline.epsg4326";
+ url: url,
+ style: "_null",
+ // optional
+ // optional
Deleted: sandbox/august/trunk/playground/wmts/wmts.html
--- sandbox/august/trunk/playground/wmts/wmts.html 2010-12-03 06:50:18 UTC (rev 10942)
+++ sandbox/august/trunk/playground/wmts/wmts.html 2010-12-03 06:53:55 UTC (rev 10943)
@@ -1,15 +0,0 @@
-<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Strict//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-strict.dtd">
-<html xmlns="http://www.w3.org/1999/xhtml">
- <head>
- <title>OpenLayers WMTS Example</title>
- <link rel="stylesheet" href="../../theme/default/style.css" type="text/css"/>
- <link rel="stylesheet" href="../style.css" type="text/css" />
- <script type="text/javascript" src="../../lib/Firebug/firebug.js"></script>
- <script type="text/javascript" src="../../lib/OpenLayers.js"></script>
- <script type="text/javascript" src="wmts.js"></script>
- </head>
- <body onload="init();">
- <div id="map" class="bigmap"></div>
- </body>
-</html>
Deleted: sandbox/august/trunk/playground/wmts/wmts.js
--- sandbox/august/trunk/playground/wmts/wmts.js 2010-12-03 06:50:18 UTC (rev 10942)
+++ sandbox/august/trunk/playground/wmts/wmts.js 2010-12-03 06:53:55 UTC (rev 10943)
@@ -1,101 +0,0 @@
-var map = null;
-function init() {
- OpenLayers.ProxyHost= "/openlayers-trunk/ApacheProxyServlet?resourceUrl=";
- var lon = -97.0;
- var lat = 38.0;
- var zoom = 1;
- var options = {
- controls: [
- new OpenLayers.Control.LayerSwitcher(),
- new OpenLayers.Control.Navigation(),
- new OpenLayers.Control.PanZoom()
- projection: "EPSG:4326",
- maxResolution: 0.3515625,
- //maxResolution: 1.40625,
- maxExtent: new OpenLayers.Bounds(-180, -90, 180, 90)
- map = new OpenLayers.Map('map', options);
- var agsTiledLayer0 = new OpenLayers.Layer.WMTS(
- "Blue Marble WMTS",
- "http://zeon/wmts/",
- layer: "world",
- style: "blue_marble",
- tilematrixset: "arcgis_online",
- format: "image/jpeg"
- tileSize: new OpenLayers.Size(512, 512),
- tileOrigin: new OpenLayers.LonLat(-180, 90),
- tileFullExtent: new OpenLayers.Bounds(-180, -90, 180, 90),
- isBaseLayer: true,
- singleTile: false,
- requestEncoding: "REST"
- map.addLayer(agsTiledLayer0);
- var agsTiledLayer1 = new OpenLayers.Layer.WMTS(
- "ESRI StreetMap WMTS",
- layer: "world",
- style: "esri_street",
- tileFormatSuffix:'jpg',
- requestEncoding: "REST",
- map.addLayer(agsTiledLayer1);
- map.setCenter(new OpenLayers.LonLat(lon, lat), zoom);
- var url = "http://sazabi:8080/geowebcache-1.2.2/service/wmts/";
- var tileMatrixSet = "arcgis-online-wgs84";
- OpenLayers.loadURL(
- url,
- { request: "GetCapabilities",service: "WMTS",version: "1.0.0" },
- this,
- function(request) {
- var format = new OpenLayers.Format.WMTSCapabilities();
