[OpenLayers-Commits] r12309 -
sandbox/camptocamp/clientzoom/tests/Layer
commits-20090109 at openlayers.org
Wed Aug 31 16:17:36 EDT 2011
Author: erilem
Date: 2011-08-31 13:17:35 -0700 (Wed, 31 Aug 2011)
New Revision: 12309
sandbox/camptocamp/clientzoom/tests/Layer/Grid.html
new test for Layer.Grid
Modified: sandbox/camptocamp/clientzoom/tests/Layer/Grid.html
--- sandbox/camptocamp/clientzoom/tests/Layer/Grid.html 2011-08-31 20:17:29 UTC (rev 12308)
+++ sandbox/camptocamp/clientzoom/tests/Layer/Grid.html 2011-08-31 20:17:35 UTC (rev 12309)
@@ -629,7 +629,103 @@
t.eq( layer.tileSize, null, "layer.tileSize is null after destroy" );
+ function test_getServerSupportedResolution(t) {
+ t.plan(4);
+ var layer = new OpenLayers.Layer.Grid('', '', {}, {});
+ var res;
+ res = layer.getServerSupportedResolution(1);
+ t.eq(res, 1, '[1] getServerSupportedResolution return value is correct');
+ layer.serverResolutions = [2, 1];
+ t.eq(res, 1, '[2] getServerSupportedResolution return value is correct');
+ layer.serverResolutions = [2];
+ t.eq(res, 2, '[3] getServerSupportedResolution return value is correct');
+ var exc;
+ layer.serverResolutions = [0.5];
+ try {
+ } catch(e) {
+ exc = e;
+ t.ok(exc != undefined, '[4] getServerSupportedResolution generates exception');
+ function test_getServerSupportedZoom(t) {
+ t.plan(5);
+ var resolution, zoom;
+ var map = new OpenLayers.Map('map', {
+ resolutions: [8, 4, 2, 1, 0.5],
+ getResolution: function() {
+ return resolution;
+ var layer = new OpenLayers.Layer.WMS('', '', {}, {isBaseLayer: true});
+ map.addLayer(layer);
+ resolution = 8;
+ zoom = layer.getServerSupportedZoom();
+ t.eq(zoom, 0, '[1] getServerSupportedZoom return value is correct');
+ resolution = 4;
+ t.eq(zoom, 1, '[2] getServerSupportedZoom return value is correct');
+ resolution = 1;
+ t.eq(zoom, 3, '[3] getServerSupportedZoom return value is correct');
+ resolution = 0.5;
+ t.eq(zoom, 2, '[4] getServerSupportedZoom return value is correct');
+ var exc;
+ resolution = 1;
+ try {
+ } catch(e) {
+ exc = e;
+ t.ok(exc != undefined, '[4] getServerSupportedZoom generates exception');
+ map.destroy();
+ function test_transformDiv(t) {
+ t.plan(6);
+ var map = new OpenLayers.Map('map');
+ isBaseLayer: true
+ map.zoomToMaxExtent();
+ var tile = layer.grid[1][1];
+ t.eq(tile.frame.style.left, '122%', 'tile (1,1) expected left');
+ t.eq(tile.frame.style.top, '83%', 'tile (1, 1) expected top');
+ layer.transformDiv(1.5);
+ t.eq(layer.div.style.width, '150%', 'layer div has correct width');
+ t.eq(layer.div.style.height, '150%', 'layer div has correct height');
+ t.eq(layer.div.style.left, '-124.75%', 'layer div has correct left');
+ t.eq(layer.div.style.top, '-137.25%', 'layer div has correct top');
+ map.destroy();
</script>
</head>
<body>
More information about the Commits
