[OpenLayers-Commits] r12211 - trunk/openlayers/tests/BaseTypes
commits-20090109 at openlayers.org
Mon Aug 8 00:58:06 EDT 2011
Author: erilem
Date: 2011-08-07 21:58:05 -0700 (Sun, 07 Aug 2011)
New Revision: 12211
trunk/openlayers/tests/BaseTypes/Class.html
add Class tests corresponding to IGN GeoPortal's usage patterns, no functional change
Modified: trunk/openlayers/tests/BaseTypes/Class.html
--- trunk/openlayers/tests/BaseTypes/Class.html 2011-08-08 04:50:36 UTC (rev 12210)
+++ trunk/openlayers/tests/BaseTypes/Class.html 2011-08-08 04:58:05 UTC (rev 12211)
@@ -308,6 +308,154 @@
t.ok(!(bad instanceof OpenLayers.Control), "bad is a control, but it is also a layer and we cannot have two superclasses");
t.ok(bad instanceof OpenLayers.Layer, "bad is a layer, it inherits from the layer first");
+ // IGN's GeoPortal API overwrite prototypes of OpenLayers constructors.
+ // The tests below aim to cover their usage pattens.
+ // the overwrite function under test
+ function overwrite(C, o) {
+ if(typeof o.initialize === "function" &&
+ C === C.prototype.initialize) {
+ // OL 2.11
+ var proto = C.prototype;
+ var staticProps = OpenLayers.Util.extend({}, C);
+ C = o.initialize;
+ C.prototype = proto;
+ OpenLayers.Util.extend(C, staticProps);
+ OpenLayers.Util.extend(C.prototype, o);
+ return C;
+ function test_overwrite_1(t) {
+ // overwrite constructor
+ t.plan(1);
+ var A = OpenLayers.Class({
+ initialize: function() {
+ this.a = "foo";
+ A = overwrite(A, {
+ this.a = "bar";
+ var a = new A;
+ t.eq(a.a, "bar", "ctor overwritten");
+ function test_overwrite_2(t) {
+ // overwrite regular method
+ t.plan(1);
+ method: function() {
+ this.a = "foo";
+ this.a = "bar";
+ var a = new A;
+ a.method();
+ t.eq(a.a, "bar", "method overwritten");
+ function test_overwrite_3(t) {
+ // overwrite constructor of subclass
+ t.plan(1);
+ this.a = "foo";
+ var B = OpenLayers.Class(A, {
+ A.prototype.initialize.call(this);
+ B = overwrite(B, {
+ this.a = "bar";
+ var b = new B;
+ t.eq(b.a, "bar", "ctor overwritten");
+ function test_overwrite_4(t) {
+ // overwrite constructor of parent class
+ t.plan(1);
+ this.a = "foo";
+ this.a = "bar";
+ var b = new B;
+ // This test doesn't currently pass.
+ function test_overwrite_5(t) {
+ // overwrite constructor of parent class, which itself
+ // doesn't defined "initialize"
+ t.plan(1);
+ this.a = "foo";
+ var B = OpenLayers.Class(A, {});
+ this.a = "bar";
+ var b = new B;
+ function test_overwrite_6(t) {
+ // with static methods
+ t.plan(1);
+ A.staticMethod = function() {};
+ var exc = false;
+ try {
+ A.staticMethod();
+ } catch(e) {
+ exc = true;
+ t.ok(!exc, "static method still there");
</script>
</head>
<body>
More information about the Commits
