[OpenLayers-Commits] r10950 - in
sandbox/camptocamp/ifremer/openlayers/build: . closurecompiler
commits-20090109 at openlayers.org
Mon Dec 6 06:29:40 EST 2010
Author: fvanderbiest
Date: 2010-12-06 03:29:40 -0800 (Mon, 06 Dec 2010)
New Revision: 10950
Added:
sandbox/camptocamp/ifremer/openlayers/build/closurecompiler/
sandbox/camptocamp/ifremer/openlayers/build/closurecompiler/COPYING
sandbox/camptocamp/ifremer/openlayers/build/closurecompiler/README
sandbox/camptocamp/ifremer/openlayers/build/closurecompiler/compiler.jar
sandbox/camptocamp/ifremer/openlayers/build/makeOL
sandbox/camptocamp/ifremer/openlayers/build/OpenLayers.cc.js
sandbox/camptocamp/ifremer/openlayers/build/README.txt
camptocamp/ifremer sandbox: added closure compiler
Modified: sandbox/camptocamp/ifremer/openlayers/build/OpenLayers.cc.js
--- sandbox/camptocamp/ifremer/openlayers/build/OpenLayers.cc.js 2010-12-06 11:09:36 UTC (rev 10949)
+++ sandbox/camptocamp/ifremer/openlayers/build/OpenLayers.cc.js 2010-12-06 11:29:40 UTC (rev 10950)
@@ -556,14 +556,14 @@
{attributes:{matchCase:a.matchCase}});this.writeNode("PropertyName",a,b);this.writeNode("Literal",a.value,b);return b},PropertyIsLike:function(a){var b=this.createElementNSPlus("ogc:PropertyIsLike",{attributes:{wildCard:"*",singleChar:".",escapeChar:"!"}});this.writeNode("PropertyName",a,b);this.writeNode("Literal",a.regex2value(),b);return b},BBOX:function(a){var b=this.createElementNSPlus("ogc:BBOX");this.writeNode("PropertyName",a,b);var c=this.writeNode("gml:Envelope",a.value);a.projection&&c.setAttribute("srsName",
a.projection);b.appendChild(c);return b}},OpenLayers.Format.Filter.v1.prototype.writers.ogc),gml:OpenLayers.Format.GML.v3.prototype.writers.gml,feature:OpenLayers.Format.GML.v3.prototype.writers.feature},writeSpatial:function(a,b){var c=this.createElementNSPlus("ogc:"+b);this.writeNode("PropertyName",a,c);var d;d=a.value instanceof OpenLayers.Geometry?this.writeNode("feature:_geometry",a.value).firstChild:this.writeNode("gml:Envelope",a.value);a.projection&&d.setAttribute("srsName",a.projection);
c.appendChild(d);return c},CLASS_NAME:"OpenLayers.Format.Filter.v1_1_0"});
-OpenLayers.Format.CSWGetRecords.v2_0_2=OpenLayers.Class(OpenLayers.Format.XML,{namespaces:{xlink:"http://www.w3.org/1999/xlink",xsi:"http://www.w3.org/2001/XMLSchema-instance",csw:"http://www.opengis.net/cat/csw/2.0.2",dc:"http://purl.org/dc/elements/1.1/",dct:"http://purl.org/dc/terms/",ogc:"http://www.opengis.net/ogc",ows:"http://www.opengis.net/ows"},defaultPrefix:"csw",version:"2.0.2",schemaLocation:"http://www.opengis.net/cat/csw/2.0.2 http://schemas.opengis.net/csw/2.0.2/CSW-discovery.xsd",requestId:null,
-resultType:null,outputFormat:null,outputSchema:null,startPosition:null,maxRecords:null,DistributedSearch:null,ResponseHandler:null,Query:null,regExes:{trimSpace:/^\s*|\s*$/g,removeSpace:/\s*/g,splitSpace:/\s+/,trimComma:/\s*,\s*/g},initialize:function(a){OpenLayers.Format.XML.prototype.initialize.apply(this,[a])},read:function(a){if(typeof a=="string")a=OpenLayers.Format.XML.prototype.read.apply(this,[a]);if(a&&a.nodeType==9)a=a.documentElement;var b={};this.readNode(a,b);return b},readers:{csw:{GetRecordsResponse:function(a,
-b){b.records=[];this.readChildNodes(a,b);var c=this.getAttributeNS(a,"","version");if(c!="")b.version=c},RequestId:function(a,b){b.RequestId=this.getChildValue(a)},SearchStatus:function(a,b){b.SearchStatus={};var c=this.getAttributeNS(a,"","timestamp");if(c!="")b.SearchStatus.timestamp=c},SearchResults:function(a,b){this.readChildNodes(a,b);for(var c=a.attributes,d={},e=0,f=c.length;e<f;++e)d[c[e].name]=c[e].name=="numberOfRecordsMatched"||c[e].name=="numberOfRecordsReturned"||c[e].name=="nextRecord"?
