[OpenLayers-Commits] r12236 - in trunk/openlayers: lib/OpenLayers
tests
commits-20090109 at openlayers.org
Thu Aug 11 09:21:05 EDT 2011
Author: erilem
Date: 2011-08-11 06:21:04 -0700 (Thu, 11 Aug 2011)
New Revision: 12236
trunk/openlayers/lib/OpenLayers/Map.js
trunk/openlayers/tests/Map.html
a grid layer may be moved while its grid hasn't been initialized yet, r=ahocevar (references #3458)
Modified: trunk/openlayers/lib/OpenLayers/Map.js
--- trunk/openlayers/lib/OpenLayers/Map.js 2011-08-11 11:51:57 UTC (rev 12235)
+++ trunk/openlayers/lib/OpenLayers/Map.js 2011-08-11 13:21:04 UTC (rev 12236)
@@ -1722,7 +1722,8 @@
var layer, i, len;
for (i=0, len=this.layers.length; i<len; ++i) {
layer = this.layers[i];
- if (layer.visibility) {
+ if (layer.visibility &&
+ (layer === this.baseLayer || layer.inRange)) {
layer.moveByPx(dx, dy);
layer.events.triggerEvent("move");
Modified: trunk/openlayers/tests/Map.html
--- trunk/openlayers/tests/Map.html 2011-08-11 11:51:57 UTC (rev 12235)
+++ trunk/openlayers/tests/Map.html 2011-08-11 13:21:04 UTC (rev 12236)
@@ -1790,37 +1790,77 @@
function test_moveByPx(t) {
- t.plan(8);
+ t.plan(16);
+ var moved;
+ var Layer = OpenLayers.Class(OpenLayers.Layer, {
+ moveByPx: function(dx, dy) {
+ moved[this.name] = true;
var map = new OpenLayers.Map({
div: 'map',
maxExtent: new OpenLayers.Bounds(-50, -50, 50, 50),
restrictedExtent: new OpenLayers.Bounds(-10, -10, 10, 10),
layers: [
- new OpenLayers.Layer('name', {isBaseLayer: true})
+ new Layer('base',
+ {isBaseLayer: true}),
+ new Layer('outofrange',
+ {isBaseLayer: false, minResolution:2})
+ moved = {};
map.zoomToExtent(new OpenLayers.Bounds(-1, -1, 1, 1));
// check initial state
- t.eq(map.layerContainerDiv.style.left, '0px', 'layer container left correct');
- t.eq(map.layerContainerDiv.style.top, '0px', 'layer container top correct');
+ t.eq(map.layerContainerDiv.style.left, '0px',
+ '[initial state] layer container left correct');
+ t.eq(map.layerContainerDiv.style.top, '0px',
+ '[initial state] layer container top correct');
+ t.eq(moved['base'], undefined,
+ '[initial state] base layer not moved');
+ t.eq(moved['outofrange'], undefined,
+ '[initial state] out-of-range layer not moved');
// move to a valid position
+ moved = {};
map.moveByPx(-455, 455);
- t.eq(map.layerContainerDiv.style.left, '455px', 'layer container left correct');
- t.eq(map.layerContainerDiv.style.top, '-455px', 'layer container top correct');
+ t.eq(map.layerContainerDiv.style.left, '455px',
+ '[valid position] layer container left correct');
+ t.eq(map.layerContainerDiv.style.top, '-455px',
+ '[valid position] layer container top correct');
+ t.eq(moved['base'], true,
+ '[valid position] base layer moved');
+ '[valid position] out-of-range layer not moved');
// move outside the max extent
+ moved = {};
map.moveByPx(-4500, 4500);
+ '[outside max extent] layer container left correct');
+ '[outside max extent] layer container top correct');
+ '[outside max extent] base layer not moved');
+ '[outside max extent] out-of-range layer not moved');
// move outside the restricted extent
+ moved = {};
map.moveByPx(-500, 500);
+ '[outside restricted extent] layer container left correct');
+ '[outside restricted extent] layer container top correct');
+ '[outside restricted extent] base layer not moved');
+ '[outside restricted extent] out-of-range layer not moved');
map.destroy();
More information about the Commits
