[OpenLayers-Commits] r12274 - in branches/openlayers/2.11: .
lib/OpenLayers lib/OpenLayers/Control lib/OpenLayers/Format
lib/OpenLayers/Layer lib/OpenLayers/Protocol tests
tests/BaseTypes tests/Control tests/Layer tests/Protocol tools
commits-20090109 at openlayers.org
Wed Aug 24 19:32:37 EDT 2011
Author: crschmidt
Date: 2011-08-24 16:32:34 -0700 (Wed, 24 Aug 2011)
New Revision: 12274
branches/openlayers/2.11/
branches/openlayers/2.11/lib/OpenLayers/Control/ModifyFeature.js
branches/openlayers/2.11/lib/OpenLayers/Format/WPSDescribeProcess.js
branches/openlayers/2.11/lib/OpenLayers/Layer/ArcGISCache.js
branches/openlayers/2.11/lib/OpenLayers/Layer/HTTPRequest.js
branches/openlayers/2.11/lib/OpenLayers/Map.js
branches/openlayers/2.11/lib/OpenLayers/Protocol/Script.js
branches/openlayers/2.11/tests/BaseTypes/Date.html
branches/openlayers/2.11/tests/Control/ModifyFeature.html
branches/openlayers/2.11/tests/Layer/ArcGISCache.html
branches/openlayers/2.11/tests/Map.html
branches/openlayers/2.11/tests/Protocol/Script.html
branches/openlayers/2.11/tools/closure.py
Pulling in patches for OL 2.11 RC3:
* ArcGISCache resolutions get compromised by some JS frameworks. (Closes #3474)
* OpenLayers.Layer.HTTPRequest initialize simplification (Closes #3470)
* missing requires (Closes #3467)
* deleting a vertex does not update feature.modified (Closes #3463)
* fixing test failure in some browsers (Closes #3461)
* a grid layer may be moved while its grid hasn't been initialized yet (Closes #3458) -- this one is the actual release blocker
* Change the callback function of Protocol.Script (JSONP) (Closes #3417)
* "build.py -c closure" does not work on Windows systems. (Closes #3158)
Property changes on: branches/openlayers/2.11
___________________________________________________________________
Modified: svn:mergeinfo
- /sandbox/roberthl/openlayers:9745-9748
+ /sandbox/roberthl/openlayers:9745-9748
/trunk/openlayers:12236,12248,12250,12252,12254,12267-12270
Modified: branches/openlayers/2.11/lib/OpenLayers/Control/ModifyFeature.js
--- branches/openlayers/2.11/lib/OpenLayers/Control/ModifyFeature.js 2011-08-24 14:35:35 UTC (rev 12273)
+++ branches/openlayers/2.11/lib/OpenLayers/Control/ModifyFeature.js 2011-08-24 23:32:34 UTC (rev 12274)
@@ -633,6 +633,7 @@
this.layer.drawFeature(this.feature, this.standalone ?
undefined :
this.selectControl.renderIntent);
+ this.modified = true;
this.resetVertices();
this.setFeatureState();
this.onModification(this.feature);
Modified: branches/openlayers/2.11/lib/OpenLayers/Format/WPSDescribeProcess.js
--- branches/openlayers/2.11/lib/OpenLayers/Format/WPSDescribeProcess.js 2011-08-24 14:35:35 UTC (rev 12273)
+++ branches/openlayers/2.11/lib/OpenLayers/Format/WPSDescribeProcess.js 2011-08-24 23:32:34 UTC (rev 12274)
@@ -5,6 +5,7 @@
* @requires OpenLayers/Format/XML.js
+ * @requires OpenLayers/Format/OWSCommon/v1_1_0.js
Modified: branches/openlayers/2.11/lib/OpenLayers/Layer/ArcGISCache.js
--- branches/openlayers/2.11/lib/OpenLayers/Layer/ArcGISCache.js 2011-08-24 14:35:35 UTC (rev 12273)
+++ branches/openlayers/2.11/lib/OpenLayers/Layer/ArcGISCache.js 2011-08-24 23:32:34 UTC (rev 12274)
@@ -172,21 +172,23 @@
this.lods = [];
for(var key in info.tileInfo.lods) {
- var lod = info.tileInfo.lods[key];
- if (this.useScales) {
- this.scales.push(lod.scale);
- } else {
- this.resolutions.push(lod.resolution);
+ if (info.tileInfo.lods.hasOwnProperty(key)) {
+ var lod = info.tileInfo.lods[key];
