[OpenLayers-Commits] r10887 - in sandbox/elemoine/kinetic: . build
examples
commits-20090109 at openlayers.org
Wed Nov 10 16:09:00 EST 2010
Author: erilem
Date: 2010-11-10 13:08:59 -0800 (Wed, 10 Nov 2010)
New Revision: 10887
Added:
sandbox/elemoine/kinetic/OpenLayers.js
sandbox/elemoine/kinetic/build/kinetic.cfg
sandbox/elemoine/kinetic/examples/kinetic.html
use an OpenLayers build for the kinetic example
Added: sandbox/elemoine/kinetic/OpenLayers.js
--- sandbox/elemoine/kinetic/OpenLayers.js (rev 0)
+++ sandbox/elemoine/kinetic/OpenLayers.js 2010-11-10 21:08:59 UTC (rev 10887)
@@ -0,0 +1,621 @@
+ OpenLayers.js -- OpenLayers Map Viewer Library
+ Copyright 2005-2010 OpenLayers Contributors, released under the Clear BSD
+ license. Please see http://svn.openlayers.org/trunk/openlayers/license.txt
+ for the full text of the license.
+ Includes compressed code under the following licenses:
+ (For uncompressed versions of the code used please see the
+ OpenLayers SVN repository: <http://openlayers.org/>)
+/* Contains portions of Prototype.js:
+ * Prototype JavaScript framework, version 1.4.0
+ * (c) 2005 Sam Stephenson <sam at conio.net>
+ * Prototype is freely distributable under the terms of an MIT-style license.
+ * For details, see the Prototype web site: http://prototype.conio.net/
+* Contains portions of Rico <http://openrico.org/>
+* Copyright 2005 Sabre Airline Solutions
+* Licensed under the Apache License, Version 2.0 (the "License"); you
+* may not use this file except in compliance with the License. You
+* may obtain a copy of the License at
+* http://www.apache.org/licenses/LICENSE-2.0
+* Unless required by applicable law or agreed to in writing, software
+* distributed under the License is distributed on an "AS IS" BASIS,
+* WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or
+* implied. See the License for the specific language governing
+* permissions and limitations under the License.
+ * Contains XMLHttpRequest.js <http://code.google.com/p/xmlhttprequest/>
+ * Copyright 2007 Sergey Ilinsky (http://www.ilinsky.com)
+ * Licensed under the Apache License, Version 2.0 (the "License");
+ * you may not use this file except in compliance with the License.
+ * You may obtain a copy of the License at
+ * http://www.apache.org/licenses/LICENSE-2.0
+ * Contains portions of Gears <http://code.google.com/apis/gears/>
+ * Copyright 2007, Google Inc.
+ * Redistribution and use in source and binary forms, with or without
+ * modification, are permitted provided that the following conditions are met:
+ * 1. Redistributions of source code must retain the above copyright notice,
+ * this list of conditions and the following disclaimer.
+ * 2. Redistributions in binary form must reproduce the above copyright notice,
+ * this list of conditions and the following disclaimer in the documentation
+ * and/or other materials provided with the distribution.
+ * 3. Neither the name of Google Inc. nor the names of its contributors may be
+ * used to endorse or promote products derived from this software without
+ * specific prior written permission.
+ * THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS OR IMPLIED
+ * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF
+ * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO
+ * EVENT SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
+ * SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
+ * PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS;
+ * OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
+ * WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
+ * OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF
+ * ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
+ * Sets up google.gears.*, which is *the only* supported way to access Gears.
+ * Circumvent this file at your own risk!
+ * In the future, Gears may automatically define google.gears.* without this
+ * file. Gears may use these objects to transparently fix bugs and compatibility
+ * issues. Applications that use the code below will continue to work seamlessly
+ * when that happens.
+ * OpenLayers.Util.pagePosition is based on Yahoo's getXY method, which is
+ * Copyright (c) 2006, Yahoo! Inc.
+ * All rights reserved.
+ * Redistribution and use of this software in source and binary forms, with or
+ * without modification, are permitted provided that the following conditions
+ * are met:
+ * * Redistributions of source code must retain the above copyright notice,
+ * * Redistributions in binary form must reproduce the above copyright notice,
+ * * Neither the name of Yahoo! Inc. nor the names of its contributors may be
+ * specific prior written permission of Yahoo! Inc.
+ * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
+ * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+ * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
+ * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
+ * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
+ * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
+ * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
+ * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
+ * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
+ * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
+ * POSSIBILITY OF SUCH DAMAGE.
+ */var OpenLayers={VERSION_NUMBER:"$Revision$",singleFile:true,_getScriptLocation:(function(){var r=new RegExp("(^|(.*?\\/))(OpenLayers\.js)(\\?|$)"),s=document.getElementsByTagName('script'),src,m,l="";for(var i=0,len=s.length;i<len;i++){src=s[i].getAttribute('src');if(src){var m=src.match(r);if(m){l=m[1];break;}}}
+return(function(){return l;});})()};OpenLayers.String={startsWith:function(str,sub){return(str.indexOf(sub)==0);},contains:function(str,sub){return(str.indexOf(sub)!=-1);},trim:function(str){return str.replace(/^\s\s*/,'').replace(/\s\s*$/,'');},camelize:function(str){var oStringList=str.split('-');var camelizedString=oStringList[0];for(var i=1,len=oStringList.length;i<len;i++){var s=oStringList[i];camelizedString+=s.charAt(0).toUpperCase()+s.substring(1);}
+return camelizedString;},format:function(template,context,args){if(!context){context=window;}
+var replacer=function(str,match){var replacement;var subs=match.split(/\.+/);for(var i=0;i<subs.length;i++){if(i==0){replacement=context;}
+replacement=replacement[subs[i]];}
+if(typeof replacement=="function"){replacement=args?replacement.apply(null,args):replacement();}
+if(typeof replacement=='undefined'){return'undefined';}else{return replacement;}};return template.replace(OpenLayers.String.tokenRegEx,replacer);},tokenRegEx:/\$\{([\w.]+?)\}/g,numberRegEx:/^([+-]?)(?=\d|\.\d)\d*(\.\d*)?([Ee]([+-]?\d+))?$/,isNumeric:function(value){return OpenLayers.String.numberRegEx.test(value);},numericIf:function(value){return OpenLayers.String.isNumeric(value)?parseFloat(value):value;}};if(!String.prototype.startsWith){String.prototype.startsWith=function(sStart){OpenLayers.Console.warn(OpenLayers.i18n("methodDeprecated",{'newMethod':'OpenLayers.String.startsWith'}));return OpenLayers.String.startsWith(this,sStart);};}
+if(!String.prototype.contains){String.prototype.contains=function(str){OpenLayers.Console.warn(OpenLayers.i18n("methodDeprecated",{'newMethod':'OpenLayers.String.contains'}));return OpenLayers.String.contains(this,str);};}
+if(!String.prototype.trim){String.prototype.trim=function(){OpenLayers.Console.warn(OpenLayers.i18n("methodDeprecated",{'newMethod':'OpenLayers.String.trim'}));return OpenLayers.String.trim(this);};}
+if(!String.prototype.camelize){String.prototype.camelize=function(){OpenLayers.Console.warn(OpenLayers.i18n("methodDeprecated",{'newMethod':'OpenLayers.String.camelize'}));return OpenLayers.String.camelize(this);};}
+OpenLayers.Number={decimalSeparator:".",thousandsSeparator:",",limitSigDigs:function(num,sig){var fig=0;if(sig>0){fig=parseFloat(num.toPrecision(sig));}
+return fig;},format:function(num,dec,tsep,dsep){dec=(typeof dec!="undefined")?dec:0;tsep=(typeof tsep!="undefined")?tsep:OpenLayers.Number.thousandsSeparator;dsep=(typeof dsep!="undefined")?dsep:OpenLayers.Number.decimalSeparator;if(dec!=null){num=parseFloat(num.toFixed(dec));}
+var parts=num.toString().split(".");if(parts.length==1&&dec==null){dec=0;}
+var integer=parts[0];if(tsep){var thousands=/(-?[0-9]+)([0-9]{3})/;while(thousands.test(integer)){integer=integer.replace(thousands,"$1"+tsep+"$2");}}
+var str;if(dec==0){str=integer;}else{var rem=parts.length>1?parts[1]:"0";if(dec!=null){rem=rem+new Array(dec-rem.length+1).join("0");}
+str=integer+dsep+rem;}
+return str;}};if(!Number.prototype.limitSigDigs){Number.prototype.limitSigDigs=function(sig){OpenLayers.Console.warn(OpenLayers.i18n("methodDeprecated",{'newMethod':'OpenLayers.Number.limitSigDigs'}));return OpenLayers.Number.limitSigDigs(this,sig);};}
+OpenLayers.Function={bind:function(func,object){var args=Array.prototype.slice.apply(arguments,[2]);return function(){var newArgs=args.concat(Array.prototype.slice.apply(arguments,[0]));return func.apply(object,newArgs);};},bindAsEventListener:function(func,object){return function(event){return func.call(object,event||window.event);};},False:function(){return false;},True:function(){return true;}};if(!Function.prototype.bind){Function.prototype.bind=function(){OpenLayers.Console.warn(OpenLayers.i18n("methodDeprecated",{'newMethod':'OpenLayers.Function.bind'}));Array.prototype.unshift.apply(arguments,[this]);return OpenLayers.Function.bind.apply(null,arguments);};}
+if(!Function.prototype.bindAsEventListener){Function.prototype.bindAsEventListener=function(object){OpenLayers.Console.warn(OpenLayers.i18n("methodDeprecated",{'newMethod':'OpenLayers.Function.bindAsEventListener'}));return OpenLayers.Function.bindAsEventListener(this,object);};}
+OpenLayers.Array={filter:function(array,callback,caller){var selected=[];if(Array.prototype.filter){selected=array.filter(callback,caller);}else{var len=array.length;if(typeof callback!="function"){throw new TypeError();}
+for(var i=0;i<len;i++){if(i in array){var val=array[i];if(callback.call(caller,val,i,array)){selected.push(val);}}}}
+return selected;}};OpenLayers.Date={toISOString:(function(){if("toISOString"in Date.prototype){return function(date){return date.toISOString();};}else{function pad(num,len){var str=num+"";while(str.length<len){str="0"+str;}
+return str;}
+return function(date){var str;if(isNaN(date.getTime())){str="Invalid Date";}else{str=date.getUTCFullYear()+"-"+
+pad(date.getUTCMonth()+1,2)+"-"+
+pad(date.getUTCDate(),2)+"T"+
+pad(date.getUTCHours(),2)+":"+
+pad(date.getUTCMinutes(),2)+":"+
+pad(date.getUTCSeconds(),2)+"."+
+pad(date.getUTCMilliseconds(),3)+"Z";}
+return str;};}})(),parse:function(str){var date;var elapsed=Date.parse(str);if(!isNaN(elapsed)){date=new Date(elapsed);}else{var match=str.match(/^(?:(\d{4})(?:-(\d{2})(?:-(\d{2}))?)?)?(?:T(\d{1,2}):(\d{2}):(\d{2}(?:\.\d+)?)(Z|(?:[+-]\d{1,2}(?::(\d{2}))?)))?$/);if(match&&(match[1]||match[7])){var year=parseInt(match[1],10)||0;var month=(parseInt(match[2],10)-1)||0;var day=parseInt(match[3],10)||1;date=new Date(Date.UTC(year,month,day));var type=match[7];if(type){var hours=parseInt(match[4],10);var minutes=parseInt(match[5],10);var secFrac=parseFloat(match[6]);var seconds=secFrac|0;var milliseconds=Math.round(1000*(secFrac-seconds));date.setUTCHours(hours,minutes,seconds,milliseconds);if(type!=="Z"){var hoursOffset=parseInt(type,10);var minutesOffset=parseInt(match[8])||0;var offset=-1000*(60*(hoursOffset*60)+minutesOffset*60);date=new Date(date.getTime()+offset);}}}else{date=new Date("invalid");}}
+return date;}};OpenLayers.Class=function(){var len=arguments.length;var P=arguments[0];var F=arguments[len-1];var C=typeof F.initialize=="function"?F.initialize:function(){P.apply(this,arguments);};if(len>1){var newArgs=[C,P].concat(Array.prototype.slice.call(arguments).slice(1,len-1),F);OpenLayers.inherit.apply(null,newArgs);}else{C.prototype=F;}
+return C;};OpenLayers.Class.isPrototype=function(){};OpenLayers.Class.create=function(){return function(){if(arguments&&arguments[0]!=OpenLayers.Class.isPrototype){this.initialize.apply(this,arguments);}};};OpenLayers.Class.inherit=function(P){var C=function(){P.call(this);};var newArgs=[C].concat(Array.prototype.slice.call(arguments));OpenLayers.inherit.apply(null,newArgs);return C.prototype;};OpenLayers.inherit=function(C,P){var F=function(){};F.prototype=P.prototype;C.prototype=new F;var i,l,o;for(i=2,l=arguments.length;i<l;i++){o=arguments[i];if(typeof o==="function"){o=o.prototype;}
+OpenLayers.Util.extend(C.prototype,o);}};OpenLayers.Util={};OpenLayers.Util.getElement=function(){var elements=[];for(var i=0,len=arguments.length;i<len;i++){var element=arguments[i];if(typeof element=='string'){element=document.getElementById(element);}
+if(arguments.length==1){return element;}
+elements.push(element);}
+return elements;};OpenLayers.Util.isElement=function(o){return!!(o&&o.nodeType===1);};if(typeof window.$==="undefined"){window.$=OpenLayers.Util.getElement;}
+OpenLayers.Util.extend=function(destination,source){destination=destination||{};if(source){for(var property in source){var value=source[property];if(value!==undefined){destination[property]=value;}}
+var sourceIsEvt=typeof window.Event=="function"&&source instanceof window.Event;if(!sourceIsEvt&&source.hasOwnProperty&&source.hasOwnProperty('toString')){destination.toString=source.toString;}}
+return destination;};OpenLayers.Util.removeItem=function(array,item){for(var i=array.length-1;i>=0;i--){if(array[i]==item){array.splice(i,1);}}
+return array;};OpenLayers.Util.clearArray=function(array){OpenLayers.Console.warn(OpenLayers.i18n("methodDeprecated",{'newMethod':'array = []'}));array.length=0;};OpenLayers.Util.indexOf=function(array,obj){if(typeof array.indexOf=="function"){return array.indexOf(obj);}else{for(var i=0,len=array.length;i<len;i++){if(array[i]==obj){return i;}}
+return-1;}};OpenLayers.Util.modifyDOMElement=function(element,id,px,sz,position,border,overflow,opacity){if(id){element.id=id;}
+if(px){element.style.left=px.x+"px";element.style.top=px.y+"px";}
+if(sz){element.style.width=sz.w+"px";element.style.height=sz.h+"px";}
+if(position){element.style.position=position;}
+if(border){element.style.border=border;}
+if(overflow){element.style.overflow=overflow;}
+if(parseFloat(opacity)>=0.0&&parseFloat(opacity)<1.0){element.style.filter='alpha(opacity='+(opacity*100)+')';element.style.opacity=opacity;}else if(parseFloat(opacity)==1.0){element.style.filter='';element.style.opacity='';}};OpenLayers.Util.createDiv=function(id,px,sz,imgURL,position,border,overflow,opacity){var dom=document.createElement('div');if(imgURL){dom.style.backgroundImage='url('+imgURL+')';}
+if(!id){id=OpenLayers.Util.createUniqueID("OpenLayersDiv");}
+if(!position){position="absolute";}
+OpenLayers.Util.modifyDOMElement(dom,id,px,sz,position,border,overflow,opacity);return dom;};OpenLayers.Util.createImage=function(id,px,sz,imgURL,position,border,opacity,delayDisplay){var image=document.createElement("img");if(!id){id=OpenLayers.Util.createUniqueID("OpenLayersDiv");}
+if(!position){position="relative";}
+OpenLayers.Util.modifyDOMElement(image,id,px,sz,position,border,null,opacity);if(delayDisplay){image.style.display="none";OpenLayers.Event.observe(image,"load",OpenLayers.Function.bind(OpenLayers.Util.onImageLoad,image));OpenLayers.Event.observe(image,"error",OpenLayers.Function.bind(OpenLayers.Util.onImageLoadError,image));}
+image.style.alt=id;image.galleryImg="no";if(imgURL){image.src=imgURL;}
+return image;};OpenLayers.Util.setOpacity=function(element,opacity){OpenLayers.Util.modifyDOMElement(element,null,null,null,null,null,null,opacity);};OpenLayers.Util.onImageLoad=function(){if(!this.viewRequestID||(this.map&&this.viewRequestID==this.map.viewRequestID)){this.style.display="";}
+OpenLayers.Element.removeClass(this,"olImageLoadError");};OpenLayers.IMAGE_RELOAD_ATTEMPTS=0;OpenLayers.Util.onImageLoadError=function(){this._attempts=(this._attempts)?(this._attempts+1):1;if(this._attempts<=OpenLayers.IMAGE_RELOAD_ATTEMPTS){var urls=this.urls;if(urls&&urls instanceof Array&&urls.length>1){var src=this.src.toString();var current_url,k;for(k=0;current_url=urls[k];k++){if(src.indexOf(current_url)!=-1){break;}}
+var guess=Math.floor(urls.length*Math.random());var new_url=urls[guess];k=0;while(new_url==current_url&&k++<4){guess=Math.floor(urls.length*Math.random());new_url=urls[guess];}
+this.src=src.replace(current_url,new_url);}else{this.src=this.src;}}else{OpenLayers.Element.addClass(this,"olImageLoadError");}
+this.style.display="";};OpenLayers.Util.alphaHackNeeded=null;OpenLayers.Util.alphaHack=function(){if(OpenLayers.Util.alphaHackNeeded==null){var arVersion=navigator.appVersion.split("MSIE");var version=parseFloat(arVersion[1]);var filter=false;try{filter=!!(document.body.filters);}catch(e){}
+OpenLayers.Util.alphaHackNeeded=(filter&&(version>=5.5)&&(version<7));}
+return OpenLayers.Util.alphaHackNeeded;};OpenLayers.Util.modifyAlphaImageDiv=function(div,id,px,sz,imgURL,position,border,sizing,opacity){OpenLayers.Util.modifyDOMElement(div,id,px,sz,position,null,null,opacity);var img=div.childNodes[0];if(imgURL){img.src=imgURL;}
+OpenLayers.Util.modifyDOMElement(img,div.id+"_innerImage",null,sz,"relative",border);if(OpenLayers.Util.alphaHack()){if(div.style.display!="none"){div.style.display="inline-block";}
