[OpenLayers-Commits] r10838 - trunk/openlayers/lib/OpenLayers/Format
commits-20090109 at openlayers.org
Fri Oct 15 10:36:48 EDT 2010
Author: bartvde
Date: 2010-10-15 07:36:48 -0700 (Fri, 15 Oct 2010)
New Revision: 10838
trunk/openlayers/lib/OpenLayers/Format/SOSGetObservation.js
dos2unix, non-functional change
Modified: trunk/openlayers/lib/OpenLayers/Format/SOSGetObservation.js
--- trunk/openlayers/lib/OpenLayers/Format/SOSGetObservation.js 2010-10-15 13:47:35 UTC (rev 10837)
+++ trunk/openlayers/lib/OpenLayers/Format/SOSGetObservation.js 2010-10-15 14:36:48 UTC (rev 10838)
@@ -2,261 +2,261 @@
* full list of contributors). Published under the Clear BSD license.
* See http://svn.openlayers.org/trunk/openlayers/license.txt for the
* full text of the license. */
- * @requires OpenLayers/Format/XML.js
- * @requires OpenLayers/Format/GML.js
- * @requires OpenLayers/Format/GML/v3.js
- * Class: OpenLayers.Format.SOSGetObservation
- * Read and write SOS GetObersation (to get the actual values from a sensor)
- * version 1.0.0
- * Inherits from:
- * - <OpenLayers.Format.XML>
-OpenLayers.Format.SOSGetObservation = OpenLayers.Class(OpenLayers.Format.XML, {
- * Property: namespaces
- * {Object} Mapping of namespace aliases to namespace URIs.
- namespaces: {
- ows: "http://www.opengis.net/ows",
- gml: "http://www.opengis.net/gml",
- sos: "http://www.opengis.net/sos/1.0",
- ogc: "http://www.opengis.net/ogc",
- om: "http://www.opengis.net/om/1.0",
- xlink: "http://www.w3.org/1999/xlink",
- xsi: "http://www.w3.org/2001/XMLSchema-instance"
- * Property: regExes
- * Compiled regular expressions for manipulating strings.
- regExes: {
- trimSpace: (/^\s*|\s*$/g),
- removeSpace: (/\s*/g),
- splitSpace: (/\s+/),
- trimComma: (/\s*,\s*/g)
- * Constant: VERSION
- * {String} 1.0.0
- VERSION: "1.0.0",
- * Property: schemaLocation
- * {String} Schema location
- schemaLocation: "http://www.opengis.net/sos/1.0 http://schemas.opengis.net/sos/1.0.0/sosGetObservation.xsd",
- * Property: defaultPrefix
- defaultPrefix: "sos",
- * Constructor: OpenLayers.Format.SOSGetObservation
- * Parameters:
- * options - {Object} An optional object whose properties will be set on
- * this instance.
- initialize: function(options) {
- OpenLayers.Format.XML.prototype.initialize.apply(this, [options]);
- * Method: read
- * Parameters:
- * data - {String} or {DOMElement} data to read/parse.
- * Returns:
- * {Object} An object containing the measurements
- read: function(data) {
- if(typeof data == "string") {
- data = OpenLayers.Format.XML.prototype.read.apply(this, [data]);
- if(data && data.nodeType == 9) {
- data = data.documentElement;
- var info = {measurements: []};
- this.readNode(data, info);
- return info;
- * Method: write
- * Parameters:
- * options - {Object} Optional object.
- * Returns:
- * {String} An SOS GetObservation request XML string.
- write: function(options) {
- var node = this.writeNode("sos:GetObservation", options);
+ * @requires OpenLayers/Format/XML.js
+ * @requires OpenLayers/Format/GML.js
+ * @requires OpenLayers/Format/GML/v3.js
+ * Class: OpenLayers.Format.SOSGetObservation
+ * Read and write SOS GetObersation (to get the actual values from a sensor)
+ * version 1.0.0
+ * Inherits from:
+ * - <OpenLayers.Format.XML>
+OpenLayers.Format.SOSGetObservation = OpenLayers.Class(OpenLayers.Format.XML, {
+ * Property: namespaces
+ * {Object} Mapping of namespace aliases to namespace URIs.
+ namespaces: {
+ ows: "http://www.opengis.net/ows",
+ gml: "http://www.opengis.net/gml",
+ sos: "http://www.opengis.net/sos/1.0",
+ ogc: "http://www.opengis.net/ogc",
+ om: "http://www.opengis.net/om/1.0",
+ xlink: "http://www.w3.org/1999/xlink",
+ xsi: "http://www.w3.org/2001/XMLSchema-instance"
+ * Property: regExes
+ * Compiled regular expressions for manipulating strings.
+ regExes: {
+ trimSpace: (/^\s*|\s*$/g),
+ removeSpace: (/\s*/g),
+ splitSpace: (/\s+/),
+ trimComma: (/\s*,\s*/g)
+ * Constant: VERSION
+ * {String} 1.0.0
+ VERSION: "1.0.0",
+ * Property: schemaLocation
+ * {String} Schema location
+ schemaLocation: "http://www.opengis.net/sos/1.0 http://schemas.opengis.net/sos/1.0.0/sosGetObservation.xsd",
+ * Property: defaultPrefix
+ defaultPrefix: "sos",
+ * Constructor: OpenLayers.Format.SOSGetObservation
+ * Parameters:
+ * options - {Object} An optional object whose properties will be set on
+ * this instance.