+ if (this.useScales) {
+ this.scales.push(lod.scale);
+ } else {
+ this.resolutions.push(lod.resolution);
- var start = this.getContainingTileCoords(upperLeft, lod.resolution);
- lod.startTileCol = start.x;
- lod.startTileRow = start.y;
+ var start = this.getContainingTileCoords(upperLeft, lod.resolution);
+ lod.startTileCol = start.x;
+ lod.startTileRow = start.y;
- var end = this.getContainingTileCoords(bottomRight, lod.resolution);
- lod.endTileCol = end.x;
- lod.endTileRow = end.y;
- this.lods.push(lod);
+ var end = this.getContainingTileCoords(bottomRight, lod.resolution);
+ lod.endTileCol = end.x;
+ lod.endTileRow = end.y;
+ this.lods.push(lod);
this.maxExtent = this.calculateMaxExtentWithLOD(this.lods[0]);
Modified: branches/openlayers/2.11/lib/OpenLayers/Layer/HTTPRequest.js
--- branches/openlayers/2.11/lib/OpenLayers/Layer/HTTPRequest.js 2011-08-24 14:35:35 UTC (rev 12273)
+++ branches/openlayers/2.11/lib/OpenLayers/Layer/HTTPRequest.js 2011-08-24 23:32:34 UTC (rev 12274)
@@ -58,9 +58,7 @@
* options - {Object} Hashtable of extra options to tag onto the layer
initialize: function(name, url, params, options) {
- var newArguments = arguments;
- newArguments = [name, options];
- OpenLayers.Layer.prototype.initialize.apply(this, newArguments);
+ OpenLayers.Layer.prototype.initialize.apply(this, [name, options]);
this.url = url;
this.params = OpenLayers.Util.extend( {}, params);
Modified: branches/openlayers/2.11/lib/OpenLayers/Map.js
--- branches/openlayers/2.11/lib/OpenLayers/Map.js 2011-08-24 14:35:35 UTC (rev 12273)
+++ branches/openlayers/2.11/lib/OpenLayers/Map.js 2011-08-24 23:32:34 UTC (rev 12274)
@@ -1722,7 +1722,8 @@
var layer, i, len;
for (i=0, len=this.layers.length; i<len; ++i) {
layer = this.layers[i];
- if (layer.visibility) {
+ if (layer.visibility &&
+ (layer === this.baseLayer || layer.inRange)) {
layer.moveByPx(dx, dy);
layer.events.triggerEvent("move");
Modified: branches/openlayers/2.11/lib/OpenLayers/Protocol/Script.js
--- branches/openlayers/2.11/lib/OpenLayers/Protocol/Script.js 2011-08-24 14:35:35 UTC (rev 12273)
+++ branches/openlayers/2.11/lib/OpenLayers/Protocol/Script.js 2011-08-24 23:32:34 UTC (rev 12274)
@@ -207,7 +207,7 @@
createRequest: function(url, params, callback) {
var id = OpenLayers.Protocol.Script.register(callback);
- var name = "OpenLayers.Protocol.Script.getCallback(" + id + ")";
+ var name = "OpenLayers.Protocol.Script.registry[" + id + "]";
params = OpenLayers.Util.extend({}, params);
params[this.callbackKey] = this.callbackPrefix + name;
url = OpenLayers.Util.urlAppend(
@@ -328,7 +328,7 @@
(function() {
var o = OpenLayers.Protocol.Script;
var counter = 0;
- var registry = {};
+ o.registry = [];
* Function: OpenLayers.Protocol.Script.register
@@ -344,7 +344,10 @@
o.register = function(callback) {
var id = ++counter;
- registry[id] = callback;
+ o.registry[id] = function() {
+ o.unregister(id);
+ callback.apply(this, arguments);
return id;
@@ -356,22 +359,6 @@
* id: {Number} The identifer returned by the register function.
o.unregister = function(id) {
- delete registry[id];
+ delete o.registry[id];
- * Function: OpenLayers.Protocol.Script.getCallback
- * Retreive and unregister a callback. A call to this function is the "P"
- * in JSONP. For example, a script may be added with a src attribute
- * http://example.com/features.json?callback=OpenLayers.Protocol.Script.getCallback(1)
- * Parameters:
- * id: {Number} The identifer returned by the register function.