-parseInt(c[e].nodeValue):c[e].nodeValue;b.SearchResults=d},SummaryRecord:function(a,b){var c={type:"SummaryRecord"};this.readChildNodes(a,c);b.records.push(c)},BriefRecord:function(a,b){var c={type:"BriefRecord"};this.readChildNodes(a,c);b.records.push(c)},DCMIRecord:function(a,b){var c={type:"DCMIRecord"};this.readChildNodes(a,c);b.records.push(c)},Record:function(a,b){var c={type:"Record"};this.readChildNodes(a,c);b.records.push(c)}},dc:{"*":function(a,b){var c=a.localName||a.nodeName.split(":").pop();
-b[c]instanceof Array||(b[c]=[]);for(var d={},e=a.attributes,f=0,g=e.length;f<g;++f)d[e[f].name]=e[f].nodeValue;d.value=this.getChildValue(a);b[c].push(d)}},dct:{"*":function(a,b){var c=a.localName||a.nodeName.split(":").pop();b[c]instanceof Array||(b[c]=[]);b[c].push(this.getChildValue(a))}},ows:OpenLayers.Util.applyDefaults({BoundingBox:function(a,b){if(b.bounds){b.BoundingBox=[{crs:b.projection,value:[b.bounds.left,b.bounds.bottom,b.bounds.right,b.bounds.top]}];delete b.projection;delete b.bounds}OpenLayers.Format.OWSCommon.v1_0_0.prototype.readers.ows.BoundingBox.apply(this,
-arguments)}},OpenLayers.Format.OWSCommon.v1_0_0.prototype.readers.ows)},write:function(a){a=this.writeNode("csw:GetRecords",a);return OpenLayers.Format.XML.prototype.write.apply(this,[a])},writers:{ogc:{SortBy:function(a){var b=this.createElementNSPlus("ogc:SortBy");a.SortProperty&&this.writeNode("ogc:SortProperty",a.SortProperty,b);return b},SortProperty:function(a){var b=this.createElementNSPlus("ogc:SortProperty");this.writeNode("ogc:PropertyName",a.PropertyName,b);this.writeNode("ogc:SortOrder",
-a.SortOrder?a.SortOrder:"ASC",b);return b},PropertyName:function(a){return this.createElementNSPlus("ogc:PropertyName",{value:a})},SortOrder:function(a){return this.createElementNSPlus("ogc:SortOrder",{value:a})}},csw:{GetRecords:function(a){a||(a={});var b=this.createElementNSPlus("csw:GetRecords",{attributes:{service:"CSW",version:this.version,requestId:a.requestId||this.requestId,resultType:a.resultType||this.resultType,outputFormat:a.outputFormat||this.outputFormat,outputSchema:a.outputSchema||
-this.outputSchema,startPosition:a.startPosition||this.startPosition,maxRecords:a.maxRecords||this.maxRecords}});if(a.DistributedSearch||this.DistributedSearch)this.writeNode("csw:DistributedSearch",a.DistributedSearch||this.DistributedSearch,b);var c=a.ResponseHandler||this.ResponseHandler;if(c instanceof Array&&c.length>0)for(var d=0,e=c.length;d<e;d++)this.writeNode("csw:ResponseHandler",c[d],b);this.writeNode("Query",a.Query||this.Query,b);return b},DistributedSearch:function(a){return this.createElementNSPlus("csw:DistributedSearch",
-{attributes:{hopCount:a.hopCount}})},ResponseHandler:function(a){return this.createElementNSPlus("csw:ResponseHandler",{value:a.value})},Query:function(a){a||(a={});var b=this.createElementNSPlus("csw:Query",{attributes:{typeNames:a.typeNames||"csw:Record"}}),c=a.ElementName;if(c instanceof Array&&c.length>0)for(var d=0,e=c.length;d<e;d++)this.writeNode("csw:ElementName",c[d],b);else this.writeNode("csw:ElementSetName",a.ElementSetName||{value:"summary"},b);a.Constraint&&this.writeNode("csw:Constraint",
