[OpenLayers-Commits] r11072 -
sandbox/elemoine/draw-feature/lib/OpenLayers/Handler
commits-20090109 at openlayers.org
Wed Feb 9 09:55:27 EST 2011
Author: erilem
Date: 2011-02-09 06:55:27 -0800 (Wed, 09 Feb 2011)
New Revision: 11072
sandbox/elemoine/draw-feature/lib/OpenLayers/Handler/Point.js
Point Handler - remove the drawing property, check modifiers and for double-clicks in mouseup instead of mousedown
Modified: sandbox/elemoine/draw-feature/lib/OpenLayers/Handler/Point.js
--- sandbox/elemoine/draw-feature/lib/OpenLayers/Handler/Point.js 2011-02-08 20:47:23 UTC (rev 11071)
+++ sandbox/elemoine/draw-feature/lib/OpenLayers/Handler/Point.js 2011-02-09 14:55:27 UTC (rev 11072)
@@ -11,9 +11,9 @@
* Class: OpenLayers.Handler.Point
- * Handler to draw a point on the map. Point is displayed on mouse down,
- * moves on mouse move, and is finished on mouse up. The handler triggers
- * callbacks for 'done', 'cancel', and 'modify'. The modify callback is
+ * Handler to draw a point on the map. Point is displayed on activation,
+ * moves on mouse move, and is finished on mouse up. The handler triggers
+ * callbacks for 'done', 'cancel', and 'modify'. The modify callback is
* called with each change in the sketch and will receive the latest point
* drawn. Create a new instance with the <OpenLayers.Handler.Point>
* constructor.
@@ -43,12 +43,6 @@
multi: false,
- * Property: drawing
- * {Boolean} A point is being drawn
- drawing: false,
* Property: mouseDown
* {Boolean} The mouse is down
@@ -179,11 +173,7 @@
if(!OpenLayers.Handler.prototype.deactivate.apply(this, arguments)) {
return false;
- // call the cancel callback if mid-drawing
- if(this.drawing) {
- this.cancel();
- this.destroyFeature();
+ this.cancel();
// If a layer's map property is set to null, it means that that layer
// isn't added to the map. Since we ourself added the layer to the map
// in activate(), we can assume that if this.layer.map is null it means
@@ -225,7 +215,9 @@
if(cancel || !this.persist) {
- this.createFeature();
+ if(!cancel) {
+ this.createFeature();
@@ -332,17 +324,8 @@
* {Boolean} Allow event propagation
mousedown: function(evt) {
- // check keyboard modifiers
- if(!this.checkModifiers(evt)) {
- return true;
- // ignore double-clicks
- if(this.lastDown && this.lastDown.equals(evt.xy)) {
- return true;
- this.drawing = true;
- this.modifyFeature(evt.xy);
this.lastDown = evt.xy;
+ this.modifyFeature(evt.xy);
return !this.stopDown;
@@ -374,7 +357,16 @@
mouseup: function (evt) {
- if(this.lastDown.equals(evt.xy)) {
+ // check keyboard modifiers
+ if(!this.checkModifiers(evt)) {
+ return true;
+ // ignore double-clicks
+ if(this.lastUp && this.lastUp.equals(evt.xy)) {
+ return true;
+ if(this.lastDown && this.lastDown.equals(evt.xy)) {
+ this.lastUp = evt.xy;
this.finalize();
return !this.stopUp;
} else {
More information about the Commits