- o.getCallback = function(id) {
- var callback = registry[id];
- o.unregister(id);
- return callback;
Modified: branches/openlayers/2.11/tests/BaseTypes/Date.html
--- branches/openlayers/2.11/tests/BaseTypes/Date.html 2011-08-24 14:35:35 UTC (rev 12273)
+++ branches/openlayers/2.11/tests/BaseTypes/Date.html 2011-08-24 23:32:34 UTC (rev 12274)
@@ -20,7 +20,15 @@
// check invalid date
date = new Date("foo");
- str = OpenLayers.Date.toISOString(date);
+ try {
+ str = OpenLayers.Date.toISOString(date);
+ } catch (err) {
+ // some implementations throw RangeError
+ // see https://bugzilla.mozilla.org/show_bug.cgi?id=649575
+ if (err instanceof RangeError) {
+ str = "Invalid Date";
t.eq(str, "Invalid Date", "invalid date");
Modified: branches/openlayers/2.11/tests/Control/ModifyFeature.html
--- branches/openlayers/2.11/tests/Control/ModifyFeature.html 2011-08-24 14:35:35 UTC (rev 12273)
+++ branches/openlayers/2.11/tests/Control/ModifyFeature.html 2011-08-24 23:32:34 UTC (rev 12274)
@@ -74,7 +74,7 @@
function test_handleKeypress(t) {
- t.plan(14);
+ t.plan(16);
* There are two things that we want to test here
@@ -101,6 +101,8 @@
// mock up vertex deletion
control.dragControl.feature = point;
control.feature = poly;
+ // we cannot use selectFeature since the control is not part of a map
+ control._originalGeometry = poly.geometry.clone();
control.vertices = [point];
point.geometry.parent = {
removeComponent: function(geometry) {
@@ -110,6 +112,7 @@
layer.events.on({
"featuremodified": function(event) {
+ t.ok(event.feature.modified !== null, "modified property of feature should have been set");
t.eq(event.feature.id, poly.id, "vertex deletion: featuremodifed triggered");
"vertexremoved": function(evt) {
Modified: branches/openlayers/2.11/tests/Layer/ArcGISCache.html
--- branches/openlayers/2.11/tests/Layer/ArcGISCache.html 2011-08-24 14:35:35 UTC (rev 12273)
+++ branches/openlayers/2.11/tests/Layer/ArcGISCache.html 2011-08-24 23:32:34 UTC (rev 12274)
@@ -219,6 +219,32 @@
t.ok((tile.x >= 0 && tile.y >= 0), 'layer should not generate negative tile ranges for level of detail');
+ * Test that messing up the Array.prototype does not mess up the lods of the layer.
+ * This messes up zooming when resolutions are very small/scales are very large/zoomed way in.
+ function test_Layer_ARCGISCACHE_lods (t) {
+ t.plan( 2 );
+ var layerInfo = capabilitiesObject;
+ lods = layerInfo.tileInfo.lods.length;
+ // mess up the Array prototype
+ Array.prototype.foo = function() { };
+ t.ok( lods == layerInfo.tileInfo.lods.length, 'proper number of "Levels of Detail" before initialization' );
+ // initialize the layer using the JSON object from an arcgis server
+ // see: ArcGISCache.json
+ var layer = new OpenLayers.Layer.ArcGISCache(name, url, {
+ layerInfo: layerInfo
+ t.ok( lods == layer.lods.length, 'proper number of "Levels of Detail" after initialization.' );
+ // restore the Array prototype
+ delete Array.prototype.foo;
</script>
</head>
<body>
Modified: branches/openlayers/2.11/tests/Map.html
--- branches/openlayers/2.11/tests/Map.html 2011-08-24 14:35:35 UTC (rev 12273)
+++ branches/openlayers/2.11/tests/Map.html 2011-08-24 23:32:34 UTC (rev 12274)
@@ -1790,37 +1790,77 @@
function test_moveByPx(t) {
- t.plan(8);
+ t.plan(16);
+ var moved;
+ var Layer = OpenLayers.Class(OpenLayers.Layer, {
+ moveByPx: function(dx, dy) {
+ moved[this.name] = true;
var map = new OpenLayers.Map({
div: 'map',
maxExtent: new OpenLayers.Bounds(-50, -50, 50, 50),
restrictedExtent: new OpenLayers.Bounds(-10, -10, 10, 10),
layers: [
- new OpenLayers.Layer('name', {isBaseLayer: true})