- var capabilities = format.read(request.responseXML || request.responseText);
- var gwcWmtsLayer0 = new OpenLayers.Layer.WMTS(
- "GeoWebCache USA WMTS",
- url,
- layer: "arcgis-online-wms",
- style: "",
- tilematrixset: tileMatrixSet,
- format: "image/png"
- isBaseLayer: false,
- // WMTS specific options
- requestEncoding: "KVP",
- tileMatrics: capabilities.contents.tileMatrixSets[tileMatrixSet].tileMatrics,
- gwcWmtsLayer0.setOpacity(0.49);
- map.addLayer(gwcWmtsLayer0);
Added: sandbox/august/trunk/playground/wmts/wmts2tileinfo.css
--- sandbox/august/trunk/playground/wmts/wmts2tileinfo.css (rev 0)
+++ sandbox/august/trunk/playground/wmts/wmts2tileinfo.css 2010-12-03 06:53:55 UTC (rev 10943)
@@ -0,0 +1,9 @@
+.standardinput {
+ width: 512px;
+ border: 1px solid #666;
+.standard {
+ font-family: "Lucida Grande", Verdana, Geneva, Lucida, Arial, Helvetica, sans-serif;
+ font-size: 80%;
+ color: #666;
Added: sandbox/august/trunk/playground/wmts/wmts2tileinfo.html
--- sandbox/august/trunk/playground/wmts/wmts2tileinfo.html (rev 0)
+++ sandbox/august/trunk/playground/wmts/wmts2tileinfo.html 2010-12-03 06:53:55 UTC (rev 10943)
@@ -0,0 +1,126 @@
+ <head>
+ <title>wmts2tileinfo</title>
+ <link rel="stylesheet" href="wmts2tileinfo.css" type="text/css" />
+ <script type="text/javascript" src="http://august-openlayers.appspot.com/openlayers/trunk+/OpenLayers.js"></script>
+ <script type="text/javascript" src="wmts2tileinfo.js"></script>
+ </head>
+ <div id="url_input_div">
+ <table class="standard">
+ <tr>
+ <td valign="top"><b>WMTS URL: </b></td>
+ <td valign="top"><input id="url_input" type="text" value="http://sazabiii:8080/geowebcache.10012010.snapshot/service/wmts" class="standardinput"></input></td>
+ <td valign="top">
+ <input type="button" value="Connect" onclick="loadWmtsUrl();"></input>
+ <b>Step 1: Type in WMTS URL and Click "Connect";</b>
+ </td>
+ </tr>
+ <tr>
+ <td valign="top"><b>Layers: </b></td>
+ <td valign="top">
+ <select name="layers" id="layers_select" size="5" class="standardinput" onchange="updateTilingSchemaList();"></select>
+ </td>
+ <td valign="top"> <b>Step 2: Select a WMTS Layer;</b></td>
+ </tr>
+ <tr>
+ <td valign="top"><b>TileMatrixSet: </b></td>
+ <td valign="top">
+ <select name="tilingschema" id="tilingschema_select" size="5" class="standardinput" onchange="updateSupportedCRS();"></select>
+ </td>
+ <td valign="top"> <b>Step 2: Select a WMTS TileMatrix (Tiling Schema);</b></td>
+ </tr>
+ <tr>
+ <td valign="top"><b>TileMatrix: </b></td>
+ <td valign="top">
+ <select name="tilematrix" id="tilematrix_select" size="5" class="standardinput" onchange="updateSupportedCRS();"></select>
+ </td>
+ <td valign="top"> <b>Step 3: You don't need to select, but pay attention to how tile matrix are named e.g.
