[OpenLayers-Commits] r12269 - in trunk/openlayers:
lib/OpenLayers/Layer tests/Layer
commits-20090109 at openlayers.org
Wed Aug 24 02:18:56 EDT 2011
Author: bartvde
Date: 2011-08-23 23:18:55 -0700 (Tue, 23 Aug 2011)
New Revision: 12269
trunk/openlayers/lib/OpenLayers/Layer/ArcGISCache.js
trunk/openlayers/tests/Layer/ArcGISCache.html
make sure the for loop for lods is not messed up by frameworks changing the Array.prototype, p=dzwarg, r=me (closes #3474)
Modified: trunk/openlayers/lib/OpenLayers/Layer/ArcGISCache.js
--- trunk/openlayers/lib/OpenLayers/Layer/ArcGISCache.js 2011-08-22 10:10:46 UTC (rev 12268)
+++ trunk/openlayers/lib/OpenLayers/Layer/ArcGISCache.js 2011-08-24 06:18:55 UTC (rev 12269)
@@ -172,21 +172,23 @@
this.lods = [];
for(var key in info.tileInfo.lods) {
- var lod = info.tileInfo.lods[key];
- if (this.useScales) {
- this.scales.push(lod.scale);
- } else {
- this.resolutions.push(lod.resolution);
+ if (info.tileInfo.lods.hasOwnProperty(key)) {
+ var lod = info.tileInfo.lods[key];
+ if (this.useScales) {
+ this.scales.push(lod.scale);
+ } else {
+ this.resolutions.push(lod.resolution);
- var start = this.getContainingTileCoords(upperLeft, lod.resolution);
- lod.startTileCol = start.x;
- lod.startTileRow = start.y;
+ var start = this.getContainingTileCoords(upperLeft, lod.resolution);
+ lod.startTileCol = start.x;
+ lod.startTileRow = start.y;
- var end = this.getContainingTileCoords(bottomRight, lod.resolution);
- lod.endTileCol = end.x;
- lod.endTileRow = end.y;
- this.lods.push(lod);
+ var end = this.getContainingTileCoords(bottomRight, lod.resolution);
+ lod.endTileCol = end.x;
+ lod.endTileRow = end.y;
+ this.lods.push(lod);
this.maxExtent = this.calculateMaxExtentWithLOD(this.lods[0]);
Modified: trunk/openlayers/tests/Layer/ArcGISCache.html
--- trunk/openlayers/tests/Layer/ArcGISCache.html 2011-08-22 10:10:46 UTC (rev 12268)
+++ trunk/openlayers/tests/Layer/ArcGISCache.html 2011-08-24 06:18:55 UTC (rev 12269)
@@ -219,6 +219,32 @@
t.ok((tile.x >= 0 && tile.y >= 0), 'layer should not generate negative tile ranges for level of detail');
+ * Test that functions don't end up in the lods of the layer. This messes up zooming when
+ * resolutions are very small/scales are very large/zoomed way in.
+ function test_Layer_ARCGISCACHE_lods (t) {
+ t.plan( 2 );
+ var layerInfo = capabilitiesObject;
+ lods = layerInfo.tileInfo.lods.length;
+ // mess up the Array prototype
+ Array.prototype.foo = function() { };
+ t.ok( lods == layerInfo.tileInfo.lods.length, 'proper number of "Levels of Detail" before initialization' );
+ // initialize the layer using the JSON object from an arcgis server
+ // see: ArcGISCache.json
+ var layer = new OpenLayers.Layer.ArcGISCache(name, url, {
+ layerInfo: layerInfo
+ t.ok( lods == layer.lods.length, 'proper number of "Levels of Detail" after initialization.' );
+ // restore the Array prototype
+ delete Array.prototype.foo;
</script>
</head>
<body>
More information about the Commits