-a.Constraint,b);a.SortBy&&this.writeNode("ogc:SortBy",a.SortBy,b);return b},ElementName:function(a){return this.createElementNSPlus("csw:ElementName",{value:a.value})},ElementSetName:function(a){return this.createElementNSPlus("csw:ElementSetName",{attributes:{typeNames:a.typeNames},value:a.value})},Constraint:function(a){var b=this.createElementNSPlus("csw:Constraint",{attributes:{version:a.version}});if(a.Filter){var c=new OpenLayers.Format.Filter({version:a.version});b.appendChild(c.write(a.Filter))}else if(a.CqlText){a=
-this.createElementNSPlus("CqlText",{value:a.CqlText.value});b.appendChild(a)}return b}}},CLASS_NAME:"OpenLayers.Format.CSWGetRecords.v2_0_2"});
\ No newline at end of file
+OpenLayers.Format.CSWGetRecords.v2_0_2=OpenLayers.Class(OpenLayers.Format.XML,{namespaces:{xlink:"http://www.w3.org/1999/xlink",xsi:"http://www.w3.org/2001/XMLSchema-instance",csw:"http://www.opengis.net/cat/csw/2.0.2",dc:"http://purl.org/dc/elements/1.1/",dct:"http://purl.org/dc/terms/",ogc:"http://www.opengis.net/ogc",ows:"http://www.opengis.net/ows",geonet:"http://www.fao.org/geonetwork"},defaultPrefix:"csw",version:"2.0.2",schemaLocation:"http://www.opengis.net/cat/csw/2.0.2 http://schemas.opengis.net/csw/2.0.2/CSW-discovery.xsd",
+requestId:null,resultType:null,outputFormat:null,outputSchema:null,startPosition:null,maxRecords:null,DistributedSearch:null,ResponseHandler:null,Query:null,regExes:{trimSpace:/^\s*|\s*$/g,removeSpace:/\s*/g,splitSpace:/\s+/,trimComma:/\s*,\s*/g},initialize:function(a){OpenLayers.Format.XML.prototype.initialize.apply(this,[a])},read:function(a){if(typeof a=="string")a=OpenLayers.Format.XML.prototype.read.apply(this,[a]);if(a&&a.nodeType==9)a=a.documentElement;var b={};this.readNode(a,b);return b},
+readers:{csw:{GetRecordsResponse:function(a,b){b.records=[];this.readChildNodes(a,b);var c=this.getAttributeNS(a,"","version");if(c!="")b.version=c},RequestId:function(a,b){b.RequestId=this.getChildValue(a)},SearchStatus:function(a,b){b.SearchStatus={};var c=this.getAttributeNS(a,"","timestamp");if(c!="")b.SearchStatus.timestamp=c},SearchResults:function(a,b){this.readChildNodes(a,b);for(var c=a.attributes,d={},e=0,f=c.length;e<f;++e)d[c[e].name]=c[e].name=="numberOfRecordsMatched"||c[e].name=="numberOfRecordsReturned"||
+c[e].name=="nextRecord"?parseInt(c[e].nodeValue):c[e].nodeValue;b.SearchResults=d},SummaryRecord:function(a,b){var c={type:"SummaryRecord"};this.readChildNodes(a,c);b.records.push(c)},BriefRecord:function(a,b){var c={type:"BriefRecord"};this.readChildNodes(a,c);b.records.push(c)},DCMIRecord:function(a,b){var c={type:"DCMIRecord"};this.readChildNodes(a,c);b.records.push(c)},Record:function(a,b){var c={type:"Record"};this.readChildNodes(a,c);b.records.push(c)},"*":function(a,b){var c=a.localName||a.nodeName.split(":").pop();
+b[c]=this.getChildValue(a)}},geonet:{info:function(a,b){var c={};this.readChildNodes(a,c);b.gninfo=c}},dc:{"*":function(a,b){var c=a.localName||a.nodeName.split(":").pop();b[c]instanceof Array||(b[c]=[]);for(var d={},e=a.attributes,f=0,g=e.length;f<g;++f)d[e[f].name]=e[f].nodeValue;d.value=this.getChildValue(a);b[c].push(d)}},dct:{"*":function(a,b){var c=a.localName||a.nodeName.split(":").pop();b[c]instanceof Array||(b[c]=[]);b[c].push(this.getChildValue(a))}},ows:OpenLayers.Util.applyDefaults({BoundingBox:function(a,
