[OpenLayers-Commits] r12232 - in branches/openlayers/2.11: lib/OpenLayers lib/OpenLayers/Layer tests tests/Layer
commits-20090109 at openlayers.org commits-20090109 at openlayers.org
Wed Aug 10 04:41:38 EDT 2011
Author: ahocevar
Date: 2011-08-10 01:41:37 -0700 (Wed, 10 Aug 2011)
New Revision: 12232
   branches/openlayers/2.11/lib/OpenLayers/Layer.js
   branches/openlayers/2.11/lib/OpenLayers/Layer/Markers.js
   branches/openlayers/2.11/lib/OpenLayers/Layer/WFS.js
   branches/openlayers/2.11/tests/Layer.html
   branches/openlayers/2.11/tests/Layer/ArcGIS93Rest.html
   branches/openlayers/2.11/tests/Layer/MapServer.html
   branches/openlayers/2.11/tests/Layer/Markers.html
   branches/openlayers/2.11/tests/Layer/WFS.html
   branches/openlayers/2.11/tests/Layer/WMS.html
reverting r12185 from #3431
Modified: branches/openlayers/2.11/lib/OpenLayers/Layer/Markers.js
--- branches/openlayers/2.11/lib/OpenLayers/Layer/Markers.js	2011-08-10 08:35:27 UTC (rev 12231)
+++ branches/openlayers/2.11/lib/OpenLayers/Layer/Markers.js	2011-08-10 08:41:37 UTC (rev 12232)
@@ -60,6 +60,22 @@
         OpenLayers.Layer.prototype.destroy.apply(this, arguments);
+     * APIMethod: setOpacity
+     * Sets the opacity for all the markers.
+     * Parameter:
+     * opacity - {Float}
+    setOpacity: function(opacity) {
+        if (opacity != this.opacity) {
+            this.opacity = opacity;
+            for (var i=0, len=this.markers.length; i<len; i++) {
+                this.markers[i].setOpacity(this.opacity);
      * Method: moveTo
Modified: branches/openlayers/2.11/lib/OpenLayers/Layer/WFS.js
--- branches/openlayers/2.11/lib/OpenLayers/Layer/WFS.js	2011-08-10 08:35:27 UTC (rev 12231)
+++ branches/openlayers/2.11/lib/OpenLayers/Layer/WFS.js	2011-08-10 08:41:37 UTC (rev 12232)
@@ -590,5 +590,21 @@
         return extent;
+     * Call the setOpacity method of the appropriate parent class to set the
+     *     opacity.
+     * Parameter:
+    setOpacity: function (opacity) {
+        if (this.vectorMode) {
+            OpenLayers.Layer.Vector.prototype.setOpacity.apply(this, [opacity]);
+        } else {
+            OpenLayers.Layer.Markers.prototype.setOpacity.apply(this, [opacity]);
     CLASS_NAME: "OpenLayers.Layer.WFS"
Modified: branches/openlayers/2.11/lib/OpenLayers/Layer.js
--- branches/openlayers/2.11/lib/OpenLayers/Layer.js	2011-08-10 08:35:27 UTC (rev 12231)
+++ branches/openlayers/2.11/lib/OpenLayers/Layer.js	2011-08-10 08:41:37 UTC (rev 12232)
@@ -349,11 +349,6 @@
             this.div.style.width = "100%";
             this.div.style.height = "100%";
             this.div.dir = "ltr";
-            if (this.opacity != null) {
-                OpenLayers.Util.modifyDOMElement(
-                    this.div, null, null, null, null, null, null, this.opacity
             this.events = new OpenLayers.Events(this, this.div,
                                                 this.EVENT_TYPES);
@@ -1274,8 +1269,11 @@
-            OpenLayers.Util.modifyDOMElement(this.div, null, null, null,
-                                             null, null, null, opacity);
+            for(var i=0, len=this.div.childNodes.length; i<len; ++i) {
+                var element = this.div.childNodes[i].firstChild;
+                OpenLayers.Util.modifyDOMElement(element, null, null, null,
+                                                 null, null, null, opacity);