+ {tileMatrixSet}:{level}, {tileMatrixSet}.{level}, etc; you may need to adjust that in getTileUrl function at the end.</b></td>
+ </tr>
+ <tr>
+ <td valign="top"><b>Tile Full Extent: </b></td>
+ <td valign="top">
+ <input id="tilefullextent_input" type="text" value="UNKNOWN" class="standardinput" disabled="true">
+ </td>
+ <td valign="top"> </td>
+ </tr>
+ <tr>
+ <td valign="top"><b>Supported CRS: </b></td>
+ <td valign="top">
+ <input id="supportedcrs_input" type="text" value="UNKNOWN" class="standardinput" disabled="true"></input>
+ </td>
+ </tr>
+ <tr>
+ <td valign="top"><b>DPI: </b></td>
+ <td valign="top">
+ <select name="dpi" id="dpi_select" size="1" class="standardinput">
+ <option value="90.71428571427429" selected="true">0.28mm (90.714 DPI)</option>
+ <option value="96">96</option>
+ </select>
+ </td>
+ <td valign="top"> <b>Step 4: Select 0.28mm (90.714 DPI) for most WMTS UNLESS you're sure it's 96 DPI</b></td>
+ </tr>
+ <tr>
+ <td valign="top"><b>Format: </b></td>
+ <td valign="top">
+ <select name="format" id="format_select" size="1" class="standardinput">
+ <option value="image/png" selected="true">PNG</option>
+ <option value="image/jpg">JPG</option>
+ </select>
+ </td>
+ <td valign="top"> <b>Step 5: Select tile format</b></td>
+ </tr>
+ <tr>
+ <td valign="top"><b>Unit: </b></td>
+ <td valign="top">
+ <select name="unit" id="unit_select" size="1" class="standardinput">
+ <option value="Meter" selected="true">Meter</option>
+ <option value="Feet">Feet</option>
+ <option value="Degree">Degree</option>
+ </select>
+ </td>
+ <td valign="top"> <b>Step 6: Select Map unit;</b></td>
+ </tr>
+ <tr>
+ <td valign="top"><b>Axis Order: </b></td>
+ <td valign="top">
+ <select name="unit" id="axisorder_select" size="1" class="standardinput">
+ <option value="lonlat" selected="true">Lon/Lat</option>
+ <option value="latlon">Lat/Lon</option>
+ </select>
+ </td>
+ <td valign="top"> <b>Step 7: Adjust lon/lat or lat/lon order of tile origin</b></td>
+ </tr>
+ <tr>
+ <td valign="top"><b>TileInfo Object: </b></td>
+ <td valign="top">
+ <textarea id="tileinfo_textarea" rows="25" cols="20" class="standardinput">
+ </textarea>
+ </td>
+ <td valign="top">
+ <input type="button" value="wmts2tileinfo" onclick="wmts2tileinfo();"></input>
+ <input type="button" value="cleanup" onclick="cleanup();"></input>
+ <b>Step 10: Click "wmts2tileinfo" to generate ArcGIS JavaScript API code</b>
+ </td>
+ </tr>
+ <tr>
+ <td valign="top"><b>getTileUrl Function: </b></td>
+ <td valign="top">
+ <textarea id="gettileurl_textarea" rows="10" cols="20" class="standardinput">
+ </textarea>
+ </td>
+ <td valign="top"> <b>You may need to adjust "...&TILEMATRIX=..." in getTileUrl() according to step 3</b></td>
+ </tr>
+ </table>
+ </div>
+ </body>
+</html>
Added: sandbox/august/trunk/playground/wmts/wmts2tileinfo.js
--- sandbox/august/trunk/playground/wmts/wmts2tileinfo.js (rev 0)
+++ sandbox/august/trunk/playground/wmts/wmts2tileinfo.js 2010-12-03 06:53:55 UTC (rev 10943)
@@ -0,0 +1,216 @@
+var _capabilities;
+var _tileMatrixSets;
+var _layers;
+var _generatedCode = "";
+var _pixelPerUnit = {
+ 'Meter': (1/(12))*0.3048,
+ 'Feet': 1/(12),
+ 'Degree': (1/(12*111319.8888888889))*0.3048
+function init() {
+ cleanup();
+function loadWmtsUrl() {
+ // WMTS end point url
+ //var url = "http://sazabiii:8080/geowebcache.10012010.snapshot/service/wmts";
+ var url = document.getElementById("url_input").value;