+b){if(b.bounds){b.BoundingBox=[{crs:b.projection,value:[b.bounds.left,b.bounds.bottom,b.bounds.right,b.bounds.top]}];delete b.projection;delete b.bounds}OpenLayers.Format.OWSCommon.v1_0_0.prototype.readers.ows.BoundingBox.apply(this,arguments)}},OpenLayers.Format.OWSCommon.v1_0_0.prototype.readers.ows)},write:function(a){a=this.writeNode("csw:GetRecords",a);return OpenLayers.Format.XML.prototype.write.apply(this,[a])},writers:{ogc:{SortBy:function(a){var b=this.createElementNSPlus("ogc:SortBy");a.SortProperty&&
+this.writeNode("ogc:SortProperty",a.SortProperty,b);return b},SortProperty:function(a){var b=this.createElementNSPlus("ogc:SortProperty");this.writeNode("ogc:PropertyName",a.PropertyName,b);this.writeNode("ogc:SortOrder",a.SortOrder?a.SortOrder:"ASC",b);return b},PropertyName:function(a){return this.createElementNSPlus("ogc:PropertyName",{value:a})},SortOrder:function(a){return this.createElementNSPlus("ogc:SortOrder",{value:a})}},csw:{GetRecords:function(a){a||(a={});var b=this.createElementNSPlus("csw:GetRecords",
+{attributes:{service:"CSW",version:this.version,requestId:a.requestId||this.requestId,resultType:a.resultType||this.resultType,outputFormat:a.outputFormat||this.outputFormat,outputSchema:a.outputSchema||this.outputSchema,startPosition:a.startPosition||this.startPosition,maxRecords:a.maxRecords||this.maxRecords}});if(a.DistributedSearch||this.DistributedSearch)this.writeNode("csw:DistributedSearch",a.DistributedSearch||this.DistributedSearch,b);var c=a.ResponseHandler||this.ResponseHandler;if(c instanceof
+Array&&c.length>0)for(var d=0,e=c.length;d<e;d++)this.writeNode("csw:ResponseHandler",c[d],b);this.writeNode("Query",a.Query||this.Query,b);return b},DistributedSearch:function(a){return this.createElementNSPlus("csw:DistributedSearch",{attributes:{hopCount:a.hopCount}})},ResponseHandler:function(a){return this.createElementNSPlus("csw:ResponseHandler",{value:a.value})},Query:function(a){a||(a={});var b=this.createElementNSPlus("csw:Query",{attributes:{typeNames:a.typeNames||"csw:Record"}}),c=a.ElementName;
+if(c instanceof Array&&c.length>0)for(var d=0,e=c.length;d<e;d++)this.writeNode("csw:ElementName",c[d],b);else this.writeNode("csw:ElementSetName",a.ElementSetName||{value:"summary"},b);a.Constraint&&this.writeNode("csw:Constraint",a.Constraint,b);a.SortBy&&this.writeNode("ogc:SortBy",a.SortBy,b);return b},ElementName:function(a){return this.createElementNSPlus("csw:ElementName",{value:a.value})},ElementSetName:function(a){return this.createElementNSPlus("csw:ElementSetName",{attributes:{typeNames:a.typeNames},
+value:a.value})},Constraint:function(a){var b=this.createElementNSPlus("csw:Constraint",{attributes:{version:a.version}});if(a.Filter){var c=new OpenLayers.Format.Filter({version:a.version});b.appendChild(c.write(a.Filter))}else if(a.CqlText){a=this.createElementNSPlus("CqlText",{value:a.CqlText.value});b.appendChild(a)}return b}}},CLASS_NAME:"OpenLayers.Format.CSWGetRecords.v2_0_2"});
Modified: sandbox/camptocamp/ifremer/openlayers/build/README.txt
--- sandbox/camptocamp/ifremer/openlayers/build/README.txt 2010-12-06 11:09:36 UTC (rev 10949)
+++ sandbox/camptocamp/ifremer/openlayers/build/README.txt 2010-12-06 11:29:40 UTC (rev 10950)
@@ -1,12 +1,8 @@
## HowTo: Build & deploy "Shrunk" Single File Library version of OpenLayers ##
- * Build:
+ * Build: ./makeOL
- cd build
- python build.py ifremer
- the resulting build is further minified using http://closure-compiler.appspot.com/home
- cd ..
