[OpenLayers-Commits] r10973 - trunk/openlayers/examples
commits-20090109 at openlayers.org
Fri Dec 17 05:02:05 EST 2010
Author: ahocevar
Date: 2010-12-17 02:02:05 -0800 (Fri, 17 Dec 2010)
New Revision: 10973
trunk/openlayers/examples/simplify-linestring.html
updated the description and documentation of the example. p=marcjansen, r=me (closes #2869)
Modified: trunk/openlayers/examples/simplify-linestring.html
--- trunk/openlayers/examples/simplify-linestring.html 2010-12-16 19:31:10 UTC (rev 10972)
+++ trunk/openlayers/examples/simplify-linestring.html 2010-12-17 10:02:05 UTC (rev 10973)
@@ -1,7 +1,8 @@
<!DOCTYPE html>
<html>
<head>
- <title>Simplify LineString</title>
+ <meta http-equiv="Content-Type" content="text/html; charset=utf-8">
+ <title>Simplify a LineString geometry</title>
<link rel="stylesheet" href="../theme/default/style.css" type="text/css">
<link rel="stylesheet" href="style.css" type="text/css">
<style type="text/css">
@@ -15,19 +16,23 @@
width: 300px;
float: left;
+ #docs {
+ clear: both;
</style>
</head>
<body>
- <h1 id="title">Simplify a LineString</h1>
+ <h1 id="title">Simplify a LineString geometry</h1>
<div id="tags">
Douglas-Peucker, Douglas, Peucker, Peuker, tolerance
</div>
<p id="shortdesc">
- Shows the usage of the utility method "simplifyLineString" that
- implements the Douglas-Peucker algorithm to remove "insignificant"
- vertices from LineString geometries.
+ Shows the usage of the method "simplify" that implements
+ the Douglas-Peucker algorithm to remove "insignificant"
+ vertices from LineString geometries.
</p>
<div id="control-simplify">
+ <label for="tolerance">Tolerance factor:</label>
<input name="tolerance" id="tolerance" type="number" min="0" max="1" step="0.02" value="0.1">
<input type="button" id="simplify" value="Simplify LineString">
<input type="button" id="animation" value="Start animation">
@@ -38,20 +43,21 @@
</div>
<div id="info">
</div>
- <div id="docs" style="clear: both;">
+ <div id="docs">
<p>
- The method OpenLayers.Util.simplifyLineString can be used to
- simplify linestring geometries. Simplification sometimes is
- useful to enhance the perfomance of vector rendering or to
- reduce complexity of geometries. This might be especially handy
- when viewing geometries a small scales.
+ Instances of OpenLayers.Geometry.LineString have a method simplify,
+ that can be used to simplify linestring geometries.
+ Simplification sometimes is useful to enhance the perfomance of
+ vector rendering or to reduce complexity of geometries. This
+ might be especially handy when viewing geometries a small
+ scales.
</p>
<p>
- OpenLayers.Util.simplifyLineString is a recursive implementation
- of the famous Douglas-Peucker algorithm. It
- is controlled by a tolerance factor that defines the threshold
- for vertices to be considered "insignificant" for the general
- structure of the geometry.
+ OpenLayers.Geometry.LineString::simplify is a recursive
+ implementation of the famous Douglas-Peucker algorithm. It is
+ controlled by a tolerance factor that defines the threshold for
+ vertices to be considered "insignificant" for the
+ general structure of the geometry.
</p>
<p>
The LineString on the left map can be simplified according to
@@ -59,12 +65,18 @@
Use a value between 0 and 1 for best results. If you navigate
the left map, the right map will show the same location to make
it easier to spot the differeces between the LineStrings.
- </p>
+ </p>
<p>
- The LineString
- represents a part of the coastline of
- <a href="http://www.openstreetmap.org/?lat=54.7309684753418&lon=83.1809234619141&zoom=11">this
- place in Russia</a> — found via <a href="http://ryba4.com/python/ramer-douglas-peucker">an
+ You can also use the button "Start animation" to get
+ results for increasing tolerance-factors from 0.02 to 1.0. The
+ animation can be paused by clicking on the button "Stop
+ animation".
+ </p>
+ <p>
+ The LineString represents a part of the coastline of
+ <a href="http://www.openstreetmap.org/?lat=54.7309684753418&lon=83.1809234619141&zoom=11">this
+ place southeast of Novosibirsk in Russia</a> — found via
+ <a href="http://ryba4.com/python/ramer-douglas-peucker">an
example implementation of the algorithm in python</a>.
</p>
<p>
@@ -77,10 +89,12 @@
(<a href="http://dx.doi.org/10.3138/FM57-6770-U75U-7727">DOI:
10.3138/FM57-6770-U75U-7727</a>).
</p>
+ <p>See <a href="simplify-linestring.js">simplify-linestring.js</a>
+ for the source code of this example.</p>
</div>
<script type="text/javascript" src="../lib/OpenLayers.js">
</script>
- <script type="text/javascript" src="simplify-linestring.js">
+ <script type="text/javascript" src="./simplify-linestring.js">
</script>
</body>
</html>
More information about the Commits
