[OpenLayers-Commits] r12255 - in trunk/openlayers:
lib/OpenLayers/Control tests/Control
commits-20090109 at openlayers.org
Wed Aug 17 09:47:10 EDT 2011
Author: bartvde
Date: 2011-08-17 06:47:08 -0700 (Wed, 17 Aug 2011)
New Revision: 12255
trunk/openlayers/lib/OpenLayers/Control/Snapping.js
trunk/openlayers/tests/Control/Snapping.html
filter on snapping target does not work for all filter types, r=ahocevar (closes #3468)
Modified: trunk/openlayers/lib/OpenLayers/Control/Snapping.js
--- trunk/openlayers/lib/OpenLayers/Control/Snapping.js 2011-08-17 02:29:09 UTC (rev 12254)
+++ trunk/openlayers/lib/OpenLayers/Control/Snapping.js 2011-08-17 13:47:08 UTC (rev 12255)
@@ -476,7 +476,7 @@
feature = features[i];
if(feature !== this.feature && !feature._sketch &&
feature.state !== OpenLayers.State.DELETE &&
- (!target.filter || target.filter.evaluate(feature.attributes))) {
+ (!target.filter || target.filter.evaluate(feature))) {
if(feature.atPoint(ll, maxTolerance, maxTolerance)) {
for(var j=0, stop=Math.min(result.rank+1, numTypes); j<stop; ++j) {
type = this.precedence[j];
Modified: trunk/openlayers/tests/Control/Snapping.html
--- trunk/openlayers/tests/Control/Snapping.html 2011-08-17 02:29:09 UTC (rev 12254)
+++ trunk/openlayers/tests/Control/Snapping.html 2011-08-17 13:47:08 UTC (rev 12255)
@@ -236,6 +236,56 @@
map.destroy();
+ function test_filter(t) {
+ t.plan(3);
+ var map = new OpenLayers.Map("map", {
+ resolutions: [1],
+ maxExtent: new OpenLayers.Bounds(0, 0, 100, 100)
+ var layer1 = new OpenLayers.Layer.Vector(null, {
+ isBaseLayer: true
+ var f1 = new OpenLayers.Feature.Vector(OpenLayers.Geometry.fromWKT(
+ "LINESTRING(0 0, 10 10, 20 20, 30 30)"
+ ), {foo: 'bar'});
+ f1.fid = "FID1";
+ var f2 = new OpenLayers.Feature.Vector(OpenLayers.Geometry.fromWKT(
+ "LINESTRING(11 10, 20 10, 30 10)"
+ ), {foo: 'bar'});
+ f2.fid = "FID2";
+ layer1.addFeatures([f1, f2]);
+ map.addLayers([layer1]);
+ map.zoomToMaxExtent();
+ var control = new OpenLayers.Control.Snapping({
+ layer: layer1,
+ targets: [layer1],
+ defaults: {tolerance: 4}
+ control.activate();
+ var result;
+ var loc = new OpenLayers.Geometry.Point(1, 1);
+ control.setTargets([{layer: layer1}]);
+ result = control.testTarget(control.targets[0], loc);
+ t.ok(result !== null, "target is eligible without a filter set");
+ var filter = new OpenLayers.Filter.Logical({
+ type: OpenLayers.Filter.Logical.NOT,
+ filters: [
+ new OpenLayers.Filter.FeatureId({fids: ["FID1", "FID2"]})
+ control.setTargets([{layer: layer1, filter: filter}]);
+ t.ok(result === null, "target is not eligible with a filter set which excludes the target's features");
+ filter = new OpenLayers.Filter.Comparison({type: OpenLayers.Filter.Comparison.NOT_EQUAL_TO, value: 'bar', property: 'foo'});
+ t.ok(result === null, "target is not eligible with a filter set which excludes the target's features using a comparison filter");
function test_snapping(t) {
More information about the Commits