Added: sandbox/camptocamp/ifremer/openlayers/build/closurecompiler/COPYING
--- sandbox/camptocamp/ifremer/openlayers/build/closurecompiler/COPYING (rev 0)
+++ sandbox/camptocamp/ifremer/openlayers/build/closurecompiler/COPYING 2010-12-06 11:29:40 UTC (rev 10950)
@@ -0,0 +1,202 @@
+ Apache License
+ Version 2.0, January 2004
+ http://www.apache.org/licenses/
+ TERMS AND CONDITIONS FOR USE, REPRODUCTION, AND DISTRIBUTION
+ 1. Definitions.
+ "License" shall mean the terms and conditions for use, reproduction,
+ and distribution as defined by Sections 1 through 9 of this document.
+ "Licensor" shall mean the copyright owner or entity authorized by
+ the copyright owner that is granting the License.
+ "Legal Entity" shall mean the union of the acting entity and all
+ other entities that control, are controlled by, or are under common
+ control with that entity. For the purposes of this definition,
+ "control" means (i) the power, direct or indirect, to cause the
+ direction or management of such entity, whether by contract or
+ otherwise, or (ii) ownership of fifty percent (50%) or more of the
+ outstanding shares, or (iii) beneficial ownership of such entity.
+ "You" (or "Your") shall mean an individual or Legal Entity
+ exercising permissions granted by this License.
+ "Source" form shall mean the preferred form for making modifications,
+ including but not limited to software source code, documentation
+ source, and configuration files.
+ "Object" form shall mean any form resulting from mechanical
+ transformation or translation of a Source form, including but
+ not limited to compiled object code, generated documentation,
+ and conversions to other media types.
+ "Work" shall mean the work of authorship, whether in Source or
+ Object form, made available under the License, as indicated by a
+ copyright notice that is included in or attached to the work
+ (an example is provided in the Appendix below).
+ "Derivative Works" shall mean any work, whether in Source or Object
+ form, that is based on (or derived from) the Work and for which the
+ editorial revisions, annotations, elaborations, or other modifications
+ represent, as a whole, an original work of authorship. For the purposes
+ of this License, Derivative Works shall not include works that remain
+ separable from, or merely link (or bind by name) to the interfaces of,
+ the Work and Derivative Works thereof.
+ "Contribution" shall mean any work of authorship, including
+ the original version of the Work and any modifications or additions
+ to that Work or Derivative Works thereof, that is intentionally
+ submitted to Licensor for inclusion in the Work by the copyright owner
+ or by an individual or Legal Entity authorized to submit on behalf of
+ the copyright owner. For the purposes of this definition, "submitted"
+ means any form of electronic, verbal, or written communication sent
+ to the Licensor or its representatives, including but not limited to
+ communication on electronic mailing lists, source code control systems,
+ and issue tracking systems that are managed by, or on behalf of, the
+ Licensor for the purpose of discussing and improving the Work, but
+ excluding communication that is conspicuously marked or otherwise
+ designated in writing by the copyright owner as "Not a Contribution."
+ "Contributor" shall mean Licensor and any individual or Legal Entity
+ on behalf of whom a Contribution has been received by Licensor and
+ subsequently incorporated within the Work.
+ 2. Grant of Copyright License. Subject to the terms and conditions of
+ this License, each Contributor hereby grants to You a perpetual,
+ worldwide, non-exclusive, no-charge, royalty-free, irrevocable
+ copyright license to reproduce, prepare Derivative Works of,
+ publicly display, publicly perform, sublicense, and distribute the
+ Work and such Derivative Works in Source or Object form.
+ 3. Grant of Patent License. Subject to the terms and conditions of
+ (except as stated in this section) patent license to make, have made,
+ use, offer to sell, sell, import, and otherwise transfer the Work,
+ where such license applies only to those patent claims licensable
+ by such Contributor that are necessarily infringed by their
+ Contribution(s) alone or by combination of their Contribution(s)
+ with the Work to which such Contribution(s) was submitted. If You
+ institute patent litigation against any entity (including a
+ cross-claim or counterclaim in a lawsuit) alleging that the Work
+ or a Contribution incorporated within the Work constitutes direct
+ or contributory patent infringement, then any patent licenses
+ granted to You under this License for that Work shall terminate
+ as of the date such litigation is filed.