             if (this.map != null) {
                 this.map.events.triggerEvent("changelayer", {
                     layer: this,
Modified: branches/openlayers/2.11/tests/Layer/ArcGIS93Rest.html
--- branches/openlayers/2.11/tests/Layer/ArcGIS93Rest.html	2011-08-10 08:35:27 UTC (rev 12231)
+++ branches/openlayers/2.11/tests/Layer/ArcGIS93Rest.html	2011-08-10 08:41:37 UTC (rev 12232)
@@ -195,6 +195,31 @@
+    function test_Layer_AGS93_setOpacity (t) {
+        var params = {layers: "show:0,2"};
+        t.plan( 5 );
+        var map = new OpenLayers.Map('map');
+        map.projection = "xx";
+        tParams = { layers: 'show:0,2',
+                   format: 'png'};
+        tOptions = { 'opacity': '0.5' };
+        var tLayer = new OpenLayers.Layer.ArcGIS93Rest(name, url, tParams, tOptions);
+        map.addLayer(tLayer);
+        map.zoomToMaxExtent();
+        t.eq(tLayer.opacity, "0.5", "Opacity is set correctly");
+        t.eq(parseFloat(tLayer.div.firstChild.firstChild.style.opacity), 0.5, "Opacity on tile is correct");
+        tLayer.setOpacity("0.6");
+        t.eq(tLayer.opacity, "0.6", "setOpacity works properly");
+        t.eq(parseFloat(tLayer.div.firstChild.firstChild.style.opacity), 0.6, "Opacity on tile is changed correctly");
+        var pixel = new OpenLayers.Pixel(5,6);
+        var tile = tLayer.addTile(new OpenLayers.Bounds(1,2,3,4), pixel);
+        tile.draw();
+        t.eq(parseFloat(tile.imgDiv.style.opacity), 0.6, "Tile opacity is set correctly");
+        map.destroy();
     function test_Layer_AGS93_noGutters (t) {
         t.plan(2);
Modified: branches/openlayers/2.11/tests/Layer/MapServer.html
--- branches/openlayers/2.11/tests/Layer/MapServer.html	2011-08-10 08:35:27 UTC (rev 12231)
+++ branches/openlayers/2.11/tests/Layer/MapServer.html	2011-08-10 08:41:37 UTC (rev 12232)
@@ -196,6 +196,31 @@
+    function test_Layer_MapServer_setOpacity (t) {
+        t.plan( 5 );
+        tUrl = "http://labs.metacarta.com/cgi-bin/mapserv";
+        tParams = { layers: 'basic',
+                   format: 'image/png'};
+        var tLayer = new OpenLayers.Layer.MapServer(name, tUrl, tParams, tOptions);
+        tile.draw();
+        map.destroy();
     function test_Layer_MapServer_Reproject (t) {
         var validkey = (window.location.protocol == "file:") ||
                        (window.location.host == "localhost") ||
@@ -386,6 +411,27 @@
+    function test_Layer_MapServer_Untiled_setOpacity (t) {
+        t.plan( 4 );
+        var tLayer = new OpenLayers.Layer.MapServer.Untiled(name, tUrl, tParams, tOptions);
+        map.destroy();
     // DEPRECATED -- REMOVE IN 3.0
     function test_Layer_Untiled_MapServer(t) {
         t.plan(1);
Modified: branches/openlayers/2.11/tests/Layer/Markers.html
--- branches/openlayers/2.11/tests/Layer/Markers.html	2011-08-10 08:35:27 UTC (rev 12231)
+++ branches/openlayers/2.11/tests/Layer/Markers.html	2011-08-10 08:41:37 UTC (rev 12232)
@@ -121,6 +121,33 @@
+    function test_setOpacity(t) {
+        t.plan(1);
+        layer = new OpenLayers.Layer.Markers('Test Layer');
+        var opacity = 0.1234;
+        for (var i = 0; i < 12; i++) {
+            layer.addMarker(new OpenLayers.Marker(new OpenLayers.LonLat(0,0), new OpenLayers.Icon()));
+        layer.setOpacity(opacity);
+        for (var i = 0; i < 4; i++) {