+ url,
+ service: "WMTS",
+ version: "1.0.0"
+ this,
+ _capabilities = format.read(request.responseXML || request.responseText);
+ _tileMatrixSets = _capabilities.contents.tileMatrixSets;
+ _layers = _capabilities.contents.layers;
+ var layers_select = document.getElementById("layers_select");
+ for(var i=0; i<_layers.length; i++) {
+ var layer = _layers[i];
+ var layerOpt = document.createElement("option");
+ layerOpt.setAttribute("value", layer.identifier);
+ var text = document.createTextNode(layer.identifier);
+ layerOpt.appendChild(text);
+ layers_select.appendChild(layerOpt);
+ layers_select.onchange = function() {
+ var tilingschema_select = document.getElementById("tilingschema_select");
+ var oldListLength = tilingschema_select.options.length
+ for(var k=0; k<oldListLength; k++) {
+ tilingschema_select.remove(0);
+ var selectedLayerId = getSelectedOptionValue("layers_select");
+ if(layer.identifier == selectedLayerId) {
+ for(var j=0; j<layer.tileMatrixSetLinks.length; j++) {
+ var tileMatrixSet = layer.tileMatrixSetLinks[j];
+ var tilingSchemaOpt = document.createElement("option");
+ tilingSchemaOpt.setAttribute("value", tileMatrixSet.tileMatrixSet);
+ var text = document.createTextNode(tileMatrixSet.tileMatrixSet);
+ tilingSchemaOpt.appendChild(text);
+ tilingschema_select.appendChild(tilingSchemaOpt);
+function wmts2tileinfo() {
+ if(tilingschema_select.options.length <= 0) {
+ alert("...invalid tiling schema...");
+ return;
+ var selectedIdx = -1;
+ for(var i=0; i<tilingschema_select.options.length; i++) {
+ if(tilingschema_select.options[i].selected == true) {
+ selectedIdx = i;
+ if(selectedIdx < 0) {
+ alert("...select tiling schema...");
+ return;
+ } else {
+ var tileMatrixSetId = tilingschema_select.options[selectedIdx].value;
+ if(_capabilities) {
+ var EsriTileInfoObj = {};
+ EsriTileInfoObj.dpi = getSelectedOptionValue("dpi_select"); // WMTS capabilities does provide DPI
+ OpenLayers.Console.debug("...dpi: " + EsriTileInfoObj.dpi);
+ EsriTileInfoObj.format = getSelectedOptionValue("format_select"); // WMTS capabilities does provide DPI
+ OpenLayers.Console.debug("...format: " + EsriTileInfoObj.format);
+ EsriTileInfoObj.compressionQuality = 0;
+ var tileMatrixSet = _capabilities.contents.tileMatrixSets[tileMatrixSetId];
+ // supportedCRS has syntax like 'urn:ogc:def:crs:EPSG::4326'
+ var supportedCRSTokens = tileMatrixSet.supportedCRS.split(":");
+ var supportedCRS = supportedCRSTokens[supportedCRSTokens.length-1];
+ EsriTileInfoObj.spatialReference = {};
+ EsriTileInfoObj.spatialReference.wkid = supportedCRS;
+ // take the tile origin and tile width/height of the first tileMatrix
+ var tileWidth = tileMatrixSet.matrixIds[0].tileWidth;
+ OpenLayers.Console.debug("...tile width: " + tileWidth);
+ var tileHeight = tileMatrixSet.matrixIds[0].tileHeight;
+ OpenLayers.Console.debug("...tile height: " + tileHeight);
+ EsriTileInfoObj.rows = tileWidth;
+ EsriTileInfoObj.cols = tileHeight;
+ var axisorder = getSelectedOptionValue("axisorder_select");
+ if(axisorder == "latlon") {
+ var x = tileMatrixSet.matrixIds[0].topLeftCorner.lat;
+ var y = tileMatrixSet.matrixIds[0].topLeftCorner.lon;
+ } else {
+ var x = tileMatrixSet.matrixIds[0].topLeftCorner.lon;
+ var y = tileMatrixSet.matrixIds[0].topLeftCorner.lat;
+ EsriTileInfoObj.origin = {};
+ EsriTileInfoObj.origin.x = x;
+ EsriTileInfoObj.origin.y = y;