+ new Layer('base',
+ {isBaseLayer: true}),
+ new Layer('outofrange',
+ {isBaseLayer: false, minResolution:2})
+ moved = {};
map.zoomToExtent(new OpenLayers.Bounds(-1, -1, 1, 1));
// check initial state
- t.eq(map.layerContainerDiv.style.left, '0px', 'layer container left correct');
- t.eq(map.layerContainerDiv.style.top, '0px', 'layer container top correct');
+ t.eq(map.layerContainerDiv.style.left, '0px',
+ '[initial state] layer container left correct');
+ t.eq(map.layerContainerDiv.style.top, '0px',
+ '[initial state] layer container top correct');
+ t.eq(moved['base'], undefined,
+ '[initial state] base layer not moved');
+ t.eq(moved['outofrange'], undefined,
+ '[initial state] out-of-range layer not moved');
// move to a valid position
+ moved = {};
map.moveByPx(-455, 455);
- t.eq(map.layerContainerDiv.style.left, '455px', 'layer container left correct');
- t.eq(map.layerContainerDiv.style.top, '-455px', 'layer container top correct');
+ t.eq(map.layerContainerDiv.style.left, '455px',
+ '[valid position] layer container left correct');
+ t.eq(map.layerContainerDiv.style.top, '-455px',
+ '[valid position] layer container top correct');
+ t.eq(moved['base'], true,
+ '[valid position] base layer moved');
+ '[valid position] out-of-range layer not moved');
// move outside the max extent
+ moved = {};
map.moveByPx(-4500, 4500);
+ '[outside max extent] layer container left correct');
+ '[outside max extent] layer container top correct');
+ '[outside max extent] base layer not moved');
+ '[outside max extent] out-of-range layer not moved');
// move outside the restricted extent
+ moved = {};
map.moveByPx(-500, 500);
+ '[outside restricted extent] layer container left correct');
+ '[outside restricted extent] layer container top correct');
+ '[outside restricted extent] base layer not moved');
+ '[outside restricted extent] out-of-range layer not moved');
map.destroy();
Modified: branches/openlayers/2.11/tests/Protocol/Script.html
--- branches/openlayers/2.11/tests/Protocol/Script.html 2011-08-24 14:35:35 UTC (rev 12273)
+++ branches/openlayers/2.11/tests/Protocol/Script.html 2011-08-24 23:32:34 UTC (rev 12274)
@@ -150,7 +150,7 @@
t.eq(script.type, 'text/javascript',
'created script has a correct type');
- t.eq(script.src, 'http://bar_url/?k=bar_param&cb_key=cb_prefix%3AOpenLayers.Protocol.Script.getCallback(bar)',
+ t.eq(script.src, 'http://bar_url/?k=bar_param&cb_key=cb_prefix%3AOpenLayers.Protocol.Script.registry%5Bbar%5D',
'created script has a correct url');
t.eq(script.id, 'OpenLayers_Protocol_Script_bar',
'created script has a correct id');
Modified: branches/openlayers/2.11/tools/closure.py
--- branches/openlayers/2.11/tools/closure.py 2011-08-24 14:35:35 UTC (rev 12273)
+++ branches/openlayers/2.11/tools/closure.py 2011-08-24 23:32:34 UTC (rev 12274)
@@ -2,20 +2,21 @@
import os
import tempfile
-path = os.path.abspath(os.path.join(os.path.dirname(__file__), "closure-compiler.jar"))
+path = "../tools/closure-compiler.jar"
if not os.path.exists(path):
raise Exception("No closure-compiler.jar at %s; read README.txt!" % path)
def minimize(code):
- ntf = tempfile.NamedTemporaryFile()
+ ntf = tempfile.NamedTemporaryFile(delete=False)
ntf.write(code)
ntf.flush()
- ntf2 = tempfile.NamedTemporaryFile()
+ ntf2 = tempfile.NamedTemporaryFile(delete=False)
+ ntf.close()
+ ntf2.close()
os.system("java -jar %s --js %s --js_output_file %s" % (path, ntf.name, ntf2.name))
- ntf2.seek(0)
- data = ntf2.read()
- ntf.close()
- ntf2.close()
+ data = open(ntf2.name).read()
+ os.unlink(ntf.name)
+ os.unlink(ntf2.name)
return data
More information about the Commits
