[OpenLayers-Commits] r10842 -
sandbox/bjornharrtell/swipe/lib/OpenLayers/Control
commits-20090109 at openlayers.org
Sat Oct 16 13:49:24 EDT 2010
Author: bjornharrtell
Date: 2010-10-16 10:49:24 -0700 (Sat, 16 Oct 2010)
New Revision: 10842
sandbox/bjornharrtell/swipe/lib/OpenLayers/Control/Swipe.js
Fix behaviour when panning and use IE compatible syntax for clip
Modified: sandbox/bjornharrtell/swipe/lib/OpenLayers/Control/Swipe.js
--- sandbox/bjornharrtell/swipe/lib/OpenLayers/Control/Swipe.js 2010-10-16 13:10:31 UTC (rev 10841)
+++ sandbox/bjornharrtell/swipe/lib/OpenLayers/Control/Swipe.js 2010-10-16 17:49:24 UTC (rev 10842)
@@ -8,11 +8,11 @@
* Inherits from: - <OpenLayers.Control>
OpenLayers.Control.Swipe = OpenLayers.Class(OpenLayers.Control, {
- map: null,
- layer: null,
- layerContainerDiv: null,
- div: null,
+ map : null,
+ layer : null,
+ layerContainerDiv : null,
+ div : null,
* Property: type {OpenLayers.Control.TYPES}
@@ -21,9 +21,7 @@
* Constructor: OpenLayers.Control.Swipe
- * Parameters:
- * layer - {OpenLayers.Layer}
- * options - {Object} An optional object whose properties will be used to extend the control.
+ * Parameters: layer - {OpenLayers.Layer} options - {Object} An optional object whose properties will be used to extend the control.
initialize : function(layer, options) {
this.map = layer.map;
@@ -48,8 +46,8 @@
var deactivated = OpenLayers.Control.prototype.deactivate.call(this);
if (deactivated) {
- this.div.style.clip = '';
+ this.div.style.clip = '';
this.map.events.un({
mousemove : this.onMousemove,
scope : this
@@ -58,9 +56,15 @@
onMousemove : function(e) {
- var offset = (e.clientX - 20) - this.layerContainerDiv.offsetLeft;
+ var offsetX = (e.clientX - this.map.div.offsetLeft) - this.layerContainerDiv.offsetLeft;
+ var offsetY = -this.layerContainerDiv.offsetTop;
- this.div.style.clip = 'rect(0px, '+ this.map.getSize().w +'px, '+ this.map.getSize().h +'px, ' + offset + 'px)';
+ var top = offsetY;
+ var right = this.map.getSize().w + offsetX;
+ var bottom = this.map.getSize().h + offsetY;
+ var left = offsetX;
+ this.div.style.clip = 'rect(' + top + 'px ' + right + 'px ' + bottom + 'px ' + left + 'px)';
CLASS_NAME : "OpenLayers.Control.Swipe"
More information about the Commits