+        var itWorks = false;
+        for (var i = 0; i < layer.markers.length; i++) {
+            itWorks = parseFloat(layer.markers[i].icon.imageDiv.style.opacity) == opacity;
+            if (!itWorks) {
+                break;
+        t.ok(itWorks, "setOpacity change markers opacity");
   </script>
 </head>
 <body>
Modified: branches/openlayers/2.11/tests/Layer/WFS.html
--- branches/openlayers/2.11/tests/Layer/WFS.html	2011-08-10 08:35:27 UTC (rev 12231)
+++ branches/openlayers/2.11/tests/Layer/WFS.html	2011-08-10 08:41:37 UTC (rev 12232)
@@ -25,6 +25,22 @@
+    function test_Layer_WFS_setOpacity(t) {
+        t.plan(3);
+        var layer = new OpenLayers.Layer.WFS(name, "url", {});
+        layer.setOpacity(.5);
+        t.eq(layer.opacity, 0.5, "vector setOpacity didn't fail");
+        var layer = new OpenLayers.Layer.WFS(name, "url", {}, {'featureClass': OpenLayers.Feature.WFS});
+        var marker = new OpenLayers.Marker(new OpenLayers.LonLat(0,0));
+        marker.setOpacity = function() {
+            t.ok(true, "Marker setOpacity was called");
+        layer.addMarker(marker);
+        layer.setOpacity(.6);
+        t.eq(layer.opacity, 0.6, "setOpacity didn't fail on markers");
     function test_Layer_WFS_destroy(t) {
         t.plan(13);
Modified: branches/openlayers/2.11/tests/Layer/WMS.html
--- branches/openlayers/2.11/tests/Layer/WMS.html	2011-08-10 08:35:27 UTC (rev 12231)
+++ branches/openlayers/2.11/tests/Layer/WMS.html	2011-08-10 08:41:37 UTC (rev 12232)
@@ -281,6 +281,31 @@
+    function test_Layer_WMS_setOpacity (t) {
+        t.plan( 5 );
+        tUrl = "http://octo.metacarta.com/cgi-bin/mapserv";
+        var tLayer = new OpenLayers.Layer.WMS(name, tUrl, tParams, tOptions);
+        tile.draw();
+        map.destroy();
     function test_Layer_WMS_Reproject (t) {
Modified: branches/openlayers/2.11/tests/Layer.html
--- branches/openlayers/2.11/tests/Layer.html	2011-08-10 08:35:27 UTC (rev 12231)
+++ branches/openlayers/2.11/tests/Layer.html	2011-08-10 08:41:37 UTC (rev 12232)
@@ -786,15 +786,14 @@
-        t.plan(8);
+        t.plan(5);
         var map, layer, log;
         map = new OpenLayers.Map("map");
-        layer = new OpenLayers.Layer("", {opacity: 0.56});
+        layer = new OpenLayers.Layer("");
         map.addLayer(layer);
-        t.eq(layer.div.style.opacity, "0.56", "initial opacity correctly applied as layer.div style");
         log = [];
         map.events.register('changelayer', t, function(event) {
             log.push({layer: event.layer, property: event.property});
@@ -802,7 +801,6 @@
         layer.setOpacity(0.42);
         t.eq(layer.opacity, 0.42,
              "setOpacity() set layer.opacity to correct value");
-        t.eq(layer.div.style.opacity, "0.42", "opacity correctly applied as layer.div style");
         t.eq(log.length, 1,
              "setOpacity() triggers changelayer once");
         t.ok(log[0].layer == layer,
@@ -815,12 +813,6 @@
         t.eq(log.length, 0,
              "setOpacity() does not trigger changelayer if the opacity value is the same");
-        // 0 as initial opacity
-        layer.destroy();
-        layer = new OpenLayers.Layer("", {opacity: 0});
-        map.addLayer(layer);
-        t.eq(layer.div.style.opacity, "0", "initial opacity correctly applied as layer.div style");
More information about the Commits mailing list