+if(sizing==null){sizing="scale";}
+div.style.filter="progid:DXImageTransform.Microsoft"+".AlphaImageLoader(src='"+img.src+"', "+"sizingMethod='"+sizing+"')";if(parseFloat(div.style.opacity)>=0.0&&parseFloat(div.style.opacity)<1.0){div.style.filter+=" alpha(opacity="+div.style.opacity*100+")";}
+img.style.filter="alpha(opacity=0)";}};OpenLayers.Util.createAlphaImageDiv=function(id,px,sz,imgURL,position,border,sizing,opacity,delayDisplay){var div=OpenLayers.Util.createDiv();var img=OpenLayers.Util.createImage(null,null,null,null,null,null,null,false);div.appendChild(img);if(delayDisplay){img.style.display="none";OpenLayers.Event.observe(img,"load",OpenLayers.Function.bind(OpenLayers.Util.onImageLoad,div));OpenLayers.Event.observe(img,"error",OpenLayers.Function.bind(OpenLayers.Util.onImageLoadError,div));}
+OpenLayers.Util.modifyAlphaImageDiv(div,id,px,sz,imgURL,position,border,sizing,opacity);return div;};OpenLayers.Util.upperCaseObject=function(object){var uObject={};for(var key in object){uObject[key.toUpperCase()]=object[key];}
+return uObject;};OpenLayers.Util.applyDefaults=function(to,from){to=to||{};var fromIsEvt=typeof window.Event=="function"&&from instanceof window.Event;for(var key in from){if(to[key]===undefined||(!fromIsEvt&&from.hasOwnProperty&&from.hasOwnProperty(key)&&!to.hasOwnProperty(key))){to[key]=from[key];}}
+if(!fromIsEvt&&from&&from.hasOwnProperty&&from.hasOwnProperty('toString')&&!to.hasOwnProperty('toString')){to.toString=from.toString;}
+return to;};OpenLayers.Util.getParameterString=function(params){var paramsArray=[];for(var key in params){var value=params[key];if((value!=null)&&(typeof value!='function')){var encodedValue;if(typeof value=='object'&&value.constructor==Array){var encodedItemArray=[];var item;for(var itemIndex=0,len=value.length;itemIndex<len;itemIndex++){item=value[itemIndex];encodedItemArray.push(encodeURIComponent((item===null||item===undefined)?"":item));}
+encodedValue=encodedItemArray.join(",");}
+else{encodedValue=encodeURIComponent(value);}
+paramsArray.push(encodeURIComponent(key)+"="+encodedValue);}}
+return paramsArray.join("&");};OpenLayers.Util.urlAppend=function(url,paramStr){var newUrl=url;if(paramStr){var parts=(url+" ").split(/[?&]/);newUrl+=(parts.pop()===" "?paramStr:parts.length?"&"+paramStr:"?"+paramStr);}
+return newUrl;};OpenLayers.ImgPath='';OpenLayers.Util.getImagesLocation=function(){return OpenLayers.ImgPath||(OpenLayers._getScriptLocation()+"img/");};OpenLayers.Util.Try=function(){var returnValue=null;for(var i=0,len=arguments.length;i<len;i++){var lambda=arguments[i];try{returnValue=lambda();break;}catch(e){}}
+return returnValue;};OpenLayers.Util.getNodes=function(p,tagName){var nodes=OpenLayers.Util.Try(function(){return OpenLayers.Util._getNodes(p.documentElement.childNodes,tagName);},function(){return OpenLayers.Util._getNodes(p.childNodes,tagName);});return nodes;};OpenLayers.Util._getNodes=function(nodes,tagName){var retArray=[];for(var i=0,len=nodes.length;i<len;i++){if(nodes[i].nodeName==tagName){retArray.push(nodes[i]);}}
+return retArray;};OpenLayers.Util.getTagText=function(parent,item,index){var result=OpenLayers.Util.getNodes(parent,item);if(result&&(result.length>0))
+{if(!index){index=0;}
+if(result[index].childNodes.length>1){return result.childNodes[1].nodeValue;}
+else if(result[index].childNodes.length==1){return result[index].firstChild.nodeValue;}}else{return"";}};OpenLayers.Util.getXmlNodeValue=function(node){var val=null;OpenLayers.Util.Try(function(){val=node.text;if(!val){val=node.textContent;}
+if(!val){val=node.firstChild.nodeValue;}},function(){val=node.textContent;});return val;};OpenLayers.Util.mouseLeft=function(evt,div){var target=(evt.relatedTarget)?evt.relatedTarget:evt.toElement;while(target!=div&&target!=null){target=target.parentNode;}
+return(target!=div);};OpenLayers.Util.DEFAULT_PRECISION=14;OpenLayers.Util.toFloat=function(number,precision){if(precision==null){precision=OpenLayers.Util.DEFAULT_PRECISION;}
+var number;if(precision==0){number=parseFloat(number);}else{number=parseFloat(parseFloat(number).toPrecision(precision));}
+return number;};OpenLayers.Util.rad=function(x){return x*Math.PI/180;};OpenLayers.Util.deg=function(x){return x*180/Math.PI;};OpenLayers.Util.VincentyConstants={a:6378137,b:6356752.3142,f:1/298.257223563};OpenLayers.Util.distVincenty=function(p1,p2){var ct=OpenLayers.Util.VincentyConstants;var a=ct.a,b=ct.b,f=ct.f;var L=OpenLayers.Util.rad(p2.lon-p1.lon);var U1=Math.atan((1-f)*Math.tan(OpenLayers.Util.rad(p1.lat)));var U2=Math.atan((1-f)*Math.tan(OpenLayers.Util.rad(p2.lat)));var sinU1=Math.sin(U1),cosU1=Math.cos(U1);var sinU2=Math.sin(U2),cosU2=Math.cos(U2);var lambda=L,lambdaP=2*Math.PI;var iterLimit=20;while(Math.abs(lambda-lambdaP)>1e-12&&--iterLimit>0){var sinLambda=Math.sin(lambda),cosLambda=Math.cos(lambda);var sinSigma=Math.sqrt((cosU2*sinLambda)*(cosU2*sinLambda)+
+(cosU1*sinU2-sinU1*cosU2*cosLambda)*(cosU1*sinU2-sinU1*cosU2*cosLambda));if(sinSigma==0){return 0;}
+var cosSigma=sinU1*sinU2+cosU1*cosU2*cosLambda;var sigma=Math.atan2(sinSigma,cosSigma);var alpha=Math.asin(cosU1*cosU2*sinLambda/sinSigma);var cosSqAlpha=Math.cos(alpha)*Math.cos(alpha);var cos2SigmaM=cosSigma-2*sinU1*sinU2/cosSqAlpha;var C=f/16*cosSqAlpha*(4+f*(4-3*cosSqAlpha));lambdaP=lambda;lambda=L+(1-C)*f*Math.sin(alpha)*(sigma+C*sinSigma*(cos2SigmaM+C*cosSigma*(-1+2*cos2SigmaM*cos2SigmaM)));}
+if(iterLimit==0){return NaN;}
+var uSq=cosSqAlpha*(a*a-b*b)/(b*b);var A=1+uSq/16384*(4096+uSq*(-768+uSq*(320-175*uSq)));var B=uSq/1024*(256+uSq*(-128+uSq*(74-47*uSq)));var deltaSigma=B*sinSigma*(cos2SigmaM+B/4*(cosSigma*(-1+2*cos2SigmaM*cos2SigmaM)-
+B/6*cos2SigmaM*(-3+4*sinSigma*sinSigma)*(-3+4*cos2SigmaM*cos2SigmaM)));var s=b*A*(sigma-deltaSigma);var d=s.toFixed(3)/1000;return d;};OpenLayers.Util.destinationVincenty=function(lonlat,brng,dist){var u=OpenLayers.Util;var ct=u.VincentyConstants;var a=ct.a,b=ct.b,f=ct.f;var lon1=lonlat.lon;var lat1=lonlat.lat;var s=dist;var alpha1=u.rad(brng);var sinAlpha1=Math.sin(alpha1);var cosAlpha1=Math.cos(alpha1);var tanU1=(1-f)*Math.tan(u.rad(lat1));var cosU1=1/Math.sqrt((1+tanU1*tanU1)),sinU1=tanU1*cosU1;var sigma1=Math.atan2(tanU1,cosAlpha1);var sinAlpha=cosU1*sinAlpha1;var cosSqAlpha=1-sinAlpha*sinAlpha;var uSq=cosSqAlpha*(a*a-b*b)/(b*b);var A=1+uSq/16384*(4096+uSq*(-768+uSq*(320-175*uSq)));var B=uSq/1024*(256+uSq*(-128+uSq*(74-47*uSq)));var sigma=s/(b*A),sigmaP=2*Math.PI;while(Math.abs(sigma-sigmaP)>1e-12){var cos2SigmaM=Math.cos(2*sigma1+sigma);var sinSigma=Math.sin(sigma);var cosSigma=Math.cos(sigma);var deltaSigma=B*sinSigma*(cos2SigmaM+B/4*(cosSigma*(-1+2*cos2SigmaM*cos2Sigm
aM)-
+B/6*cos2SigmaM*(-3+4*sinSigma*sinSigma)*(-3+4*cos2SigmaM*cos2SigmaM)));sigmaP=sigma;sigma=s/(b*A)+deltaSigma;}
+var tmp=sinU1*sinSigma-cosU1*cosSigma*cosAlpha1;var lat2=Math.atan2(sinU1*cosSigma+cosU1*sinSigma*cosAlpha1,(1-f)*Math.sqrt(sinAlpha*sinAlpha+tmp*tmp));var lambda=Math.atan2(sinSigma*sinAlpha1,cosU1*cosSigma-sinU1*sinSigma*cosAlpha1);var C=f/16*cosSqAlpha*(4+f*(4-3*cosSqAlpha));var L=lambda-(1-C)*f*sinAlpha*(sigma+C*sinSigma*(cos2SigmaM+C*cosSigma*(-1+2*cos2SigmaM*cos2SigmaM)));var revAz=Math.atan2(sinAlpha,-tmp);return new OpenLayers.LonLat(lon1+u.deg(L),u.deg(lat2));};OpenLayers.Util.getParameters=function(url){url=url||window.location.href;var paramsString="";if(OpenLayers.String.contains(url,'?')){var start=url.indexOf('?')+1;var end=OpenLayers.String.contains(url,"#")?url.indexOf('#'):url.length;paramsString=url.substring(start,end);}
+var parameters={};var pairs=paramsString.split(/[&;]/);for(var i=0,len=pairs.length;i<len;++i){var keyValue=pairs[i].split('=');if(keyValue[0]){var key=keyValue[0];try{key=decodeURIComponent(key);}catch(err){key=unescape(key);}
+var value=(keyValue[1]||'').replace(/\+/g," ");try{value=decodeURIComponent(value);}catch(err){value=unescape(value);}
+value=value.split(",")
+if(value.length==1){value=value[0];}
+parameters[key]=value;}}
+return parameters;};OpenLayers.Util.getArgs=function(url){OpenLayers.Console.warn(OpenLayers.i18n("methodDeprecated",{'newMethod':'OpenLayers.Util.getParameters'}));return OpenLayers.Util.getParameters(url);};OpenLayers.Util.lastSeqID=0;OpenLayers.Util.createUniqueID=function(prefix){if(prefix==null){prefix="id_";}
+OpenLayers.Util.lastSeqID+=1;return prefix+OpenLayers.Util.lastSeqID;};OpenLayers.INCHES_PER_UNIT={'inches':1.0,'ft':12.0,'mi':63360.0,'m':39.3701,'km':39370.1,'dd':4374754,'yd':36};OpenLayers.INCHES_PER_UNIT["in"]=OpenLayers.INCHES_PER_UNIT.inches;OpenLayers.INCHES_PER_UNIT["degrees"]=OpenLayers.INCHES_PER_UNIT.dd;OpenLayers.INCHES_PER_UNIT["nmi"]=1852*OpenLayers.INCHES_PER_UNIT.m;OpenLayers.METERS_PER_INCH=0.02540005080010160020;OpenLayers.Util.extend(OpenLayers.INCHES_PER_UNIT,{"Inch":OpenLayers.INCHES_PER_UNIT.inches,"Meter":1.0/OpenLayers.METERS_PER_INCH,"Foot":0.30480060960121920243/OpenLayers.METERS_PER_INCH,"IFoot":0.30480000000000000000/OpenLayers.METERS_PER_INCH,"ClarkeFoot":0.3047972651151/OpenLayers.METERS_PER_INCH,"SearsFoot":0.30479947153867624624/OpenLayers.METERS_PER_INCH,"GoldCoastFoot":0.30479971018150881758/OpenLayers.METERS_PER_INCH,"IInch":0.02540000000000000000/OpenLayers.METERS_PER_INCH,"MicroInch":0.00002540000000000000/OpenLayers.METERS_PER_INCH,"Mil
":0.00000002540000000000/OpenLayers.METERS_PER_INCH,"Centimeter":0.01000000000000000000/OpenLayers.METERS_PER_INCH,"Kilometer":1000.00000000000000000000/OpenLayers.METERS_PER_INCH,"Yard":0.91440182880365760731/OpenLayers.METERS_PER_INCH,"SearsYard":0.914398414616029/OpenLayers.METERS_PER_INCH,"IndianYard":0.91439853074444079983/OpenLayers.METERS_PER_INCH,"IndianYd37":0.91439523/OpenLayers.METERS_PER_INCH,"IndianYd62":0.9143988/OpenLayers.METERS_PER_INCH,"IndianYd75":0.9143985/OpenLayers.METERS_PER_INCH,"IndianFoot":0.30479951/OpenLayers.METERS_PER_INCH,"IndianFt37":0.30479841/OpenLayers.METERS_PER_INCH,"IndianFt62":0.3047996/OpenLayers.METERS_PER_INCH,"IndianFt75":0.3047995/OpenLayers.METERS_PER_INCH,"Mile":1609.34721869443738887477/OpenLayers.METERS_PER_INCH,"IYard":0.91440000000000000000/OpenLayers.METERS_PER_INCH,"IMile":1609.34400000000000000000/OpenLayers.METERS_PER_INCH,"NautM":1852.00000000000000000000/OpenLayers.METERS_PER_INCH,"Lat-66":110943.316488932731/OpenLayers
.METERS_PER_INCH,"Lat-83":110946.25736872234125/OpenLayers.METERS_PER_INCH,"Decimeter":0.10000000000000000000/OpenLayers.METERS_PER_INCH,"Millimeter":0.00100000000000000000/OpenLayers.METERS_PER_INCH,"Dekameter":10.00000000000000000000/OpenLayers.METERS_PER_INCH,"Decameter":10.00000000000000000000/OpenLayers.METERS_PER_INCH,"Hectometer":100.00000000000000000000/OpenLayers.METERS_PER_INCH,"GermanMeter":1.0000135965/OpenLayers.METERS_PER_INCH,"CaGrid":0.999738/OpenLayers.METERS_PER_INCH,"ClarkeChain":20.1166194976/OpenLayers.METERS_PER_INCH,"GunterChain":20.11684023368047/OpenLayers.METERS_PER_INCH,"BenoitChain":20.116782494375872/OpenLayers.METERS_PER_INCH,"SearsChain":20.11676512155/OpenLayers.METERS_PER_INCH,"ClarkeLink":0.201166194976/OpenLayers.METERS_PER_INCH,"GunterLink":0.2011684023368047/OpenLayers.METERS_PER_INCH,"BenoitLink":0.20116782494375872/OpenLayers.METERS_PER_INCH,"SearsLink":0.2011676512155/OpenLayers.METERS_PER_INCH,"Rod":5.02921005842012/OpenLayers.METERS_
PER_INCH,"IntnlChain":20.1168/OpenLayers.METERS_PER_INCH,"IntnlLink":0.201168/OpenLayers.METERS_PER_INCH,"Perch":5.02921005842012/OpenLayers.METERS_PER_INCH,"Pole":5.02921005842012/OpenLayers.METERS_PER_INCH,"Furlong":201.1684023368046/OpenLayers.METERS_PER_INCH,"Rood":3.778266898/OpenLayers.METERS_PER_INCH,"CapeFoot":0.3047972615/OpenLayers.METERS_PER_INCH,"Brealey":375.00000000000000000000/OpenLayers.METERS_PER_INCH,"ModAmFt":0.304812252984505969011938/OpenLayers.METERS_PER_INCH,"Fathom":1.8288/OpenLayers.METERS_PER_INCH,"NautM-UK":1853.184/OpenLayers.METERS_PER_INCH,"50kilometers":50000.0/OpenLayers.METERS_PER_INCH,"150kilometers":150000.0/OpenLayers.METERS_PER_INCH});OpenLayers.Util.extend(OpenLayers.INCHES_PER_UNIT,{"mm":OpenLayers.INCHES_PER_UNIT["Meter"]/1000.0,"cm":OpenLayers.INCHES_PER_UNIT["Meter"]/100.0,"dm":OpenLayers.INCHES_PER_UNIT["Meter"]*100.0,"km":OpenLayers.INCHES_PER_UNIT["Meter"]*1000.0,"kmi":OpenLayers.INCHES_PER_UNIT["nmi"],"fath":OpenLayers.INCHES_PER
_UNIT["Fathom"],"ch":OpenLayers.INCHES_PER_UNIT["IntnlChain"],"link":OpenLayers.INCHES_PER_UNIT["IntnlLink"],"us-in":OpenLayers.INCHES_PER_UNIT["inches"],"us-ft":OpenLayers.INCHES_PER_UNIT["Foot"],"us-yd":OpenLayers.INCHES_PER_UNIT["Yard"],"us-ch":OpenLayers.INCHES_PER_UNIT["GunterChain"],"us-mi":OpenLayers.INCHES_PER_UNIT["Mile"],"ind-yd":OpenLayers.INCHES_PER_UNIT["IndianYd37"],"ind-ft":OpenLayers.INCHES_PER_UNIT["IndianFt37"],"ind-ch":20.11669506/OpenLayers.METERS_PER_INCH});OpenLayers.DOTS_PER_INCH=72;OpenLayers.Util.normalizeScale=function(scale){var normScale=(scale>1.0)?(1.0/scale):scale;return normScale;};OpenLayers.Util.getResolutionFromScale=function(scale,units){var resolution;if(scale){if(units==null){units="degrees";}
+var normScale=OpenLayers.Util.normalizeScale(scale);resolution=1/(normScale*OpenLayers.INCHES_PER_UNIT[units]*OpenLayers.DOTS_PER_INCH);}
+return resolution;};OpenLayers.Util.getScaleFromResolution=function(resolution,units){if(units==null){units="degrees";}
+var scale=resolution*OpenLayers.INCHES_PER_UNIT[units]*OpenLayers.DOTS_PER_INCH;return scale;};OpenLayers.Util.safeStopPropagation=function(evt){OpenLayers.Event.stop(evt,true);};OpenLayers.Util.pagePosition=function(forElement){var pos=[0,0];var viewportElement=OpenLayers.Util.getViewportElement();if(!forElement||forElement==window||forElement==viewportElement){return pos;}
+var BUGGY_GECKO_BOX_OBJECT=OpenLayers.IS_GECKO&&document.getBoxObjectFor&&OpenLayers.Element.getStyle(forElement,'position')=='absolute'&&(forElement.style.top==''||forElement.style.left=='');var parent=null;var box;if(forElement.getBoundingClientRect){box=forElement.getBoundingClientRect();var scrollTop=viewportElement.scrollTop;var scrollLeft=viewportElement.scrollLeft;pos[0]=box.left+scrollLeft;pos[1]=box.top+scrollTop;}else if(document.getBoxObjectFor&&!BUGGY_GECKO_BOX_OBJECT){box=document.getBoxObjectFor(forElement);var vpBox=document.getBoxObjectFor(viewportElement);pos[0]=box.screenX-vpBox.screenX;pos[1]=box.screenY-vpBox.screenY;}else{pos[0]=forElement.offsetLeft;pos[1]=forElement.offsetTop;parent=forElement.offsetParent;if(parent!=forElement){while(parent){pos[0]+=parent.offsetLeft;pos[1]+=parent.offsetTop;parent=parent.offsetParent;}}
+var browser=OpenLayers.BROWSER_NAME;if(browser=="opera"||(browser=="safari"&&OpenLayers.Element.getStyle(forElement,'position')=='absolute')){pos[1]-=document.body.offsetTop;}
+parent=forElement.offsetParent;while(parent&&parent!=document.body){pos[0]-=parent.scrollLeft;if(browser!="opera"||parent.tagName!='TR'){pos[1]-=parent.scrollTop;}
+parent=parent.offsetParent;}}
+return pos;};OpenLayers.Util.getViewportElement=function(){var viewportElement=arguments.callee.viewportElement;if(viewportElement==undefined){viewportElement=(OpenLayers.BROWSER_NAME=="msie"&&document.compatMode!='CSS1Compat')?document.body:document.documentElement;arguments.callee.viewportElement=viewportElement;}
+return viewportElement;};OpenLayers.Util.isEquivalentUrl=function(url1,url2,options){options=options||{};OpenLayers.Util.applyDefaults(options,{ignoreCase:true,ignorePort80:true,ignoreHash:true});var urlObj1=OpenLayers.Util.createUrlObject(url1,options);var urlObj2=OpenLayers.Util.createUrlObject(url2,options);for(var key in urlObj1){if(key!=="args"){if(urlObj1[key]!=urlObj2[key]){return false;}}}
+for(var key in urlObj1.args){if(urlObj1.args[key]!=urlObj2.args[key]){return false;}
+delete urlObj2.args[key];}
+for(var key in urlObj2.args){return false;}
+return true;};OpenLayers.Util.createUrlObject=function(url,options){options=options||{};if(!(/^\w+:\/\//).test(url)){var loc=window.location;var port=loc.port?":"+loc.port:"";var fullUrl=loc.protocol+"//"+loc.host.split(":").shift()+port;if(url.indexOf("/")===0){url=fullUrl+url;}else{var parts=loc.pathname.split("/");parts.pop();url=fullUrl+parts.join("/")+"/"+url;}}
+if(options.ignoreCase){url=url.toLowerCase();}
+var a=document.createElement('a');a.href=url;var urlObject={};urlObject.host=a.host.split(":").shift();urlObject.protocol=a.protocol;if(options.ignorePort80){urlObject.port=(a.port=="80"||a.port=="0")?"":a.port;}else{urlObject.port=(a.port==""||a.port=="0")?"80":a.port;}
+urlObject.hash=(options.ignoreHash||a.hash==="#")?"":a.hash;var queryString=a.search;if(!queryString){var qMark=url.indexOf("?");queryString=(qMark!=-1)?url.substr(qMark):"";}
+urlObject.args=OpenLayers.Util.getParameters(queryString);urlObject.pathname=(a.pathname.charAt(0)=="/")?a.pathname:"/"+a.pathname;return urlObject;};OpenLayers.Util.removeTail=function(url){var head=null;var qMark=url.indexOf("?");var hashMark=url.indexOf("#");if(qMark==-1){head=(hashMark!=-1)?url.substr(0,hashMark):url;}else{head=(hashMark!=-1)?url.substr(0,Math.min(qMark,hashMark)):url.substr(0,qMark);}
+return head;};OpenLayers.IS_GECKO=(function(){return navigator.userAgent.toLowerCase().indexOf("gecko")!=-1;})();OpenLayers.BROWSER_NAME=(function(){var name="";var ua=navigator.userAgent.toLowerCase();if(ua.indexOf("opera")!=-1){name="opera";}else if(ua.indexOf("msie")!=-1){name="msie";}else if(ua.indexOf("safari")!=-1){name="safari";}else if(ua.indexOf("mozilla")!=-1){if(ua.indexOf("firefox")!=-1){name="firefox";}else{name="mozilla";}}
