[OpenLayers-Commits] r12206 - in trunk/openlayers: examples
lib/OpenLayers
commits-20090109 at openlayers.org
Wed Aug 3 11:55:16 EDT 2011
Author: fredj
Date: 2011-08-03 08:55:14 -0700 (Wed, 03 Aug 2011)
New Revision: 12206
trunk/openlayers/examples/KMLParser.html
trunk/openlayers/examples/WMSDescribeLayerParser.html
trunk/openlayers/examples/sld.js
trunk/openlayers/examples/xml.html
trunk/openlayers/lib/OpenLayers/Ajax.js
mark the OpenLayers.loadURL method as deprecated (replaced by OpenLayers.Request.GET). r=erilem,rdewit,ahocevar (closes #3443)
Modified: trunk/openlayers/examples/KMLParser.html
--- trunk/openlayers/examples/KMLParser.html 2011-08-03 15:47:06 UTC (rev 12205)
+++ trunk/openlayers/examples/KMLParser.html 2011-08-03 15:55:14 UTC (rev 12206)
@@ -28,7 +28,10 @@
document.getElementById('output').innerHTML = html;
function load() {
- OpenLayers.loadURL("kml/lines.kml", "", null, parseData);
+ OpenLayers.Request.GET({
+ url: "kml/lines.kml",
+ success: parseData
</script>
</head>
Modified: trunk/openlayers/examples/WMSDescribeLayerParser.html
--- trunk/openlayers/examples/WMSDescribeLayerParser.html 2011-08-03 15:47:06 UTC (rev 12205)
+++ trunk/openlayers/examples/WMSDescribeLayerParser.html 2011-08-03 15:55:14 UTC (rev 12206)
@@ -9,7 +9,7 @@
<script src="../lib/OpenLayers.js"></script>
<script type="text/javascript">
function parseData(req) {
- format = new OpenLayers.Format.WMSDescribeLayer();
+ format = new OpenLayers.Format.WMSDescribeLayer();
html = "<br>"
resp = format.read(req.responseText);
for(var i = 0; i < resp.length; i++) {
@@ -22,7 +22,10 @@
function load() {
- OpenLayers.loadURL("xml/wmsdescribelayer.xml", "", null, parseData);
+ url: "xml/wmsdescribelayer.xml",
</script>
</head>
Modified: trunk/openlayers/examples/sld.js
--- trunk/openlayers/examples/sld.js 2011-08-03 15:47:06 UTC (rev 12205)
+++ trunk/openlayers/examples/sld.js 2011-08-03 15:55:14 UTC (rev 12206)
@@ -12,10 +12,13 @@
map.addControl(new OpenLayers.Control.LayerSwitcher());
- OpenLayers.loadURL("tasmania/sld-tasmania.xml", null, null, complete);
+ url: "tasmania/sld-tasmania.xml",
+ success: complete
-// handler for the loadURL function in the init method
+// handler for the OpenLayers.Request.GET function in the init method
function complete(req) {
sld = format.read(req.responseXML || req.responseText);
buildStyleChooser();
Modified: trunk/openlayers/examples/xml.html
--- trunk/openlayers/examples/xml.html 2011-08-03 15:47:06 UTC (rev 12205)
+++ trunk/openlayers/examples/xml.html 2011-08-03 15:55:14 UTC (rev 12206)
@@ -39,8 +39,11 @@
var doc = null;
function init() {
- var url = "xml/features.xml";
- OpenLayers.loadURL(url, null, null, loadSuccess, loadFailure);
+ url: "xml/features.xml",
+ success: loadSuccess,
+ failure: loadFailure
function loadSuccess(request) {
Modified: trunk/openlayers/lib/OpenLayers/Ajax.js
--- trunk/openlayers/lib/OpenLayers/Ajax.js 2011-08-03 15:47:06 UTC (rev 12205)
+++ trunk/openlayers/lib/OpenLayers/Ajax.js 2011-08-03 15:55:14 UTC (rev 12206)
@@ -46,8 +46,8 @@
* APIFunction: OpenLayers.loadURL
- * Background load a document. For more flexibility in using XMLHttpRequest,
- * see the <OpenLayers.Request> methods.
+ * Background load a document.
+ * *Deprecated*. Use <OpenLayers.Request.GET> method instead.
* Parameters:
* uri - {String} URI of source doc
More information about the Commits