+ initialize: function(options) {
+ OpenLayers.Format.XML.prototype.initialize.apply(this, [options]);
+ * Method: read
+ * Parameters:
+ * data - {String} or {DOMElement} data to read/parse.
+ * Returns:
+ * {Object} An object containing the measurements
+ read: function(data) {
+ if(typeof data == "string") {
+ data = OpenLayers.Format.XML.prototype.read.apply(this, [data]);
+ if(data && data.nodeType == 9) {
+ data = data.documentElement;
+ var info = {measurements: []};
+ this.readNode(data, info);
+ return info;
+ * Method: write
+ * Parameters:
+ * options - {Object} Optional object.
+ * Returns:
+ * {String} An SOS GetObservation request XML string.
+ write: function(options) {
+ var node = this.writeNode("sos:GetObservation", options);
node.setAttribute("xmlns:om", this.namespaces.om);
- this.setAttributeNS(
- node, this.namespaces.xsi,
- "xsi:schemaLocation", this.schemaLocation
- return OpenLayers.Format.XML.prototype.write.apply(this, [node]);
- * Property: readers
- * Contains public functions, grouped by namespace prefix, that will
- * be applied when a namespaced node is found matching the function
- * name. The function will be applied in the scope of this parser
- * with two arguments: the node being read and a context object passed
- * from the parent.
- readers: {
- "om": {
- "ObservationCollection": function(node, obj) {
- obj.id = this.getAttributeNS(node, this.namespaces.gml, "id");
- this.readChildNodes(node, obj);
- "member": function(node, observationCollection) {
- this.readChildNodes(node, observationCollection);
- "Measurement": function(node, observationCollection) {
- var measurement = {};
- observationCollection.measurements.push(measurement);
- this.readChildNodes(node, measurement);
- "samplingTime": function(node, measurement) {
- var samplingTime = {};
- measurement.samplingTime = samplingTime;
- this.readChildNodes(node, samplingTime);
- "observedProperty": function(node, measurement) {
- measurement.observedProperty =
- this.getAttributeNS(node, this.namespaces.xlink, "href");
- "procedure": function(node, measurement) {
- measurement.procedure =
- "result": function(node, measurement) {
- var result = {};
- measurement.result = result;
- if (this.getChildValue(node) !== '') {
- result.value = this.getChildValue(node);
- result.uom = node.getAttribute("uom");
- } else {
- this.readChildNodes(node, result);
- "gml": OpenLayers.Util.applyDefaults({
- "TimeInstant": function(node, samplingTime) {
- var timeInstant = {};
- samplingTime.timeInstant = timeInstant;
- this.readChildNodes(node, timeInstant);
- "timePosition": function(node, timeInstant) {
- timeInstant.timePosition = this.getChildValue(node);
- }, OpenLayers.Format.GML.v3.prototype.readers.gml)
- * Property: writers
- * As a compliment to the readers property, this structure contains public
- * writing functions grouped by namespace alias and named like the
- * node names they produce.
- writers: {
- "sos": {
- "GetObservation": function(options) {
- var node = this.createElementNSPlus("GetObservation", {
- attributes: {
- version: this.VERSION,
- service: 'SOS'
- this.writeNode("offering", options, node);
- this.writeNode("eventTime", options, node);
- this.writeNode("procedure", options, node);
- this.writeNode("observedProperty", options, node);
- this.writeNode("responseFormat", options, node);
- this.writeNode("resultModel", options, node);
- this.writeNode("responseMode", options, node);
- return node;
- "responseFormat": function(options) {
- return this.createElementNSPlus("responseFormat",
- {value: options.responseFormat});
- "procedure": function(options) {
- return this.createElementNSPlus("procedure",
- {value: options.procedure});
- "offering": function(options) {
- return this.createElementNSPlus("offering", {value:
- options.offering});
- "observedProperty": function(options) {
- return this.createElementNSPlus("observedProperty",
- {value: options.observedProperty});
- "eventTime": function(options) {
- var node = this.createElementNSPlus("eventTime");
- if (options.eventTime === 'latest') {
- this.writeNode("ogc:TM_Equals", options, node);
- return node;
- "resultModel": function(options) {
- return this.createElementNSPlus("resultModel", {value:
- options.resultModel});
- "responseMode": function(options) {
- return this.createElementNSPlus("responseMode", {value:
- options.responseMode});
- "ogc": {
- "TM_Equals": function(options) {
- var node = this.createElementNSPlus("ogc:TM_Equals");
- this.writeNode("ogc:PropertyName", {property:
- "urn:ogc:data:time:iso8601"}, node);
- this.writeNode("gml:TimeInstant", {value: 'latest'}, node);
- return node;
- "PropertyName": function(options) {
- return this.createElementNSPlus("ogc:PropertyName",
- {value: options.property});
- "gml": {
- "TimeInstant": function(options) {
- var node = this.createElementNSPlus("gml:TimeInstant");
- this.writeNode("gml:timePosition", options, node);
- return node;
- "timePosition": function(options) {
- var node = this.createElementNSPlus("gml:timePosition",
- {value: options.value});
- return node;
- CLASS_NAME: "OpenLayers.Format.SOSGetObservation"
+ this.setAttributeNS(
+ node, this.namespaces.xsi,
+ "xsi:schemaLocation", this.schemaLocation
+ return OpenLayers.Format.XML.prototype.write.apply(this, [node]);
+ * Property: readers
+ * Contains public functions, grouped by namespace prefix, that will
+ * be applied when a namespaced node is found matching the function
+ * name. The function will be applied in the scope of this parser
+ * with two arguments: the node being read and a context object passed
+ * from the parent.