+return name;})();OpenLayers.Util.getBrowserName=function(){return OpenLayers.BROWSER_NAME;};OpenLayers.Util.getRenderedDimensions=function(contentHTML,size,options){var w,h;var container=document.createElement("div");container.style.visibility="hidden";var containerElement=(options&&options.containerElement)?options.containerElement:document.body;if(size){if(size.w){w=size.w;container.style.width=w+"px";}else if(size.h){h=size.h;container.style.height=h+"px";}}
+if(options&&options.displayClass){container.className=options.displayClass;}
+var content=document.createElement("div");content.innerHTML=contentHTML;content.style.overflow="visible";if(content.childNodes){for(var i=0,l=content.childNodes.length;i<l;i++){if(!content.childNodes[i].style)continue;content.childNodes[i].style.overflow="visible";}}
+container.appendChild(content);containerElement.appendChild(container);var parentHasPositionAbsolute=false;var parent=container.parentNode;while(parent&&parent.tagName.toLowerCase()!="body"){var parentPosition=OpenLayers.Element.getStyle(parent,"position");if(parentPosition=="absolute"){parentHasPositionAbsolute=true;break;}else if(parentPosition&&parentPosition!="static"){break;}
+parent=parent.parentNode;}
+if(!parentHasPositionAbsolute){container.style.position="absolute";}
+if(!w){w=parseInt(content.scrollWidth);container.style.width=w+"px";}
+if(!h){h=parseInt(content.scrollHeight);}
+container.removeChild(content);containerElement.removeChild(container);return new OpenLayers.Size(w,h);};OpenLayers.Util.getScrollbarWidth=function(){var scrollbarWidth=OpenLayers.Util._scrollbarWidth;if(scrollbarWidth==null){var scr=null;var inn=null;var wNoScroll=0;var wScroll=0;scr=document.createElement('div');scr.style.position='absolute';scr.style.top='-1000px';scr.style.left='-1000px';scr.style.width='100px';scr.style.height='50px';scr.style.overflow='hidden';inn=document.createElement('div');inn.style.width='100%';inn.style.height='200px';scr.appendChild(inn);document.body.appendChild(scr);wNoScroll=inn.offsetWidth;scr.style.overflow='scroll';wScroll=inn.offsetWidth;document.body.removeChild(document.body.lastChild);OpenLayers.Util._scrollbarWidth=(wNoScroll-wScroll);scrollbarWidth=OpenLayers.Util._scrollbarWidth;}
+return scrollbarWidth;};OpenLayers.Util.getFormattedLonLat=function(coordinate,axis,dmsOption){if(!dmsOption){dmsOption='dms';}
+var abscoordinate=Math.abs(coordinate)
+var coordinatedegrees=Math.floor(abscoordinate);var coordinateminutes=(abscoordinate-coordinatedegrees)/(1/60);var tempcoordinateminutes=coordinateminutes;coordinateminutes=Math.floor(coordinateminutes);var coordinateseconds=(tempcoordinateminutes-coordinateminutes)/(1/60);coordinateseconds=Math.round(coordinateseconds*10);coordinateseconds/=10;if(coordinatedegrees<10){coordinatedegrees="0"+coordinatedegrees;}
+var str=coordinatedegrees+"\u00B0";if(dmsOption.indexOf('dm')>=0){if(coordinateminutes<10){coordinateminutes="0"+coordinateminutes;}
+str+=coordinateminutes+"'";if(dmsOption.indexOf('dms')>=0){if(coordinateseconds<10){coordinateseconds="0"+coordinateseconds;}
+str+=coordinateseconds+'"';}}
+if(axis=="lon"){str+=coordinate<0?OpenLayers.i18n("W"):OpenLayers.i18n("E");}else{str+=coordinate<0?OpenLayers.i18n("S"):OpenLayers.i18n("N");}
+return str;};OpenLayers.Element={visible:function(element){return OpenLayers.Util.getElement(element).style.display!='none';},toggle:function(){for(var i=0,len=arguments.length;i<len;i++){var element=OpenLayers.Util.getElement(arguments[i]);var display=OpenLayers.Element.visible(element)?'hide':'show';OpenLayers.Element[display](element);}},hide:function(){for(var i=0,len=arguments.length;i<len;i++){var element=OpenLayers.Util.getElement(arguments[i]);if(element){element.style.display='none';}}},show:function(){for(var i=0,len=arguments.length;i<len;i++){var element=OpenLayers.Util.getElement(arguments[i]);if(element){element.style.display='';}}},remove:function(element){element=OpenLayers.Util.getElement(element);element.parentNode.removeChild(element);},getHeight:function(element){element=OpenLayers.Util.getElement(element);return element.offsetHeight;},getDimensions:function(element){element=OpenLayers.Util.getElement(element);if(OpenLayers.Element.getStyle(element,'displ
ay')!='none'){return{width:element.offsetWidth,height:element.offsetHeight};}
+var els=element.style;var originalVisibility=els.visibility;var originalPosition=els.position;var originalDisplay=els.display;els.visibility='hidden';els.position='absolute';els.display='';var originalWidth=element.clientWidth;var originalHeight=element.clientHeight;els.display=originalDisplay;els.position=originalPosition;els.visibility=originalVisibility;return{width:originalWidth,height:originalHeight};},hasClass:function(element,name){var names=element.className;return(!!names&&new RegExp("(^|\\s)"+name+"(\\s|$)").test(names));},addClass:function(element,name){if(!OpenLayers.Element.hasClass(element,name)){element.className+=(element.className?" ":"")+name;}
+return element;},removeClass:function(element,name){var names=element.className;if(names){element.className=OpenLayers.String.trim(names.replace(new RegExp("(^|\\s+)"+name+"(\\s+|$)")," "));}
+return element;},toggleClass:function(element,name){if(OpenLayers.Element.hasClass(element,name)){OpenLayers.Element.removeClass(element,name);}else{OpenLayers.Element.addClass(element,name);}
+return element;},getStyle:function(element,style){element=OpenLayers.Util.getElement(element);var value=null;if(element&&element.style){value=element.style[OpenLayers.String.camelize(style)];if(!value){if(document.defaultView&&document.defaultView.getComputedStyle){var css=document.defaultView.getComputedStyle(element,null);value=css?css.getPropertyValue(style):null;}else if(element.currentStyle){value=element.currentStyle[OpenLayers.String.camelize(style)];}}
+var positions=['left','top','right','bottom'];if(window.opera&&(OpenLayers.Util.indexOf(positions,style)!=-1)&&(OpenLayers.Element.getStyle(element,'position')=='static')){value='auto';}}
+return value=='auto'?null:value;}};OpenLayers.Size=OpenLayers.Class({w:0.0,h:0.0,initialize:function(w,h){this.w=parseFloat(w);this.h=parseFloat(h);},toString:function(){return("w="+this.w+",h="+this.h);},clone:function(){return new OpenLayers.Size(this.w,this.h);},equals:function(sz){var equals=false;if(sz!=null){equals=((this.w==sz.w&&this.h==sz.h)||(isNaN(this.w)&&isNaN(this.h)&&isNaN(sz.w)&&isNaN(sz.h)));}
+return equals;},CLASS_NAME:"OpenLayers.Size"});OpenLayers.Console={log:function(){},debug:function(){},info:function(){},warn:function(){},error:function(){},userError:function(error){alert(error);},assert:function(){},dir:function(){},dirxml:function(){},trace:function(){},group:function(){},groupEnd:function(){},time:function(){},timeEnd:function(){},profile:function(){},profileEnd:function(){},count:function(){},CLASS_NAME:"OpenLayers.Console"};(function(){var scripts=document.getElementsByTagName("script");for(var i=0,len=scripts.length;i<len;++i){if(scripts[i].src.indexOf("firebug.js")!=-1){if(console){OpenLayers.Util.extend(OpenLayers.Console,console);break;}}}})();OpenLayers.Kinetic=OpenLayers.Class({map:null,threshold:0,points:undefined,initialize:function(options){OpenLayers.Util.extend(this,options);},begin:function(){this.points=[];},update:function(xy){this.points.unshift({xy:xy,tick:new Date().getTime()});if(this.points.length>100){this.points.pop();}},end:funct
ion(xy){var map=this.map;var last,now=new Date().getTime();for(var i=0,points=this.points,l=points.length,point;i<l;i++){point=points[i];if(now-point.tick>200){break;}
+last=point;}
+if(!last){return;}
+var time=new Date().getTime()-last.tick;var dist=Math.sqrt(Math.pow(xy.x-last.xy.x,2)+
+Math.pow(xy.y-last.xy.y,2));var speed=dist/time;if(speed==0||speed<this.threshold){return;}
+var theta=Math.asin((xy.y-last.xy.y)/dist);if(last.xy.x<=xy.x){theta=Math.PI-theta;}
+return this.getDelta(speed,xy,theta);},getDelta:function(speed,curr,theta){var dist=speed*10;var vect={x:Math.cos(theta)*-dist,y:Math.sin(theta)*dist};return{x:vect.x/(-Math.pow(2,-10*1/this.map.panDuration)+1),y:vect.y/(-Math.pow(2,-10*1/this.map.panDuration)+1)};},CLASS_NAME:"OpenLayers.Kinetic"});OpenLayers.Bounds=OpenLayers.Class({left:null,bottom:null,right:null,top:null,centerLonLat:null,initialize:function(left,bottom,right,top){if(left!=null){this.left=OpenLayers.Util.toFloat(left);}
+if(bottom!=null){this.bottom=OpenLayers.Util.toFloat(bottom);}
+if(right!=null){this.right=OpenLayers.Util.toFloat(right);}
+if(top!=null){this.top=OpenLayers.Util.toFloat(top);}},clone:function(){return new OpenLayers.Bounds(this.left,this.bottom,this.right,this.top);},equals:function(bounds){var equals=false;if(bounds!=null){equals=((this.left==bounds.left)&&(this.right==bounds.right)&&(this.top==bounds.top)&&(this.bottom==bounds.bottom));}
+return equals;},toString:function(){return("left-bottom=("+this.left+","+this.bottom+")"
++" right-top=("+this.right+","+this.top+")");},toArray:function(reverseAxisOrder){if(reverseAxisOrder===true){return[this.bottom,this.left,this.top,this.right];}else{return[this.left,this.bottom,this.right,this.top];}},toBBOX:function(decimal,reverseAxisOrder){if(decimal==null){decimal=6;}
+var mult=Math.pow(10,decimal);var xmin=Math.round(this.left*mult)/mult;var ymin=Math.round(this.bottom*mult)/mult;var xmax=Math.round(this.right*mult)/mult;var ymax=Math.round(this.top*mult)/mult;if(reverseAxisOrder===true){return ymin+","+xmin+","+ymax+","+xmax;}else{return xmin+","+ymin+","+xmax+","+ymax;}},toGeometry:function(){return new OpenLayers.Geometry.Polygon([new OpenLayers.Geometry.LinearRing([new OpenLayers.Geometry.Point(this.left,this.bottom),new OpenLayers.Geometry.Point(this.right,this.bottom),new OpenLayers.Geometry.Point(this.right,this.top),new OpenLayers.Geometry.Point(this.left,this.top)])]);},getWidth:function(){return(this.right-this.left);},getHeight:function(){return(this.top-this.bottom);},getSize:function(){return new OpenLayers.Size(this.getWidth(),this.getHeight());},getCenterPixel:function(){return new OpenLayers.Pixel((this.left+this.right)/2,(this.bottom+this.top)/2);},getCenterLonLat:function(){if(!this.centerLonLat){this.centerLonLat=new Op
enLayers.LonLat((this.left+this.right)/2,(this.bottom+this.top)/2);}
+return this.centerLonLat;},scale:function(ratio,origin){if(origin==null){origin=this.getCenterLonLat();}
+var origx,origy;if(origin.CLASS_NAME=="OpenLayers.LonLat"){origx=origin.lon;origy=origin.lat;}else{origx=origin.x;origy=origin.y;}
+var left=(this.left-origx)*ratio+origx;var bottom=(this.bottom-origy)*ratio+origy;var right=(this.right-origx)*ratio+origx;var top=(this.top-origy)*ratio+origy;return new OpenLayers.Bounds(left,bottom,right,top);},add:function(x,y){if((x==null)||(y==null)){var msg=OpenLayers.i18n("boundsAddError");OpenLayers.Console.error(msg);return null;}
+return new OpenLayers.Bounds(this.left+x,this.bottom+y,this.right+x,this.top+y);},extend:function(object){var bounds=null;if(object){switch(object.CLASS_NAME){case"OpenLayers.LonLat":bounds=new OpenLayers.Bounds(object.lon,object.lat,object.lon,object.lat);break;case"OpenLayers.Geometry.Point":bounds=new OpenLayers.Bounds(object.x,object.y,object.x,object.y);break;case"OpenLayers.Bounds":bounds=object;break;}
+if(bounds){this.centerLonLat=null;if((this.left==null)||(bounds.left<this.left)){this.left=bounds.left;}
+if((this.bottom==null)||(bounds.bottom<this.bottom)){this.bottom=bounds.bottom;}
+if((this.right==null)||(bounds.right>this.right)){this.right=bounds.right;}
+if((this.top==null)||(bounds.top>this.top)){this.top=bounds.top;}}}},containsLonLat:function(ll,inclusive){return this.contains(ll.lon,ll.lat,inclusive);},containsPixel:function(px,inclusive){return this.contains(px.x,px.y,inclusive);},contains:function(x,y,inclusive){if(inclusive==null){inclusive=true;}
+if(x==null||y==null){return false;}
+x=OpenLayers.Util.toFloat(x);y=OpenLayers.Util.toFloat(y);var contains=false;if(inclusive){contains=((x>=this.left)&&(x<=this.right)&&(y>=this.bottom)&&(y<=this.top));}else{contains=((x>this.left)&&(x<this.right)&&(y>this.bottom)&&(y<this.top));}
+return contains;},intersectsBounds:function(bounds,inclusive){if(inclusive==null){inclusive=true;}
+var intersects=false;var mightTouch=(this.left==bounds.right||this.right==bounds.left||this.top==bounds.bottom||this.bottom==bounds.top);if(inclusive||!mightTouch){var inBottom=(((bounds.bottom>=this.bottom)&&(bounds.bottom<=this.top))||((this.bottom>=bounds.bottom)&&(this.bottom<=bounds.top)));var inTop=(((bounds.top>=this.bottom)&&(bounds.top<=this.top))||((this.top>bounds.bottom)&&(this.top<bounds.top)));var inLeft=(((bounds.left>=this.left)&&(bounds.left<=this.right))||((this.left>=bounds.left)&&(this.left<=bounds.right)));var inRight=(((bounds.right>=this.left)&&(bounds.right<=this.right))||((this.right>=bounds.left)&&(this.right<=bounds.right)));intersects=((inBottom||inTop)&&(inLeft||inRight));}
+return intersects;},containsBounds:function(bounds,partial,inclusive){if(partial==null){partial=false;}
+if(inclusive==null){inclusive=true;}
+var bottomLeft=this.contains(bounds.left,bounds.bottom,inclusive);var bottomRight=this.contains(bounds.right,bounds.bottom,inclusive);var topLeft=this.contains(bounds.left,bounds.top,inclusive);var topRight=this.contains(bounds.right,bounds.top,inclusive);return(partial)?(bottomLeft||bottomRight||topLeft||topRight):(bottomLeft&&bottomRight&&topLeft&&topRight);},determineQuadrant:function(lonlat){var quadrant="";var center=this.getCenterLonLat();quadrant+=(lonlat.lat<center.lat)?"b":"t";quadrant+=(lonlat.lon<center.lon)?"l":"r";return quadrant;},transform:function(source,dest){this.centerLonLat=null;var ll=OpenLayers.Projection.transform({'x':this.left,'y':this.bottom},source,dest);var lr=OpenLayers.Projection.transform({'x':this.right,'y':this.bottom},source,dest);var ul=OpenLayers.Projection.transform({'x':this.left,'y':this.top},source,dest);var ur=OpenLayers.Projection.transform({'x':this.right,'y':this.top},source,dest);this.left=Math.min(ll.x,ul.x);this.bottom=Math.min(
ll.y,lr.y);this.right=Math.max(lr.x,ur.x);this.top=Math.max(ul.y,ur.y);return this;},wrapDateLine:function(maxExtent,options){options=options||{};var leftTolerance=options.leftTolerance||0;var rightTolerance=options.rightTolerance||0;var newBounds=this.clone();if(maxExtent){while(newBounds.left<maxExtent.left&&(newBounds.right-rightTolerance)<=maxExtent.left){newBounds=newBounds.add(maxExtent.getWidth(),0);}
+while((newBounds.left+leftTolerance)>=maxExtent.right&&newBounds.right>maxExtent.right){newBounds=newBounds.add(-maxExtent.getWidth(),0);}}
+return newBounds;},CLASS_NAME:"OpenLayers.Bounds"});OpenLayers.Bounds.fromString=function(str){var bounds=str.split(",");return OpenLayers.Bounds.fromArray(bounds);};OpenLayers.Bounds.fromArray=function(bbox){return new OpenLayers.Bounds(parseFloat(bbox[0]),parseFloat(bbox[1]),parseFloat(bbox[2]),parseFloat(bbox[3]));};OpenLayers.Bounds.fromSize=function(size){return new OpenLayers.Bounds(0,size.h,size.w,0);};OpenLayers.Bounds.oppositeQuadrant=function(quadrant){var opp="";opp+=(quadrant.charAt(0)=='t')?'b':'t';opp+=(quadrant.charAt(1)=='l')?'r':'l';return opp;};OpenLayers.LonLat=OpenLayers.Class({lon:0.0,lat:0.0,initialize:function(lon,lat){this.lon=OpenLayers.Util.toFloat(lon);this.lat=OpenLayers.Util.toFloat(lat);},toString:function(){return("lon="+this.lon+",lat="+this.lat);},toShortString:function(){return(this.lon+", "+this.lat);},clone:function(){return new OpenLayers.LonLat(this.lon,this.lat);},add:function(lon,lat){if((lon==null)||(lat==null)){var msg=OpenLayers.i18
n("lonlatAddError");OpenLayers.Console.error(msg);return null;}
+return new OpenLayers.LonLat(this.lon+OpenLayers.Util.toFloat(lon),this.lat+OpenLayers.Util.toFloat(lat));},equals:function(ll){var equals=false;if(ll!=null){equals=((this.lon==ll.lon&&this.lat==ll.lat)||(isNaN(this.lon)&&isNaN(this.lat)&&isNaN(ll.lon)&&isNaN(ll.lat)));}
+return equals;},transform:function(source,dest){var point=OpenLayers.Projection.transform({'x':this.lon,'y':this.lat},source,dest);this.lon=point.x;this.lat=point.y;return this;},wrapDateLine:function(maxExtent){var newLonLat=this.clone();if(maxExtent){while(newLonLat.lon<maxExtent.left){newLonLat.lon+=maxExtent.getWidth();}
+while(newLonLat.lon>maxExtent.right){newLonLat.lon-=maxExtent.getWidth();}}
+return newLonLat;},CLASS_NAME:"OpenLayers.LonLat"});OpenLayers.LonLat.fromString=function(str){var pair=str.split(",");return new OpenLayers.LonLat(pair[0],pair[1]);};OpenLayers.Pixel=OpenLayers.Class({x:0.0,y:0.0,initialize:function(x,y){this.x=parseFloat(x);this.y=parseFloat(y);},toString:function(){return("x="+this.x+",y="+this.y);},clone:function(){return new OpenLayers.Pixel(this.x,this.y);},equals:function(px){var equals=false;if(px!=null){equals=((this.x==px.x&&this.y==px.y)||(isNaN(this.x)&&isNaN(this.y)&&isNaN(px.x)&&isNaN(px.y)));}
+return equals;},add:function(x,y){if((x==null)||(y==null)){var msg=OpenLayers.i18n("pixelAddError");OpenLayers.Console.error(msg);return null;}
+return new OpenLayers.Pixel(this.x+x,this.y+y);},offset:function(px){var newPx=this.clone();if(px){newPx=this.add(px.x,px.y);}
