[OpenLayers-Commits] r12280 -
sandbox/camptocamp/clientzoom/lib/OpenLayers/Layer
commits-20090109 at openlayers.org
Mon Aug 29 04:29:35 EDT 2011
Author: erilem
Date: 2011-08-29 01:29:34 -0700 (Mon, 29 Aug 2011)
New Revision: 12280
sandbox/camptocamp/clientzoom/lib/OpenLayers/Layer/Grid.js
load tiles before applying "client zoom", panning still does not work when the layer div has been scaled
Modified: sandbox/camptocamp/clientzoom/lib/OpenLayers/Layer/Grid.js
--- sandbox/camptocamp/clientzoom/lib/OpenLayers/Layer/Grid.js 2011-08-25 20:55:04 UTC (rev 12279)
+++ sandbox/camptocamp/clientzoom/lib/OpenLayers/Layer/Grid.js 2011-08-29 08:29:34 UTC (rev 12280)
@@ -221,38 +221,13 @@
moveTo:function(bounds, zoomChanged, dragging) {
- // if we know the server doesn't support the new resolution
- // we apply "client zoom", that is transform the layer div,
- // and return
+ var resolution = this.map.getResolution(),
+ availableResolution = this.getAvailableResolution();
- var resolution = this.map.getResolution();
- if(this.serverResolutions && OpenLayers.Util.indexOf(
- this.serverResolutions, resolution) === -1) {
- // TODO
- // - we should have a better way to find the base resolution,
- // currently we only support the case where non-supported
- // resolutions are at the end of the resolutions array.
- // - verify whether HTTPRequest.moveTo should be called here
- // too
- if(zoomChanged) {
- var baseResolution = this.serverResolutions[
- this.serverResolutions.length-1];
- this.transformDiv(resolution, baseResolution);
- return;
+ if(resolution !== availableResolution) {
+ bounds = this.map.calculateBounds(null, availableResolution);
- // reset the layer width, height, left, top, to deal with
- // the case where the layer has been transformDivd
- this.div.style.width = '100%';
- this.div.style.height = '100%';
- this.div.style.left = '0%';
- this.div.style.top = '0%';
OpenLayers.Layer.HTTPRequest.prototype.moveTo.apply(this, arguments);
bounds = bounds || this.map.getExtent();
@@ -288,26 +263,69 @@
+ if(zoomChanged) {
+ // apply "client zoom"
+ var scale = availableResolution / resolution;
+ this.transformDiv(scale);
+ } else {
+ // reset the layer width, height, left, top, to deal with
+ // the case where the layer has been transformDivd
+ this.div.style.width = '100%';
+ this.div.style.height = '100%';
+ this.div.style.left = '0%';
+ this.div.style.top = '0%';
+ * Method: getAvailableResolution
+ * Return the server-supported resolution that is the closest to
+ * the resolution passed as a parameter. If no resolution is
+ * passed the map resolution is used.
+ * Parameters:
+ * resolution - {Number} The base resolution.
+ * Returns:
+ * {Number} The closest available resolution.
+ getAvailableResolution: function(resolution) {
+ resolution = resolution || this.map.getResolution();
+ if(this.serverResolutions &&
+ OpenLayers.Util.indexOf(this.serverResolutions, resolution) === -1) {
+ var i, serverResolution;
+ for(var i=this.serverResolutions.length-1; i>= 0; i--) {
+ serverResolution = this.serverResolutions[i];
+ if(serverResolution > resolution) {
+ resolution = serverResolution;
+ break;
+ if(i === -1) {
+ throw 'no appropriate resolution in serverResolutions';
+ return resolution;
* Method: transformDiv
* Transform the layer div.
* Parameters:
- * resolution - {Number} The target resolution.
- * baseResolution - {Number} The base resolution.
+ * scale - {Number} The value by which the layer div is to
+ * be scaled.
- transformDiv: function(resolution, baseResolution) {
+ transformDiv: function(scale) {
// TODO
- // - transformDiv generates an error if the grid isn't initialized yet
// - serverResolutions should be documented
- var scale = baseResolution / resolution;
// scale the layer div
this.div.style.width = 100 * scale + '%';
@@ -342,6 +360,7 @@
moveByPx: function(dx, dy) {
// do not move schedule move of gridded tiles if in single
// tile or client zoom mode
+ // FIXME this must be fixed
if (!this.singleTile &&
(!this.serverResolutions ||
@@ -549,7 +568,7 @@
Math.max(1, 2 * this.buffer);
var origin = this.getTileOrigin();
+ var resolution = this.getAvailableResolution();
var tileLayout = this.calculateGridLayout(bounds, origin, resolution);
@@ -816,7 +835,7 @@
var grid = this.grid;
var modelRow = grid[modelRowIndex];
var deltaY = (prepend) ? -this.tileSize.h : this.tileSize.h;
var deltaLat = resolution * -deltaY;
@@ -849,7 +868,7 @@
shiftColumn: function(prepend) {
var deltaX = (prepend) ? -this.tileSize.w : this.tileSize.w;
var deltaLon = resolution * deltaX;
for (var i=0, len=this.grid.length; i<len; i++) {
More information about the Commits