+ readers: {
+ "om": {
+ "ObservationCollection": function(node, obj) {
+ obj.id = this.getAttributeNS(node, this.namespaces.gml, "id");
+ this.readChildNodes(node, obj);
+ "member": function(node, observationCollection) {
+ this.readChildNodes(node, observationCollection);
+ "Measurement": function(node, observationCollection) {
+ var measurement = {};
+ observationCollection.measurements.push(measurement);
+ this.readChildNodes(node, measurement);
+ "samplingTime": function(node, measurement) {
+ var samplingTime = {};
+ measurement.samplingTime = samplingTime;
+ this.readChildNodes(node, samplingTime);
+ "observedProperty": function(node, measurement) {
+ measurement.observedProperty =
+ this.getAttributeNS(node, this.namespaces.xlink, "href");
+ "procedure": function(node, measurement) {
+ measurement.procedure =
+ "result": function(node, measurement) {
+ var result = {};
+ measurement.result = result;
+ if (this.getChildValue(node) !== '') {
+ result.value = this.getChildValue(node);
+ result.uom = node.getAttribute("uom");
+ } else {
+ this.readChildNodes(node, result);
+ "gml": OpenLayers.Util.applyDefaults({
+ "TimeInstant": function(node, samplingTime) {
+ var timeInstant = {};
+ samplingTime.timeInstant = timeInstant;
+ this.readChildNodes(node, timeInstant);
+ "timePosition": function(node, timeInstant) {
+ timeInstant.timePosition = this.getChildValue(node);
+ }, OpenLayers.Format.GML.v3.prototype.readers.gml)
+ * Property: writers
+ * As a compliment to the readers property, this structure contains public
+ * writing functions grouped by namespace alias and named like the
+ * node names they produce.
+ writers: {
+ "sos": {
+ "GetObservation": function(options) {
+ var node = this.createElementNSPlus("GetObservation", {
+ attributes: {
+ version: this.VERSION,
+ service: 'SOS'
+ this.writeNode("offering", options, node);
+ this.writeNode("eventTime", options, node);
+ this.writeNode("procedure", options, node);
+ this.writeNode("observedProperty", options, node);
+ this.writeNode("responseFormat", options, node);
+ this.writeNode("resultModel", options, node);
+ this.writeNode("responseMode", options, node);
+ return node;
+ "responseFormat": function(options) {
+ return this.createElementNSPlus("responseFormat",
+ {value: options.responseFormat});
+ "procedure": function(options) {
+ return this.createElementNSPlus("procedure",
+ {value: options.procedure});
+ "offering": function(options) {
+ return this.createElementNSPlus("offering", {value:
+ options.offering});
+ "observedProperty": function(options) {
+ return this.createElementNSPlus("observedProperty",
+ {value: options.observedProperty});
+ "eventTime": function(options) {
+ var node = this.createElementNSPlus("eventTime");
+ if (options.eventTime === 'latest') {
+ this.writeNode("ogc:TM_Equals", options, node);
+ return node;
+ "resultModel": function(options) {
+ return this.createElementNSPlus("resultModel", {value:
+ options.resultModel});
+ "responseMode": function(options) {
+ return this.createElementNSPlus("responseMode", {value:
+ options.responseMode});
+ "ogc": {
+ "TM_Equals": function(options) {
+ var node = this.createElementNSPlus("ogc:TM_Equals");
+ this.writeNode("ogc:PropertyName", {property:
+ "urn:ogc:data:time:iso8601"}, node);
+ this.writeNode("gml:TimeInstant", {value: 'latest'}, node);
+ return node;
+ "PropertyName": function(options) {
+ return this.createElementNSPlus("ogc:PropertyName",
+ {value: options.property});
+ "gml": {
+ "TimeInstant": function(options) {
+ var node = this.createElementNSPlus("gml:TimeInstant");
+ this.writeNode("gml:timePosition", options, node);
+ return node;
+ "timePosition": function(options) {
+ var node = this.createElementNSPlus("gml:timePosition",
+ {value: options.value});
+ return node;
+ CLASS_NAME: "OpenLayers.Format.SOSGetObservation"
More information about the Commits