+return newPx;},CLASS_NAME:"OpenLayers.Pixel"});OpenLayers.Control=OpenLayers.Class({id:null,map:null,div:null,type:null,allowSelection:false,displayClass:"",title:"",autoActivate:false,active:null,handler:null,eventListeners:null,events:null,EVENT_TYPES:["activate","deactivate"],initialize:function(options){this.displayClass=this.CLASS_NAME.replace("OpenLayers.","ol").replace(/\./g,"");OpenLayers.Util.extend(this,options);this.events=new OpenLayers.Events(this,null,this.EVENT_TYPES);if(this.eventListeners instanceof Object){this.events.on(this.eventListeners);}
+if(this.id==null){this.id=OpenLayers.Util.createUniqueID(this.CLASS_NAME+"_");}},destroy:function(){if(this.events){if(this.eventListeners){this.events.un(this.eventListeners);}
+this.events.destroy();this.events=null;}
+this.eventListeners=null;if(this.handler){this.handler.destroy();this.handler=null;}
+if(this.handlers){for(var key in this.handlers){if(this.handlers.hasOwnProperty(key)&&typeof this.handlers[key].destroy=="function"){this.handlers[key].destroy();}}
+this.handlers=null;}
+if(this.map){this.map.removeControl(this);this.map=null;}},setMap:function(map){this.map=map;if(this.handler){this.handler.setMap(map);}},draw:function(px){if(this.div==null){this.div=OpenLayers.Util.createDiv(this.id);this.div.className=this.displayClass;if(!this.allowSelection){this.div.className+=" olControlNoSelect";this.div.setAttribute("unselectable","on",0);this.div.onselectstart=OpenLayers.Function.False;}
+if(this.title!=""){this.div.title=this.title;}}
+if(px!=null){this.position=px.clone();}
+this.moveTo(this.position);return this.div;},moveTo:function(px){if((px!=null)&&(this.div!=null)){this.div.style.left=px.x+"px";this.div.style.top=px.y+"px";}},activate:function(){if(this.active){return false;}
+if(this.handler){this.handler.activate();}
+this.active=true;if(this.map){OpenLayers.Element.addClass(this.map.viewPortDiv,this.displayClass.replace(/ /g,"")+"Active");}
+this.events.triggerEvent("activate");return true;},deactivate:function(){if(this.active){if(this.handler){this.handler.deactivate();}
+this.active=false;if(this.map){OpenLayers.Element.removeClass(this.map.viewPortDiv,this.displayClass.replace(/ /g,"")+"Active");}
+this.events.triggerEvent("deactivate");return true;}
+return false;},CLASS_NAME:"OpenLayers.Control"});OpenLayers.Control.TYPE_BUTTON=1;OpenLayers.Control.TYPE_TOGGLE=2;OpenLayers.Control.TYPE_TOOL=3;OpenLayers.Lang={code:null,defaultCode:"en",getCode:function(){if(!OpenLayers.Lang.code){OpenLayers.Lang.setCode();}
+return OpenLayers.Lang.code;},setCode:function(code){var lang;if(!code){code=(OpenLayers.BROWSER_NAME=="msie")?navigator.userLanguage:navigator.language;}
+var parts=code.split('-');parts[0]=parts[0].toLowerCase();if(typeof OpenLayers.Lang[parts[0]]=="object"){lang=parts[0];}
+if(parts[1]){var testLang=parts[0]+'-'+parts[1].toUpperCase();if(typeof OpenLayers.Lang[testLang]=="object"){lang=testLang;}}
+if(!lang){OpenLayers.Console.warn('Failed to find OpenLayers.Lang.'+parts.join("-")+' dictionary, falling back to default language');lang=OpenLayers.Lang.defaultCode;}
+OpenLayers.Lang.code=lang;},translate:function(key,context){var dictionary=OpenLayers.Lang[OpenLayers.Lang.getCode()];var message=dictionary[key];if(!message){message=key;}
+if(context){message=OpenLayers.String.format(message,context);}
+return message;}};OpenLayers.i18n=OpenLayers.Lang.translate;OpenLayers.Tween=OpenLayers.Class({INTERVAL:10,easing:null,begin:null,finish:null,duration:null,callbacks:null,time:null,interval:null,playing:false,initialize:function(easing){this.easing=(easing)?easing:OpenLayers.Easing.Expo.easeOut;},start:function(begin,finish,duration,options){this.playing=true;this.begin=begin;this.finish=finish;this.duration=duration;this.callbacks=options.callbacks;this.time=0;if(this.interval){window.clearInterval(this.interval);this.interval=null;}
+if(this.callbacks&&this.callbacks.start){this.callbacks.start.call(this,this.begin);}
+this.interval=window.setInterval(OpenLayers.Function.bind(this.play,this),this.INTERVAL);},stop:function(){if(!this.playing){return;}
+if(this.callbacks&&this.callbacks.done){this.callbacks.done.call(this,this.finish);}
+window.clearInterval(this.interval);this.interval=null;this.playing=false;},play:function(){var value={};for(var i in this.begin){var b=this.begin[i];var f=this.finish[i];if(b==null||f==null||isNaN(b)||isNaN(f)){OpenLayers.Console.error('invalid value for Tween');}
+var c=f-b;value[i]=this.easing.apply(this,[this.time,b,c,this.duration]);}
+this.time++;if(this.callbacks&&this.callbacks.eachStep){this.callbacks.eachStep.call(this,value);}
+if(this.time>this.duration){this.stop();}},CLASS_NAME:"OpenLayers.Tween"});OpenLayers.Easing={CLASS_NAME:"OpenLayers.Easing"};OpenLayers.Easing.Linear={easeIn:function(t,b,c,d){return c*t/d+b;},easeOut:function(t,b,c,d){return c*t/d+b;},easeInOut:function(t,b,c,d){return c*t/d+b;},CLASS_NAME:"OpenLayers.Easing.Linear"};OpenLayers.Easing.Expo={easeIn:function(t,b,c,d){return(t==0)?b:c*Math.pow(2,10*(t/d-1))+b;},easeOut:function(t,b,c,d){return(t==d)?b+c:c*(-Math.pow(2,-10*t/d)+1)+b;},easeInOut:function(t,b,c,d){if(t==0)return b;if(t==d)return b+c;if((t/=d/2)<1)return c/2*Math.pow(2,10*(t-1))+b;return c/2*(-Math.pow(2,-10*--t)+2)+b;},CLASS_NAME:"OpenLayers.Easing.Expo"};OpenLayers.Easing.Quad={easeIn:function(t,b,c,d){return c*(t/=d)*t+b;},easeOut:function(t,b,c,d){return-c*(t/=d)*(t-2)+b;},easeInOut:function(t,b,c,d){if((t/=d/2)<1)return c/2*t*t+b;return-c/2*((--t)*(t-2)-1)+b;},CLASS_NAME:"OpenLayers.Easing.Quad"};OpenLayers.Event={observers:false,KEY_BACKSPACE:8,KEY_TAB:9,KE
Y_RETURN:13,KEY_ESC:27,KEY_LEFT:37,KEY_UP:38,KEY_RIGHT:39,KEY_DOWN:40,KEY_DELETE:46,element:function(event){return event.target||event.srcElement;},isLeftClick:function(event){return(((event.which)&&(event.which==1))||((event.button)&&(event.button==1)));},isRightClick:function(event){return(((event.which)&&(event.which==3))||((event.button)&&(event.button==2)));},stop:function(event,allowDefault){if(!allowDefault){if(event.preventDefault){event.preventDefault();}else{event.returnValue=false;}}
+if(event.stopPropagation){event.stopPropagation();}else{event.cancelBubble=true;}},findElement:function(event,tagName){var element=OpenLayers.Event.element(event);while(element.parentNode&&(!element.tagName||(element.tagName.toUpperCase()!=tagName.toUpperCase()))){element=element.parentNode;}
+return element;},observe:function(elementParam,name,observer,useCapture){var element=OpenLayers.Util.getElement(elementParam);useCapture=useCapture||false;if(name=='keypress'&&(navigator.appVersion.match(/Konqueror|Safari|KHTML/)||element.attachEvent)){name='keydown';}
+if(!this.observers){this.observers={};}
+if(!element._eventCacheID){var idPrefix="eventCacheID_";if(element.id){idPrefix=element.id+"_"+idPrefix;}
+element._eventCacheID=OpenLayers.Util.createUniqueID(idPrefix);}
+var cacheID=element._eventCacheID;if(!this.observers[cacheID]){this.observers[cacheID]=[];}
+this.observers[cacheID].push({'element':element,'name':name,'observer':observer,'useCapture':useCapture});if(element.addEventListener){element.addEventListener(name,observer,useCapture);}else if(element.attachEvent){element.attachEvent('on'+name,observer);}},stopObservingElement:function(elementParam){var element=OpenLayers.Util.getElement(elementParam);var cacheID=element._eventCacheID;this._removeElementObservers(OpenLayers.Event.observers[cacheID]);},_removeElementObservers:function(elementObservers){if(elementObservers){for(var i=elementObservers.length-1;i>=0;i--){var entry=elementObservers[i];var args=new Array(entry.element,entry.name,entry.observer,entry.useCapture);var removed=OpenLayers.Event.stopObserving.apply(this,args);}}},stopObserving:function(elementParam,name,observer,useCapture){useCapture=useCapture||false;var element=OpenLayers.Util.getElement(elementParam);var cacheID=element._eventCacheID;if(name=='keypress'){if(navigator.appVersion.match(/Konqueror|Sa
fari|KHTML/)||element.detachEvent){name='keydown';}}
+var foundEntry=false;var elementObservers=OpenLayers.Event.observers[cacheID];if(elementObservers){var i=0;while(!foundEntry&&i<elementObservers.length){var cacheEntry=elementObservers[i];if((cacheEntry.name==name)&&(cacheEntry.observer==observer)&&(cacheEntry.useCapture==useCapture)){elementObservers.splice(i,1);if(elementObservers.length==0){delete OpenLayers.Event.observers[cacheID];}
+foundEntry=true;break;}
+i++;}}
+if(foundEntry){if(element.removeEventListener){element.removeEventListener(name,observer,useCapture);}else if(element&&element.detachEvent){element.detachEvent('on'+name,observer);}}
+return foundEntry;},unloadCache:function(){if(OpenLayers.Event&&OpenLayers.Event.observers){for(var cacheID in OpenLayers.Event.observers){var elementObservers=OpenLayers.Event.observers[cacheID];OpenLayers.Event._removeElementObservers.apply(this,[elementObservers]);}
+OpenLayers.Event.observers=false;}},CLASS_NAME:"OpenLayers.Event"};OpenLayers.Event.observe(window,'unload',OpenLayers.Event.unloadCache,false);if(window.Event){OpenLayers.Util.applyDefaults(window.Event,OpenLayers.Event);}else{var Event=OpenLayers.Event;}
+OpenLayers.Events=OpenLayers.Class({BROWSER_EVENTS:["mouseover","mouseout","mousedown","mouseup","mousemove","click","dblclick","rightclick","dblrightclick","resize","focus","blur"],listeners:null,object:null,element:null,eventTypes:null,eventHandler:null,fallThrough:null,includeXY:false,clearMouseListener:null,initialize:function(object,element,eventTypes,fallThrough,options){OpenLayers.Util.extend(this,options);this.object=object;this.fallThrough=fallThrough;this.listeners={};this.eventHandler=OpenLayers.Function.bindAsEventListener(this.handleBrowserEvent,this);this.clearMouseListener=OpenLayers.Function.bind(this.clearMouseCache,this);this.eventTypes=[];if(eventTypes!=null){for(var i=0,len=eventTypes.length;i<len;i++){this.addEventType(eventTypes[i]);}}
+if(element!=null){this.attachToElement(element);}},destroy:function(){if(this.element){OpenLayers.Event.stopObservingElement(this.element);if(this.element.hasScrollEvent){OpenLayers.Event.stopObserving(window,"scroll",this.clearMouseListener);}}
+this.element=null;this.listeners=null;this.object=null;this.eventTypes=null;this.fallThrough=null;this.eventHandler=null;},addEventType:function(eventName){if(!this.listeners[eventName]){this.eventTypes.push(eventName);this.listeners[eventName]=[];}},attachToElement:function(element){if(this.element){OpenLayers.Event.stopObservingElement(this.element);}
+this.element=element;for(var i=0,len=this.BROWSER_EVENTS.length;i<len;i++){var eventType=this.BROWSER_EVENTS[i];this.addEventType(eventType);OpenLayers.Event.observe(element,eventType,this.eventHandler);}
+OpenLayers.Event.observe(element,"dragstart",OpenLayers.Event.stop);},on:function(object){for(var type in object){if(type!="scope"){this.register(type,object.scope,object[type]);}}},register:function(type,obj,func){if((func!=null)&&(OpenLayers.Util.indexOf(this.eventTypes,type)!=-1)){if(obj==null){obj=this.object;}
+var listeners=this.listeners[type];listeners.push({obj:obj,func:func});}},registerPriority:function(type,obj,func){if(func!=null){if(obj==null){obj=this.object;}
+var listeners=this.listeners[type];if(listeners!=null){listeners.unshift({obj:obj,func:func});}}},un:function(object){for(var type in object){if(type!="scope"){this.unregister(type,object.scope,object[type]);}}},unregister:function(type,obj,func){if(obj==null){obj=this.object;}
+var listeners=this.listeners[type];if(listeners!=null){for(var i=0,len=listeners.length;i<len;i++){if(listeners[i].obj==obj&&listeners[i].func==func){listeners.splice(i,1);break;}}}},remove:function(type){if(this.listeners[type]!=null){this.listeners[type]=[];}},triggerEvent:function(type,evt){var listeners=this.listeners[type];if(!listeners||listeners.length==0){return;}
+if(evt==null){evt={};}
+evt.object=this.object;evt.element=this.element;if(!evt.type){evt.type=type;}
+var listeners=listeners.slice(),continueChain;for(var i=0,len=listeners.length;i<len;i++){var callback=listeners[i];continueChain=callback.func.apply(callback.obj,[evt]);if((continueChain!=undefined)&&(continueChain==false)){break;}}
+if(!this.fallThrough){OpenLayers.Event.stop(evt,true);}
+return continueChain;},handleBrowserEvent:function(evt){var type=evt.type,listeners=this.listeners[type];if(!listeners||listeners.length==0){return;}
+if(this.includeXY){evt.xy=this.getMousePosition(evt);}
+this.triggerEvent(type,evt);},clearMouseCache:function(){this.element.scrolls=null;this.element.lefttop=null;this.element.offsets=null;},getMousePosition:function(evt){if(!this.includeXY){this.clearMouseCache();}else if(!this.element.hasScrollEvent){OpenLayers.Event.observe(window,"scroll",this.clearMouseListener);this.element.hasScrollEvent=true;}
+if(!this.element.scrolls){var viewportElement=OpenLayers.Util.getViewportElement();this.element.scrolls=[viewportElement.scrollLeft,viewportElement.scrollTop];}
+if(!this.element.lefttop){this.element.lefttop=[(document.documentElement.clientLeft||0),(document.documentElement.clientTop||0)];}
+if(!this.element.offsets){this.element.offsets=OpenLayers.Util.pagePosition(this.element);}
+return new OpenLayers.Pixel((evt.clientX+this.element.scrolls[0])-this.element.offsets[0]
+-this.element.lefttop[0],(evt.clientY+this.element.scrolls[1])-this.element.offsets[1]
+-this.element.lefttop[1]);},CLASS_NAME:"OpenLayers.Events"});OpenLayers.Lang.en={'unhandledRequest':"Unhandled request return ${statusText}",'permalink':"Permalink",'overlays':"Overlays",'baseLayer':"Base Layer",'sameProjection':"The overview map only works when it is in the same projection as the main map",'readNotImplemented':"Read not implemented.",'writeNotImplemented':"Write not implemented.",'noFID':"Can't update a feature for which there is no FID.",'errorLoadingGML':"Error in loading GML file ${url}",'browserNotSupported':"Your browser does not support vector rendering. Currently supported renderers are:\n${renderers}",'componentShouldBe':"addFeatures : component should be an ${geomType}",'getFeatureError':"getFeatureFromEvent called on layer with no renderer. This usually means you "+"destroyed a layer, but not some handler which is associated with it.",'minZoomLevelError':"The minZoomLevel property is only intended for use "+"with the FixedZoomLevels-descendent lay
ers. That this "+"wfs layer checks for minZoomLevel is a relic of the"+"past. We cannot, however, remove it without possibly "+"breaking OL based applications that may depend on it."+" Therefore we are deprecating it -- the minZoomLevel "+"check below will be removed at 3.0. Please instead "+"use min/max resolution setting as described here: "+"http://trac.openlayers.org/wiki/SettingZoomLevels",'commitSuccess':"WFS Transaction: SUCCESS ${response}",'commitFailed':"WFS Transaction: FAILED ${response}",'googleWarning':"The Google Layer was unable to load correctly.<br><br>"+"To get rid of this message, select a new BaseLayer "+"in the layer switcher in the upper-right corner.<br><br>"+"Most likely, this is because the Google Maps library "+"script was either not included, or does not contain the "+"correct API key for your site.<br><br>"+"Developers: For help getting this working correctly, "+"<a href='http://trac.openlayers.org/wiki/Google' "+"target='_blank'>click here</a>",
'getLayerWarning':"The ${layerType} Layer was unable to load correctly.<br><br>"+"To get rid of this message, select a new BaseLayer "+"in the layer switcher in the upper-right corner.<br><br>"+"Most likely, this is because the ${layerLib} library "+"script was not correctly included.<br><br>"+"Developers: For help getting this working correctly, "+"<a href='http://trac.openlayers.org/wiki/${layerLib}' "+"target='_blank'>click here</a>",'scale':"Scale = 1 : ${scaleDenom}",'W':'W','E':'E','N':'N','S':'S','graticule':'Graticule','layerAlreadyAdded':"You tried to add the layer: ${layerName} to the map, but it has already been added",'reprojectDeprecated':"You are using the 'reproject' option "+"on the ${layerName} layer. This option is deprecated: "+"its use was designed to support displaying data over commercial "+"basemaps, but that functionality should now be achieved by using "+"Spherical Mercator support. More information is available from "+"http://trac.openlayers.org/wik
i/SphericalMercator.",'methodDeprecated':"This method has been deprecated and will be removed in 3.0. "+"Please use ${newMethod} instead.",'boundsAddError':"You must pass both x and y values to the add function.",'lonlatAddError':"You must pass both lon and lat values to the add function.",'pixelAddError':"You must pass both x and y values to the add function.",'unsupportedGeometryType':"Unsupported geometry type: ${geomType}",'pagePositionFailed':"OpenLayers.Util.pagePosition failed: element with id ${elemId} may be misplaced.",'filterEvaluateNotImplemented':"evaluate is not implemented for this filter type.",'end':''};OpenLayers.Projection=OpenLayers.Class({proj:null,projCode:null,titleRegEx:/\+title=[^\+]*/,initialize:function(projCode,options){OpenLayers.Util.extend(this,options);this.projCode=projCode;if(window.Proj4js){this.proj=new Proj4js.Proj(projCode);}},getCode:function(){return this.proj?this.proj.srsCode:this.projCode;},getUnits:function(){return this.proj?this.
