[OpenLayers-Commits] r10965 - trunk/openlayers/tests/Request
commits-20090109 at openlayers.org
Wed Dec 15 02:51:50 EST 2010
Author: erilem
Date: 2010-12-14 23:51:50 -0800 (Tue, 14 Dec 2010)
New Revision: 10965
trunk/openlayers/tests/Request/XMLHttpRequest.html
add XMLHttpRequest readyState compliance tests, p=jorix (References #2913)
Modified: trunk/openlayers/tests/Request/XMLHttpRequest.html
--- trunk/openlayers/tests/Request/XMLHttpRequest.html 2010-12-14 16:08:44 UTC (rev 10964)
+++ trunk/openlayers/tests/Request/XMLHttpRequest.html 2010-12-15 07:51:50 UTC (rev 10965)
@@ -7,6 +7,51 @@
t.ok(new OpenLayers.Request.XMLHttpRequest(),
"constructor didn't fail and we trust the code is well tested in OpenLayers.Request methods");
+ function test_readyState(t) {
+ // Verify compliance of the standard (a part) See: http://www.w3.org/TR/XMLHttpRequest/
+ t.plan(9);
+ // Case 1: Request-A: open & abort
+ var requestA = new OpenLayers.Request.XMLHttpRequest();
+ //requestA.onreadystatechange = function() {};
+ t.eq(requestA.readyState, 0, "Request-A: readyState after new is 0-UNSENT");
+ requestA.open("GET", ".", true);
+ t.eq(requestA.readyState, 1, "Request-A: readyState after open is 1-OPENED");
+ requestA.abort();
+ t.eq(requestA.readyState, 0, "Request-A: readyState after abort is 0-UNSENT");
+ // Case 2: Request-B: open & send
+ var requestB = new OpenLayers.Request.XMLHttpRequest();
+ requestB.onreadystatechange = function() {
+ if (requestB.readyState == 4) {
+ t.ok(true, "Request-B: triggered the event onreadystatechange when 4-DONE");
+ t.eq(requestB.readyState, 0, "Request-B: readyState after new is 0-UNSENT");
+ requestB.open("GET", ".", true);
+ t.eq(requestB.readyState, 1, "Request-B: readyState after open is 1-OPENED");
+ requestB.send();
+ // Case 3: Request-C: open, send & abort
+ var requestC = new OpenLayers.Request.XMLHttpRequest();
+ requestC.onreadystatechange = function() {
+ if (requestC.readyState == 4) {
+ t.fail("Request-C: triggered the event onreadystatechange when 4-DONE after abort");
+ t.eq(requestC.readyState, 0, "Request-C: readyState after new is 0-UNSENT");
+ requestC.open("GET", ".", true);
+ t.eq(requestC.readyState, 1, "Request-C: readyState after open is 1-OPENED");
+ requestC.send();
+ requestC.abort();
+ t.eq(requestC.readyState, 0, "Request-C: readyState after abort is 0-UNSENT");
+ // delay destroy
+ t.delay_call(
+ 2, function() {
+ // to await the end of requestB and requestC
</script>
</head>
<body>
More information about the Commits
