[OpenLayers-Commits] r10844 -
sandbox/bjornharrtell/swipe/lib/OpenLayers/Control
commits-20090109 at openlayers.org
Sun Oct 17 14:10:28 EDT 2010
Author: bjornharrtell
Date: 2010-10-17 11:10:28 -0700 (Sun, 17 Oct 2010)
New Revision: 10844
sandbox/bjornharrtell/swipe/lib/OpenLayers/Control/Swipe.js
Commented source
Modified: sandbox/bjornharrtell/swipe/lib/OpenLayers/Control/Swipe.js
--- sandbox/bjornharrtell/swipe/lib/OpenLayers/Control/Swipe.js 2010-10-16 21:58:49 UTC (rev 10843)
+++ sandbox/bjornharrtell/swipe/lib/OpenLayers/Control/Swipe.js 2010-10-17 18:10:28 UTC (rev 10844)
@@ -4,26 +4,39 @@
* Class: OpenLayers.Control.Swipe
+ * The Swipe control will reveal/hide a target layer right/left side of mouse mouse position on the map.
* Inherits from: - <OpenLayers.Control>
OpenLayers.Control.Swipe = OpenLayers.Class(OpenLayers.Control, {
- map : null,
+ * Property: layer
+ * {<OpenLayers.Layer>} The target layer to be swiped
layer : null,
+ * Property: layerContainerDiv
+ * {DOMElement} Layer container div used to read panning offset
layerContainerDiv : null,
- div : null,
- * Property: type {OpenLayers.Control.TYPES}
+ * Property: div
+ * {DOMElement} Layer div for CSS clip manipulation
- type : OpenLayers.Control.TYPE_TOOL,
+ div : null,
* Constructor: OpenLayers.Control.Swipe
- * Parameters: layer - {OpenLayers.Layer} options - {Object} An optional object whose properties will be used to extend the control.
+ * Parameters:
+ * layer - {OpenLayers.Layer} Target layer for the swipe effect.
+ * options - {Object} An optional object whose properties will be used to extend the control.
initialize : function(layer, options) {
+ // setup properties to be used for swipe logic
this.map = layer.map;
this.layer = layer;
this.div = this.layer.div;
@@ -32,8 +45,13 @@
OpenLayers.Control.prototype.initialize.apply(this, [ options ]);
+ * APIMethod: activate
+ * Activate the control.
activate : function() {
var activated = OpenLayers.Control.prototype.activate.call(this);
if (activated) {
this.map.events.on({
mousemove : this.onMousemove,
@@ -42,6 +60,10 @@
+ * APIMethod: deactivate
+ * Deactivate the control.
deactivate : function() {
var deactivated = OpenLayers.Control.prototype.deactivate.call(this);
@@ -55,6 +77,14 @@
+ * Method: onMousemove
+ * Registered as a listener for mousemove events on the map. Calculates clip region
+ * that will create the swipe effect.
+ * Parameters:
+ * e - {Object} The mousemove event.
onMousemove : function(e) {
var offsetX = (e.clientX - this.map.div.offsetLeft) - this.layerContainerDiv.offsetLeft;
var offsetY = -this.layerContainerDiv.offsetTop;
More information about the Commits
