[OpenLayers-Commits] r12243 - in
trunk/openlayers/lib/OpenLayers/Tile: . Image
commits-20090109 at openlayers.org
Sat Aug 13 04:15:37 EDT 2011
Author: ahocevar
Date: 2011-08-13 01:15:36 -0700 (Sat, 13 Aug 2011)
New Revision: 12243
trunk/openlayers/lib/OpenLayers/Tile/Image.js
trunk/openlayers/lib/OpenLayers/Tile/Image/IFrame.js
using blank image to avoid the "Loading Image" frames on Firefox that were discussed during the review (see #3419)
Modified: trunk/openlayers/lib/OpenLayers/Tile/Image/IFrame.js
--- trunk/openlayers/lib/OpenLayers/Tile/Image/IFrame.js 2011-08-13 02:49:25 UTC (rev 12242)
+++ trunk/openlayers/lib/OpenLayers/Tile/Image/IFrame.js 2011-08-13 08:15:36 UTC (rev 12243)
@@ -28,15 +28,7 @@
useIFrame: null,
- * Property: blankImageUrl
- * {String} This is only used as background image for the eventPane, so we
- * don't care that this doesn't actually result in a blank image on all
- * browsers
- blankImageUrl: "data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAQAIBRAA7",
* Method: updateBackBuffer
* Update the <backBufferData>, and return a new or reposition the
* backBuffer. When a backbuffer is returned, the tile's markup is not
@@ -193,4 +185,4 @@
\ No newline at end of file
Modified: trunk/openlayers/lib/OpenLayers/Tile/Image.js
--- trunk/openlayers/lib/OpenLayers/Tile/Image.js 2011-08-13 02:49:25 UTC (rev 12242)
+++ trunk/openlayers/lib/OpenLayers/Tile/Image.js 2011-08-13 08:15:36 UTC (rev 12243)
@@ -39,7 +39,16 @@
frame: null,
+ * Property: blankImageUrl
+ * {String} Does not result in a blank image on all browsers, but this is
+ * only required in some browsers as transparent backgroundImage, or as
+ * temporary image src while the tile is invisible and loading, so we don't
+ * care.
+ blankImageUrl: "data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAQAIBRAA7",
* Property: imageReloadAttempts
* {Integer} Attempts to load the image.
@@ -274,10 +283,9 @@
* url - {String} or undefined to hide the image
setImgSrc: function(url) {
- this.imgDiv.style.display = "none";
- if (url) {
- this.imgDiv.src = url;
+ var img = this.imgDiv;
+ img.style.display = "none";
+ img.src = url ? url : this.blankImageUrl;
@@ -342,4 +350,4 @@
CLASS_NAME: "OpenLayers.Tile.Image"
More information about the Commits
