[OpenLayers-Commits] r10954 -
trunk/openlayers/lib/OpenLayers/Handler
commits-20090109 at openlayers.org
Tue Dec 7 18:48:20 EST 2010
Author: ahocevar
Date: 2010-12-07 15:48:20 -0800 (Tue, 07 Dec 2010)
New Revision: 10954
trunk/openlayers/lib/OpenLayers/Handler/Drag.js
fix document dragging which was broken with r10871. Note that this could also have been fixed by creating the Events instance on the element returned by OpenLayers.Util.getViewportElement() instead of document. r=erilem (closes #2941)
Modified: trunk/openlayers/lib/OpenLayers/Handler/Drag.js
--- trunk/openlayers/lib/OpenLayers/Handler/Drag.js 2010-12-07 23:37:56 UTC (rev 10953)
+++ trunk/openlayers/lib/OpenLayers/Handler/Drag.js 2010-12-07 23:48:20 UTC (rev 10954)
@@ -94,8 +94,7 @@
* Property: documentEvents
- * {<OpenLayers.Events>} Event instance for observing document events. Will
- * be set on mouseout if documentDrag is set to true.
+ * {Boolean} Are we currently observing document events?
documentEvents: null,
@@ -117,6 +116,19 @@
initialize: function(control, callbacks, options) {
OpenLayers.Handler.prototype.initialize.apply(this, arguments);
+ if (this.documentDrag === true) {
+ var me = this;
+ this._docMove = function(evt) {
+ me.mousemove({
+ xy: {x: evt.clientX, y: evt.clientY},
+ element: document
+ this._docUp = function(evt) {
+ me.mouseup({xy: {x: evt.clientX, y: evt.clientY}});
@@ -232,7 +244,7 @@
// registered with the map
this.setEvent(evt);
} else {
- this.destroyDocumentEvents();
+ this.removeDocumentEvents();
if (this.interval > 0) {
@@ -272,7 +284,7 @@
if (this.started) {
if(this.documentDrag === true && this.documentEvents) {
this.adjustXY(evt);
var dragged = (this.start != this.last);
this.started = false;
@@ -303,15 +315,7 @@
mouseout: function (evt) {
if (this.started && OpenLayers.Util.mouseLeft(evt, this.map.div)) {
if(this.documentDrag === true) {
- this.documentEvents = new OpenLayers.Events(this, document,
- null, null, {includeXY: true});
- this.documentEvents.on({
- mousemove: this.mousemove,
- mouseup: this.mouseup
- OpenLayers.Element.addClass(
- document.body, "olDragDown"
+ this.addDocumentEvents();
} else {
@@ -403,18 +407,28 @@
- * Method: destroyDocumentEvents
- * Destroys the events instance that gets added to the document body when
- * documentDrag is true and the mouse cursor leaves the map viewport while
- * dragging.
+ * Method: addDocumentEvents
+ * Start observing document events when documentDrag is true and the mouse
+ * cursor leaves the map viewport while dragging.
- destroyDocumentEvents: function() {
- OpenLayers.Element.removeClass(
- this.documentEvents.destroy();
- this.documentEvents = null;
+ addDocumentEvents: function() {
+ OpenLayers.Element.addClass(document.body, "olDragDown");
+ this.documentEvents = true;
+ OpenLayers.Event.observe(document, "mousemove", this._docMove);
+ OpenLayers.Event.observe(document, "mouseup", this._docUp);
+ * Method: removeDocumentEvents
+ * Stops observing document events when documentDrag is true and the mouse
+ * cursor re-enters the map viewport while dragging.
+ removeDocumentEvents: function() {
+ OpenLayers.Element.removeClass(document.body, "olDragDown");
+ this.documentEvents = false;
+ OpenLayers.Event.stopObserving(document, "mousemove", this._docMove);
+ OpenLayers.Event.stopObserving(document, "mouseup", this._docUp);
CLASS_NAME: "OpenLayers.Handler.Drag"
More information about the Commits
