[OpenLayers-Commits] r10864 -
trunk/openlayers/lib/OpenLayers/Control
commits-20090109 at openlayers.org
Thu Oct 28 02:50:31 EDT 2010
Author: fredj
Date: 2010-10-27 23:50:31 -0700 (Wed, 27 Oct 2010)
New Revision: 10864
trunk/openlayers/lib/OpenLayers/Control/WMTSGetFeatureInfo.js
Remove the activate, deactivate and setMap functions from the
WMTSGetFeatureInfo control. Not needed because they do the same as the
parent class. r=erilem (closes #2805)
Modified: trunk/openlayers/lib/OpenLayers/Control/WMTSGetFeatureInfo.js
--- trunk/openlayers/lib/OpenLayers/Control/WMTSGetFeatureInfo.js 2010-10-28 06:44:35 UTC (rev 10863)
+++ trunk/openlayers/lib/OpenLayers/Control/WMTSGetFeatureInfo.js 2010-10-28 06:50:31 UTC (rev 10864)
@@ -213,35 +213,6 @@
- * Method: activate
- * Activates the control.
- * Returns:
- * {Boolean} The control was effectively activated.
- activate: function () {
- if (!this.active) {
- this.handler.activate();
- return OpenLayers.Control.prototype.activate.apply(
- this, arguments
- * Method: deactivate
- * Deactivates the control.
- * Returns:
- * {Boolean} The control was effectively deactivated.
- deactivate: function () {
- return OpenLayers.Control.prototype.deactivate.apply(
- this, arguments
* Method: getInfoForClick
* Called on click
@@ -425,18 +396,6 @@
- * Method: setMap
- * Set the map property for the control.
- * Parameters:
- * map - {<OpenLayers.Map>}
- setMap: function(map) {
- this.handler.setMap(map);
- OpenLayers.Control.prototype.setMap.apply(this, arguments);
CLASS_NAME: "OpenLayers.Control.WMTSGetFeatureInfo"
More information about the Commits
