[OpenLayers-Commits] r10816 - in trunk/openlayers: build tools
    commits-20090109 at openlayers.org
    Mon Oct 11 11:51:30 EDT 2010
Author: tschaub
Date: 2010-10-11 08:51:29 -0700 (Mon, 11 Oct 2010)
New Revision: 10816
   trunk/openlayers/build/full.cfg
   trunk/openlayers/tools/mergejs.py
Adding support for excluding directories when an includes list is not explicitly provided.  For our full.cfg example profile, we can exclude the OpenLayers/Lang and Firebug directories instead of having to explicitly list language files to exclude (see #2871).
Modified: trunk/openlayers/build/full.cfg
--- trunk/openlayers/build/full.cfg	2010-10-09 22:15:20 UTC (rev 10815)
+++ trunk/openlayers/build/full.cfg	2010-10-11 15:51:29 UTC (rev 10816)
@@ -14,19 +14,5 @@
 [include]
 [exclude]
-Firebug/firebug.js
-Firebug/firebugx.js
-OpenLayers/Lang/ca.js
-OpenLayers/Lang/cs-CZ.js
-OpenLayers/Lang/da-DK.js
-OpenLayers/Lang/de.js
-OpenLayers/Lang/en-CA.js
-OpenLayers/Lang/es.js
-OpenLayers/Lang/fr.js
-OpenLayers/Lang/it.js
-OpenLayers/Lang/nb.js
-OpenLayers/Lang/nl.js
-OpenLayers/Lang/pt-BR.js
-OpenLayers/Lang/sv-SE.js
-OpenLayers/Lang/zh-TW.js
-OpenLayers/Lang/zh-CN.js
+Firebug
+OpenLayers/Lang
Modified: trunk/openlayers/tools/mergejs.py
--- trunk/openlayers/tools/mergejs.py	2010-10-09 22:15:20 UTC (rev 10815)
+++ trunk/openlayers/tools/mergejs.py	2010-10-11 15:51:29 UTC (rev 10816)
@@ -94,6 +94,7 @@
         [exclude]
         3rd/logger.js
+        exclude/this/dir
     All headings are required.
@@ -122,6 +123,20 @@
         self.include =  lines[lines.index("[include]") + 1:lines.index("[exclude]")]
         self.exclude =  lines[lines.index("[exclude]") + 1:]
+def undesired(filepath, excludes):
+    # exclude file if listed
+    exclude = filepath in excludes
+    if not exclude:
+        # check if directory is listed
+        for excludepath in excludes:
+            if not excludepath.endswith("/"):
+                excludepath += "/"
+            if filepath.startswith(excludepath):
+                exclude = True
+                break
+    return exclude
 def run (sourceDirectory, outputFilename = None, configFile = None):
     cfg = None
     if configFile:
@@ -138,7 +153,7 @@
                 if cfg and cfg.include:
                     if filepath in cfg.include or filepath in cfg.forceFirst:
                         allFiles.append(filepath)
-                elif (not cfg) or (filepath not in cfg.exclude):
+                elif (not cfg) or (not undesired(filepath, cfg.exclude)):
     ## Header inserted at the start of each file in the output
More information about the Commits