proj.units:null;},toString:function(){return this.getCode();},equals:function(projection){var p=projection,equals=false;if(p){if(window.Proj4js&&this.proj.defData&&p.proj.defData){equals=this.proj.defData.replace(this.titleRegEx,"")==p.proj.defData.replace(this.titleRegEx,"");}else if(p.getCode){var source=this.getCode(),target=p.getCode();equals=source==target||!!OpenLayers.Projection.transforms[source]&&OpenLayers.Projection.transforms[source][target]===OpenLayers.Projection.nullTransform;}}
+return equals;},destroy:function(){delete this.proj;delete this.projCode;},CLASS_NAME:"OpenLayers.Projection"});OpenLayers.Projection.transforms={};OpenLayers.Projection.addTransform=function(from,to,method){if(!OpenLayers.Projection.transforms[from]){OpenLayers.Projection.transforms[from]={};}
+OpenLayers.Projection.transforms[from][to]=method;};OpenLayers.Projection.transform=function(point,source,dest){if(source.proj&&dest.proj){point=Proj4js.transform(source.proj,dest.proj,point);}else if(source&&dest&&OpenLayers.Projection.transforms[source.getCode()]&&OpenLayers.Projection.transforms[source.getCode()][dest.getCode()]){OpenLayers.Projection.transforms[source.getCode()][dest.getCode()](point);}
+return point;};OpenLayers.Projection.nullTransform=function(point){return point;};OpenLayers.Tile=OpenLayers.Class({EVENT_TYPES:["loadstart","loadend","reload","unload"],events:null,id:null,layer:null,url:null,bounds:null,size:null,position:null,isLoading:false,initialize:function(layer,position,bounds,url,size,options){this.layer=layer;this.position=position.clone();this.bounds=bounds.clone();this.url=url;this.size=size.clone();this.id=OpenLayers.Util.createUniqueID("Tile_");this.events=new OpenLayers.Events(this,null,this.EVENT_TYPES);OpenLayers.Util.extend(this,options);},unload:function(){if(this.isLoading){this.isLoading=false;this.events.triggerEvent("unload");}},destroy:function(){this.layer=null;this.bounds=null;this.size=null;this.position=null;this.events.destroy();this.events=null;},clone:function(obj){if(obj==null){obj=new OpenLayers.Tile(this.layer,this.position,this.bounds,this.url,this.size);}
+OpenLayers.Util.applyDefaults(obj,this);return obj;},draw:function(){var maxExtent=this.layer.maxExtent;var withinMaxExtent=(maxExtent&&this.bounds.intersectsBounds(maxExtent,false));this.shouldDraw=(withinMaxExtent||this.layer.displayOutsideMaxExtent);this.clear();return this.shouldDraw;},moveTo:function(bounds,position,redraw){if(redraw==null){redraw=true;}
+this.bounds=bounds.clone();this.position=position.clone();if(redraw){this.draw();}},clear:function(){},getBoundsFromBaseLayer:function(position){var msg=OpenLayers.i18n('reprojectDeprecated',{'layerName':this.layer.name});OpenLayers.Console.warn(msg);var topLeft=this.layer.map.getLonLatFromLayerPx(position);var bottomRightPx=position.clone();bottomRightPx.x+=this.size.w;bottomRightPx.y+=this.size.h;var bottomRight=this.layer.map.getLonLatFromLayerPx(bottomRightPx);if(topLeft.lon>bottomRight.lon){if(topLeft.lon<0){topLeft.lon=-180-(topLeft.lon+180);}else{bottomRight.lon=180+bottomRight.lon+180;}}
+var bounds=new OpenLayers.Bounds(topLeft.lon,bottomRight.lat,bottomRight.lon,topLeft.lat);return bounds;},showTile:function(){if(this.shouldDraw){this.show();}},show:function(){},hide:function(){},CLASS_NAME:"OpenLayers.Tile"});OpenLayers.Handler=OpenLayers.Class({id:null,control:null,map:null,keyMask:null,active:false,evt:null,initialize:function(control,callbacks,options){OpenLayers.Util.extend(this,options);this.control=control;this.callbacks=callbacks;var map=this.map||control.map;if(map){this.setMap(map);}
+this.id=OpenLayers.Util.createUniqueID(this.CLASS_NAME+"_");},setMap:function(map){this.map=map;},checkModifiers:function(evt){if(this.keyMask==null){return true;}
+var keyModifiers=(evt.shiftKey?OpenLayers.Handler.MOD_SHIFT:0)|(evt.ctrlKey?OpenLayers.Handler.MOD_CTRL:0)|(evt.altKey?OpenLayers.Handler.MOD_ALT:0);return(keyModifiers==this.keyMask);},activate:function(){if(this.active){return false;}
+var events=OpenLayers.Events.prototype.BROWSER_EVENTS;for(var i=0,len=events.length;i<len;i++){if(this[events[i]]){this.register(events[i],this[events[i]]);}}
+this.active=true;return true;},deactivate:function(){if(!this.active){return false;}
+var events=OpenLayers.Events.prototype.BROWSER_EVENTS;for(var i=0,len=events.length;i<len;i++){if(this[events[i]]){this.unregister(events[i],this[events[i]]);}}
+this.active=false;return true;},callback:function(name,args){if(name&&this.callbacks[name]){this.callbacks[name].apply(this.control,args);}},register:function(name,method){this.map.events.registerPriority(name,this,method);this.map.events.registerPriority(name,this,this.setEvent);},unregister:function(name,method){this.map.events.unregister(name,this,method);this.map.events.unregister(name,this,this.setEvent);},setEvent:function(evt){this.evt=evt;return true;},destroy:function(){this.deactivate();this.control=this.map=null;},CLASS_NAME:"OpenLayers.Handler"});OpenLayers.Handler.MOD_NONE=0;OpenLayers.Handler.MOD_SHIFT=1;OpenLayers.Handler.MOD_CTRL=2;OpenLayers.Handler.MOD_ALT=4;OpenLayers.Map=OpenLayers.Class({Z_INDEX_BASE:{BaseLayer:100,Overlay:325,Feature:725,Popup:750,Control:1000},EVENT_TYPES:["preaddlayer","addlayer","removelayer","changelayer","movestart","move","moveend","zoomend","popupopen","popupclose","addmarker","removemarker","clearmarkers","mouseover","mouseout",
"mousemove","dragstart","drag","dragend","changebaselayer"],id:null,fractionalZoom:false,events:null,allOverlays:false,div:null,dragging:false,size:null,viewPortDiv:null,layerContainerOrigin:null,layerContainerDiv:null,layers:null,controls:null,popups:null,baseLayer:null,center:null,resolution:null,zoom:0,panRatio:1.5,viewRequestID:0,tileSize:null,projection:"EPSG:4326",units:'degrees',resolutions:null,maxResolution:1.40625,minResolution:null,maxScale:null,minScale:null,maxExtent:null,minExtent:null,restrictedExtent:null,numZoomLevels:16,theme:null,displayProjection:null,fallThrough:true,panTween:null,eventListeners:null,panMethod:OpenLayers.Easing.Expo.easeOut,panDuration:50,paddingForPopups:null,initialize:function(div,options){if(arguments.length===1&&typeof div==="object"){options=div;div=options&&options.div;}
+this.tileSize=new OpenLayers.Size(OpenLayers.Map.TILE_WIDTH,OpenLayers.Map.TILE_HEIGHT);this.maxExtent=new OpenLayers.Bounds(-180,-90,180,90);this.paddingForPopups=new OpenLayers.Bounds(15,15,15,15);this.theme=OpenLayers._getScriptLocation()+'theme/default/style.css';OpenLayers.Util.extend(this,options);this.layers=[];this.id=OpenLayers.Util.createUniqueID("OpenLayers.Map_");this.div=OpenLayers.Util.getElement(div);if(!this.div){this.div=document.createElement("div");this.div.style.height="1px";this.div.style.width="1px";}
+OpenLayers.Element.addClass(this.div,'olMap');var id=this.id+"_OpenLayers_ViewPort";this.viewPortDiv=OpenLayers.Util.createDiv(id,null,null,null,"relative",null,"hidden");this.viewPortDiv.style.width="100%";this.viewPortDiv.style.height="100%";this.viewPortDiv.className="olMapViewport";this.div.appendChild(this.viewPortDiv);id=this.id+"_OpenLayers_Container";this.layerContainerDiv=OpenLayers.Util.createDiv(id);this.layerContainerDiv.style.zIndex=this.Z_INDEX_BASE['Popup']-1;this.viewPortDiv.appendChild(this.layerContainerDiv);this.events=new OpenLayers.Events(this,this.viewPortDiv,this.EVENT_TYPES,this.fallThrough,{includeXY:true});this.updateSize();if(this.eventListeners instanceof Object){this.events.on(this.eventListeners);}
+this.events.register("movestart",this,this.updateSize);if(OpenLayers.String.contains(navigator.appName,"Microsoft")){this.events.register("resize",this,this.updateSize);}else{this.updateSizeDestroy=OpenLayers.Function.bind(this.updateSize,this);OpenLayers.Event.observe(window,'resize',this.updateSizeDestroy);}
+if(this.theme){var addNode=true;var nodes=document.getElementsByTagName('link');for(var i=0,len=nodes.length;i<len;++i){if(OpenLayers.Util.isEquivalentUrl(nodes.item(i).href,this.theme)){addNode=false;break;}}
+if(addNode){var cssNode=document.createElement('link');cssNode.setAttribute('rel','stylesheet');cssNode.setAttribute('type','text/css');cssNode.setAttribute('href',this.theme);document.getElementsByTagName('head')[0].appendChild(cssNode);}}
+if(this.controls==null){if(OpenLayers.Control!=null){this.controls=[new OpenLayers.Control.Navigation(),new OpenLayers.Control.PanZoom(),new OpenLayers.Control.ArgParser(),new OpenLayers.Control.Attribution()];}else{this.controls=[];}}
+for(var i=0,len=this.controls.length;i<len;i++){this.addControlToMap(this.controls[i]);}
+this.popups=[];this.unloadDestroy=OpenLayers.Function.bind(this.destroy,this);OpenLayers.Event.observe(window,'unload',this.unloadDestroy);if(options&&options.layers){this.addLayers(options.layers);if(options.center){this.setCenter(options.center,options.zoom);}}},render:function(div){this.div=OpenLayers.Util.getElement(div);OpenLayers.Element.addClass(this.div,'olMap');this.viewPortDiv.parentNode.removeChild(this.viewPortDiv);this.div.appendChild(this.viewPortDiv);this.updateSize();},unloadDestroy:null,updateSizeDestroy:null,destroy:function(){if(!this.unloadDestroy){return false;}
+if(this.panTween){this.panTween.stop();this.panTween=null;}
+OpenLayers.Event.stopObserving(window,'unload',this.unloadDestroy);this.unloadDestroy=null;if(this.updateSizeDestroy){OpenLayers.Event.stopObserving(window,'resize',this.updateSizeDestroy);}else{this.events.unregister("resize",this,this.updateSize);}
+this.paddingForPopups=null;if(this.controls!=null){for(var i=this.controls.length-1;i>=0;--i){this.controls[i].destroy();}
+this.controls=null;}
+if(this.layers!=null){for(var i=this.layers.length-1;i>=0;--i){this.layers[i].destroy(false);}
+this.layers=null;}
+if(this.viewPortDiv){this.div.removeChild(this.viewPortDiv);}
+this.viewPortDiv=null;if(this.eventListeners){this.events.un(this.eventListeners);this.eventListeners=null;}
+this.events.destroy();this.events=null;},setOptions:function(options){OpenLayers.Util.extend(this,options);},getTileSize:function(){return this.tileSize;},getBy:function(array,property,match){var test=(typeof match.test=="function");var found=OpenLayers.Array.filter(this[array],function(item){return item[property]==match||(test&&match.test(item[property]));});return found;},getLayersBy:function(property,match){return this.getBy("layers",property,match);},getLayersByName:function(match){return this.getLayersBy("name",match);},getLayersByClass:function(match){return this.getLayersBy("CLASS_NAME",match);},getControlsBy:function(property,match){return this.getBy("controls",property,match);},getControlsByClass:function(match){return this.getControlsBy("CLASS_NAME",match);},getLayer:function(id){var foundLayer=null;for(var i=0,len=this.layers.length;i<len;i++){var layer=this.layers[i];if(layer.id==id){foundLayer=layer;break;}}
+return foundLayer;},setLayerZIndex:function(layer,zIdx){layer.setZIndex(this.Z_INDEX_BASE[layer.isBaseLayer?'BaseLayer':'Overlay']
++zIdx*5);},resetLayersZIndex:function(){for(var i=0,len=this.layers.length;i<len;i++){var layer=this.layers[i];this.setLayerZIndex(layer,i);}},addLayer:function(layer){for(var i=0,len=this.layers.length;i<len;i++){if(this.layers[i]==layer){var msg=OpenLayers.i18n('layerAlreadyAdded',{'layerName':layer.name});OpenLayers.Console.warn(msg);return false;}}
+if(this.allOverlays){layer.isBaseLayer=false;}
+if(this.events.triggerEvent("preaddlayer",{layer:layer})===false){return;}
+layer.div.className="olLayerDiv";layer.div.style.overflow="";this.setLayerZIndex(layer,this.layers.length);if(layer.isFixed){this.viewPortDiv.appendChild(layer.div);}else{this.layerContainerDiv.appendChild(layer.div);}
+this.layers.push(layer);layer.setMap(this);if(layer.isBaseLayer||(this.allOverlays&&!this.baseLayer)){if(this.baseLayer==null){this.setBaseLayer(layer);}else{layer.setVisibility(false);}}else{layer.redraw();}
+this.events.triggerEvent("addlayer",{layer:layer});layer.afterAdd();},addLayers:function(layers){for(var i=0,len=layers.length;i<len;i++){this.addLayer(layers[i]);}},removeLayer:function(layer,setNewBaseLayer){if(setNewBaseLayer==null){setNewBaseLayer=true;}
+if(layer.isFixed){this.viewPortDiv.removeChild(layer.div);}else{this.layerContainerDiv.removeChild(layer.div);}
+OpenLayers.Util.removeItem(this.layers,layer);layer.removeMap(this);layer.map=null;if(this.baseLayer==layer){this.baseLayer=null;if(setNewBaseLayer){for(var i=0,len=this.layers.length;i<len;i++){var iLayer=this.layers[i];if(iLayer.isBaseLayer||this.allOverlays){this.setBaseLayer(iLayer);break;}}}}
+this.resetLayersZIndex();this.events.triggerEvent("removelayer",{layer:layer});},getNumLayers:function(){return this.layers.length;},getLayerIndex:function(layer){return OpenLayers.Util.indexOf(this.layers,layer);},setLayerIndex:function(layer,idx){var base=this.getLayerIndex(layer);if(idx<0){idx=0;}else if(idx>this.layers.length){idx=this.layers.length;}
+if(base!=idx){this.layers.splice(base,1);this.layers.splice(idx,0,layer);for(var i=0,len=this.layers.length;i<len;i++){this.setLayerZIndex(this.layers[i],i);}
+this.events.triggerEvent("changelayer",{layer:layer,property:"order"});if(this.allOverlays){if(idx===0){this.setBaseLayer(layer);}else if(this.baseLayer!==this.layers[0]){this.setBaseLayer(this.layers[0]);}}}},raiseLayer:function(layer,delta){var idx=this.getLayerIndex(layer)+delta;this.setLayerIndex(layer,idx);},setBaseLayer:function(newBaseLayer){if(newBaseLayer!=this.baseLayer){if(OpenLayers.Util.indexOf(this.layers,newBaseLayer)!=-1){var center=this.getCenter();var newResolution=OpenLayers.Util.getResolutionFromScale(this.getScale(),newBaseLayer.units);if(this.baseLayer!=null&&!this.allOverlays){this.baseLayer.setVisibility(false);}
+this.baseLayer=newBaseLayer;this.viewRequestID++;if(!this.allOverlays||this.baseLayer.visibility){this.baseLayer.setVisibility(true);}
+if(center!=null){var newZoom=this.getZoomForResolution(newResolution||this.resolution,true);this.setCenter(center,newZoom,false,true);}
+this.events.triggerEvent("changebaselayer",{layer:this.baseLayer});}}},addControl:function(control,px){this.controls.push(control);this.addControlToMap(control,px);},addControls:function(controls,pixels){var pxs=(arguments.length===1)?[]:pixels;for(var i=0,len=controls.length;i<len;i++){var ctrl=controls[i];var px=(pxs[i])?pxs[i]:null;this.addControl(ctrl,px);}},addControlToMap:function(control,px){control.outsideViewport=(control.div!=null);if(this.displayProjection&&!control.displayProjection){control.displayProjection=this.displayProjection;}
+control.setMap(this);var div=control.draw(px);if(div){if(!control.outsideViewport){div.style.zIndex=this.Z_INDEX_BASE['Control']+
+this.controls.length;this.viewPortDiv.appendChild(div);}}
+if(control.autoActivate){control.activate();}},getControl:function(id){var returnControl=null;for(var i=0,len=this.controls.length;i<len;i++){var control=this.controls[i];if(control.id==id){returnControl=control;break;}}
+return returnControl;},removeControl:function(control){if((control)&&(control==this.getControl(control.id))){if(control.div&&(control.div.parentNode==this.viewPortDiv)){this.viewPortDiv.removeChild(control.div);}
+OpenLayers.Util.removeItem(this.controls,control);}},addPopup:function(popup,exclusive){if(exclusive){for(var i=this.popups.length-1;i>=0;--i){this.removePopup(this.popups[i]);}}
+popup.map=this;this.popups.push(popup);var popupDiv=popup.draw();if(popupDiv){popupDiv.style.zIndex=this.Z_INDEX_BASE['Popup']+
+this.popups.length;this.layerContainerDiv.appendChild(popupDiv);}},removePopup:function(popup){OpenLayers.Util.removeItem(this.popups,popup);if(popup.div){try{this.layerContainerDiv.removeChild(popup.div);}
+catch(e){}}
+popup.map=null;},getSize:function(){var size=null;if(this.size!=null){size=this.size.clone();}
+return size;},updateSize:function(){var newSize=this.getCurrentSize();if(newSize&&!isNaN(newSize.h)&&!isNaN(newSize.w)){this.events.clearMouseCache();var oldSize=this.getSize();if(oldSize==null){this.size=oldSize=newSize;}
+if(!newSize.equals(oldSize)){this.size=newSize;for(var i=0,len=this.layers.length;i<len;i++){this.layers[i].onMapResize();}
+var center=this.getCenter();if(this.baseLayer!=null&¢er!=null){var zoom=this.getZoom();this.zoom=null;this.setCenter(center,zoom);}}}},getCurrentSize:function(){var size=new OpenLayers.Size(this.div.clientWidth,this.div.clientHeight);if(size.w==0&&size.h==0||isNaN(size.w)&&isNaN(size.h)){size.w=this.div.offsetWidth;size.h=this.div.offsetHeight;}
+if(size.w==0&&size.h==0||isNaN(size.w)&&isNaN(size.h)){size.w=parseInt(this.div.style.width);size.h=parseInt(this.div.style.height);}
+return size;},calculateBounds:function(center,resolution){var extent=null;if(center==null){center=this.getCenter();}
+if(resolution==null){resolution=this.getResolution();}
+if((center!=null)&&(resolution!=null)){var size=this.getSize();var w_deg=size.w*resolution;var h_deg=size.h*resolution;extent=new OpenLayers.Bounds(center.lon-w_deg/2,center.lat-h_deg/2,center.lon+w_deg/2,center.lat+h_deg/2);}
+return extent;},getCenter:function(){var center=null;if(this.center){center=this.center.clone();}
+return center;},getZoom:function(){return this.zoom;},pan:function(dx,dy,options){options=OpenLayers.Util.applyDefaults(options,{animate:true,dragging:false});var centerPx=this.getViewPortPxFromLonLat(this.getCenter());var newCenterPx=centerPx.add(dx,dy);if(!options.dragging||!newCenterPx.equals(centerPx)){var newCenterLonLat=this.getLonLatFromViewPortPx(newCenterPx);if(options.animate){this.panTo(newCenterLonLat);}else{this.setCenter(newCenterLonLat,null,options.dragging);}}},panTo:function(lonlat){if(this.panMethod&&this.getExtent().scale(this.panRatio).containsLonLat(lonlat)){if(!this.panTween){this.panTween=new OpenLayers.Tween(this.panMethod);}
+var center=this.getCenter();if(lonlat.lon==center.lon&&lonlat.lat==center.lat){return;}
+var from={lon:center.lon,lat:center.lat};var to={lon:lonlat.lon,lat:lonlat.lat};this.panTween.start(from,to,this.panDuration,{callbacks:{start:OpenLayers.Function.bind(function(lonlat){this.events.triggerEvent("movestart");},this),eachStep:OpenLayers.Function.bind(function(lonlat){lonlat=new OpenLayers.LonLat(lonlat.lon,lonlat.lat);this.moveTo(lonlat,this.zoom,{'dragging':true,'noEvent':true});},this),done:OpenLayers.Function.bind(function(lonlat){lonlat=new OpenLayers.LonLat(lonlat.lon,lonlat.lat);this.moveTo(lonlat,this.zoom,{'noEvent':true});this.events.triggerEvent("moveend");},this)}});}else{this.setCenter(lonlat);}},setCenter:function(lonlat,zoom,dragging,forceZoomChange){this.moveTo(lonlat,zoom,{'dragging':dragging,'forceZoomChange':forceZoomChange,'caller':'setCenter'});},moveTo:function(lonlat,zoom,options){if(!options){options={};}
+if(zoom!=null){zoom=parseFloat(zoom);if(!this.fractionalZoom){zoom=Math.round(zoom);}}
+var dragging=options.dragging;var forceZoomChange=options.forceZoomChange;var noEvent=options.noEvent;if(this.panTween&&options.caller=="setCenter"){this.panTween.stop();}
+if(!this.center&&!this.isValidLonLat(lonlat)){lonlat=this.maxExtent.getCenterLonLat();}
+if(this.restrictedExtent!=null){if(lonlat==null){lonlat=this.getCenter();}
+if(zoom==null){zoom=this.getZoom();}
+var resolution=this.getResolutionForZoom(zoom);var extent=this.calculateBounds(lonlat,resolution);if(!this.restrictedExtent.containsBounds(extent)){var maxCenter=this.restrictedExtent.getCenterLonLat();if(extent.getWidth()>this.restrictedExtent.getWidth()){lonlat=new OpenLayers.LonLat(maxCenter.lon,lonlat.lat);}else if(extent.left<this.restrictedExtent.left){lonlat=lonlat.add(this.restrictedExtent.left-
