[OpenLayers-Commits] r10851 - in trunk/openlayers:
lib/OpenLayers/Renderer tests/Renderer
commits-20090109 at openlayers.org
Wed Oct 20 10:01:36 EDT 2010
Author: ahocevar
Date: 2010-10-20 07:01:36 -0700 (Wed, 20 Oct 2010)
New Revision: 10851
trunk/openlayers/lib/OpenLayers/Renderer/Elements.js
trunk/openlayers/tests/Renderer/Elements.html
Make sure that the background node is removed when redrawing with a different symbolizer. Thanks ahtih for this excellent debut patch. p=ahtih, r=me (closes #2891)
Modified: trunk/openlayers/lib/OpenLayers/Renderer/Elements.js
--- trunk/openlayers/lib/OpenLayers/Renderer/Elements.js 2010-10-20 10:51:51 UTC (rev 10850)
+++ trunk/openlayers/lib/OpenLayers/Renderer/Elements.js 2010-10-20 14:01:36 UTC (rev 10851)
@@ -509,10 +509,13 @@
rendered = false;
+ var removeBackground = false;
if (style.display != "none") {
if (style.backgroundGraphic) {
this.redrawBackgroundNode(geometry.id, geometry, style,
featureId);
+ } else {
+ removeBackground = true;
rendered = this.redrawNode(geometry.id, geometry, style,
featureId);
@@ -521,12 +524,18 @@
var node = document.getElementById(geometry.id);
if (node) {
if (node._style.backgroundGraphic) {
- node.parentNode.removeChild(document.getElementById(
- geometry.id + this.BACKGROUND_ID_SUFFIX));
node.parentNode.removeChild(node);
+ if (removeBackground) {
+ var node = document.getElementById(
+ geometry.id + this.BACKGROUND_ID_SUFFIX);
+ if (node) {
+ node.parentNode.removeChild(node);
return rendered;
Modified: trunk/openlayers/tests/Renderer/Elements.html
--- trunk/openlayers/tests/Renderer/Elements.html 2010-10-20 10:51:51 UTC (rev 10850)
+++ trunk/openlayers/tests/Renderer/Elements.html 2010-10-20 14:01:36 UTC (rev 10851)
@@ -561,8 +561,63 @@
tearDown();
+ function test_Elements_drawGeometry_3(t) {
+ t.plan(2);
+ setUp();
+ var r = create_renderer();
+ var element = document.createElement("div");
+ r.vectorRoot = element;
+ r.nodeFactory = function(id, type) {
+ return document.createElement("div");
+ var g_Node = null;
+ var b_Node = null;
+ r.drawGeometryNode = function(node, geometry, style) {
+ g_Node = node;
+ return {node: node, complete: true};
+ r.redrawBackgroundNode = function(id, geometry, style, featureId) {
+ b_Node = r.nodeFactory();
+ b_Node.id = "foo_background";
+ element.appendChild(b_Node);
+ r.getNodeType = function(geometry, style) {
+ return "div";
+ var geometry = {
+ id: 'foo',
+ CLASS_NAME: 'bar',
+ getBounds: function() {return {bottom: 0}}
+ var style = {'backgroundGraphic': 'foo'};
+ var featureId = 'dude';
+ r.drawGeometry(geometry, style, featureId);
+ t.ok(b_Node.parentNode == element, "redrawBackgroundNode appended background node");
+ var returnNode = function(id) {
+ return id == "foo_background" ? b_Node : g_Node;
+ var _getElement = document.getElementById;
+ document.getElementById = returnNode;
+ OpenLayers.Util.getElement = returnNode;
+ style = {};
+ t.ok(b_Node.parentNode != element, "background node correctly removed")
+ document.getElementById = _getElement;
+ tearDown();
</script>
</head>
<body>
More information about the Commits