+ 4. Redistribution. You may reproduce and distribute copies of the
+ Work or Derivative Works thereof in any medium, with or without
+ modifications, and in Source or Object form, provided that You
+ meet the following conditions:
+ (a) You must give any other recipients of the Work or
+ Derivative Works a copy of this License; and
+ (b) You must cause any modified files to carry prominent notices
+ stating that You changed the files; and
+ (c) You must retain, in the Source form of any Derivative Works
+ that You distribute, all copyright, patent, trademark, and
+ attribution notices from the Source form of the Work,
+ excluding those notices that do not pertain to any part of
+ the Derivative Works; and
+ (d) If the Work includes a "NOTICE" text file as part of its
+ distribution, then any Derivative Works that You distribute must
+ include a readable copy of the attribution notices contained
+ within such NOTICE file, excluding those notices that do not
+ pertain to any part of the Derivative Works, in at least one
+ of the following places: within a NOTICE text file distributed
+ as part of the Derivative Works; within the Source form or
+ documentation, if provided along with the Derivative Works; or,
+ within a display generated by the Derivative Works, if and
+ wherever such third-party notices normally appear. The contents
+ of the NOTICE file are for informational purposes only and
+ do not modify the License. You may add Your own attribution
+ notices within Derivative Works that You distribute, alongside
+ or as an addendum to the NOTICE text from the Work, provided
+ that such additional attribution notices cannot be construed
+ as modifying the License.
+ You may add Your own copyright statement to Your modifications and
+ may provide additional or different license terms and conditions
+ for use, reproduction, or distribution of Your modifications, or
+ for any such Derivative Works as a whole, provided Your use,
+ reproduction, and distribution of the Work otherwise complies with
+ the conditions stated in this License.
+ 5. Submission of Contributions. Unless You explicitly state otherwise,
+ any Contribution intentionally submitted for inclusion in the Work
+ by You to the Licensor shall be under the terms and conditions of
+ this License, without any additional terms or conditions.
+ Notwithstanding the above, nothing herein shall supersede or modify
+ the terms of any separate license agreement you may have executed
+ with Licensor regarding such Contributions.
+ 6. Trademarks. This License does not grant permission to use the trade
+ names, trademarks, service marks, or product names of the Licensor,
+ except as required for reasonable and customary use in describing the
+ origin of the Work and reproducing the content of the NOTICE file.
+ 7. Disclaimer of Warranty. Unless required by applicable law or
+ agreed to in writing, Licensor provides the Work (and each
+ Contributor provides its Contributions) on an "AS IS" BASIS,
+ WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or
+ implied, including, without limitation, any warranties or conditions
+ of TITLE, NON-INFRINGEMENT, MERCHANTABILITY, or FITNESS FOR A
+ PARTICULAR PURPOSE. You are solely responsible for determining the
+ appropriateness of using or redistributing the Work and assume any
+ risks associated with Your exercise of permissions under this License.
+ 8. Limitation of Liability. In no event and under no legal theory,
+ whether in tort (including negligence), contract, or otherwise,
+ unless required by applicable law (such as deliberate and grossly
+ negligent acts) or agreed to in writing, shall any Contributor be
+ liable to You for damages, including any direct, indirect, special,
+ incidental, or consequential damages of any character arising as a
+ result of this License or out of the use or inability to use the
+ Work (including but not limited to damages for loss of goodwill,
+ work stoppage, computer failure or malfunction, or any and all
+ other commercial damages or losses), even if such Contributor
+ has been advised of the possibility of such damages.
+ 9. Accepting Warranty or Additional Liability. While redistributing
+ the Work or Derivative Works thereof, You may choose to offer,
+ and charge a fee for, acceptance of support, warranty, indemnity,
+ or other liability obligations and/or rights consistent with this
+ License. However, in accepting such obligations, You may act only
+ on Your own behalf and on Your sole responsibility, not on behalf
+ of any other Contributor, and only if You agree to indemnify,
+ defend, and hold each Contributor harmless for any liability
+ incurred by, or claims asserted against, such Contributor by reason
+ of your accepting any such warranty or additional liability.
+ END OF TERMS AND CONDITIONS
+ APPENDIX: How to apply the Apache License to your work.
