[OpenLayers-Commits] r12284 - sandbox/camptocamp/clientzoom/examples
commits-20090109 at openlayers.org
Mon Aug 29 08:50:45 EDT 2011
Author: erilem
Date: 2011-08-29 05:50:44 -0700 (Mon, 29 Aug 2011)
New Revision: 12284
sandbox/camptocamp/clientzoom/examples/wmts.html
sandbox/camptocamp/clientzoom/examples/wmts.js
better demonstrate "client zoom" in the wmts.html example
Modified: sandbox/camptocamp/clientzoom/examples/wmts.html
--- sandbox/camptocamp/clientzoom/examples/wmts.html 2011-08-29 12:50:33 UTC (rev 12283)
+++ sandbox/camptocamp/clientzoom/examples/wmts.html 2011-08-29 12:50:44 UTC (rev 12284)
@@ -27,27 +27,34 @@
</p>
<div id="map" class="smallmap"></div>
<div id="docs">
<p>
This example uses an OpenLayers.Layer.WMTS layer to display
cached tiles over an OSM layer in spherical mercator coordinates.
- </p><p>
+ </p>
- <strong>client zoom</strong> - In this example the OSM layer,
- which is the base layer, defines
- 19 resolutions, from 156543.0339 to 0.5971. The WMTS layer is
- configured as if its WMTS service only supported 18
- resolutions, from 156543.0339 to 1.1943 (through the
- <code>serverResolutions</code> option). So when the map
- changes to the smallest resolution,
- 0.5971, "client zooming" is applied to the WMTS layer, that is
- the layer div is transformed client-side to inflate the tiles
- and make it so the layer was zoomed.
+ <p>
- </p><p>
+ This example demonstrates the <strong>"client zoom"</strong>
+ functionality.
+ The map works with 19 resolutions. But the WMTS layer is
+ configured as its WMTS service supported only 17 of these
+ resolutions. The resolutions for the zoom levels 16 and 18 are
+ indeed not included in the WMTS layer's
+ <code>serverResolutions</code> option.
+ The map's initial zoom is 17. So if you zoom in or out
+ you'll see that "client zoom" is applied.
+ </p>
+ <p>
See the <a href="wmts.js" target="_blank">
wmts.js source</a> to see how this is done.
</p>
</div>
</body>
Modified: sandbox/camptocamp/clientzoom/examples/wmts.js
--- sandbox/camptocamp/clientzoom/examples/wmts.js 2011-08-29 12:50:33 UTC (rev 12283)
+++ sandbox/camptocamp/clientzoom/examples/wmts.js 2011-08-29 12:50:44 UTC (rev 12284)
@@ -33,7 +33,7 @@
style: "_null",
opacity: 0.7,
isBaseLayer: false,
- serverResolutions: [156543.03390625, 78271.516953125, 39135.7584765625, 19567.87923828125, 9783.939619140625, 4891.9698095703125, 2445.9849047851562, 1222.9924523925781, 611.4962261962891, 305.74811309814453, 152.87405654907226, 76.43702827453613, 38.218514137268066, 19.109257068634033, 9.554628534317017, 4.777314267158508, 2.388657133579254, 1.194328566789627]
+ serverResolutions: [156543.03390625, 78271.516953125, 39135.7584765625, 19567.87923828125, 9783.939619140625, 4891.9698095703125, 2445.9849047851562, 1222.9924523925781, 611.4962261962891, 305.74811309814453, 152.87405654907226, 76.43702827453613, 38.218514137268066, 19.109257068634033, 9.554628534317017, 4.777314267158508, 1.194328566789627]
map.addLayers([osm, wmts]);
More information about the Commits
