[OpenLayers-Commits] r10862 - in trunk/openlayers: lib
lib/OpenLayers tests
commits-20090109 at openlayers.org
Wed Oct 27 06:26:05 EDT 2010
Author: erilem
Date: 2010-10-27 03:26:05 -0700 (Wed, 27 Oct 2010)
New Revision: 10862
Added:
trunk/openlayers/tests/OpenLayers4.html
trunk/openlayers/lib/OpenLayers.js
trunk/openlayers/lib/OpenLayers/SingleFile.js
trunk/openlayers/tests/list-tests.html
do not assume that the browser won't add new script tags to the DOM before it's done with the evaluation of OpenLayers.js, r=fredj,ahocevar (closes #2873)
Modified: trunk/openlayers/lib/OpenLayers/SingleFile.js
--- trunk/openlayers/lib/OpenLayers/SingleFile.js 2010-10-27 10:12:01 UTC (rev 10861)
+++ trunk/openlayers/lib/OpenLayers/SingleFile.js 2010-10-27 10:26:05 UTC (rev 10862)
@@ -25,9 +25,19 @@
* {String} Path to this script
_getScriptLocation: (function() {
- var s = document.getElementsByTagName('script');
- var m = s[s.length-1].getAttribute("src").match(/(^|(.*?\/))(OpenLayers\.js)(\?|$)/);
- var l = m ? m[1] : "";
+ var r = new RegExp("(^|(.*?\\/))(OpenLayers\.js)(\\?|$)"),
+ s = document.getElementsByTagName('script'),
+ src, m, l = "";
+ for(var i=0, len=s.length; i<len; i++) {
+ src = s[i].getAttribute('src');
+ if(src) {
+ var m = src.match(r);
+ if(m) {
+ l = m[1];
+ break;
return (function() { return l; });
Modified: trunk/openlayers/lib/OpenLayers.js
--- trunk/openlayers/lib/OpenLayers.js 2010-10-27 10:12:01 UTC (rev 10861)
+++ trunk/openlayers/lib/OpenLayers.js 2010-10-27 10:26:05 UTC (rev 10862)
@@ -44,10 +44,19 @@
- var r = new RegExp("(^|(.*?\\/))(" + scriptName + ")(\\?|$)");
- var m = s[s.length-1].getAttribute("src").match(r);
+ var r = new RegExp("(^|(.*?\\/))(" + scriptName + ")(\\?|$)"),
+ src, m, l = "";
+ if(src) {
+ if(m) {
+ l = m[1];
+ break;
Added: trunk/openlayers/tests/OpenLayers4.html
--- trunk/openlayers/tests/OpenLayers4.html (rev 0)
+++ trunk/openlayers/tests/OpenLayers4.html 2010-10-27 10:26:05 UTC (rev 10862)
@@ -0,0 +1,18 @@
+<html>
+<head>
+ <script type="text/javascript">
+ OpenLayers = {singleFile: true}; // just to make the test run faster
+ document.write('<scr'+'ipt src="../lib/OpenLayers.js"></scr'+'ipt>');
+ document.write('<scr'+'ipt src="bogus/foo-/OpenLayers.js"></scr'+'ipt>');
+ </script>
+ function test_OpenLayers(t) {
+ t.plan(1);
+ t.eq(OpenLayers._getScriptLocation(), "../lib/",
+ "Script location correctly detected, and not fooled by other scripts.");
+ </script>
+</head>
+<body>
+</body>
+</html>
Modified: trunk/openlayers/tests/list-tests.html
--- trunk/openlayers/tests/list-tests.html 2010-10-27 10:12:01 UTC (rev 10861)
+++ trunk/openlayers/tests/list-tests.html 2010-10-27 10:26:05 UTC (rev 10862)
@@ -159,6 +159,7 @@
<li>OpenLayers1.html</li>
<li>OpenLayers2.html</li>
<li>OpenLayers3.html</li>
+ <li>OpenLayers4.html</li>
<li>Popup.html</li>
<li>Popup/Anchored.html</li>
<li>Popup/AnchoredBubble.html</li>
More information about the Commits