+ To apply the Apache License to your work, attach the following
+ boilerplate notice, with the fields enclosed by brackets "[]"
+ replaced with your own identifying information. (Don't include
+ the brackets!) The text should be enclosed in the appropriate
+ comment syntax for the file format. We also recommend that a
+ file or class name and description of purpose be included on the
+ same "printed page" as the copyright notice for easier
+ identification within third-party archives.
+ Copyright [yyyy] [name of copyright owner]
+ Licensed under the Apache License, Version 2.0 (the "License");
+ you may not use this file except in compliance with the License.
+ You may obtain a copy of the License at
+ http://www.apache.org/licenses/LICENSE-2.0
+ Unless required by applicable law or agreed to in writing, software
+ distributed under the License is distributed on an "AS IS" BASIS,
+ WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
+ See the License for the specific language governing permissions and
+ limitations under the License.
Added: sandbox/camptocamp/ifremer/openlayers/build/closurecompiler/README
--- sandbox/camptocamp/ifremer/openlayers/build/closurecompiler/README (rev 0)
+++ sandbox/camptocamp/ifremer/openlayers/build/closurecompiler/README 2010-12-06 11:29:40 UTC (rev 10950)
@@ -0,0 +1,289 @@
+ * Copyright 2009 Google Inc.
+ * Licensed under the Apache License, Version 2.0 (the "License");
+ * you may not use this file except in compliance with the License.
+ * You may obtain a copy of the License at
+ * http://www.apache.org/licenses/LICENSE-2.0
+ * Unless required by applicable law or agreed to in writing, software
+ * distributed under the License is distributed on an "AS IS" BASIS,
+ * WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
+ * See the License for the specific language governing permissions and
+ * limitations under the License.
+// Contents
+The Closure Compiler performs checking, instrumentation, and
+optimizations on JavaScript code. The purpose of this README is to
+explain how to build and run the Closure Compiler.
+The Closure Compiler requires Java 6 or higher.
+http://www.java.com/
+// Building The Closure Compiler
+There are three ways to get a Closure Compiler executable.
+1) Use one we built for you.
+Pre-built Closure binaries can be found at
+http://code.google.com/p/closure-compiler/downloads/list
+2) Check out the source and build it with Apache Ant.
+First, check out the full source tree of the Closure Compiler. There
+are instructions on how to do this at the project site.
+http://code.google.com/p/closure-compiler/source/checkout
+Apache Ant is a cross-platform build tool.
+http://ant.apache.org/
+At the root of the source tree, there is an Ant file named
+build.xml. To use it, navigate to the same directory and type the
+command
+ant jar
+This will produce a jar file called "build/compiler.jar".
+3) Check out the source and build it with Eclipse.
+Eclipse is a cross-platform IDE.
+http://www.eclipse.org/
+Under Eclipse's File menu, click "New > Project ..." and create a
+"Java Project." You will see an options screen. Give the project a
+name, select "Create project from existing source," and choose the
+root of the checked-out source tree as the existing directory. Verify
+that you are using JRE version 6 or higher.
+Eclipse can use the build.xml file to discover rules. When you
+navigate to the build.xml file, you will see all the build rules in
+the "Outline" pane. Run the "jar" rule to build the compiler in
+build/compiler.jar.
+// Running The Closure Compiler
+Once you have the jar binary, running the Closure Compiler is straightforward.
+On the command line, type
+java -jar compiler.jar
+This starts the compiler in interactive mode. Type
+var x = 17 + 25;
+then hit "Enter", then hit "Ctrl-Z" (on Windows) or "Ctrl-D" (on Mac or Linux)
+and "Enter" again. The Compiler will respond:
+var x=42;
+The Closure Compiler has many options for reading input from a file,
+writing output to a file, checking your code, and running
+optimizations. To learn more, type
+java -jar compiler.jar --help
+You can read more detailed documentation about the many flags at
+http://code.google.com/closure/compiler/docs/gettingstarted_app.html
+// Compiling Multiple Scripts
+If you have multiple scripts, you should compile them all together with
+one compile command.
+java -jar compiler.jar --js=in1.js --js=in2.js ... --js_output_file=out.js
+The Closure Compiler will concatenate the files in the order they're
+passed at the command line.
+If you need to compile many, many scripts together, you may start to
+run into problems with managing dependencies between scripts. You
+should check out the Closure Library. It contains functions for
+enforcing dependencies between scripts, and a tool called calcdeps.py
+that knows how to give scripts to the Closure Compiler in the right
+order.