+ EsriTileInfoObj.lods = [];
+ var unit = getSelectedOptionValue("unit_select");
+ for(var i=0; i<tileMatrixSet.matrixIds.length; i++) {
+ var lod = {};
+ lod.level = i;
+ lod.scale = tileMatrixSet.matrixIds[i].scaleDenominator;
+ lod.resolution = (lod.scale*_pixelPerUnit[unit])/EsriTileInfoObj.dpi;
+ OpenLayers.Console.debug(lod.resolution + " " + lod.scale);
+ EsriTileInfoObj.lods.push(lod);
+ var encoder = new OpenLayers.Format.JSON();
+ var json = encoder.write(EsriTileInfoObj, true);
+ OpenLayers.Console.debug(json);
+ document.getElementById("tileinfo_textarea").value =
+ "this.tileInfo = new esri.layers.TileInfo("
+ + json
+ document.getElementById("gettileurl_textarea").value =
+ "function(level, row, col) {" + "\n"
+ + " " + "return "
+ + "\"" + document.getElementById("url_input").value + "\"" + "\n"
+ + " " + "+ " + "\"?SERVICE=WMTS&VERSION=1.0.0&REQUEST=GetTile\"" + "\n"
+ + " " + "+ " + "\"&LAYER=" + getSelectedOptionValue("layers_select") + "\"" + "\n"
+ + " " + "+ " + "\"&STYLE=" + "\"" + "\n"
+ + " " + "+ " + "\"&FORMAT=" + getSelectedOptionValue("format_select") + "\"" + "\n"
+ + " " + "+ " + "\"&TILEMATRIXSET=" + getSelectedOptionValue("tilingschema_select") + "\"" + "\n"
+ + " " + "+ " + "\"&TILEMATRIX=" + getSelectedOptionValue("tilingschema_select") + ":\"" + "+ level " + "\n"
+ + " " + "+ " + "\"&TILEROW=" + "\"" + "+ row" + "\n"
+ + " " + "+ " + "\"&TILECOL=" + "\"" + "+ col;" + "\n"
+function updateSupportedCRS() {
+ var tileMatrixSetId = getSelectedOptionValue("tilingschema_select");
+ document.getElementById("supportedcrs_input").value = tileMatrixSet.supportedCRS;
+ if(tileMatrixSet.BoundingBox) {
+ // TODO:
+ //document.getElementById("tilefullextent_input").value
+ var oldListLength = document.getElementById("tilematrix_select").options.length
+ document.getElementById("tilematrix_select").remove(0);
+ var tileMatrix = tileMatrixSet.matrixIds[i];
+ var tileMatrixOpt = document.createElement("option");
+ tileMatrixOpt.setAttribute("value", tileMatrix.identifier);
+ var text = document.createTextNode(tileMatrix.identifier);
+ tileMatrixOpt.appendChild(text);
+ document.getElementById("tilematrix_select").appendChild(tileMatrixOpt);
+function cleanup() {
+ if(document.getElementById("layers_select").selectedIndex>=0) {
+ document.getElementById("layers_select").options[document.getElementById("layers_select").selectedIndex].selected = false;
+ if(document.getElementById("tilingschema_select").selectedIndex>=0) {
+ document.getElementById("tilingschema_select").options[document.getElementById("tilingschema_select").selectedIndex].selected = false;
+ document.getElementById("tilefullextent_input").value = "UNKNOWN";
+ document.getElementById("supportedcrs_input").value = "UNKNOWN";
+ document.getElementById("tileinfo_textarea").value = "";
+ document.getElementById("gettileurl_textarea").value = "";
+ document.getElementById("dpi_select").options[0].selected = true;
+ document.getElementById("format_select").options[0].selected = true;
+ document.getElementById("unit_select").options[0].selected = true;
+ document.getElementById("axisorder_select").options[0].selected = true;
+function getSelectedOptionValue(id) {
+ var element = document.getElementById(id);
+ if(element.selectedIndex >= 0) {
+ return element.options[element.selectedIndex].value;
+ } else {
+ return "";
\ No newline at end of file
More information about the Commits