+extent.left,0);}else if(extent.right>this.restrictedExtent.right){lonlat=lonlat.add(this.restrictedExtent.right-
+extent.right,0);}
+if(extent.getHeight()>this.restrictedExtent.getHeight()){lonlat=new OpenLayers.LonLat(lonlat.lon,maxCenter.lat);}else if(extent.bottom<this.restrictedExtent.bottom){lonlat=lonlat.add(0,this.restrictedExtent.bottom-
+extent.bottom);}
+else if(extent.top>this.restrictedExtent.top){lonlat=lonlat.add(0,this.restrictedExtent.top-
+extent.top);}}}
+var zoomChanged=forceZoomChange||((this.isValidZoomLevel(zoom))&&(zoom!=this.getZoom()));var centerChanged=(this.isValidLonLat(lonlat))&&(!lonlat.equals(this.center));if(zoomChanged||centerChanged||!dragging){if(!this.dragging&&!noEvent){this.events.triggerEvent("movestart");}
+if(centerChanged){if((!zoomChanged)&&(this.center)){this.centerLayerContainer(lonlat);}
+this.center=lonlat.clone();}
+if((zoomChanged)||(this.layerContainerOrigin==null)){this.layerContainerOrigin=this.center.clone();this.layerContainerDiv.style.left="0px";this.layerContainerDiv.style.top="0px";}
+if(zoomChanged){this.zoom=zoom;this.resolution=this.getResolutionForZoom(zoom);this.viewRequestID++;}
+var bounds=this.getExtent();if(this.baseLayer.visibility){this.baseLayer.moveTo(bounds,zoomChanged,dragging);if(dragging){this.baseLayer.events.triggerEvent("move");}else{this.baseLayer.events.triggerEvent("moveend",{"zoomChanged":zoomChanged});}}
+bounds=this.baseLayer.getExtent();for(var i=0,len=this.layers.length;i<len;i++){var layer=this.layers[i];if(layer!==this.baseLayer&&!layer.isBaseLayer){var inRange=layer.calculateInRange();if(layer.inRange!=inRange){layer.inRange=inRange;if(!inRange){layer.display(false);}
+this.events.triggerEvent("changelayer",{layer:layer,property:"visibility"});}
+if(inRange&&layer.visibility){layer.moveTo(bounds,zoomChanged,dragging);if(dragging){layer.events.triggerEvent("move");}else{layer.events.triggerEvent("moveend",{"zoomChanged":zoomChanged});}}}}
+if(zoomChanged){for(var i=0,len=this.popups.length;i<len;i++){this.popups[i].updatePosition();}}
+this.events.triggerEvent("move");if(zoomChanged){this.events.triggerEvent("zoomend");}}
+if(!dragging&&!noEvent){this.events.triggerEvent("moveend");}
+this.dragging=!!dragging;},centerLayerContainer:function(lonlat){var originPx=this.getViewPortPxFromLonLat(this.layerContainerOrigin);var newPx=this.getViewPortPxFromLonLat(lonlat);if((originPx!=null)&&(newPx!=null)){this.layerContainerDiv.style.left=Math.round(originPx.x-newPx.x)+"px";this.layerContainerDiv.style.top=Math.round(originPx.y-newPx.y)+"px";}},isValidZoomLevel:function(zoomLevel){return((zoomLevel!=null)&&(zoomLevel>=0)&&(zoomLevel<this.getNumZoomLevels()));},isValidLonLat:function(lonlat){var valid=false;if(lonlat!=null){var maxExtent=this.getMaxExtent();valid=maxExtent.containsLonLat(lonlat);}
+return valid;},getProjection:function(){var projection=this.getProjectionObject();return projection?projection.getCode():null;},getProjectionObject:function(){var projection=null;if(this.baseLayer!=null){projection=this.baseLayer.projection;}
+return projection;},getMaxResolution:function(){var maxResolution=null;if(this.baseLayer!=null){maxResolution=this.baseLayer.maxResolution;}
+return maxResolution;},getMaxExtent:function(options){var maxExtent=null;if(options&&options.restricted&&this.restrictedExtent){maxExtent=this.restrictedExtent;}else if(this.baseLayer!=null){maxExtent=this.baseLayer.maxExtent;}
+return maxExtent;},getNumZoomLevels:function(){var numZoomLevels=null;if(this.baseLayer!=null){numZoomLevels=this.baseLayer.numZoomLevels;}
+return numZoomLevels;},getExtent:function(){var extent=null;if(this.baseLayer!=null){extent=this.baseLayer.getExtent();}
+return extent;},getResolution:function(){var resolution=null;if(this.baseLayer!=null){resolution=this.baseLayer.getResolution();}else if(this.allOverlays===true&&this.layers.length>0){resolution=this.layers[0].getResolution();}
+return resolution;},getUnits:function(){var units=null;if(this.baseLayer!=null){units=this.baseLayer.units;}
+return units;},getScale:function(){var scale=null;if(this.baseLayer!=null){var res=this.getResolution();var units=this.baseLayer.units;scale=OpenLayers.Util.getScaleFromResolution(res,units);}
+return scale;},getZoomForExtent:function(bounds,closest){var zoom=null;if(this.baseLayer!=null){zoom=this.baseLayer.getZoomForExtent(bounds,closest);}
+return zoom;},getResolutionForZoom:function(zoom){var resolution=null;if(this.baseLayer){resolution=this.baseLayer.getResolutionForZoom(zoom);}
+return resolution;},getZoomForResolution:function(resolution,closest){var zoom=null;if(this.baseLayer!=null){zoom=this.baseLayer.getZoomForResolution(resolution,closest);}
+return zoom;},zoomTo:function(zoom){if(this.isValidZoomLevel(zoom)){this.setCenter(null,zoom);}},zoomIn:function(){this.zoomTo(this.getZoom()+1);},zoomOut:function(){this.zoomTo(this.getZoom()-1);},zoomToExtent:function(bounds,closest){var center=bounds.getCenterLonLat();if(this.baseLayer.wrapDateLine){var maxExtent=this.getMaxExtent();bounds=bounds.clone();while(bounds.right<bounds.left){bounds.right+=maxExtent.getWidth();}
+center=bounds.getCenterLonLat().wrapDateLine(maxExtent);}
+this.setCenter(center,this.getZoomForExtent(bounds,closest));},zoomToMaxExtent:function(options){var restricted=(options)?options.restricted:true;var maxExtent=this.getMaxExtent({'restricted':restricted});this.zoomToExtent(maxExtent);},zoomToScale:function(scale,closest){var res=OpenLayers.Util.getResolutionFromScale(scale,this.baseLayer.units);var size=this.getSize();var w_deg=size.w*res;var h_deg=size.h*res;var center=this.getCenter();var extent=new OpenLayers.Bounds(center.lon-w_deg/2,center.lat-h_deg/2,center.lon+w_deg/2,center.lat+h_deg/2);this.zoomToExtent(extent,closest);},getLonLatFromViewPortPx:function(viewPortPx){var lonlat=null;if(this.baseLayer!=null){lonlat=this.baseLayer.getLonLatFromViewPortPx(viewPortPx);}
+return lonlat;},getViewPortPxFromLonLat:function(lonlat){var px=null;if(this.baseLayer!=null){px=this.baseLayer.getViewPortPxFromLonLat(lonlat);}
+return px;},getLonLatFromPixel:function(px){return this.getLonLatFromViewPortPx(px);},getPixelFromLonLat:function(lonlat){var px=this.getViewPortPxFromLonLat(lonlat);px.x=Math.round(px.x);px.y=Math.round(px.y);return px;},getGeodesicPixelSize:function(px){var lonlat=px?this.getLonLatFromPixel(px):(this.getCenter()||new OpenLayers.LonLat(0,0));var res=this.getResolution();var left=lonlat.add(-res/2,0);var right=lonlat.add(res/2,0);var bottom=lonlat.add(0,-res/2);var top=lonlat.add(0,res/2);var dest=new OpenLayers.Projection("EPSG:4326");var source=this.getProjectionObject()||dest;if(!source.equals(dest)){left.transform(source,dest);right.transform(source,dest);bottom.transform(source,dest);top.transform(source,dest);}
+return new OpenLayers.Size(OpenLayers.Util.distVincenty(left,right),OpenLayers.Util.distVincenty(bottom,top));},getViewPortPxFromLayerPx:function(layerPx){var viewPortPx=null;if(layerPx!=null){var dX=parseInt(this.layerContainerDiv.style.left);var dY=parseInt(this.layerContainerDiv.style.top);viewPortPx=layerPx.add(dX,dY);}
+return viewPortPx;},getLayerPxFromViewPortPx:function(viewPortPx){var layerPx=null;if(viewPortPx!=null){var dX=-parseInt(this.layerContainerDiv.style.left);var dY=-parseInt(this.layerContainerDiv.style.top);layerPx=viewPortPx.add(dX,dY);if(isNaN(layerPx.x)||isNaN(layerPx.y)){layerPx=null;}}
+return layerPx;},getLonLatFromLayerPx:function(px){px=this.getViewPortPxFromLayerPx(px);return this.getLonLatFromViewPortPx(px);},getLayerPxFromLonLat:function(lonlat){var px=this.getPixelFromLonLat(lonlat);return this.getLayerPxFromViewPortPx(px);},CLASS_NAME:"OpenLayers.Map"});OpenLayers.Map.TILE_WIDTH=256;OpenLayers.Map.TILE_HEIGHT=256;OpenLayers.Tile.Image=OpenLayers.Class(OpenLayers.Tile,{url:null,imgDiv:null,frame:null,layerAlphaHack:null,isBackBuffer:false,lastRatio:1,isFirstDraw:true,backBufferTile:null,maxGetUrlLength:null,initialize:function(layer,position,bounds,url,size,options){OpenLayers.Tile.prototype.initialize.apply(this,arguments);if(this.maxGetUrlLength!=null){OpenLayers.Util.extend(this,OpenLayers.Tile.Image.IFrame);}
+this.url=url;this.frame=document.createElement('div');this.frame.style.overflow='hidden';this.frame.style.position='absolute';this.layerAlphaHack=this.layer.alpha&&OpenLayers.Util.alphaHack();},destroy:function(){if(this.imgDiv!=null){this.removeImgDiv();}
+this.imgDiv=null;if((this.frame!=null)&&(this.frame.parentNode==this.layer.div)){this.layer.div.removeChild(this.frame);}
+this.frame=null;if(this.backBufferTile){this.backBufferTile.destroy();this.backBufferTile=null;}
+this.layer.events.unregister("loadend",this,this.resetBackBuffer);OpenLayers.Tile.prototype.destroy.apply(this,arguments);},clone:function(obj){if(obj==null){obj=new OpenLayers.Tile.Image(this.layer,this.position,this.bounds,this.url,this.size);}
+obj=OpenLayers.Tile.prototype.clone.apply(this,[obj]);obj.imgDiv=null;return obj;},draw:function(){if(this.layer!=this.layer.map.baseLayer&&this.layer.reproject){this.bounds=this.getBoundsFromBaseLayer(this.position);}
+var drawTile=OpenLayers.Tile.prototype.draw.apply(this,arguments);if((OpenLayers.Util.indexOf(this.layer.SUPPORTED_TRANSITIONS,this.layer.transitionEffect)!=-1)||this.layer.singleTile){if(drawTile){if(!this.backBufferTile){this.backBufferTile=this.clone();this.backBufferTile.hide();this.backBufferTile.isBackBuffer=true;this.events.register('loadend',this,this.resetBackBuffer);this.layer.events.register("loadend",this,this.resetBackBuffer);}
+this.startTransition();}else{if(this.backBufferTile){this.backBufferTile.clear();}}}else{if(drawTile&&this.isFirstDraw){this.events.register('loadend',this,this.showTile);this.isFirstDraw=false;}}
+if(!drawTile){return false;}
+if(this.isLoading){this.events.triggerEvent("reload");}else{this.isLoading=true;this.events.triggerEvent("loadstart");}
+return this.renderTile();},resetBackBuffer:function(){this.showTile();if(this.backBufferTile&&(this.isFirstDraw||!this.layer.numLoadingTiles)){this.isFirstDraw=false;var maxExtent=this.layer.maxExtent;var withinMaxExtent=(maxExtent&&this.bounds.intersectsBounds(maxExtent,false));if(withinMaxExtent){this.backBufferTile.position=this.position;this.backBufferTile.bounds=this.bounds;this.backBufferTile.size=this.size;this.backBufferTile.imageSize=this.layer.getImageSize(this.bounds)||this.size;this.backBufferTile.imageOffset=this.layer.imageOffset;this.backBufferTile.resolution=this.layer.getResolution();this.backBufferTile.renderTile();}
+this.backBufferTile.hide();}},renderTile:function(){if(this.layer.async){this.initImgDiv();this.layer.getURLasync(this.bounds,this,"url",this.positionImage);}else{this.url=this.layer.getURL(this.bounds);this.initImgDiv();this.positionImage();}
+return true;},positionImage:function(){if(this.layer===null){return;}
+OpenLayers.Util.modifyDOMElement(this.frame,null,this.position,this.size);var imageSize=this.layer.getImageSize(this.bounds);if(this.layerAlphaHack){OpenLayers.Util.modifyAlphaImageDiv(this.imgDiv,null,null,imageSize,this.url);}else{OpenLayers.Util.modifyDOMElement(this.imgDiv,null,null,imageSize);this.imgDiv.src=this.url;}},clear:function(){if(this.imgDiv){this.hide();if(OpenLayers.Tile.Image.useBlankTile){this.imgDiv.src=OpenLayers.Util.getImagesLocation()+"blank.gif";}}},initImgDiv:function(){if(this.imgDiv==null){var offset=this.layer.imageOffset;var size=this.layer.getImageSize(this.bounds);if(this.layerAlphaHack){this.imgDiv=OpenLayers.Util.createAlphaImageDiv(null,offset,size,null,"relative",null,null,null,true);}else{this.imgDiv=OpenLayers.Util.createImage(null,offset,size,null,"relative",null,null,true);}
+if(this.layer.url instanceof Array){this.imgDiv.urls=this.layer.url.slice();}
+this.imgDiv.className='olTileImage';this.frame.style.zIndex=this.isBackBuffer?0:1;this.frame.appendChild(this.imgDiv);this.layer.div.appendChild(this.frame);if(this.layer.opacity!=null){OpenLayers.Util.modifyDOMElement(this.imgDiv,null,null,null,null,null,null,this.layer.opacity);}
+this.imgDiv.map=this.layer.map;var onload=function(){if(this.isLoading){this.isLoading=false;this.events.triggerEvent("loadend");}};if(this.layerAlphaHack){OpenLayers.Event.observe(this.imgDiv.childNodes[0],'load',OpenLayers.Function.bind(onload,this));}else{OpenLayers.Event.observe(this.imgDiv,'load',OpenLayers.Function.bind(onload,this));}
+var onerror=function(){if(this.imgDiv._attempts>OpenLayers.IMAGE_RELOAD_ATTEMPTS){onload.call(this);}};OpenLayers.Event.observe(this.imgDiv,"error",OpenLayers.Function.bind(onerror,this));}
+this.imgDiv.viewRequestID=this.layer.map.viewRequestID;},removeImgDiv:function(){OpenLayers.Event.stopObservingElement(this.imgDiv);if(this.imgDiv.parentNode==this.frame){this.frame.removeChild(this.imgDiv);this.imgDiv.map=null;}
+this.imgDiv.urls=null;var child=this.imgDiv.firstChild;if(child){OpenLayers.Event.stopObservingElement(child);this.imgDiv.removeChild(child);delete child;}else{this.imgDiv.src=OpenLayers.Util.getImagesLocation()+"blank.gif";}},checkImgURL:function(){if(this.layer){var loaded=this.layerAlphaHack?this.imgDiv.firstChild.src:this.imgDiv.src;if(!OpenLayers.Util.isEquivalentUrl(loaded,this.url)){this.hide();}}},startTransition:function(){if(!this.backBufferTile||!this.backBufferTile.imgDiv){return;}
+var ratio=1;if(this.backBufferTile.resolution){ratio=this.backBufferTile.resolution/this.layer.getResolution();}
+if(ratio!=this.lastRatio){if(this.layer.transitionEffect=='resize'){var upperLeft=new OpenLayers.LonLat(this.backBufferTile.bounds.left,this.backBufferTile.bounds.top);var size=new OpenLayers.Size(this.backBufferTile.size.w*ratio,this.backBufferTile.size.h*ratio);var px=this.layer.map.getLayerPxFromLonLat(upperLeft);OpenLayers.Util.modifyDOMElement(this.backBufferTile.frame,null,px,size);var imageSize=this.backBufferTile.imageSize;imageSize=new OpenLayers.Size(imageSize.w*ratio,imageSize.h*ratio);var imageOffset=this.backBufferTile.imageOffset;if(imageOffset){imageOffset=new OpenLayers.Pixel(imageOffset.x*ratio,imageOffset.y*ratio);}
+OpenLayers.Util.modifyDOMElement(this.backBufferTile.imgDiv,null,imageOffset,imageSize);this.backBufferTile.show();}}else{if(this.layer.singleTile){this.backBufferTile.show();}else{this.backBufferTile.hide();}}
+this.lastRatio=ratio;},show:function(){this.frame.style.display='';if(OpenLayers.Util.indexOf(this.layer.SUPPORTED_TRANSITIONS,this.layer.transitionEffect)!=-1){if(OpenLayers.IS_GECKO===true){this.frame.scrollLeft=this.frame.scrollLeft;}}},hide:function(){this.frame.style.display='none';},CLASS_NAME:"OpenLayers.Tile.Image"});OpenLayers.Tile.Image.useBlankTile=(OpenLayers.BROWSER_NAME=="safari"||OpenLayers.BROWSER_NAME=="opera");OpenLayers.Handler.Click=OpenLayers.Class(OpenLayers.Handler,{delay:300,single:true,'double':false,pixelTolerance:0,stopSingle:false,stopDouble:false,timerId:null,down:null,rightclickTimerId:null,initialize:function(control,callbacks,options){OpenLayers.Handler.prototype.initialize.apply(this,arguments);if(this.pixelTolerance!=null){this.mousedown=function(evt){this.down=evt.xy;return true;};}},mousedown:null,mouseup:function(evt){var propagate=true;if(this.checkModifiers(evt)&&this.control.handleRightClicks&&OpenLayers.Event.isRightClick(evt)){propag
ate=this.rightclick(evt);}
+return propagate;},rightclick:function(evt){if(this.passesTolerance(evt)){if(this.rightclickTimerId!=null){this.clearTimer();this.callback('dblrightclick',[evt]);return!this.stopDouble;}else{var clickEvent=this['double']?OpenLayers.Util.extend({},evt):this.callback('rightclick',[evt]);var delayedRightCall=OpenLayers.Function.bind(this.delayedRightCall,this,clickEvent);this.rightclickTimerId=window.setTimeout(delayedRightCall,this.delay);}}
+return!this.stopSingle;},delayedRightCall:function(evt){this.rightclickTimerId=null;if(evt){this.callback('rightclick',[evt]);}
+return!this.stopSingle;},dblclick:function(evt){if(this.passesTolerance(evt)){if(this["double"]){this.callback('dblclick',[evt]);}
+this.clearTimer();}
+return!this.stopDouble;},click:function(evt){if(this.passesTolerance(evt)){if(this.timerId!=null){this.clearTimer();}else{var clickEvent=this.single?OpenLayers.Util.extend({},evt):null;this.timerId=window.setTimeout(OpenLayers.Function.bind(this.delayedCall,this,clickEvent),this.delay);}}
+return!this.stopSingle;},passesTolerance:function(evt){var passes=true;if(this.pixelTolerance!=null&&this.down){var dpx=Math.sqrt(Math.pow(this.down.x-evt.xy.x,2)+
+Math.pow(this.down.y-evt.xy.y,2));if(dpx>this.pixelTolerance){passes=false;}}
+return passes;},clearTimer:function(){if(this.timerId!=null){window.clearTimeout(this.timerId);this.timerId=null;}
+if(this.rightclickTimerId!=null){window.clearTimeout(this.rightclickTimerId);this.rightclickTimerId=null;}},delayedCall:function(evt){this.timerId=null;if(evt){this.callback('click',[evt]);}},deactivate:function(){var deactivated=false;if(OpenLayers.Handler.prototype.deactivate.apply(this,arguments)){this.clearTimer();this.down=null;deactivated=true;}
+return deactivated;},CLASS_NAME:"OpenLayers.Handler.Click"});OpenLayers.Handler.Drag=OpenLayers.Class(OpenLayers.Handler,{started:false,stopDown:true,dragging:false,last:null,start:null,oldOnselectstart:null,interval:0,timeoutId:null,documentDrag:false,documentEvents:null,kineticDragging:false,initialize:function(control,callbacks,options){OpenLayers.Handler.prototype.initialize.apply(this,arguments);},setMap:function(map){OpenLayers.Handler.prototype.setMap.apply(this,arguments);if(this.kineticDragging){this.kinetic=new OpenLayers.Kinetic({map:map});}},down:function(evt){},move:function(evt){},up:function(evt){},out:function(evt){},mousedown:function(evt){var propagate=true;this.dragging=false;if(this.checkModifiers(evt)&&OpenLayers.Event.isLeftClick(evt)){this.started=true;this.start=evt.xy;this.last=evt.xy;if(this.kineticDragging){this.kinetic.begin();}
+OpenLayers.Element.addClass(this.map.viewPortDiv,"olDragDown");this.down(evt);this.callback("down",[evt.xy]);OpenLayers.Event.stop(evt);if(!this.oldOnselectstart){this.oldOnselectstart=(document.onselectstart)?document.onselectstart:OpenLayers.Function.True;}
+document.onselectstart=OpenLayers.Function.False;propagate=!this.stopDown;}else{this.started=false;this.start=null;this.last=null;}
+return propagate;},mousemove:function(evt){if(this.started&&!this.timeoutId&&(evt.xy.x!=this.last.x||evt.xy.y!=this.last.y)){if(this.kineticDragging){this.kinetic.update(evt.xy);}
+if(this.documentDrag===true&&this.documentEvents){if(evt.element===document){this.adjustXY(evt);this.setEvent(evt);}else{this.destroyDocumentEvents();}}
+if(this.interval>0){this.timeoutId=setTimeout(OpenLayers.Function.bind(this.removeTimeout,this),this.interval);}
+this.dragging=true;this.move(evt);this.callback("move",[evt.xy]);if(!this.oldOnselectstart){this.oldOnselectstart=document.onselectstart;document.onselectstart=OpenLayers.Function.False;}
+this.last=this.evt.xy;}
+return true;},removeTimeout:function(){this.timeoutId=null;},mouseup:function(evt){if(this.started){if(this.documentDrag===true&&this.documentEvents){this.adjustXY(evt);this.destroyDocumentEvents();}
+var dragged=(this.start!=this.last);this.started=false;this.dragging=false;OpenLayers.Element.removeClass(this.map.viewPortDiv,"olDragDown");this.up(evt);this.callback("up",[evt.xy]);if(dragged){var delta;if(this.kineticDragging){delta=this.kinetic.end(evt.xy);}
+this.callback("done",[evt.xy,delta]);}
+document.onselectstart=this.oldOnselectstart;}
