[OpenLayers-Commits] r12215 - in trunk/openlayers: lib/OpenLayers/BaseTypes tests/BaseTypes
commits-20090109 at openlayers.org commits-20090109 at openlayers.org
Mon Aug 8 08:43:48 EDT 2011
Author: erilem
Date: 2011-08-08 05:43:47 -0700 (Mon, 08 Aug 2011)
New Revision: 12215
   trunk/openlayers/lib/OpenLayers/BaseTypes/Class.js
   trunk/openlayers/tests/BaseTypes/Class.html
make constructors created by OpenLayers.Class call the parent's initialize method rather the parent constructor, this is to accomodate usage patterns of IGN's GeoPortal API, r=ahocevar (closes #3454)
Modified: trunk/openlayers/lib/OpenLayers/BaseTypes/Class.js
--- trunk/openlayers/lib/OpenLayers/BaseTypes/Class.js	2011-08-08 12:39:39 UTC (rev 12214)
+++ trunk/openlayers/lib/OpenLayers/BaseTypes/Class.js	2011-08-08 12:43:47 UTC (rev 12215)
@@ -37,7 +37,7 @@
     var C = typeof F.initialize == "function" ?
         F.initialize :
-        function(){ P.apply(this, arguments); };
+        function(){ P.prototype.initialize.apply(this, arguments); };
     if (len > 1) {
         var newArgs = [C, P].concat(
Modified: trunk/openlayers/tests/BaseTypes/Class.html
--- trunk/openlayers/tests/BaseTypes/Class.html	2011-08-08 12:39:39 UTC (rev 12214)
+++ trunk/openlayers/tests/BaseTypes/Class.html	2011-08-08 12:43:47 UTC (rev 12215)
@@ -432,27 +432,26 @@
         t.eq(b.a, "bar", "ctor overwritten");
-    // This test doesn't currently pass.
     function test_overwrite_5(t) {
         // overwrite constructor of parent class, which itself
         // doesn't defined "initialize"
-        t.plan(1);
+        t.plan(2);
         var A = OpenLayers.Class({
             initialize: function() {
                 this.a = "foo";
         var B = OpenLayers.Class(A, {});
+        var _A = A;
         A = overwrite(A, {
                 this.a = "bar";
         var b = new B;
+        t.ok(A.prototype === _A.prototype, "A and _A share the prototype");
     function test_overwrite_6(t) {
         // with static methods
More information about the Commits mailing list