+http://code.google.com/p/closure-library/
+// Licensing
+Unless otherwise stated, all source files are licensed under
+the Apache License, Version 2.0.
+Code under:
+src/com/google/javascript/rhino
+test/com/google/javascript/rhino
+URL: http://www.mozilla.org/rhino
+Version: 1.5R3, with heavy modifications
+License: Netscape Public License and MPL / GPL dual license
+Description: A partial copy of Mozilla Rhino. Mozilla Rhino is an
+implementation of JavaScript for the JVM. The JavaScript parser and
+the parse tree data structures were extracted and modified
+significantly for use by Google's JavaScript compiler.
+Local Modifications: The packages have been renamespaced. All code not
+relavant to parsing has been removed. A JSDoc parser and static typing
+system have been added.
+Code in:
+lib/libtrunk_rhino_parser_jarjared.jar
+Rhino
+Version: Trunk
+Description: Mozilla Rhino is an implementation of JavaScript for the JVM.
+Local Modifications: None. We've used JarJar to renamespace the code
+post-compilation. See:
+http://code.google.com/p/jarjar/
+Code in:
+lib/args4j_deploy.jar
+Args4j
+URL: https://args4j.dev.java.net/
+Version: 2.0.9
+License: MIT
+Description:
+args4j is a small Java class library that makes it easy to parse command line
+options/arguments in your CUI application.
+Code in:
+lib/guava-r06.jar
+Guava Libraries
+URL: http://code.google.com/p/guava-libraries/
+Version: R6
+License: Apache License 2.0
+Description: Google's core Java libraries.
+Code in:
+lib/hamcrest-core-1.1.jar
+Hamcrest
+URL: http://code.google.com/p/hamcrest
+License: BSD
+License File: LICENSE
+Description:
+Provides a library of matcher objects (also known as constraints or
+predicates) allowing 'match' rules to be defined declaratively, to be used in
+other frameworks. Typical scenarios include testing frameworks, mocking
+libraries and UI validation rules.
+Local modifications:
+The original jars contained both source code and compiled classes.
+hamcrest-core-1.1.jar just contains the compiled classes.
+Code in:
+lib/jsr305.jar
+Annotations for software defect detection
+URL: http://code.google.com/p/jsr-305/
+Version: svn revision 47
+License: BSD License
+Description: Annotations for software defect detection.
+Code in:
+lib/junit.jar
+JUnit
+URL: http://sourceforge.net/projects/junit/
+Version: 4.5
+License: Common Public License 1.0
+Description: A framework for writing and running automated tests in Java.
+Code in:
+lib/protobuf-java-2.3.0.jar
+Protocol Buffers
+URL: http://code.google.com/p/protobuf/
+Version: 2.3.0
+License: New BSD License
+Description: Supporting libraries for protocol buffers,
+an encoding of structured data.
+Code in:
+lib/ant_deploy.jar
+URL: http://ant.apache.org/bindownload.cgi
+Version: 1.6.5
+Description:
+ Ant is a Java based build tool. In theory it is kind of like "make"
+ without make's wrinkles and with the full portability of pure java code.
+ Modified apache-ant-1.6.5/bin/ant to look in the ant.runfiles directory
+Code in:
+lib/json.jar
+URL: http://json.org/java/index.html
+Version: JSON version 2
+License: MIT license
+Description:
+JSON is a set of java files for use in transmitting data in JSON format.
Added: sandbox/camptocamp/ifremer/openlayers/build/closurecompiler/compiler.jar
(Binary files differ)
Property changes on: sandbox/camptocamp/ifremer/openlayers/build/closurecompiler/compiler.jar
___________________________________________________________________
Added: svn:mime-type
+ application/octet-stream
Added: sandbox/camptocamp/ifremer/openlayers/build/makeOL
--- sandbox/camptocamp/ifremer/openlayers/build/makeOL (rev 0)
+++ sandbox/camptocamp/ifremer/openlayers/build/makeOL 2010-12-06 11:29:40 UTC (rev 10950)
@@ -0,0 +1,3 @@
+#!/bin/bash
+python build.py ifremer && echo "Closure compiling ..." && java -jar ./closurecompiler/compiler.jar --compilation_level SIMPLE_OPTIMIZATIONS --js OpenLayers.js --js_output_file OpenLayers.cc.js && echo "All done !"
Property changes on: sandbox/camptocamp/ifremer/openlayers/build/makeOL
Added: svn:executable
More information about the Commits