+return true;},mouseout:function(evt){if(this.started&&OpenLayers.Util.mouseLeft(evt,this.map.div)){if(this.documentDrag===true){this.documentEvents=new OpenLayers.Events(this,document,null,null,{includeXY:true});this.documentEvents.on({mousemove:this.mousemove,mouseup:this.mouseup});OpenLayers.Element.addClass(document.body,"olDragDown");}else{var dragged=(this.start!=this.last);this.started=false;this.dragging=false;OpenLayers.Element.removeClass(this.map.viewPortDiv,"olDragDown");this.out(evt);this.callback("out",[]);if(dragged){this.callback("done",[evt.xy]);}
+if(document.onselectstart){document.onselectstart=this.oldOnselectstart;}}}
+return true;},click:function(evt){return(this.start==this.last);},activate:function(){var activated=false;if(OpenLayers.Handler.prototype.activate.apply(this,arguments)){this.dragging=false;activated=true;}
+return activated;},deactivate:function(){var deactivated=false;if(OpenLayers.Handler.prototype.deactivate.apply(this,arguments)){this.started=false;this.dragging=false;this.start=null;this.last=null;deactivated=true;OpenLayers.Element.removeClass(this.map.viewPortDiv,"olDragDown");}
+return deactivated;},adjustXY:function(evt){var pos=OpenLayers.Util.pagePosition(this.map.viewPortDiv);evt.xy.x-=pos[0];evt.xy.y-=pos[1];},destroyDocumentEvents:function(){OpenLayers.Element.removeClass(document.body,"olDragDown");this.documentEvents.destroy();this.documentEvents=null;},CLASS_NAME:"OpenLayers.Handler.Drag"});OpenLayers.Handler.MouseWheel=OpenLayers.Class(OpenLayers.Handler,{wheelListener:null,mousePosition:null,interval:0,delta:0,cumulative:true,initialize:function(control,callbacks,options){OpenLayers.Handler.prototype.initialize.apply(this,arguments);this.wheelListener=OpenLayers.Function.bindAsEventListener(this.onWheelEvent,this);},destroy:function(){OpenLayers.Handler.prototype.destroy.apply(this,arguments);this.wheelListener=null;},onWheelEvent:function(e){if(!this.map||!this.checkModifiers(e)){return;}
+var overScrollableDiv=false;var overLayerDiv=false;var overMapDiv=false;var elem=OpenLayers.Event.element(e);while((elem!=null)&&!overMapDiv&&!overScrollableDiv){if(!overScrollableDiv){try{if(elem.currentStyle){overflow=elem.currentStyle["overflow"];}else{var style=document.defaultView.getComputedStyle(elem,null);var overflow=style.getPropertyValue("overflow");}
+overScrollableDiv=(overflow&&(overflow=="auto")||(overflow=="scroll"));}catch(err){}}
+if(!overLayerDiv){for(var i=0,len=this.map.layers.length;i<len;i++){if(elem==this.map.layers[i].div||elem==this.map.layers[i].pane){overLayerDiv=true;break;}}}
+overMapDiv=(elem==this.map.div);elem=elem.parentNode;}
+if(!overScrollableDiv&&overMapDiv){if(overLayerDiv){var delta=0;if(!e){e=window.event;}
+if(e.wheelDelta){delta=e.wheelDelta/120;if(window.opera&&window.opera.version()<9.2){delta=-delta;}}else if(e.detail){delta=-e.detail/3;}
+this.delta=this.delta+delta;if(this.interval){window.clearTimeout(this._timeoutId);this._timeoutId=window.setTimeout(OpenLayers.Function.bind(function(){this.wheelZoom(e);},this),this.interval);}else{this.wheelZoom(e);}}
+OpenLayers.Event.stop(e);}},wheelZoom:function(e){var delta=this.delta;this.delta=0;if(delta){if(this.mousePosition){e.xy=this.mousePosition;}
+if(!e.xy){e.xy=this.map.getPixelFromLonLat(this.map.getCenter());}
+if(delta<0){this.callback("down",[e,this.cumulative?delta:-1]);}else{this.callback("up",[e,this.cumulative?delta:1]);}}},mousemove:function(evt){this.mousePosition=evt.xy;},activate:function(evt){if(OpenLayers.Handler.prototype.activate.apply(this,arguments)){var wheelListener=this.wheelListener;OpenLayers.Event.observe(window,"DOMMouseScroll",wheelListener);OpenLayers.Event.observe(window,"mousewheel",wheelListener);OpenLayers.Event.observe(document,"mousewheel",wheelListener);return true;}else{return false;}},deactivate:function(evt){if(OpenLayers.Handler.prototype.deactivate.apply(this,arguments)){var wheelListener=this.wheelListener;OpenLayers.Event.stopObserving(window,"DOMMouseScroll",wheelListener);OpenLayers.Event.stopObserving(window,"mousewheel",wheelListener);OpenLayers.Event.stopObserving(document,"mousewheel",wheelListener);return true;}else{return false;}},CLASS_NAME:"OpenLayers.Handler.MouseWheel"});OpenLayers.Layer=OpenLayers.Class({id:null,name:null,div:null
,opacity:null,alwaysInRange:null,EVENT_TYPES:["loadstart","loadend","loadcancel","visibilitychanged","move","moveend"],RESOLUTION_PROPERTIES:['scales','resolutions','maxScale','minScale','maxResolution','minResolution','numZoomLevels','maxZoomLevel'],events:null,map:null,isBaseLayer:false,alpha:false,displayInLayerSwitcher:true,visibility:true,attribution:null,inRange:false,imageSize:null,imageOffset:null,options:null,eventListeners:null,gutter:0,projection:null,units:null,scales:null,resolutions:null,maxExtent:null,minExtent:null,maxResolution:null,minResolution:null,numZoomLevels:null,minScale:null,maxScale:null,displayOutsideMaxExtent:false,wrapDateLine:false,transitionEffect:null,SUPPORTED_TRANSITIONS:['resize'],metadata:{},initialize:function(name,options){this.addOptions(options);this.name=name;if(this.id==null){this.id=OpenLayers.Util.createUniqueID(this.CLASS_NAME+"_");this.div=OpenLayers.Util.createDiv(this.id);this.div.style.width="100%";this.div.style.height="100%
";this.div.dir="ltr";this.events=new OpenLayers.Events(this,this.div,this.EVENT_TYPES);if(this.eventListeners instanceof Object){this.events.on(this.eventListeners);}}
+if(this.wrapDateLine){this.displayOutsideMaxExtent=true;}},destroy:function(setNewBaseLayer){if(setNewBaseLayer==null){setNewBaseLayer=true;}
+if(this.map!=null){this.map.removeLayer(this,setNewBaseLayer);}
+this.projection=null;this.map=null;this.name=null;this.div=null;this.options=null;if(this.events){if(this.eventListeners){this.events.un(this.eventListeners);}
+this.events.destroy();}
+this.eventListeners=null;this.events=null;},clone:function(obj){if(obj==null){obj=new OpenLayers.Layer(this.name,this.getOptions());}
+OpenLayers.Util.applyDefaults(obj,this);obj.map=null;return obj;},getOptions:function(){var options={};for(var o in this.options){options[o]=this[o];}
+return options;},setName:function(newName){if(newName!=this.name){this.name=newName;if(this.map!=null){this.map.events.triggerEvent("changelayer",{layer:this,property:"name"});}}},addOptions:function(newOptions){if(this.options==null){this.options={};}
+OpenLayers.Util.extend(this.options,newOptions);OpenLayers.Util.extend(this,newOptions);if(typeof this.projection=="string"){this.projection=new OpenLayers.Projection(this.projection);}
+if(this.projection&&this.projection.getUnits()){this.units=this.projection.getUnits();}
+if(this.map){var properties=this.RESOLUTION_PROPERTIES.concat(["projection","units","minExtent","maxExtent"]);for(var o in newOptions){if(newOptions.hasOwnProperty(o)&&OpenLayers.Util.indexOf(properties,o)>=0){this.initResolutions();break;}}}},onMapResize:function(){},redraw:function(){var redrawn=false;if(this.map){this.inRange=this.calculateInRange();var extent=this.getExtent();if(extent&&this.inRange&&this.visibility){var zoomChanged=true;this.moveTo(extent,zoomChanged,false);this.events.triggerEvent("moveend",{"zoomChanged":zoomChanged});redrawn=true;}}
+return redrawn;},moveTo:function(bounds,zoomChanged,dragging){var display=this.visibility;if(!this.isBaseLayer){display=display&&this.inRange;}
+this.display(display);},setMap:function(map){if(this.map==null){this.map=map;this.maxExtent=this.maxExtent||this.map.maxExtent;this.minExtent=this.minExtent||this.map.minExtent;this.projection=this.projection||this.map.projection;if(typeof this.projection=="string"){this.projection=new OpenLayers.Projection(this.projection);}
+this.units=this.projection.getUnits()||this.units||this.map.units;this.initResolutions();if(!this.isBaseLayer){this.inRange=this.calculateInRange();var show=((this.visibility)&&(this.inRange));this.div.style.display=show?"":"none";}
+this.setTileSize();}},afterAdd:function(){},removeMap:function(map){},getImageSize:function(bounds){return(this.imageSize||this.tileSize);},setTileSize:function(size){var tileSize=(size)?size:((this.tileSize)?this.tileSize:this.map.getTileSize());this.tileSize=tileSize;if(this.gutter){this.imageOffset=new OpenLayers.Pixel(-this.gutter,-this.gutter);this.imageSize=new OpenLayers.Size(tileSize.w+(2*this.gutter),tileSize.h+(2*this.gutter));}},getVisibility:function(){return this.visibility;},setVisibility:function(visibility){if(visibility!=this.visibility){this.visibility=visibility;this.display(visibility);this.redraw();if(this.map!=null){this.map.events.triggerEvent("changelayer",{layer:this,property:"visibility"});}
+this.events.triggerEvent("visibilitychanged");}},display:function(display){if(display!=(this.div.style.display!="none")){this.div.style.display=(display&&this.calculateInRange())?"block":"none";}},calculateInRange:function(){var inRange=false;if(this.alwaysInRange){inRange=true;}else{if(this.map){var resolution=this.map.getResolution();inRange=((resolution>=this.minResolution)&&(resolution<=this.maxResolution));}}
+return inRange;},setIsBaseLayer:function(isBaseLayer){if(isBaseLayer!=this.isBaseLayer){this.isBaseLayer=isBaseLayer;if(this.map!=null){this.map.events.triggerEvent("changebaselayer",{layer:this});}}},initResolutions:function(){var i,len;var props={},alwaysInRange=true;for(i=0,len=this.RESOLUTION_PROPERTIES.length;i<len;i++){var p=this.RESOLUTION_PROPERTIES[i];props[p]=this.options[p];if(alwaysInRange&&this.options[p]){alwaysInRange=false;}}
+if(this.alwaysInRange==null){this.alwaysInRange=alwaysInRange;}
+if(props.resolutions==null){props.resolutions=this.resolutionsFromScales(props.scales);}
+if(props.resolutions==null){props.resolutions=this.calculateResolutions(props);}
+if(props.resolutions==null){for(i=0,len=this.RESOLUTION_PROPERTIES.length;i<len;i++){var p=this.RESOLUTION_PROPERTIES[i];props[p]=this.options[p]!=null?this.options[p]:this.map[p];}
+if(props.resolutions==null){props.resolutions=this.calculateResolutions(props);}}
+var maxResolution;if(this.options.maxResolution&&this.options.maxResolution!=="auto"){maxResolution=this.options.maxResolution;}
+if(this.options.minScale){maxResolution=OpenLayers.Util.getResolutionFromScale(this.options.minScale,this.units);}
+var minResolution;if(this.options.minResolution&&this.options.minResolution!=="auto"){minResolution=this.options.minResolution;}
+if(this.options.maxScale){minResolution=OpenLayers.Util.getResolutionFromScale(this.options.maxScale,this.units);}
+if(props.resolutions){props.resolutions.sort(function(a,b){return(b-a);});if(!maxResolution){maxResolution=props.resolutions[0];}
+if(!minResolution){var lastIdx=props.resolutions.length-1;minResolution=props.resolutions[lastIdx];}}
+this.resolutions=props.resolutions;if(this.resolutions){len=this.resolutions.length;this.scales=new Array(len);for(i=0;i<len;i++){this.scales[i]=OpenLayers.Util.getScaleFromResolution(this.resolutions[i],this.units);}
+this.numZoomLevels=len;}
+this.minResolution=minResolution;if(minResolution){this.maxScale=OpenLayers.Util.getScaleFromResolution(minResolution,this.units);}
+this.maxResolution=maxResolution;if(maxResolution){this.minScale=OpenLayers.Util.getScaleFromResolution(maxResolution,this.units);}},resolutionsFromScales:function(scales){if(scales==null){return;}
+var resolutions,i,len;len=scales.length;resolutions=new Array(len);for(i=0;i<len;i++){resolutions[i]=OpenLayers.Util.getResolutionFromScale(scales[i],this.units);}
+return resolutions;},calculateResolutions:function(props){var maxResolution=props.maxResolution;if(props.minScale!=null){maxResolution=OpenLayers.Util.getResolutionFromScale(props.minScale,this.units);}else if(maxResolution=="auto"&&this.maxExtent!=null){var viewSize=this.map.getSize();var wRes=this.maxExtent.getWidth()/viewSize.w;var hRes=this.maxExtent.getHeight()/viewSize.h;maxResolution=Math.max(wRes,hRes);}
+var minResolution=props.minResolution;if(props.maxScale!=null){minResolution=OpenLayers.Util.getResolutionFromScale(props.maxScale,this.units);}else if(props.minResolution=="auto"&&this.minExtent!=null){var viewSize=this.map.getSize();var wRes=this.minExtent.getWidth()/viewSize.w;var hRes=this.minExtent.getHeight()/viewSize.h;minResolution=Math.max(wRes,hRes);}
+var maxZoomLevel=props.maxZoomLevel;var numZoomLevels=props.numZoomLevels;if(typeof minResolution==="number"&&typeof maxResolution==="number"&&numZoomLevels===undefined){var ratio=maxResolution/minResolution;numZoomLevels=Math.floor(Math.log(ratio)/Math.log(2))+1;}else if(numZoomLevels===undefined&&maxZoomLevel!=null){numZoomLevels=maxZoomLevel+1;}
+if(typeof numZoomLevels!=="number"||numZoomLevels<=0||(typeof maxResolution!=="number"&&typeof minResolution!=="number")){return;}
+var resolutions=new Array(numZoomLevels);var base=2;if(typeof minResolution=="number"&&typeof maxResolution=="number"){base=Math.pow((maxResolution/minResolution),(1/(numZoomLevels-1)));}
+var i;if(typeof maxResolution==="number"){for(i=0;i<numZoomLevels;i++){resolutions[i]=maxResolution/Math.pow(base,i);}}else{for(i=0;i<numZoomLevels;i++){resolutions[numZoomLevels-1-i]=minResolution*Math.pow(base,i);}}
+return resolutions;},getResolution:function(){var zoom=this.map.getZoom();return this.getResolutionForZoom(zoom);},getExtent:function(){return this.map.calculateBounds();},getZoomForExtent:function(extent,closest){var viewSize=this.map.getSize();var idealResolution=Math.max(extent.getWidth()/viewSize.w,extent.getHeight()/viewSize.h);return this.getZoomForResolution(idealResolution,closest);},getDataExtent:function(){},getResolutionForZoom:function(zoom){zoom=Math.max(0,Math.min(zoom,this.resolutions.length-1));var resolution;if(this.map.fractionalZoom){var low=Math.floor(zoom);var high=Math.ceil(zoom);resolution=this.resolutions[low]-
+((zoom-low)*(this.resolutions[low]-this.resolutions[high]));}else{resolution=this.resolutions[Math.round(zoom)];}
+return resolution;},getZoomForResolution:function(resolution,closest){var zoom;if(this.map.fractionalZoom){var lowZoom=0;var highZoom=this.resolutions.length-1;var highRes=this.resolutions[lowZoom];var lowRes=this.resolutions[highZoom];var res;for(var i=0,len=this.resolutions.length;i<len;++i){res=this.resolutions[i];if(res>=resolution){highRes=res;lowZoom=i;}
+if(res<=resolution){lowRes=res;highZoom=i;break;}}
+var dRes=highRes-lowRes;if(dRes>0){zoom=lowZoom+((highRes-resolution)/dRes);}else{zoom=lowZoom;}}else{var diff;var minDiff=Number.POSITIVE_INFINITY;for(var i=0,len=this.resolutions.length;i<len;i++){if(closest){diff=Math.abs(this.resolutions[i]-resolution);if(diff>minDiff){break;}
+minDiff=diff;}else{if(this.resolutions[i]<resolution){break;}}}
+zoom=Math.max(0,i-1);}
+return zoom;},getLonLatFromViewPortPx:function(viewPortPx){var lonlat=null;if(viewPortPx!=null){var size=this.map.getSize();var center=this.map.getCenter();if(center){var res=this.map.getResolution();var delta_x=viewPortPx.x-(size.w/2);var delta_y=viewPortPx.y-(size.h/2);lonlat=new OpenLayers.LonLat(center.lon+delta_x*res,center.lat-delta_y*res);if(this.wrapDateLine){lonlat=lonlat.wrapDateLine(this.maxExtent);}}}
+return lonlat;},getViewPortPxFromLonLat:function(lonlat){var px=null;if(lonlat!=null){var resolution=this.map.getResolution();var extent=this.map.getExtent();px=new OpenLayers.Pixel((1/resolution*(lonlat.lon-extent.left)),(1/resolution*(extent.top-lonlat.lat)));}
+return px;},setOpacity:function(opacity){if(opacity!=this.opacity){this.opacity=opacity;for(var i=0,len=this.div.childNodes.length;i<len;++i){var element=this.div.childNodes[i].firstChild;OpenLayers.Util.modifyDOMElement(element,null,null,null,null,null,null,opacity);}
+if(this.map!=null){this.map.events.triggerEvent("changelayer",{layer:this,property:"opacity"});}}},getZIndex:function(){return this.div.style.zIndex;},setZIndex:function(zIndex){this.div.style.zIndex=zIndex;},adjustBounds:function(bounds){if(this.gutter){var mapGutter=this.gutter*this.map.getResolution();bounds=new OpenLayers.Bounds(bounds.left-mapGutter,bounds.bottom-mapGutter,bounds.right+mapGutter,bounds.top+mapGutter);}
+if(this.wrapDateLine){var wrappingOptions={'rightTolerance':this.getResolution()};bounds=bounds.wrapDateLine(this.maxExtent,wrappingOptions);}
+return bounds;},CLASS_NAME:"OpenLayers.Layer"});OpenLayers.Control.DragPan=OpenLayers.Class(OpenLayers.Control,{type:OpenLayers.Control.TYPE_TOOL,panned:false,interval:25,documentDrag:false,kineticDragging:false,draw:function(){this.handler=new OpenLayers.Handler.Drag(this,{"move":this.panMap,"done":this.panMapDone},{interval:this.interval,documentDrag:this.documentDrag,kineticDragging:this.kineticDragging});},panMap:function(xy,animate){this.panned=true;this.map.pan(this.handler.last.x-xy.x,this.handler.last.y-xy.y,{dragging:this.handler.dragging,animate:!!animate});},panMapDone:function(xy,delta){if(this.panned){this.panMap(xy);if(delta){this.handler.last.x=xy.x;this.handler.last.y=xy.y;this.panMap(xy.add(delta.x,delta.y),true);}
+this.panned=false;}},CLASS_NAME:"OpenLayers.Control.DragPan"});OpenLayers.Handler.Box=OpenLayers.Class(OpenLayers.Handler,{dragHandler:null,boxDivClassName:'olHandlerBoxZoomBox',boxCharacteristics:null,initialize:function(control,callbacks,options){OpenLayers.Handler.prototype.initialize.apply(this,arguments);var callbacks={"down":this.startBox,"move":this.moveBox,"out":this.removeBox,"up":this.endBox};this.dragHandler=new OpenLayers.Handler.Drag(this,callbacks,{keyMask:this.keyMask});},destroy:function(){if(this.dragHandler){this.dragHandler.destroy();this.dragHandler=null;}
+OpenLayers.Handler.prototype.destroy.apply(this,arguments);},setMap:function(map){OpenLayers.Handler.prototype.setMap.apply(this,arguments);if(this.dragHandler){this.dragHandler.setMap(map);}},startBox:function(xy){this.zoomBox=OpenLayers.Util.createDiv('zoomBox',this.dragHandler.start);this.zoomBox.className=this.boxDivClassName;this.zoomBox.style.zIndex=this.map.Z_INDEX_BASE["Popup"]-1;this.map.viewPortDiv.appendChild(this.zoomBox);OpenLayers.Element.addClass(this.map.viewPortDiv,"olDrawBox");},moveBox:function(xy){var startX=this.dragHandler.start.x;var startY=this.dragHandler.start.y;var deltaX=Math.abs(startX-xy.x);var deltaY=Math.abs(startY-xy.y);this.zoomBox.style.width=Math.max(1,deltaX)+"px";this.zoomBox.style.height=Math.max(1,deltaY)+"px";this.zoomBox.style.left=xy.x<startX?xy.x+"px":startX+"px";this.zoomBox.style.top=xy.y<startY?xy.y+"px":startY+"px";var box=this.getBoxCharacteristics();if(box.newBoxModel){if(xy.x>startX){this.zoomBox.style.width=Math.max(1,delta
X-box.xOffset)+"px";}
+if(xy.y>startY){this.zoomBox.style.height=Math.max(1,deltaY-box.yOffset)+"px";}}},endBox:function(end){var result;if(Math.abs(this.dragHandler.start.x-end.x)>5||Math.abs(this.dragHandler.start.y-end.y)>5){var start=this.dragHandler.start;var top=Math.min(start.y,end.y);var bottom=Math.max(start.y,end.y);var left=Math.min(start.x,end.x);var right=Math.max(start.x,end.x);result=new OpenLayers.Bounds(left,bottom,right,top);}else{result=this.dragHandler.start.clone();}
+this.removeBox();this.callback("done",[result]);},removeBox:function(){this.map.viewPortDiv.removeChild(this.zoomBox);this.zoomBox=null;this.boxCharacteristics=null;OpenLayers.Element.removeClass(this.map.viewPortDiv,"olDrawBox");},activate:function(){if(OpenLayers.Handler.prototype.activate.apply(this,arguments)){this.dragHandler.activate();return true;}else{return false;}},deactivate:function(){if(OpenLayers.Handler.prototype.deactivate.apply(this,arguments)){this.dragHandler.deactivate();return true;}else{return false;}},getBoxCharacteristics:function(){if(!this.boxCharacteristics){var xOffset=parseInt(OpenLayers.Element.getStyle(this.zoomBox,"border-left-width"))+parseInt(OpenLayers.Element.getStyle(this.zoomBox,"border-right-width"))+1;var yOffset=parseInt(OpenLayers.Element.getStyle(this.zoomBox,"border-top-width"))+parseInt(OpenLayers.Element.getStyle(this.zoomBox,"border-bottom-width"))+1;var newBoxModel=OpenLayers.BROWSER_NAME=="msie"?document.compatMode!="BackCompa
