[OpenLayers-Commits] r10952 - trunk/openlayers/lib/OpenLayers/Format
commits-20090109 at openlayers.org
Tue Dec 7 11:56:49 EST 2010
Author: ahocevar
Date: 2010-12-07 08:56:49 -0800 (Tue, 07 Dec 2010)
New Revision: 10952
trunk/openlayers/lib/OpenLayers/Format/JSON.js
Use native JSON if available. p=fredj,me r=bartvde,tschaub,elemoine (closes #1807)
Modified: trunk/openlayers/lib/OpenLayers/Format/JSON.js
--- trunk/openlayers/lib/OpenLayers/Format/JSON.js 2010-12-06 20:15:15 UTC (rev 10951)
+++ trunk/openlayers/lib/OpenLayers/Format/JSON.js 2010-12-07 16:56:49 UTC (rev 10952)
@@ -60,6 +60,14 @@
pretty: false,
+ * Property: nativeJSON
+ * {Boolean} Does the browser support native json?
+ nativeJSON: (function() {
+ return !!(window.JSON && typeof JSON.parse == "function" && typeof JSON.stringify == "function");
* Constructor: OpenLayers.Format.JSON
* Create a new parser for JSON.
@@ -87,15 +95,18 @@
* {Object} An object, array, string, or number .
read: function(json, filter) {
- * Parsing happens in three stages. In the first stage, we run the text
- * against a regular expression which looks for non-JSON
- * characters. We are especially concerned with '()' and 'new'
- * because they can cause invocation, and '=' because it can cause
- * mutation. But just to be safe, we will reject all unexpected
- * characters.
- try {
+ var object;
+ if (this.nativeJSON) {
+ object = JSON.parse(json, filter);
+ } else try {
+ * Parsing happens in three stages. In the first stage, we run the
+ * text against a regular expression which looks for non-JSON
+ * characters. We are especially concerned with '()' and 'new'
+ * because they can cause invocation, and '=' because it can
+ * cause mutation. But just to be safe, we will reject all
+ * unexpected characters.
if (/^[\],:{}\s]*$/.test(json.replace(/\\["\\\/bfnrtu]/g, '@').
replace(/"[^"\\\n\r]*"|true|false|null|-?\d+(?:\.\d*)?(?:[eE][+\-]?\d+)?/g, ']').
replace(/(?:^|:|,)(?:\s*\[)+/g, ''))) {
@@ -107,7 +118,7 @@
* begin a block or an object literal. We wrap the text in
* parens to eliminate the ambiguity.
- var object = eval('(' + json + ')');
+ object = eval('(' + json + ')');
* In the optional third stage, we recursively walk the new
@@ -127,17 +138,16 @@
object = walk('', object);
- if(this.keepData) {
- this.data = object;
- return object;
} catch(e) {
// Fall through if the regexp test fails.
- return null;
+ if(this.keepData) {
+ this.data = object;
+ return object;
@@ -159,7 +169,9 @@
var type = typeof value;
if(this.serialize[type]) {
try {
- json = this.serialize[type].apply(this, [value]);
+ json = (!this.pretty && this.nativeJSON) ?
+ JSON.stringify(value) :
+ this.serialize[type].apply(this, [value]);
} catch(err) {
OpenLayers.Console.error("Trouble serializing: " + err);
More information about the Commits
