[OpenLayers-Commits] r12228 - in trunk/openlayers: lib/OpenLayers
theme/default
commits-20090109 at openlayers.org
Wed Aug 10 04:04:54 EDT 2011
Author: ahocevar
Date: 2011-08-10 01:04:53 -0700 (Wed, 10 Aug 2011)
New Revision: 12228
trunk/openlayers/lib/OpenLayers/Layer.js
trunk/openlayers/lib/OpenLayers/Map.js
trunk/openlayers/theme/default/style.css
IE8 specific fix for opacity. r=erilem (closes #3431)
Modified: trunk/openlayers/lib/OpenLayers/Layer.js
--- trunk/openlayers/lib/OpenLayers/Layer.js 2011-08-09 17:33:37 UTC (rev 12227)
+++ trunk/openlayers/lib/OpenLayers/Layer.js 2011-08-10 08:04:53 UTC (rev 12228)
@@ -347,8 +347,11 @@
this.id = OpenLayers.Util.createUniqueID(this.CLASS_NAME + "_");
this.div = OpenLayers.Util.createDiv(this.id);
- this.div.style.width = "100%";
- this.div.style.height = "100%";
+ var style = this.div.style;
+ style.width = "100%";
+ style.height = "100%";
+ style.overflow = "";
+ this.div.className = "olLayerDiv";
this.div.dir = "ltr";
if (this.opacity != null && this.opacity < 1) {
OpenLayers.Util.modifyDOMElement(
@@ -367,6 +370,19 @@
if (this.wrapDateLine) {
this.displayOutsideMaxExtent = true;
+ //TODO remove the if block below when we drop support for IE8.
+ if (parseInt(navigator.appVersion.split("MSIE")[1], 10) == 8) {
+ // Workaround for opacity handling in IE8 - also see
+ // .ie8-opacity-hack selectors in theme/default/style.css
+ this.events.register("loadend", this, function() {
+ var opacity = this.opacity;
+ if (opacity != null && opacity >= 0 && opacity < 1) {
+ OpenLayers.Element.addClass(this.div, "ie8-opacity-hack");
+ this.div.style.filter = "alpha(opacity=" + (opacity * 100) + ")";
Modified: trunk/openlayers/lib/OpenLayers/Map.js
--- trunk/openlayers/lib/OpenLayers/Map.js 2011-08-09 17:33:37 UTC (rev 12227)
+++ trunk/openlayers/lib/OpenLayers/Map.js 2011-08-10 08:04:53 UTC (rev 12228)
@@ -971,8 +971,6 @@
- layer.div.className = "olLayerDiv";
- layer.div.style.overflow = "";
this.setLayerZIndex(layer, this.layers.length);
if (layer.isFixed) {
Modified: trunk/openlayers/theme/default/style.css
--- trunk/openlayers/theme/default/style.css 2011-08-09 17:33:37 UTC (rev 12227)
+++ trunk/openlayers/theme/default/style.css 2011-08-10 08:04:53 UTC (rev 12228)
@@ -14,6 +14,15 @@
-khtml-user-select: none;
+/* TODO remove the two style definitions below when we drop support for IE8 */
+div.olLayerDiv.ie8-opacity-hack {
+ width: 9999px !important;
+ height: 9999px !important;
+div.olLayerDiv.ie8-opacity-hack div, .ie8-opacity-hack img.olTileImage {
+ filter: inherit;
.olLayerGoogleCopyright {
left: 2px;
bottom: 2px;
More information about the Commits
