[OpenLayers-Commits] r11079 - in sandbox/elemoine/draw-feature:
lib/OpenLayers/Handler tests/Handler
commits-20090109 at openlayers.org
Thu Feb 10 05:45:35 EST 2011
Author: erilem
Date: 2011-02-10 02:45:35 -0800 (Thu, 10 Feb 2011)
New Revision: 11079
sandbox/elemoine/draw-feature/lib/OpenLayers/Handler/Path.js
sandbox/elemoine/draw-feature/tests/Handler/Path.html
path handler - watch double mousedowns
Modified: sandbox/elemoine/draw-feature/lib/OpenLayers/Handler/Path.js
--- sandbox/elemoine/draw-feature/lib/OpenLayers/Handler/Path.js 2011-02-10 10:45:25 UTC (rev 11078)
+++ sandbox/elemoine/draw-feature/lib/OpenLayers/Handler/Path.js 2011-02-10 10:45:35 UTC (rev 11079)
@@ -215,6 +215,12 @@
* {Boolean} Allow event propagation
mousedown: function(evt) {
+ // consecutive mousedowns at the same location are
+ // ignored, this occurs when finalizing the line on
+ // dlbclick
+ if (this.lastDown && this.lastDown.equals(evt.xy)) {
+ return false;
this.mouseDown = true;
this.lastDown = evt.xy;
this.modifyFeature(evt.xy);
@@ -257,7 +263,8 @@
mouseup: function (evt) {
- // ignore double-clicks
+ // consecutive mouseups at the same location must not
+ // cause adding new points to the line
if (this.lastUp && this.lastUp.equals(evt.xy)) {
return false;
Modified: sandbox/elemoine/draw-feature/tests/Handler/Path.html
--- sandbox/elemoine/draw-feature/tests/Handler/Path.html 2011-02-10 10:45:25 UTC (rev 11078)
+++ sandbox/elemoine/draw-feature/tests/Handler/Path.html 2011-02-10 10:45:35 UTC (rev 11079)
@@ -209,33 +209,33 @@
// mouse down ("modify")
handler.mousedown({type: "mousedown",
xy: new OpenLayers.Pixel(10, 10)});
- t.eq(log.length, 10, "[mousedown] called back");
+ t.eq(log.length, 9, "[mousedown] not called back");
// mouse up ("point", "modify")
handler.mouseup({type: "mouseup",
- t.eq(log.length, 10, "[mouseup] not called back");
+ t.eq(log.length, 9, "[mouseup] not called back");
// double click
handler.dblclick({type: "dblclick",
- t.eq(log.length, 12, "[dblclick] called back");
- t.eq(log[10].type, "done", "[dblclick] done called");
- t.geom_eq(log[10].args[0],
+ t.eq(log.length, 11, "[dblclick] called back twice");
+ t.eq(log[9].type, "done", "[dblclick] done called");
+ t.geom_eq(log[9].args[0],
new OpenLayers.Geometry.LineString([
new OpenLayers.Geometry.Point(-150, 75),
new OpenLayers.Geometry.Point(-140, 65)
"[dblclick] correct linestring"
- t.eq(log[11].type, "create", "[dblclick] create called");
- t.geom_eq(log[11].args[0], new OpenLayers.Geometry.Point(-200, 125),
+ t.eq(log[10].type, "create", "[dblclick] create called");
+ t.geom_eq(log[10].args[0], new OpenLayers.Geometry.Point(-200, 125),
"[dblclick] correct point");
- t.ok(log[11].args[1] == handler.line,
+ t.ok(log[10].args[1] == handler.line,
"[dblclick] correct feature");
// cancel
handler.cancel();
- t.eq(log.length, 13, "[cancel] called back");
- t.eq(log[12].type, "cancel", "[cancel] canced called");
- t.geom_eq(log[12].args[0],
+ t.eq(log.length, 12, "[cancel] called back");
+ t.eq(log[11].type, "cancel", "[cancel] canced called");
+ t.geom_eq(log[11].args[0],
More information about the Commits