t":true;this.boxCharacteristics={xOffset:xOffset,yOffset:yOffset,newBoxModel:newBoxModel};}
+return this.boxCharacteristics;},CLASS_NAME:"OpenLayers.Handler.Box"});OpenLayers.Layer.HTTPRequest=OpenLayers.Class(OpenLayers.Layer,{URL_HASH_FACTOR:(Math.sqrt(5)-1)/2,url:null,params:null,reproject:false,initialize:function(name,url,params,options){var newArguments=arguments;newArguments=[name,options];OpenLayers.Layer.prototype.initialize.apply(this,newArguments);this.url=url;this.params=OpenLayers.Util.extend({},params);},destroy:function(){this.url=null;this.params=null;OpenLayers.Layer.prototype.destroy.apply(this,arguments);},clone:function(obj){if(obj==null){obj=new OpenLayers.Layer.HTTPRequest(this.name,this.url,this.params,this.getOptions());}
+obj=OpenLayers.Layer.prototype.clone.apply(this,[obj]);return obj;},setUrl:function(newUrl){this.url=newUrl;},mergeNewParams:function(newParams){this.params=OpenLayers.Util.extend(this.params,newParams);var ret=this.redraw();if(this.map!=null){this.map.events.triggerEvent("changelayer",{layer:this,property:"params"});}
+return ret;},redraw:function(force){if(force){return this.mergeNewParams({"_olSalt":Math.random()});}else{return OpenLayers.Layer.prototype.redraw.apply(this,[]);}},selectUrl:function(paramString,urls){var product=1;for(var i=0,len=paramString.length;i<len;i++){product*=paramString.charCodeAt(i)*this.URL_HASH_FACTOR;product-=Math.floor(product);}
+return urls[Math.floor(product*urls.length)];},getFullRequestString:function(newParams,altUrl){var url=altUrl||this.url;var allParams=OpenLayers.Util.extend({},this.params);allParams=OpenLayers.Util.extend(allParams,newParams);var paramsString=OpenLayers.Util.getParameterString(allParams);if(url instanceof Array){url=this.selectUrl(paramsString,url);}
+var urlParams=OpenLayers.Util.upperCaseObject(OpenLayers.Util.getParameters(url));for(var key in allParams){if(key.toUpperCase()in urlParams){delete allParams[key];}}
+paramsString=OpenLayers.Util.getParameterString(allParams);return OpenLayers.Util.urlAppend(url,paramsString);},CLASS_NAME:"OpenLayers.Layer.HTTPRequest"});OpenLayers.Control.ZoomBox=OpenLayers.Class(OpenLayers.Control,{type:OpenLayers.Control.TYPE_TOOL,out:false,alwaysZoom:false,draw:function(){this.handler=new OpenLayers.Handler.Box(this,{done:this.zoomBox},{keyMask:this.keyMask});},zoomBox:function(position){if(position instanceof OpenLayers.Bounds){var bounds;if(!this.out){var minXY=this.map.getLonLatFromPixel(new OpenLayers.Pixel(position.left,position.bottom));var maxXY=this.map.getLonLatFromPixel(new OpenLayers.Pixel(position.right,position.top));bounds=new OpenLayers.Bounds(minXY.lon,minXY.lat,maxXY.lon,maxXY.lat);}else{var pixWidth=Math.abs(position.right-position.left);var pixHeight=Math.abs(position.top-position.bottom);var zoomFactor=Math.min((this.map.size.h/pixHeight),(this.map.size.w/pixWidth));var extent=this.map.getExtent();var center=this.map.getLonLatFromP
ixel(position.getCenterPixel());var xmin=center.lon-(extent.getWidth()/2)*zoomFactor;var xmax=center.lon+(extent.getWidth()/2)*zoomFactor;var ymin=center.lat-(extent.getHeight()/2)*zoomFactor;var ymax=center.lat+(extent.getHeight()/2)*zoomFactor;bounds=new OpenLayers.Bounds(xmin,ymin,xmax,ymax);}
+var lastZoom=this.map.getZoom();this.map.zoomToExtent(bounds);if(lastZoom==this.map.getZoom()&&this.alwaysZoom==true){this.map.zoomTo(lastZoom+(this.out?-1:1));}}else{if(!this.out){this.map.setCenter(this.map.getLonLatFromPixel(position),this.map.getZoom()+1);}else{this.map.setCenter(this.map.getLonLatFromPixel(position),this.map.getZoom()-1);}}},CLASS_NAME:"OpenLayers.Control.ZoomBox"});OpenLayers.Layer.Grid=OpenLayers.Class(OpenLayers.Layer.HTTPRequest,{tileSize:null,tileOptions:null,grid:null,singleTile:false,ratio:1.5,buffer:2,numLoadingTiles:0,initialize:function(name,url,params,options){OpenLayers.Layer.HTTPRequest.prototype.initialize.apply(this,arguments);this.events.addEventType("tileloaded");this.grid=[];},destroy:function(){this.clearGrid();this.grid=null;this.tileSize=null;OpenLayers.Layer.HTTPRequest.prototype.destroy.apply(this,arguments);},clearGrid:function(){if(this.grid){for(var iRow=0,len=this.grid.length;iRow<len;iRow++){var row=this.grid[iRow];for(var iC
ol=0,clen=row.length;iCol<clen;iCol++){var tile=row[iCol];this.removeTileMonitoringHooks(tile);tile.destroy();}}
+this.grid=[];}},clone:function(obj){if(obj==null){obj=new OpenLayers.Layer.Grid(this.name,this.url,this.params,this.getOptions());}
+obj=OpenLayers.Layer.HTTPRequest.prototype.clone.apply(this,[obj]);if(this.tileSize!=null){obj.tileSize=this.tileSize.clone();}
+obj.grid=[];return obj;},moveTo:function(bounds,zoomChanged,dragging){OpenLayers.Layer.HTTPRequest.prototype.moveTo.apply(this,arguments);bounds=bounds||this.map.getExtent();if(bounds!=null){var forceReTile=!this.grid.length||zoomChanged;var tilesBounds=this.getTilesBounds();if(this.singleTile){if(forceReTile||(!dragging&&!tilesBounds.containsBounds(bounds))){this.initSingleTile(bounds);}}else{if(forceReTile||!tilesBounds.containsBounds(bounds,true)){this.initGriddedTiles(bounds);}else{this.moveGriddedTiles(bounds);}}}},setTileSize:function(size){if(this.singleTile){size=this.map.getSize();size.h=parseInt(size.h*this.ratio);size.w=parseInt(size.w*this.ratio);}
+OpenLayers.Layer.HTTPRequest.prototype.setTileSize.apply(this,[size]);},getGridBounds:function(){var msg="The getGridBounds() function is deprecated. It will be "+"removed in 3.0. Please use getTilesBounds() instead.";OpenLayers.Console.warn(msg);return this.getTilesBounds();},getTilesBounds:function(){var bounds=null;if(this.grid.length){var bottom=this.grid.length-1;var bottomLeftTile=this.grid[bottom][0];var right=this.grid[0].length-1;var topRightTile=this.grid[0][right];bounds=new OpenLayers.Bounds(bottomLeftTile.bounds.left,bottomLeftTile.bounds.bottom,topRightTile.bounds.right,topRightTile.bounds.top);}
+return bounds;},initSingleTile:function(bounds){var center=bounds.getCenterLonLat();var tileWidth=bounds.getWidth()*this.ratio;var tileHeight=bounds.getHeight()*this.ratio;var tileBounds=new OpenLayers.Bounds(center.lon-(tileWidth/2),center.lat-(tileHeight/2),center.lon+(tileWidth/2),center.lat+(tileHeight/2));var ul=new OpenLayers.LonLat(tileBounds.left,tileBounds.top);var px=this.map.getLayerPxFromLonLat(ul);if(!this.grid.length){this.grid[0]=[];}
+var tile=this.grid[0][0];if(!tile){tile=this.addTile(tileBounds,px);this.addTileMonitoringHooks(tile);tile.draw();this.grid[0][0]=tile;}else{tile.moveTo(tileBounds,px);}
+this.removeExcessTiles(1,1);},calculateGridLayout:function(bounds,extent,resolution){var tilelon=resolution*this.tileSize.w;var tilelat=resolution*this.tileSize.h;var offsetlon=bounds.left-extent.left;var tilecol=Math.floor(offsetlon/tilelon)-this.buffer;var tilecolremain=offsetlon/tilelon-tilecol;var tileoffsetx=-tilecolremain*this.tileSize.w;var tileoffsetlon=extent.left+tilecol*tilelon;var offsetlat=bounds.top-(extent.bottom+tilelat);var tilerow=Math.ceil(offsetlat/tilelat)+this.buffer;var tilerowremain=tilerow-offsetlat/tilelat;var tileoffsety=-tilerowremain*this.tileSize.h;var tileoffsetlat=extent.bottom+tilerow*tilelat;return{tilelon:tilelon,tilelat:tilelat,tileoffsetlon:tileoffsetlon,tileoffsetlat:tileoffsetlat,tileoffsetx:tileoffsetx,tileoffsety:tileoffsety};},initGriddedTiles:function(bounds){var viewSize=this.map.getSize();var minRows=Math.ceil(viewSize.h/this.tileSize.h)+
+Math.max(1,2*this.buffer);var minCols=Math.ceil(viewSize.w/this.tileSize.w)+
+Math.max(1,2*this.buffer);var extent=this.getMaxExtent();var resolution=this.map.getResolution();var tileLayout=this.calculateGridLayout(bounds,extent,resolution);var tileoffsetx=Math.round(tileLayout.tileoffsetx);var tileoffsety=Math.round(tileLayout.tileoffsety);var tileoffsetlon=tileLayout.tileoffsetlon;var tileoffsetlat=tileLayout.tileoffsetlat;var tilelon=tileLayout.tilelon;var tilelat=tileLayout.tilelat;this.origin=new OpenLayers.Pixel(tileoffsetx,tileoffsety);var startX=tileoffsetx;var startLon=tileoffsetlon;var rowidx=0;var layerContainerDivLeft=parseInt(this.map.layerContainerDiv.style.left);var layerContainerDivTop=parseInt(this.map.layerContainerDiv.style.top);do{var row=this.grid[rowidx++];if(!row){row=[];this.grid.push(row);}
+tileoffsetlon=startLon;tileoffsetx=startX;var colidx=0;do{var tileBounds=new OpenLayers.Bounds(tileoffsetlon,tileoffsetlat,tileoffsetlon+tilelon,tileoffsetlat+tilelat);var x=tileoffsetx;x-=layerContainerDivLeft;var y=tileoffsety;y-=layerContainerDivTop;var px=new OpenLayers.Pixel(x,y);var tile=row[colidx++];if(!tile){tile=this.addTile(tileBounds,px);this.addTileMonitoringHooks(tile);row.push(tile);}else{tile.moveTo(tileBounds,px,false);}
+tileoffsetlon+=tilelon;tileoffsetx+=this.tileSize.w;}while((tileoffsetlon<=bounds.right+tilelon*this.buffer)||colidx<minCols);tileoffsetlat-=tilelat;tileoffsety+=this.tileSize.h;}while((tileoffsetlat>=bounds.bottom-tilelat*this.buffer)||rowidx<minRows);this.removeExcessTiles(rowidx,colidx);this.spiralTileLoad();},getMaxExtent:function(){return this.maxExtent;},spiralTileLoad:function(){var tileQueue=[];var directions=["right","down","left","up"];var iRow=0;var iCell=-1;var direction=OpenLayers.Util.indexOf(directions,"right");var directionsTried=0;while(directionsTried<directions.length){var testRow=iRow;var testCell=iCell;switch(directions[direction]){case"right":testCell++;break;case"down":testRow++;break;case"left":testCell--;break;case"up":testRow--;break;}
+var tile=null;if((testRow<this.grid.length)&&(testRow>=0)&&(testCell<this.grid[0].length)&&(testCell>=0)){tile=this.grid[testRow][testCell];}
+if((tile!=null)&&(!tile.queued)){tileQueue.unshift(tile);tile.queued=true;directionsTried=0;iRow=testRow;iCell=testCell;}else{direction=(direction+1)%4;directionsTried++;}}
+for(var i=0,len=tileQueue.length;i<len;i++){var tile=tileQueue[i];tile.draw();tile.queued=false;}},addTile:function(bounds,position){},addTileMonitoringHooks:function(tile){tile.onLoadStart=function(){if(this.numLoadingTiles==0){this.events.triggerEvent("loadstart");}
+this.numLoadingTiles++;};tile.events.register("loadstart",this,tile.onLoadStart);tile.onLoadEnd=function(){this.numLoadingTiles--;this.events.triggerEvent("tileloaded");if(this.numLoadingTiles==0){this.events.triggerEvent("loadend");}};tile.events.register("loadend",this,tile.onLoadEnd);tile.events.register("unload",this,tile.onLoadEnd);},removeTileMonitoringHooks:function(tile){tile.unload();tile.events.un({"loadstart":tile.onLoadStart,"loadend":tile.onLoadEnd,"unload":tile.onLoadEnd,scope:this});},moveGriddedTiles:function(bounds){var buffer=this.buffer||1;while(true){var tlLayer=this.grid[0][0].position;var tlViewPort=this.map.getViewPortPxFromLayerPx(tlLayer);if(tlViewPort.x>-this.tileSize.w*(buffer-1)){this.shiftColumn(true);}else if(tlViewPort.x<-this.tileSize.w*buffer){this.shiftColumn(false);}else if(tlViewPort.y>-this.tileSize.h*(buffer-1)){this.shiftRow(true);}else if(tlViewPort.y<-this.tileSize.h*buffer){this.shiftRow(false);}else{break;}};},shiftRow:function(prep
end){var modelRowIndex=(prepend)?0:(this.grid.length-1);var grid=this.grid;var modelRow=grid[modelRowIndex];var resolution=this.map.getResolution();var deltaY=(prepend)?-this.tileSize.h:this.tileSize.h;var deltaLat=resolution*-deltaY;var row=(prepend)?grid.pop():grid.shift();for(var i=0,len=modelRow.length;i<len;i++){var modelTile=modelRow[i];var bounds=modelTile.bounds.clone();var position=modelTile.position.clone();bounds.bottom=bounds.bottom+deltaLat;bounds.top=bounds.top+deltaLat;position.y=position.y+deltaY;row[i].moveTo(bounds,position);}
+if(prepend){grid.unshift(row);}else{grid.push(row);}},shiftColumn:function(prepend){var deltaX=(prepend)?-this.tileSize.w:this.tileSize.w;var resolution=this.map.getResolution();var deltaLon=resolution*deltaX;for(var i=0,len=this.grid.length;i<len;i++){var row=this.grid[i];var modelTileIndex=(prepend)?0:(row.length-1);var modelTile=row[modelTileIndex];var bounds=modelTile.bounds.clone();var position=modelTile.position.clone();bounds.left=bounds.left+deltaLon;bounds.right=bounds.right+deltaLon;position.x=position.x+deltaX;var tile=prepend?this.grid[i].pop():this.grid[i].shift();tile.moveTo(bounds,position);if(prepend){row.unshift(tile);}else{row.push(tile);}}},removeExcessTiles:function(rows,columns){while(this.grid.length>rows){var row=this.grid.pop();for(var i=0,l=row.length;i<l;i++){var tile=row[i];this.removeTileMonitoringHooks(tile);tile.destroy();}}
+while(this.grid[0].length>columns){for(var i=0,l=this.grid.length;i<l;i++){var row=this.grid[i];var tile=row.pop();this.removeTileMonitoringHooks(tile);tile.destroy();}}},onMapResize:function(){if(this.singleTile){this.clearGrid();this.setTileSize();}},getTileBounds:function(viewPortPx){var maxExtent=this.maxExtent;var resolution=this.getResolution();var tileMapWidth=resolution*this.tileSize.w;var tileMapHeight=resolution*this.tileSize.h;var mapPoint=this.getLonLatFromViewPortPx(viewPortPx);var tileLeft=maxExtent.left+(tileMapWidth*Math.floor((mapPoint.lon-
+maxExtent.left)/tileMapWidth));var tileBottom=maxExtent.bottom+(tileMapHeight*Math.floor((mapPoint.lat-
+maxExtent.bottom)/tileMapHeight));return new OpenLayers.Bounds(tileLeft,tileBottom,tileLeft+tileMapWidth,tileBottom+tileMapHeight);},CLASS_NAME:"OpenLayers.Layer.Grid"});OpenLayers.Control.Navigation=OpenLayers.Class(OpenLayers.Control,{dragPan:null,dragPanOptions:null,documentDrag:false,zoomBox:null,zoomBoxEnabled:true,zoomWheelEnabled:true,mouseWheelOptions:null,handleRightClicks:false,zoomBoxKeyMask:OpenLayers.Handler.MOD_SHIFT,autoActivate:true,initialize:function(options){this.handlers={};OpenLayers.Control.prototype.initialize.apply(this,arguments);},destroy:function(){this.deactivate();if(this.dragPan){this.dragPan.destroy();}
+this.dragPan=null;if(this.zoomBox){this.zoomBox.destroy();}
+this.zoomBox=null;OpenLayers.Control.prototype.destroy.apply(this,arguments);},activate:function(){this.dragPan.activate();if(this.zoomWheelEnabled){this.handlers.wheel.activate();}
+this.handlers.click.activate();if(this.zoomBoxEnabled){this.zoomBox.activate();}
+return OpenLayers.Control.prototype.activate.apply(this,arguments);},deactivate:function(){this.zoomBox.deactivate();this.dragPan.deactivate();this.handlers.click.deactivate();this.handlers.wheel.deactivate();return OpenLayers.Control.prototype.deactivate.apply(this,arguments);},draw:function(){if(this.handleRightClicks){this.map.viewPortDiv.oncontextmenu=OpenLayers.Function.False;}
+var clickCallbacks={'dblclick':this.defaultDblClick,'dblrightclick':this.defaultDblRightClick};var clickOptions={'double':true,'stopDouble':true};this.handlers.click=new OpenLayers.Handler.Click(this,clickCallbacks,clickOptions);this.dragPan=new OpenLayers.Control.DragPan(OpenLayers.Util.extend({map:this.map,documentDrag:this.documentDrag},this.dragPanOptions));this.zoomBox=new OpenLayers.Control.ZoomBox({map:this.map,keyMask:this.zoomBoxKeyMask});this.dragPan.draw();this.zoomBox.draw();this.handlers.wheel=new OpenLayers.Handler.MouseWheel(this,{"up":this.wheelUp,"down":this.wheelDown},this.mouseWheelOptions);},defaultDblClick:function(evt){var newCenter=this.map.getLonLatFromViewPortPx(evt.xy);this.map.setCenter(newCenter,this.map.zoom+1);},defaultDblRightClick:function(evt){var newCenter=this.map.getLonLatFromViewPortPx(evt.xy);this.map.setCenter(newCenter,this.map.zoom-1);},wheelChange:function(evt,deltaZ){var currentZoom=this.map.getZoom();var newZoom=this.map.getZoom()+
Math.round(deltaZ);newZoom=Math.max(newZoom,0);newZoom=Math.min(newZoom,this.map.getNumZoomLevels());if(newZoom===currentZoom){return;}
+var size=this.map.getSize();var deltaX=size.w/2-evt.xy.x;var deltaY=evt.xy.y-size.h/2;var newRes=this.map.baseLayer.getResolutionForZoom(newZoom);var zoomPoint=this.map.getLonLatFromPixel(evt.xy);var newCenter=new OpenLayers.LonLat(zoomPoint.lon+deltaX*newRes,zoomPoint.lat+deltaY*newRes);this.map.setCenter(newCenter,newZoom);},wheelUp:function(evt,delta){this.wheelChange(evt,delta||1);},wheelDown:function(evt,delta){this.wheelChange(evt,delta||-1);},disableZoomBox:function(){this.zoomBoxEnabled=false;this.zoomBox.deactivate();},enableZoomBox:function(){this.zoomBoxEnabled=true;if(this.active){this.zoomBox.activate();}},disableZoomWheel:function(){this.zoomWheelEnabled=false;this.handlers.wheel.deactivate();},enableZoomWheel:function(){this.zoomWheelEnabled=true;if(this.active){this.handlers.wheel.activate();}},CLASS_NAME:"OpenLayers.Control.Navigation"});OpenLayers.Layer.TileCache=OpenLayers.Class(OpenLayers.Layer.Grid,{isBaseLayer:true,format:'image/png',serverResolutions:n
ull,initialize:function(name,url,layername,options){this.layername=layername;OpenLayers.Layer.Grid.prototype.initialize.apply(this,[name,url,{},options]);this.extension=this.format.split('/')[1].toLowerCase();this.extension=(this.extension=='jpg')?'jpeg':this.extension;},clone:function(obj){if(obj==null){obj=new OpenLayers.Layer.TileCache(this.name,this.url,this.layername,this.getOptions());}
+obj=OpenLayers.Layer.Grid.prototype.clone.apply(this,[obj]);return obj;},getURL:function(bounds){var res=this.map.getResolution();var bbox=this.maxExtent;var size=this.tileSize;var tileX=Math.round((bounds.left-bbox.left)/(res*size.w));var tileY=Math.round((bounds.bottom-bbox.bottom)/(res*size.h));var tileZ=this.serverResolutions!=null?OpenLayers.Util.indexOf(this.serverResolutions,res):this.map.getZoom();function zeroPad(number,length){number=String(number);var zeros=[];for(var i=0;i<length;++i){zeros.push('0');}
+return zeros.join('').substring(0,length-number.length)+number;}
+var components=[this.layername,zeroPad(tileZ,2),zeroPad(parseInt(tileX/1000000),3),zeroPad((parseInt(tileX/1000)%1000),3),zeroPad((parseInt(tileX)%1000),3),zeroPad(parseInt(tileY/1000000),3),zeroPad((parseInt(tileY/1000)%1000),3),zeroPad((parseInt(tileY)%1000),3)+'.'+this.extension];var path=components.join('/');var url=this.url;if(url instanceof Array){url=this.selectUrl(path,url);}
+url=(url.charAt(url.length-1)=='/')?url:url+'/';return url+path;},addTile:function(bounds,position){var url=this.getURL(bounds);return new OpenLayers.Tile.Image(this,position,bounds,url,this.tileSize);},CLASS_NAME:"OpenLayers.Layer.TileCache"});
\ No newline at end of file
Added: sandbox/elemoine/kinetic/build/kinetic.cfg
--- sandbox/elemoine/kinetic/build/kinetic.cfg (rev 0)
+++ sandbox/elemoine/kinetic/build/kinetic.cfg 2010-11-10 21:08:59 UTC (rev 10887)
@@ -0,0 +1,23 @@
+# This file includes a small subset of OpenLayers code, designed to be
+# integrated into another application. It includes only the Layer types
+# neccesary to create tiled or untiled WMS, and does not include any Controls.
+# This is the result of what was at the time called "Webmap.js" at the FOSS4G
+# Web Mapping BOF.
+[first]
+OpenLayers/SingleFile.js
+OpenLayers/BaseTypes.js
+OpenLayers/BaseTypes/Class.js
+OpenLayers/Util.js
+[last]
+[include]
+OpenLayers/Map.js
+OpenLayers/Layer/TileCache.js
+OpenLayers/Control/Navigation.js
+OpenLayers/Kinetic.js
+[exclude]
Modified: sandbox/elemoine/kinetic/examples/kinetic.html
--- sandbox/elemoine/kinetic/examples/kinetic.html 2010-11-10 21:08:47 UTC (rev 10886)
+++ sandbox/elemoine/kinetic/examples/kinetic.html 2010-11-10 21:08:59 UTC (rev 10887)
@@ -9,7 +9,8 @@
height: 100%;
</style>
- <script src="../lib/OpenLayers.js"></script>
+ <!--<script src="../lib/OpenLayers.js"></script>-->
+ <script src="../OpenLayers.js"></script>
<script type="text/javascript">
var map, layer;
function init(){
More information about the Commits
